  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.4k Views 3 Watching
  • n3roN
    n3roN
    n3ro
    wrote on last edited by n3ro
    I have a idea,
    is it possible to build a second loop like this?
    But now i have one problem... the loop2 never run...
    #include <readVcc.h>
    #include <Scheduler.h>
    #define NODE_ID 11                       // ID of node
    unsigned long SLEEP_TIME = 600000;        // Sleep time between reports (in milliseconds)
    #define CHILD_ID_PIR 1                   // Id of the sensor PIR
    #define CHILD_ID_HUM 2                   // Id of the sensor HUM
    #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
    #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
    #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define HUMIDITY_SENSOR_DIGITAL_PIN 2
    // Initialize Variables
    MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int oldBatteryPcnt;
    int lastLightLevel;
    unsigned long time;
    int MIN_V = 2700; // empty voltage (0%)
    int MAX_V = 3200; // full voltage (100%)
      gw.begin(NULL, NODE_ID, false);
      //PIR
      gw.sendSketchInfo("Motion Sensor", "1.0");
      pinMode(PIR_SENSOR_DIGITAL, INPUT);      // sets the motion sensor digital pin as input
      digitalWrite(PIR_SENSOR_DIGITAL, HIGH);
      gw.present(CHILD_ID_PIR, S_MOTION);
      //DHT
      gw.sendSketchInfo("Humidity", "1.0");
      //LIGHT
      gw.sendSketchInfo("Light Sensor", "1.0");
      Scheduler.startLoop(loop2);
      // Read digital motion value
      boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
      Serial.print("---------- PIR: ");
      Serial.println(tripped);
      gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw
      gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    void loop2()
      //DHT
      //dht.begin();
      //delay(1000);
      //millis(dht.getMinimumSamplingPeriod());
      //Serial.print(dht.getMinimumSamplingPeriod());
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("---------- Temp: ");
      if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("---------- Humidity: ");
        Serial.println(humidity);
      // Light
      int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
      //Serial.println(lightLevel);
        gw.send(msgLight.set(lightLevel));
        lastLightLevel = lightLevel;
        Serial.print("---------- Light: ");
      // Measure battery
      float batteryV = readVcc();
      int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 );
      if (batteryPcnt > 100) {
        batteryPcnt = 100;
      if (batteryPcnt != oldBatteryPcnt) {
        gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
        oldBatteryPcnt = batteryPcnt;
      Serial.print("---------- Battery: ");
      Serial.println(batteryPcnt);
      gw.sleep(SLEEP_TIME);
    i have downloaded THIS
    But i get this error when compiling:
    In file included from MotionSensor_DHT_light_battery_mod.ino:6:0:
    Arduino\libraries\Scheduler/Scheduler.h:33:22: fatal error: WProgram.h: No such file or directory
    #include <WProgram.h>
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • rvendrameR
      rvendrameR
      rvendrame
      @n3ro , you can have only one loop().
      You need to merge the two logics into into a single loop. You might also want to remove the second sleep, otherwise PIR will not trigger there.
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      n3roN 1 Reply Last reply
      • rvendrameR rvendrame
        n3roN
        n3roN
        n3ro
        @rvendrame do you have an idea how to do it?
        • rvendrameR
          rvendrameR
          rvendrame
          Maybe you can start by to removing these 3 lines:
          void loop2()
          ... and move the 1st sleep to the end of loop (where the 2nd sleep is):
          .... and remove the 2nd sleep:
          Alexa / Google Home
            void loop2()
            n3roN
            n3roN
            n3ro
            @rvendrame
            if i use this:
            #define NODE_ID 10                       // ID of node
            DHT dht;
            float lastTemp;
            float lastHum;
            int oldBatteryPcnt;
            int lastLightLevel;
              //PIR
              //DHT
              //LIGHT
              // Measure battery
                batteryPcnt = 100;
              //DHT
              //delay(dht.getMinimumSamplingPeriod());
                if (!metric) {
                lastHum = humidity;
              // Light
            the pir works fine. but the dht doesn't work.
            when delay(dht.getMinimumSamplingPeriod()); is used the dht works and the pir fails.
            • rvendrameR
              rvendrameR
              rvendrame
              It makes sense ;-) Try this:
              create (outside the loop) a variable to count the time:
              long mytime = 0;
              .. and replace the delay by :
               if ( milis() > mytime )  {
                 <  Put the dht stuff here >
                mytime = millis() + dht.getMinimumSamplingPeriod() ;
              Alexa / Google Home
                long mytime = 0;
                n3roN
                n3roN
                n3ro
                @rvendrame
                hmm :)
                if is use this:
                unsigned long SLEEP_TIME = 10000;        // Sleep time between reports (in milliseconds)
                DHT dht;
                float lastTemp;
                float lastHum;
                int oldBatteryPcnt;
                int lastLightLevel;
                long mytime = 0;
                  //PIR
                  //DHT
                  //LIGHT
                  if ( millis() > mytime )  {
                    //DHT
                      if (!metric) {
                      lastHum = humidity;
                    // Light
                    // Measure battery
                      batteryPcnt = 100;
                    mytime = millis() + dht.getMinimumSamplingPeriod();
                     Serial.println(mytime);
                i get this output:
                ---------- PIR: 0
                send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
                6608
                ---------- PIR: 0
                6608
                ---------- PIR: 0
                6608
                ---------- PIR: 0
                6608
                ---------- PIR: 0
                send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:41.7
                ---------- Humidity: 41.70
                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:38
                ---------- Light: 38
                ---------- Battery: 100
                11148
                ---------- PIR: 0
                11148
                ---------- PIR: 0
                11148
                ---------- PIR: 0
                11148
                ---------- PIR: 0
                11148
                ---------- PIR: 0
                15441
                ---------- PIR: 0
                15441
                ---------- PIR: 0
                15441
                ---------- PIR: 0
                15441
                ---------- PIR: 1
                send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
                the pir sends 0 and didnt sleep right :(
                • rvendrameR
                  rvendrameR
                  rvendrame
                  What is this number? Did you print the milis()?
                  6608 <<<<<<
                  Alexa / Google Home
                    6608 <<<<<<
                    n3roN
                    n3roN
                    n3ro
                    yes :)
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      wrote on last edited by rvendrame
                      #21
                      Are you connecting both DHT and PIR at same pin 2 ? That must be the cause (DHT is triggering the interruption, I think you want only the PIR to trigger it).
                      Edit: looks like your PIR is at pin 3 , and DHT on pin 2 --- Should be the inverse? The PIR should be on pin 2 (to trigger the interrupt).
                      Alexa / Google Home
                      SweebeeS 1 Reply Last reply
                        SweebeeS
                        SweebeeS
                        Sweebee
                        @rvendrame Pir sensor is defined as 3
                        interrupt pin is defined as INT1: 3 - 2 = 1
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          #23
                          So PIR must connect on PIN 1 and not PIN 3.
                          Edit: Better, how did you connect DHT and PIR?
                          Alexa / Google Home
                          n3roN SweebeeS 2 Replies Last reply
                            n3roN
                            n3roN
                            n3ro
                            #24
                            @rvendrame The DHT is on pin 2 and the pir on pin 3. i use the MYS PCB.
                            i suspect the delay function disturb the sleep function. if i dont use the delay, the dht cant "heat up".
                            far as I know the interrupt is only an internal value. right?
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              Yes, it looks fine. What exactly error are you having? From your first serial monitor, it looks like your sensor woke on every 10min aprox, ( 6608 / 11148 / 15441 ).
                              Alexa / Google Home
                                n3roN
                                n3roN
                                n3ro
                                #26
                                @rvendrame
                                if i use this:
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                int oldBatteryPcnt;
                                int lastLightLevel;
                                  //PIR
                                  //DHT
                                  //LIGHT
                                  // Measure battery
                                    batteryPcnt = 100;
                                  //DHT
                                    if (!metric) {
                                    lastHum = humidity;
                                  // Light
                                i get this output after starting:
                                sensor started, id 10
                                send: 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                read: 0-0-10 s=255,c=3,t=6,pt=0,l=1:M
                                send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Motion Sensor
                                send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                send: 10-10-0-0 s=1,c=0,t=1,pt=0,l=5,st=ok:1.4.1
                                send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
                                send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                                send: 10-10-0-0 s=3,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                                send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Light Sensor
                                send: 10-10-0-0 s=4,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                                send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:100
                                ---------- PIR: 1
                                send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.6
                                ---------- Temp: 16.60
                                send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.8
                                ---------- Humidity: 43.80
                                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:39
                                ---------- Light: 39
                                ---------- PIR: 0
                                send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0
                                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:37
                                ---------- Light: 37
                                ---------- PIR: 1
                                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:34
                                ---------- Light: 34
                                ---------- PIR: 0
                                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:36
                                ---------- Light: 36
                                ---------- PIR: 1
                                ---------- PIR: 0
                                send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:38
                                The DHT gives only output the first start and the pir interrupt works perfect.
                                When delay(dht.getMinimumSamplingPeriod()); is activated the DHT works and the pit interrupts the whole time :(
                                In this configuration the arduino never sleeps ..
                                ---------- PIR: 1
                                send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.5
                                ---------- Temp: 16.50
                                send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.9
                                ---------- Humidity: 43.90
                                ---------- PIR: 1
                                ---------- PIR: 0
                                ---------- PIR: 0
                                ---------- PIR: 0
                                EDIT: i have changed the sleeptime for testing to a shorter time
                                  SweebeeS
                                  SweebeeS
                                  Sweebee
                                  @rvendrame When the PIR is connected to PIN3 the interrupt is INT1. Pin 1 does not have an interrupt.
                                  Only pin 2 and pin 3 have an interrupt.
                                  Pin 2 = int0
                                  pin 3 = int1
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    if you put the delay() inside that 'if ( mills() > mytime ) ' , what happens?
                                    Alexa / Google Home
                                    • SweebeeS Sweebee
                                      Pin 2 = int0
                                      pin 3 = int1
                                      n3roN
                                      n3roN
                                      n3ro
                                      @Sweebee is it possible to fix the problem when DHT is connected to pin 4?
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        It worth a try ...
                                        Alexa / Google Home
                                          n3roN
                                          n3roN
                                          n3ro
                                          @rvendrame
                                          i have posted it before this post:
                                          "What is this number? Did you print the milis()?
                                          6608 <<<<<<"
                                          in the posted sketch the delay is inside millis
