  3. Rain Guage
Rain Guage
128 Posts 23 Posters 158.7k Views 21 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    how about adding windspeed to the device?
    hekH 1 Reply Last reply
      Cool device. Haven't seen that one before.
      • petewillP
        petewillP
        petewill
        @BulldogLowell Cool! Do you think it detects wind from all directions? Would this be better than the traditional spinning cup design?
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          #65
          @hek
          @petewill
          A little progress on the device...
            @hek
            @petewill
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            #66
            electronics box:
            • FrancoisF
              FrancoisF
              Francois
              wrote on last edited by Francois
              #67
              @BulldogLowell this looks great once you complete it I will print it. Only problem our raining session is over till Dec. But I can start the build so long :).
                Nice. But I'm a bit worried about water finding its way into the electronics. Would it be possible to make a cavity for the electronics box in the bottom plate?
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  #69
                  @hek
                  recessing the electronics into the bottom would be tough in this design. I was taking advantage on the two parts to use the smooth plate of the printer, and then make a gasket or even use silicone. lemme think about it. I could add a couple of deflectors on the bottom plate to glue on around where the weep holes are...
                  PS enough room for 2 C sized cells
                  bottom view:
                  • petewillP
                    petewillP
                    petewill
                    @BulldogLowell Awesome!
                    I kind of wish I didn't have mine built already :)
                    I may have missed it but did you have any mounting holes (for the side of a building or pole) What is your vision for that?
                    It would also be cool to see some place to add a DHT22 in there. On mine I added one of those as well as a BH1750 for light. I'm not sure how long that will hold up though.
                    BulldogLowellB 2 Replies Last reply
                    • petewillP petewill
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      I'll try to fit that in, if I can, but I'm really focusing on sealing up the electronics. A skirt around the electronics housing may be enough...
                      I was thinking of a female 'flange-like' option for the unit to sit at the top of some galvanized pipe. It could be mounted that way on the side of a house, a fence or just a pole (back of your basketball backboard!). So, the yellow-brown part will be of two options to print.
                        Of course, didn't think that long.
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @petewill
                          • A
                            Andreas Maurer
                            If you add a little edge around the holes, the water cannt flow into the electronic box.
                            • petewillP
                              petewillP
                              petewill
                              @BulldogLowell Awesome. I would love to get a 3d printer. Someday.
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @petewill
                                As it happens, I am sort of turning the code on its head for this update. Do you want to use accumulated rain over X days as the trigger?
                                I was thinking about storing the time on EEPROM and retrieving the stored rain values from VERA for each of the last 5 days after a power-up/restart. This saves from having to create too much EEPROM management, plus we can observe how much time has passed in the event of a power-off. That is, if the unit starts up, we test EEPROM to see what was the last day of rain recorded. If it hasn't been more than one, then we retrieve the values from VERA that were previously sent up. Sound OK to you?
                                I would save an epoch timestamp once each day at midnight when we total today's rain and cascade the values back a day.
                                • petewillP
                                  petewillP
                                  petewill
                                  As opposed to hours? I don't have too strong of an opinion either way. I think whatever is easier works. If they are both the same then maybe hours so we have a little more granular control?
                                  I like that it will simplify the EEPROM more and potentially prolong the life of the device (since it's not using as much EEPROM). One thought though, if there is a communication error between Vera and the rain gauge when it is first started is there a way to prevent the rain gauge from subsequently overwriting the values in Vera? I don't know too much about the "ack" portion of the communication but maybe that would make it so it's not an issue?
                                  I'm excited to see the new code. Keep up the good work!
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    that's where we were with the 120 hour framework, so let's leave that. I'm not worried about EEPROM life, you get 100,000 writes and that is your lifetime++ using the circular buffer. I did the math on it but can't recall the exact number.
                                    So, we won't change EEPROM data, actually may need to add another 24hours. We just send to VERA the total of each of the past 5 days instead of the total accumulated rainfall over the past 24, 48, 72, 96 and 120 hours. This will be calendar days, we will verify by getting the time from VERA, and synchronize that a few times daily. the days will rollover at midnight, and the daily accumulation will be cascaded back accordingly.
                                    trigger for the sensor will still be total accumulation over so many hours.
                                    Yes?
                                    petewillP 1 Reply Last reply
                                      Yes?
                                      petewillP
                                      petewillP
                                      petewill
                                      @BulldogLowell That sounds GREAT to me! This is your baby though (and you have much more experience with this stuff) so I trust what direction you go.
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        @petewill
                                        here is some (untested) mods to update the 5 day rainfall history once per day at midnight. Take a look, let me know what you think (any problems issues). It turns out I was overthinking the problem and it really only needed minor mods...
                                         Arduino Tipping Bucket Rain Gauge
                                         April 26, 2015
                                         Version 1.4.1 alpha
                                         Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
                                         gateway you can measure and sense local rain.  This sketch will create two devices on your
                                         Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
                                         hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
                                         above a threshold.  Both these settings are user definable.
                                         * Allows you to set the rain threshold in mm
                                         * Allows you to determine the interval window up to 120 hours.
                                         * Displays the last 5 days of rain in Variable1 through Variable5
                                           of the Rain Sensor device
                                         * Configuration changes to Sensor device updated every hour
                                         * SHould run on any Arduino
                                         * Will retain Tripped/Not Tripped status and data in a power interruption, saving small ammount
                                           of data to EEPROM (Circular Buffer to maximize life of EEPROM)
                                         * LED status indicator
                                         by @BulldogLowell and @PeteWill for free public use
                                        #include <math.h>
                                        #include <Time.h>
                                        #define NODE_ID 24
                                        #define SKETCH_NAME "Rain Gauge"
                                        #define SKETCH_VERSION "1.4.1a"
                                        #define DWELL_TIME 125  // this allows for radio to come back to power after a transmission, ideally 0
                                        #define DEBUG_ON  // comment out this line to disable serial debug
                                        #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
                                        #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
                                        #define EEPROM_STATE_LOCATION 0 // location to save state to EEPROM
                                        #define EEPROM_BUFFER_LOCATION 1  // location of the EEPROM circular buffer
                                        #define BUFFER_LENGTH 121
                                        #define CALIBRATE_FACTOR 100 // e.g. 5 is .05mm (or 5 hundredths of an inch if imperial) per tip
                                        #ifdef  DEBUG_ON
                                        MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
                                        MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
                                        MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
                                        MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
                                        MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
                                        MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
                                        MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
                                        MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
                                        MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                        MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                        boolean metric = true;
                                        int eepromIndex;
                                        int tipSensorPin = 3; // Must be interrupt capable pin
                                        int ledPin = 5; // PWM capable pin required
                                        unsigned long dataMillis;
                                        const unsigned long serialInterval = 10000UL;
                                        const unsigned long oneHour = 3600000UL;
                                        unsigned long lastTipTime;
                                        unsigned long startMillis;
                                        unsigned int rainBucket [24] ; /* 24 hours = 1 day of data */
                                        unsigned int rainRate = 0;
                                        volatile int wasTippedBuffer = 0;
                                        byte rainWindow = 72;         //default rain window in hours
                                        int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
                                        byte state = 0;
                                        byte oldState = -1;
                                        int lastRainRate = 0;
                                        int lastMeasure = 0;
                                        boolean gotTime = false;
                                        byte lastHour;
                                          SERIAL_START(115200);
                                          // Set up the IO
                                          pinMode(tipSensorPin, INPUT_PULLUP);
                                          attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                          pinMode(ledPin, OUTPUT);
                                          digitalWrite(ledPin, HIGH);
                                          //Let's get the controller talking to the Arduino
                                          gw.begin(getVariables, NODE_ID);
                                          delay(DWELL_TIME);
                                          gw.present(CHILD_ID_RAIN_LOG, S_RAIN);
                                          delay(DWELL_TIME);
                                          gw.present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
                                          delay(DWELL_TIME);
                                          state = gw.loadState(EEPROM_STATE_LOCATION); //retreive prior state from EEPROM
                                          DEBUG_PRINT(F("Previous Tripped State (from EEPROM): "));
                                          DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                                          gw.send(msgTripped.set(state));
                                          delay(DWELL_TIME);
                                          //Sync time with the server, this will be called hourly in order to keep time from creeping with the crystal
                                          while(timeStatus() == timeNotSet)
                                            gw.requestTime(receiveTime);
                                            Serial.println("getting Time");
                                            delay(1000); // call once per second
                                            Serial.print(".");
                                          //retrieve from EEPROM stored values on a power cycle.
                                          boolean isDataOnEeprom = false;
                                          for (int i = 0; i < BUFFER_LENGTH; i++)
                                            byte locator = gw.loadState(EEPROM_BUFFER_LOCATION + 2 * i); //<<<<<<<<<<<
                                            if (locator == 0xFF)  // found the EEPROM circular buffer index
                                              eepromIndex = EEPROM_BUFFER_LOCATION + 2 * i;
                                              //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
                                              loadRainArray(eepromIndex);
                                              isDataOnEeprom = true;
                                              DEBUG_PRINT("EEPROM Index ");
                                              DEBUG_PRINTLN(eepromIndex);
                                          if (!isDataOnEeprom) // Added for the first time it is run on a new arduino
                                            eepromIndex = 1;
                                            gw.saveState(eepromIndex, 0xFF); // store the EEPROM index marker...
                                            gw.saveState(eepromIndex + 1, 0xFF);
                                          dataMillis = millis();
                                          startMillis = millis();
                                          lastTipTime = millis() - oneHour;
                                          //Get sensor time window and threshold from controller
                                          gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
                                          delay(DWELL_TIME);
                                          gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
                                          delay(DWELL_TIME);
                                          DEBUG_PRINTLN(F("Radio Setup Complete!"));
                                          if (state)
                                            prettyFade();  // breathe if tripped
                                            slowFlash();   // blink if not tripped
                                        #ifdef DEBUG_ON  // Serial Debug Block
                                          if ( (millis() - dataMillis) >= serialInterval)
                                            for (int i = 24; i <= 120; i = i + 24)
                                              updateSerialData(i);
                                          // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
                                          int measure = 0; // Check to see if we need to show sensor tripped in this block
                                          for (int i = 0; i < rainWindow; i++)
                                            measure += rainBucket [i];
                                            if (measure != lastMeasure)
                                              DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                                              DEBUG_PRINTLN(measure);
                                              lastMeasure = measure;
                                          state = (measure >= rainSensorThreshold);
                                          if (state != oldState)
                                            delay(DWELL_TIME);
                                            gw.saveState(EEPROM_STATE_LOCATION, state); //New Code
                                            DEBUG_PRINT(F("New Sensor State... Sensor: "));
                                            DEBUG_PRINTLN(state? "Tripped" : "Not Tripped");
                                            oldState = state;
                                          unsigned long tipDelay = millis() - lastTipTime;
                                          if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
                                            DEBUG_PRINTLN(F("Sensor Tipped"));
                                            DEBUG_PRINT(F("rainBucket [0] value: "));
                                            DEBUG_PRINTLN(rainBucket [0]);
                                            int dayTotal = 0;
                                            for (int i = 0; i < 24; i++)
                                              dayTotal = dayTotal + rainBucket [i];
                                            DEBUG_PRINT(F("dayTotal value: "));
                                            DEBUG_PRINTLN(dayTotal);
                                            gw.send(msgRain.set(dayTotal, 1));
                                            delay(DWELL_TIME);
                                            wasTippedBuffer--;
                                            rainRate = ((oneHour) / tipDelay);
                                            if (rainRate != lastRainRate)
                                              gw.send(msgRainRate.set(rainRate, 1));
                                              delay(DWELL_TIME);
                                              DEBUG_PRINT(F("RainRate= "));
                                              DEBUG_PRINTLN(rainRate);
                                              lastRainRate = rainRate;
                                          if (tipDelay > oneHour)
                                            rainRate = 0;
                                          if (millis() - startMillis >= oneHour)
                                            DEBUG_PRINTLN(F("One hour elapsed."));
                                            for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values back into the array
                                              rainBucket [i + 1] = rainBucket [i];
                                            rainBucket[0] = 0;
                                            gw.send(msgRain.set(rainTotal(24), 1)); // send 24hr tips
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            gw.saveState(eepromIndex, highByte(rainBucket[0]));
                                            gw.saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                                            eepromIndex++;
                                            if (eepromIndex > EEPROM_BUFFER_LOCATION + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER_LOCATION;
                                            DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                                            gw.requestTime(receiveTime); // sync the time every hour
                                            delay(DWELL_TIME);
                                          if (hour() == 0 and lastHour == 23)
                                            transmitRainData();
                                          lastHour = hour();
                                        void sensorTipped()
                                          unsigned long thisTipTime = millis();
                                          if (thisTipTime - lastTipTime > 100UL)
                                            rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                                            wasTippedBuffer++;
                                          lastTipTime = thisTipTime;
                                        int rainTotal(int hours)
                                          int total = 0;
                                          for ( int i = 0; i < hours; i++)
                                            total += rainBucket [i];
                                          return total;
                                        void updateSerialData(int x)
                                          DEBUG_PRINT(F("Tips last "));
                                          DEBUG_PRINT(x);
                                          DEBUG_PRINTLN(F(" hours: "));
                                          int tipCount = 0;
                                          for (int i = 0; i < x; i++)
                                            tipCount = tipCount + rainBucket [i];
                                          DEBUG_PRINTLN(tipCount);
                                        void loadRainArray(int value) // load stored rain array from EEPROM on powerup
                                          for (int i = 0; i < BUFFER_LENGTH - 1; i++)
                                            value--;
                                            DEBUG_PRINT("EEPROM location: ");
                                            DEBUG_PRINTLN(value);
                                            if (value < EEPROM_BUFFER_LOCATION)
                                              value = EEPROM_BUFFER_LOCATION + BUFFER_LENGTH;
                                            byte rainValueHigh = gw.loadState(value);
                                            byte rainValueLow = gw.loadState(value + 1);
                                            int rainValue = (rainValueHigh << 8) & rainValueLow;
                                            rainBucket[i] = rainValue;
                                            DEBUG_PRINT(F("rainBucket[ value: "));
                                            DEBUG_PRINT(i);
                                            DEBUG_PRINT(F("] value: "));
                                            DEBUG_PRINTLN(rainBucket[i]);
                                        void transmitRainData(void)
                                          int rainUpdateTotal = 0;
                                            rainUpdateTotal += rainBucket[i];
                                          gw.send(msgRainVAR1.set(( float) rainUpdateTotal / 100.0 , 1));
                                          delay(DWELL_TIME);
                                          for (int i = 24; i < 48; i++)
                                          gw.send(msgRainVAR2.set( (float) rainUpdateTotal / 100.0 , 1));
                                          delay(DWELL_TIME);
                                          for (int i = 48; i < 72; i++)
                                          gw.send(msgRainVAR3.set( (float) rainUpdateTotal / 100.0 , 1));
                                          delay(DWELL_TIME);
                                          for (int i = 72; i < 96; i++)
                                          gw.send(msgRainVAR4.set( (float) rainUpdateTotal / 100.0 , 1));
                                          delay(DWELL_TIME);
                                          for (int i = 96; i < 120; i++)
                                          gw.send(msgRainVAR5.set( (float) rainUpdateTotal / 100.0 , 1));
                                          delay(DWELL_TIME);
                                          if (message.sensor == CHILD_ID_RAIN_LOG)
                                            // nothing to do here
                                          else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
                                            if (message.type == V_VAR1)
                                              rainWindow = atoi(message.data);
                                              if (rainWindow > 120)
                                                rainWindow = 120;
                                              else if (rainWindow < 1)
                                                rainWindow = 1;
                                              if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
                                                gw.send(msgTrippedVar1.set(rainWindow));
                                              rainSensorThreshold = atoi(message.data);
                                              if (rainSensorThreshold > 10000)
                                                rainSensorThreshold = 10000;
                                              else if (rainSensorThreshold < 1)
                                                rainSensorThreshold = 1;
                                              if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
                                                gw.send(msgTrippedVar2.set(rainSensorThreshold));
                                        void prettyFade(void)
                                          float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
                                          analogWrite(ledPin, val);
                                        void slowFlash(void)
                                          static boolean ledState = true;
                                          static unsigned long pulseStart = millis();
                                          if (millis() - pulseStart < 100UL)
                                            digitalWrite(ledPin, !ledState);
                                          DEBUG_PRINTLN(F("Time received from controller..."));
                                          setTime(time);
                                          char theTime[26];
                                          sprintf(theTime, "The current time is %d:%2d", hour(), minute());
                                          DEBUG_PRINTLN(theTime);
                                        RJ_MakeR 1 Reply Last reply
                                          @petewill
                                           April 26, 2015
                                           Version 1.4.1 alpha
                                          #include <math.h>
                                          #include <Time.h>
                                          #define NODE_ID 24
                                          #ifdef  DEBUG_ON
                                          int eepromIndex;
                                          byte state = 0;
                                          byte oldState = -1;
                                          byte lastHour;
                                            // Set up the IO
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                              Serial.print(".");
                                              eepromIndex = 1;
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            if (state)
                                              delay(DWELL_TIME);
                                              oldState = state;
                                              int dayTotal = 0;
                                              delay(DWELL_TIME);
                                              wasTippedBuffer--;
                                                delay(DWELL_TIME);
                                              rainRate = 0;
                                              rainBucket[0] = 0;
                                              delay(DWELL_TIME);
                                              delay(DWELL_TIME);
                                              delay(DWELL_TIME);
                                              eepromIndex++;
                                              delay(DWELL_TIME);
                                              transmitRainData();
                                            lastHour = hour();
                                          void sensorTipped()
                                              wasTippedBuffer++;
                                            int total = 0;
                                            return total;
                                            DEBUG_PRINT(x);
                                            int tipCount = 0;
                                              value--;
                                              DEBUG_PRINT(i);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                            delay(DWELL_TIME);
                                                  rainWindow = 120;
                                                  rainWindow = 1;
                                            setTime(time);
                                            char theTime[26];
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @BulldogLowell
                                          Wow, just wow man.... that is a thing of beauty!!
                                          RJ_Make
