  3. Vera
  4. VeraEdge
VeraEdge
19 Posts 3 Posters 9.7k Views 2 Watching
  • L legaultf
    I see all the devices but none have any controls. Does that mean they are not properly configured ?
    jeylitesJ
    jeylitesJ
    jeylites
    @legaultf
    If your gateway is connected, it should look something like this.. See below. On my setup I have it connected via Serial. Initially I had it connected via Ethernet, but felt there was a delay. The serial route seem to be working great for me.
    Are you using the latest Vera version: 1.7.1089
    • L
      L
      legaultf
      Please find below the config screen for my device.
      Could you either copy paste your configuration screens or tell me what is not set properly ?
      Your help is greatly appreciated
      Francois
      jeylitesJ 1 Reply Last reply
      • L legaultf
        Francois
        jeylitesJ
        jeylitesJ
        jeylites
        wrote on last edited by jeylites
        @legaultf
        Essentially, you don't have to do anything on this page unless you are using an Ethernet Gateway. If so you will have to copy the IP address with port No. into the ip column in Vera.
        • L
          L
          legaultf
          any idea why I can not pair any device or have a screen similar to yours showing the gateway ?
          • L legaultf
            jeylitesJ
            jeylitesJ
            jeylites
            @legaultf
            Can you take a screen shot of your devices on Vera. Try doing a power off / on reset. Or there could be something you didn't create after uploading the Lupp...
            • L
              L
              legaultf
              I just made some progress
              I now have the start stop control. I did not initially uploaded the .json file. Now I made sure I have the following d_arduino1.xml, d_arduino1.json, d_arduinorelay1.xml & json
              jeylitesJ 2 Replies Last reply
              • L legaultf
                jeylitesJ
                jeylitesJ
                jeylites
                @legaultf
                The Error message is a normal because the vera need time to reload the new setting. I suggest to go to serial devices and reload the lupp. Hope it work after. I still fill you mist a couple of steps. I suggest doing through all steps again just to make sure.
                • L legaultf
                  jeylitesJ
                  jeylitesJ
                  jeylites
                  @legaultf
                  Also make sure you are using UI7 files as linked https://github.com/mysensors/Vera/tree/UI7
                  • C4VetteC
                    C4VetteC
                    C4Vette
                    An uno as serial gateway?.
                    I think that is not supported and you should use a nano for that:
                    http://www.mysensors.org/build/serial_gateway
                    • L
                      L
                      legaultf
                      Major improvement with the latest version for the ui7 ! I now have the gateway being recognized.
                      When I press the start button it does work once after 10 tries and then I get the following ScreenHunter_69 Apr. 26 16.01.jpg
                      your help as got me this far thank you again I feel that I am making progress
                      • L
                        L
                        legaultf
                        Ok so I made a new gateway with an Arduino Nano and do not have any error anymore but I can not add any devices.
                        I contacted the people from Vera because my serial port option is gone.
                        They were able to reactive it but they told me "Arduino seems to be a replica (it should use FTDI) " which probably mean I have to order new one. Are you aware of this issue ? is this a show stopper as they seem to imply.
                        I will probably order what I need now and in the mean time I thank you all for your help.
                        Kindest regards,
                        Francois
                        • C4VetteC
                          C4VetteC
                          C4Vette
                          Thuis non-FTDI problem has been mentioned before:
                          http://forum.mysensors.org/topic/1024/serial-port-configuration-not-available
