  3. Multisensor PIR problem [solved]
53 Posts 7 Posters 27.4k Views 3 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @n3ro , you can have only one loop().
    You need to merge the two logics into into a single loop. You might also want to remove the second sleep, otherwise PIR will not trigger there.
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    n3roN 1 Reply Last reply
    • rvendrameR rvendrame
      n3roN
      n3roN
      n3ro
      @rvendrame do you have an idea how to do it?
      pimatic + MySensors + Homeduino + z-way
      https://github.com/n3roGit/MySensors_n3ro
      • rvendrameR
        rvendrameR
        rvendrame
        Maybe you can start by to removing these 3 lines:
        void loop2()
        ... and move the 1st sleep to the end of loop (where the 2nd sleep is):
         gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
        .... and remove the 2nd sleep:
        gw.sleep(SLEEP_TIME);
        Alexa / Google Home
          void loop2()
          n3roN
          n3roN
          n3ro
          @rvendrame
          if i use this:
          #include <readVcc.h>
          #define NODE_ID 10                       // ID of node
          unsigned long SLEEP_TIME = 600000;        // Sleep time between reports (in milliseconds)
          #define CHILD_ID_PIR 1                   // Id of the sensor PIR
          #define CHILD_ID_HUM 2                   // Id of the sensor HUM
          #define CHILD_ID_TEMP 3                  // Id of the sensor TEMP
          #define CHILD_ID_LIGHT 4                 // Id of the sensor LIGHT
          #define PIR_SENSOR_DIGITAL 3           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define INTERRUPT PIR_SENSOR_DIGITAL-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define HUMIDITY_SENSOR_DIGITAL_PIN 2
          // Initialize Variables
          MyMessage msgPir(CHILD_ID_PIR, V_TRIPPED);
          MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
          DHT dht;
          float lastTemp;
          float lastHum;
          boolean metric = true;
          int oldBatteryPcnt;
          int lastLightLevel;
          int MIN_V = 2700; // empty voltage (0%)
          int MAX_V = 3200; // full voltage (100%)
            gw.begin(NULL, NODE_ID, false);
            //PIR
            gw.sendSketchInfo("Motion Sensor", "1.0");
            pinMode(PIR_SENSOR_DIGITAL, INPUT);      // sets the motion sensor digital pin as input
            digitalWrite(PIR_SENSOR_DIGITAL, HIGH);
            gw.present(CHILD_ID_PIR, S_MOTION);
            //DHT
            gw.sendSketchInfo("Humidity", "1.0");
            //LIGHT
            gw.sendSketchInfo("Light Sensor", "1.0");
            // Measure battery
            float batteryV = readVcc();
            int batteryPcnt = (((batteryV - MIN_V) / (MAX_V - MIN_V)) * 100 );
            if (batteryPcnt > 100) {
              batteryPcnt = 100;
            if (batteryPcnt != oldBatteryPcnt) {
              gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
              oldBatteryPcnt = batteryPcnt;
            Serial.print("---------- Battery: ");
            Serial.println(batteryPcnt);
            // Read digital motion value
            boolean tripped = digitalRead(PIR_SENSOR_DIGITAL) == HIGH;
            Serial.print("---------- PIR: ");
            Serial.println(tripped);
            gw.send(msgPir.set(tripped ? "1" : "0")); // Send tripped value to gw
            //DHT
            //delay(dht.getMinimumSamplingPeriod());
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("---------- Temp: ");
            if (isnan(humidity)) {
              lastHum = humidity;
              Serial.print("---------- Humidity: ");
              Serial.println(humidity);
            // Light
            int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
            //Serial.println(lightLevel);
              gw.send(msgLight.set(lightLevel));
              lastLightLevel = lightLevel;
              Serial.print("---------- Light: ");
          the pir works fine. but the dht doesn't work.
          when delay(dht.getMinimumSamplingPeriod()); is used the dht works and the pir fails.
          • rvendrameR
            rvendrameR
            rvendrame
            It makes sense ;-) Try this:
            create (outside the loop) a variable to count the time:
            long mytime = 0;
            .. and replace the delay by :
             if ( milis() > mytime )  {
               <  Put the dht stuff here >
              mytime = millis() + dht.getMinimumSamplingPeriod() ;
            Alexa / Google Home
              long mytime = 0;
              n3roN
              n3roN
              n3ro
              @rvendrame
              hmm :)
              if is use this:
              unsigned long SLEEP_TIME = 10000;        // Sleep time between reports (in milliseconds)
              DHT dht;
              float lastTemp;
              float lastHum;
              int oldBatteryPcnt;
              int lastLightLevel;
              long mytime = 0;
                //PIR
                //DHT
                //LIGHT
                if ( millis() > mytime )  {
                  //DHT
                    if (!metric) {
                    lastHum = humidity;
                  // Light
                  // Measure battery
                    batteryPcnt = 100;
                  mytime = millis() + dht.getMinimumSamplingPeriod();
                   Serial.println(mytime);
              i get this output:
              ---------- PIR: 0
              send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=fail:0
              6608
              ---------- PIR: 0
              6608
              ---------- PIR: 0
              6608
              ---------- PIR: 0
              6608
              ---------- PIR: 0
              send: 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
              send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=fail:41.7
              ---------- Humidity: 41.70
              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=fail:38
              ---------- Light: 38
              ---------- Battery: 100
              11148
              ---------- PIR: 0
              11148
              ---------- PIR: 0
              11148
              ---------- PIR: 0
              11148
              ---------- PIR: 0
              11148
              ---------- PIR: 0
              15441
              ---------- PIR: 0
              15441
              ---------- PIR: 0
              15441
              ---------- PIR: 0
              15441
              ---------- PIR: 1
              send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:1
              the pir sends 0 and didnt sleep right :(
              • rvendrameR
                rvendrameR
                rvendrame
                What is this number? Did you print the milis()?
                6608 <<<<<<
                Alexa / Google Home
                  6608 <<<<<<
                  n3roN
                  n3roN
                  n3ro
                  yes :)
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    wrote on last edited by rvendrame
                    #21
                    Are you connecting both DHT and PIR at same pin 2 ? That must be the cause (DHT is triggering the interruption, I think you want only the PIR to trigger it).
                    Edit: looks like your PIR is at pin 3 , and DHT on pin 2 --- Should be the inverse? The PIR should be on pin 2 (to trigger the interrupt).
                    Alexa / Google Home
                    SweebeeS 1 Reply Last reply
                      SweebeeS
                      SweebeeS
                      Sweebee
                      @rvendrame Pir sensor is defined as 3
                      interrupt pin is defined as INT1: 3 - 2 = 1
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        #23
                        So PIR must connect on PIN 1 and not PIN 3.
                        Edit: Better, how did you connect DHT and PIR?
                        Alexa / Google Home
                        n3roN SweebeeS 2 Replies Last reply
                          n3roN
                          n3roN
                          n3ro
                          wrote on last edited by n3ro
                          #24
                          @rvendrame The DHT is on pin 2 and the pir on pin 3. i use the MYS PCB.
                          i suspect the delay function disturb the sleep function. if i dont use the delay, the dht cant "heat up".
                          far as I know the interrupt is only an internal value. right?
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Yes, it looks fine. What exactly error are you having? From your first serial monitor, it looks like your sensor woke on every 10min aprox, ( 6608 / 11148 / 15441 ).
                            Alexa / Google Home
                              n3roN
                              n3roN
                              n3ro
                              #26
                              @rvendrame
                              if i use this:
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              int oldBatteryPcnt;
                              int lastLightLevel;
                                //PIR
                                //DHT
                                //LIGHT
                                // Measure battery
                                  batteryPcnt = 100;
                                //DHT
                                  if (!metric) {
                                  lastHum = humidity;
                                // Light
                              i get this output after starting:
                              sensor started, id 10
                              send: 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                              send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                              read: 0-0-10 s=255,c=3,t=6,pt=0,l=1:M
                              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:Motion Sensor
                              send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                              send: 10-10-0-0 s=1,c=0,t=1,pt=0,l=5,st=ok:1.4.1
                              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
                              send: 10-10-0-0 s=2,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                              send: 10-10-0-0 s=3,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                              send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Light Sensor
                              send: 10-10-0-0 s=4,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                              send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:100
                              ---------- PIR: 1
                              send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.6
                              ---------- Temp: 16.60
                              send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.8
                              ---------- Humidity: 43.80
                              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:39
                              ---------- Light: 39
                              ---------- PIR: 0
                              send: 10-10-0-0 s=1,c=1,t=16,pt=0,l=1,st=ok:0
                              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:37
                              ---------- Light: 37
                              ---------- PIR: 1
                              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:34
                              ---------- Light: 34
                              ---------- PIR: 0
                              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:36
                              ---------- Light: 36
                              ---------- PIR: 1
                              ---------- PIR: 0
                              send: 10-10-0-0 s=4,c=1,t=23,pt=2,l=2,st=ok:38
                              The DHT gives only output the first start and the pir interrupt works perfect.
                              When delay(dht.getMinimumSamplingPeriod()); is activated the DHT works and the pit interrupts the whole time :(
                              In this configuration the arduino never sleeps ..
                              ---------- PIR: 1
                              send: 10-10-0-0 s=3,c=1,t=0,pt=7,l=5,st=ok:16.5
                              ---------- Temp: 16.50
                              send: 10-10-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:43.9
                              ---------- Humidity: 43.90
                              ---------- PIR: 1
                              ---------- PIR: 0
                              ---------- PIR: 0
                              ---------- PIR: 0
                              EDIT: i have changed the sleeptime for testing to a shorter time
                                SweebeeS
                                SweebeeS
                                Sweebee
                                @rvendrame When the PIR is connected to PIN3 the interrupt is INT1. Pin 1 does not have an interrupt.
                                Only pin 2 and pin 3 have an interrupt.
                                Pin 2 = int0
                                pin 3 = int1
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  if you put the delay() inside that 'if ( mills() > mytime ) ' , what happens?
                                  Alexa / Google Home
                                  • SweebeeS Sweebee
                                    Pin 2 = int0
                                    pin 3 = int1
                                    n3roN
                                    n3roN
                                    n3ro
                                    @Sweebee is it possible to fix the problem when DHT is connected to pin 4?
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      It worth a try ...
                                      Alexa / Google Home
                                        n3roN
                                        n3roN
                                        n3ro
                                        @rvendrame
                                        i have posted it before this post:
                                        "What is this number? Did you print the milis()?
                                        6608 <<<<<<"
                                        in the posted sketch the delay is inside millis
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          I didn't find the if ( millis() > my time) in the last sketch you posted ...
                                          Alexa / Google Home
