  3. radio ID in EEPROM
radio ID in EEPROM
5 Posts 2 Posters 3.3k Views 1 Watching
  • B Offline
    B Offline
    BulldogLowell
    At which address does the Radio ID get stored? I want to use the EEPROM on my sensor, but I want to make sure I'm not overwriting
    hekH 1 Reply Last reply
    • B BulldogLowell
      hekH Offline
      hekH Offline
      @BulldogLowell
      Pos 0. Have a look in Sensor.h
      #define EEPROM_RADIO_ID_ADDRESS 0 // Where to store radio id in EEPROM
      #define EEPROM_RELAY_ID_ADDRESS 1 // Where to store relay id in EEPROM
      #define EEPROM_DISTANCE_ADDRESS 2 // Where to store distance to gateway in EEPROM
      If you're building a relaying node your have to lease space for routing table also (255 additional bytes).
      B 1 Reply Last reply
        @BulldogLowell
        B Offline
        B Offline
        BulldogLowell
        @hek said:
        yes, this part I found:
        This part, help me to know
        means only the relaying node needs this routing table, or if I add the relaying capability to a specific device.
        Did you guys plan to reach any deeper into EEPROM in upcoming versions (foreseeable)?
        I'm going to take 125 bytes for a project, but it only a project specific need and I want to make sure that I'm not creating another problem later.
        In this project, I am going to hold some rain history data in EEPROM in case of a power loss for the rain gauge...
        thanks for the help.
        • hekH Offline
          hekH Offline
          If your write above address 512 you should be safe.
          If you look at the beta version of 1.4 you can see I've added eeprom read/write in the API for sketch usage (that doesn't overwrite any important MySensor stuff). Will make life easier for you.
            B Offline
            B Offline
            BulldogLowell
            cheers mate
            appreciated, as usual.
