Multisensor PIR problem [solved]
Maybe you can start by to removing these 3 lines:
} void loop2() {... and move the 1st sleep to the end of loop (where the 2nd sleep is):
// Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);.... and remove the 2nd sleep:
gw.sleep(SLEEP_TIME);@rvendrame
if i use this:#include <MySensor.h> #include <readVcc.h> #include <SPI.h> #include <DHT.h> #define NODE_ID 10 // ID of node unsigned long SLEEP_TIME = 600000; // Sleep time between reports (in milliseconds) #define CHILD_ID_PIR 1 // Id of the sensor PIR #define CHILD_ID_HUM 2 // Id of the sensor HUM #define CHILD_ID_TEMP 3 // Id of the sensor TEMP #define CHILD_ID_LIGHT 4 // Id of the sensor LIGHT #define PIR_SENSOR_DIGITAL 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define HUMIDITY_SENSOR_DIGITAL_PIN 2 #define LIGHT_SENSOR_ANALOG_PIN 0 MySensor gw; // Initialize Variables MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED); MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); DHT dht; float lastTemp; float lastHum; boolean metric = true; int oldBatteryPcnt; int lastLightLevel; int MIN_V = 2700; // empty voltage (0%) int MAX_V = 3200; // full voltage (100%) void setup() { gw.begin(NULL, NODE_ID, false); //PIR // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Motion Sensor", "1.0"); pinMode(PIR_SENSOR_DIGITAL, INPUT); // sets the motion sensor digital pin as input digitalWrite(PIR_SENSOR_DIGITAL, HIGH); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_PIR, S_MOTION); //DHT dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Send the Sketch Version Information to the Gateway gw.sendSketchInfo("Humidity", "1.0"); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); metric = gw.getConfig().isMetric; //LIGHT // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Light Sensor", "1.0"); // Register all sensors to gateway (they will be created as child devices) gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); } void loop() { // Measure battery float batteryV = readVcc(); int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 ); if (batteryPcnt > 100) { batteryPcnt = 100; } if (batteryPcnt != oldBatteryPcnt) { gw.sendBatteryLevel(batteryPcnt); // Send battery percentage oldBatteryPcnt = batteryPcnt; } Serial.print("---------- Battery: "); Serial.println(batteryPcnt); // Read digital motion value boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH; Serial.print("---------- PIR: "); Serial.println(tripped); gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw //DHT //delay(dht.getMinimumSamplingPeriod()); float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT"); } else if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.toFahrenheit(temperature); } gw.send(msgTemp.set(temperature, 1)); Serial.print("---------- Temp: "); Serial.println(temperature); } float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("---------- Humidity: "); Serial.println(humidity); } // Light int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //Serial.println(lightLevel); if (lightLevel != lastLightLevel) { gw.send(msgLight.set(lightLevel)); lastLightLevel = lightLevel; Serial.print("---------- Light: "); Serial.println(lightLevel); } // Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); }the pir works fine. but the dht doesn't work.
when delay(dht.getMinimumSamplingPeriod()); is used the dht works and the pir fails.
It makes sense ;-) Try this:
create (outside the loop) a variable to count the time:
long mytime = 0;.. and replace the delay by :
if ( milis() > mytime ) { < Put the dht stuff here > mytime = millis() + dht.getMinimumSamplingPeriod() ; } -
if ( milis() > mytime ) { < Put the dht stuff here > mytime = millis() + dht.getMinimumSamplingPeriod() ; }hmm :)
if is use this:#include <MySensor.h> #include <readVcc.h> #include <SPI.h> #include <DHT.h> #define NODE_ID 10 // ID of node unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds) #define CHILD_ID_PIR 1 // Id of the sensor PIR #define CHILD_ID_HUM 2 // Id of the sensor HUM #define CHILD_ID_TEMP 3 // Id of the sensor TEMP #define CHILD_ID_LIGHT 4 // Id of the sensor LIGHT #define PIR_SENSOR_DIGITAL 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define HUMIDITY_SENSOR_DIGITAL_PIN 2 #define LIGHT_SENSOR_ANALOG_PIN 0 MySensor gw; // Initialize Variables MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED); MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); DHT dht; float lastTemp; float lastHum; boolean metric = true; int oldBatteryPcnt; int lastLightLevel; long mytime = 0; int MIN_V = 2700; // empty voltage (0%) int MAX_V = 3200; // full voltage (100%) void setup() { gw.begin(NULL, NODE_ID, false); //PIR // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Motion Sensor", "1.0"); pinMode(PIR_SENSOR_DIGITAL, INPUT); // sets the motion sensor digital pin as input digitalWrite(PIR_SENSOR_DIGITAL, HIGH); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_PIR, S_MOTION); //DHT dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Send the Sketch Version Information to the Gateway gw.sendSketchInfo("Humidity", "1.0"); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); metric = gw.getConfig().isMetric; //LIGHT // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Light Sensor", "1.0"); // Register all sensors to gateway (they will be created as child devices) gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); } void loop() { // Read digital motion value boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH; Serial.print("---------- PIR: "); Serial.println(tripped); gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw if ( millis() > mytime ) { //DHT delay(dht.getMinimumSamplingPeriod()); float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT"); } else if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.toFahrenheit(temperature); } gw.send(msgTemp.set(temperature, 1)); Serial.print("---------- Temp: "); Serial.println(temperature); } float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("---------- Humidity: "); Serial.println(humidity); } // Light int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //Serial.println(lightLevel); if (lightLevel != lastLightLevel) { gw.send(msgLight.set(lightLevel)); lastLightLevel = lightLevel; Serial.print("---------- Light: "); Serial.println(lightLevel); } // Measure battery float batteryV = readVcc(); int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 ); if (batteryPcnt > 100) { batteryPcnt = 100; } if (batteryPcnt != oldBatteryPcnt) { gw.sendBatteryLevel(batteryPcnt); // Send battery percentage oldBatteryPcnt = batteryPcnt; } Serial.print("---------- Battery: "); Serial.println(batteryPcnt); mytime = millis() + dht.getMinimumSamplingPeriod(); } Serial.println(mytime); // Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); }i get this output:
---------- PIR: 0
send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
6608
---------- PIR: 0
6608
---------- PIR: 0
6608
---------- PIR: 0
6608
---------- PIR: 0
send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:41.7
---------- Humidity: 41.70
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:38
---------- Light: 38
---------- Battery: 100
11148
---------- PIR: 0
11148
---------- PIR: 0
11148
---------- PIR: 0
11148
---------- PIR: 0
11148
---------- PIR: 0
15441
---------- PIR: 0
15441
---------- PIR: 0
15441
---------- PIR: 0
15441
---------- PIR: 1
send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1the pir sends 0 and didnt sleep right :(
What is this number? Did you print the milis()?
6608 <<<<<< -
6608 <<<<<< -
#define PIR_SENSOR_DIGITAL 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define HUMIDITY_SENSOR_DIGITAL_PIN 2 #define LIGHT_SENSOR_ANALOG_PIN 0Are you connecting both DHT and PIR at same pin 2 ? That must be the cause (DHT is triggering the interruption, I think you want only the PIR to trigger it).
Edit: looks like your PIR is at pin 3 , and DHT on pin 2 --- Should be the inverse? The PIR should be on pin 2 (to trigger the interrupt).
@rvendrame Pir sensor is defined as 3
interrupt pin is defined as INT1: 3 - 2 = 1
So PIR must connect on PIN 1 and not PIN 3.
Edit: Better, how did you connect DHT and PIR?
@rvendrame The DHT is on pin 2 and the pir on pin 3. i use the MYS PCB.
i suspect the delay function disturb the sleep function. if i dont use the delay, the dht cant "heat up".
far as I know the interrupt is only an internal value. right?
Yes, it looks fine. What exactly error are you having? From your first serial monitor, it looks like your sensor woke on every 10min aprox, ( 6608 / 11148 / 15441 ).
@rvendrame
if i use this:#include <MySensor.h> #include <readVcc.h> #include <SPI.h> #include <DHT.h> #define NODE_ID 10 // ID of node unsigned long SLEEP_TIME = 600000; // Sleep time between reports (in milliseconds) #define CHILD_ID_PIR 1 // Id of the sensor PIR #define CHILD_ID_HUM 2 // Id of the sensor HUM #define CHILD_ID_TEMP 3 // Id of the sensor TEMP #define CHILD_ID_LIGHT 4 // Id of the sensor LIGHT #define PIR_SENSOR_DIGITAL 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define HUMIDITY_SENSOR_DIGITAL_PIN 2 #define LIGHT_SENSOR_ANALOG_PIN 0 MySensor gw; // Initialize Variables MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED); MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); DHT dht; float lastTemp; float lastHum; boolean metric = true; int oldBatteryPcnt; int lastLightLevel; int MIN_V = 2700; // empty voltage (0%) int MAX_V = 3200; // full voltage (100%) void setup() { gw.begin(NULL, NODE_ID, false); //PIR // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Motion Sensor", "1.0"); pinMode(PIR_SENSOR_DIGITAL, INPUT); // sets the motion sensor digital pin as input digitalWrite(PIR_SENSOR_DIGITAL, HIGH); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_PIR, S_MOTION); //DHT dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Send the Sketch Version Information to the Gateway gw.sendSketchInfo("Humidity", "1.0"); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); metric = gw.getConfig().isMetric; //LIGHT // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Light Sensor", "1.0"); // Register all sensors to gateway (they will be created as child devices) gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); } void loop() { // Measure battery float batteryV = readVcc(); int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 ); if (batteryPcnt > 100) { batteryPcnt = 100; } if (batteryPcnt != oldBatteryPcnt) { gw.sendBatteryLevel(batteryPcnt); // Send battery percentage oldBatteryPcnt = batteryPcnt; } Serial.print("---------- Battery: "); Serial.println(batteryPcnt); // Read digital motion value boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH; Serial.print("---------- PIR: "); Serial.println(tripped); gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw //DHT //delay(dht.getMinimumSamplingPeriod()); float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT"); } else if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.toFahrenheit(temperature); } gw.send(msgTemp.set(temperature, 1)); Serial.print("---------- Temp: "); Serial.println(temperature); } float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("---------- Humidity: "); Serial.println(humidity); } // Light int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //Serial.println(lightLevel); if (lightLevel != lastLightLevel) { gw.send(msgLight.set(lightLevel)); lastLightLevel = lightLevel; Serial.print("---------- Light: "); Serial.println(lightLevel); } // Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); }i get this output after starting:
sensor started, id 10
send: 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
read: 0-0-10 s=255,c=3,t=6,pt=0,l=1:M
send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Motion Sensor
send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
send: 10-10-0-0 s=1,c=0,t=1,pt=0,l=5,st=ok:1.4.1
send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
send: 10-10-0-0 s=3,c=0,t=6,pt=0,l=5,st=ok:1.4.1
send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Light Sensor
send: 10-10-0-0 s=4,c=0,t=16,pt=0,l=5,st=ok:1.4.1
send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:100
---------- PIR: 1
send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.6
---------- Temp: 16.60
send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.8
---------- Humidity: 43.80
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:39
---------- Light: 39
---------- PIR: 0
send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:37
---------- Light: 37
---------- PIR: 1
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:34
---------- Light: 34
---------- PIR: 0
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:36
---------- Light: 36
---------- PIR: 1
---------- PIR: 0
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:38
---------- Light: 38The DHT gives only output the first start and the pir interrupt works perfect.
When delay(dht.getMinimumSamplingPeriod()); is activated the DHT works and the pit interrupts the whole time :(
In this configuration the arduino never sleeps ..sensor started, id 10
---------- PIR: 1
send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.5
---------- Temp: 16.50
send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.9
---------- Humidity: 43.90
---------- PIR: 1
---------- PIR: 0
---------- PIR: 0
---------- PIR: 0
send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:38EDIT: i have changed the sleeptime for testing to a shorter time
@rvendrame When the PIR is connected to PIN3 the interrupt is INT1. Pin 1 does not have an interrupt.
Only pin 2 and pin 3 have an interrupt.
Pin 2 = int0
pin 3 = int1
if you put the delay() inside that 'if ( mills() > mytime ) ' , what happens?
Pin 2 = int0
pin 3 = int1
@rvendrame
i have posted it before this post:"What is this number? Did you print the milis()?
6608 <<<<<<"in the posted sketch the delay is inside millis
I didn't find the if ( millis() > my time) in the last sketch you posted ...
if i use this
#include <MySensor.h> #include <readVcc.h> #include <SPI.h> #include <DHT.h> #define NODE_ID 10 // ID of node unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds) #define CHILD_ID_PIR 1 // Id of the sensor PIR #define CHILD_ID_HUM 2 // Id of the sensor HUM #define CHILD_ID_TEMP 3 // Id of the sensor TEMP #define CHILD_ID_LIGHT 4 // Id of the sensor LIGHT #define PIR_SENSOR_DIGITAL 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define HUMIDITY_SENSOR_DIGITAL_PIN 2 #define LIGHT_SENSOR_ANALOG_PIN 0 MySensor gw; // Initialize Variables MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED); MyMessage msgHum(CHILD_ID_HUM, V_HUM); MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP); MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); DHT dht; float lastTemp; float lastHum; boolean metric = true; int oldBatteryPcnt; int lastLightLevel; long mytime = 0; int MIN_V = 2700; // empty voltage (0%) int MAX_V = 3200; // full voltage (100%) void setup() { gw.begin(NULL, NODE_ID, false); //PIR // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Motion Sensor", "1.0"); pinMode(PIR_SENSOR_DIGITAL, INPUT); // sets the motion sensor digital pin as input digitalWrite(PIR_SENSOR_DIGITAL, HIGH); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_PIR, S_MOTION); //DHT dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN); // Send the Sketch Version Information to the Gateway gw.sendSketchInfo("Humidity", "1.0"); // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID_HUM, S_HUM); gw.present(CHILD_ID_TEMP, S_TEMP); metric = gw.getConfig().isMetric; //LIGHT // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Light Sensor", "1.0"); // Register all sensors to gateway (they will be created as child devices) gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); } void loop() { // Read digital motion value boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH; Serial.print("---------- PIR: "); Serial.println(tripped); gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw if ( millis() > mytime ) { //DHT delay(dht.getMinimumSamplingPeriod()); float temperature = dht.getTemperature(); if (isnan(temperature)) { Serial.println("Failed reading temperature from DHT"); } else if (temperature != lastTemp) { lastTemp = temperature; if (!metric) { temperature = dht.toFahrenheit(temperature); } gw.send(msgTemp.set(temperature, 1)); Serial.print("---------- Temp: "); Serial.println(temperature); } float humidity = dht.getHumidity(); if (isnan(humidity)) { Serial.println("Failed reading humidity from DHT"); } else if (humidity != lastHum) { lastHum = humidity; gw.send(msgHum.set(humidity, 1)); Serial.print("---------- Humidity: "); Serial.println(humidity); } mytime = millis() + dht.getMinimumSamplingPeriod(); } // Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME); }i get this output:
---------- PIR: 1
send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:17.2
---------- Temp: 17.20
---------- PIR: 1
---------- PIR: 0
---------- PIR: 0
---------- PIR: 0
---------- PIR: 1
---------- PIR: 0
---------- PIR: 1
---------- PIR: 0
---------- PIR: 1
---------- PIR: 0
---------- PIR: 0
---------- PIR: 0
send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0 -
This can't work well. Your interrupt is set on pin1 - 2 = int-1?
What happens when you remove the pir and use a switch instead?
