  3. Bad range
Bad range
16 Posts 6 Posters 9.8k Views 2 Watching
  • n3roN
    n3roN
    n3ro
    wrote on last edited by n3ro
    Hey folks,
    i have some problems with the rage of my nodes.
    the maximum is only 3-7 meters and 1 wall.
    i use 10 uA capacitors on each node and the gw.
    Is it possible to change some settings to extend the range or set something that the node resend the signal if the gw dont get the signal?
    Regards,
    n3ro
    Edit:
    Some output from the Node:
    Battery: 100
    PIR: 0
    send: 11-11-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
    send: 11-11-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    send: 11-11-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:51.3
    Humidity: 51.30
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:1
    send: 11-11-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:77
    Light: 77
    Battery: 100
    PIR: 0
    Battery: 100
    PIR: 1
    Battery: 100
    PIR: 0
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=3,c=1,t=0,pt=7,l=5,st=fail:21.6
    Temp: 21.60
    send: 11-11-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:51.2
    Humidity: 51.20
    Battery: 100
    PIR: 1
    send: 11-11-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:76
    Light: 76
    Battery: 100
    PIR: 0
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • A
      andriej
      10uA? should be uF and at least 47uF caps (remember about +/-)
      You can also get te LNA+PA version with antenna...
      I have much better range anyway... maybe your modules are too much from China? ;-)
      • n3roN
        n3roN
        n3ro
        Hehe, yes :D 10uF. It's not good to write technical issues to late in the night.
        I use the nfrs from banggood.com
        Do you know better ones?
        • n3roN
          n3roN
          n3ro
          is it possible that my wifi router make problems with mysensors?
          A 1 Reply Last reply
          • J
            J
            Jan Gatzke
            This must be a problem with your nrf modules. 3m is nothing. The cheap version you are u sing should have a range of about 10-15 meters in normal buildings. The better version LNA+PA works for ranges >20 meters with multiple walls in between.
            • n3roN n3ro
              andriej
              @n3ro It is possible - try changing 'channel' in RF24 Config on every node (by reflashing it).
              n3roN 1 Reply Last reply
              • A andriej
                n3roN
                n3roN
                n3ro
                @andriej this sounds interesting. what is to do to reflash it?
                • n3roN n3ro
                  andriej
                  @n3ro just change the channel in config file (try to set it in higher values in example) and reprogram all sensors and gateway on your network.
                  • n3roN
                    n3roN
                    n3ro
                    ah okay. So far I have this sketch to test the distance:
                    https://github.com/n3roGit/MySensors_n3ro/tree/master/test_sketch
                    tomorrow I'll reflash all nodes+gw and test it again :)
                    • A
                      Andreas Maurer
                      Have you seen this new Video
                      n3roN Sander TeunissenS 2 Replies Last reply
                      • A Andreas Maurer
                        n3roN
                        n3roN
                        n3ro
                        @Andreas-Maurer Cant play Video :(
                        • A Andreas Maurer
                          Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          • A
                            Andreas Maurer
                            https://www.youtube.com/watch?v=gtM832Z0ujE
                            • n3roN
                              n3roN
                              n3ro
                              i have still a band range. next i will test a gw with a nrf antenna version. i hope this helps
                              • R
                                R
                                rickmontana83
                                If you're using the cheaper low-power variants of the nrf24l01+ on the gateway then make sure that your MyConfig.h file has RF24_PA_MAX for RF24_PA_LEVEL_GW.
                                I noticed the other day that the default value from GitHub is RF24_PA_LOW, which gave me only a couple of feet of comms. Changing the default made everything work much better. Seems like the default repos is set up for the high-power radio variants.
                                • R rickmontana83
                                  n3roN
                                  n3roN
                                  n3ro
                                  @rickmontana83 YEAH!!!!! This has fixed my problem!!
                                  Now i have much better rage with my nodes :+1:
                                  Big THX!
