  3. Log Translation
Log Translation
12 Posts 6 Posters 5.4k Views 2 Watching
  • K kopite
    Still trying to get my 1st sensor communication in Domoticz, can anyone translate the arduino serial log for me?
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    I think it is communicating but will not show up in Domoticz??
    AWIA
    AWIA
    AWI
    @kopite Your sensor-node is trying to get a Node-id from the controller.
    The 0;0;.... messages come from the controller
    The 255;255; message come from you node and are "internal" (3) messages with "node_req" from the node. Domoticz should issue a node-id when received, but supposedly this is not happening.
    • A
      andriej
      Make sure that you have 'accept new devices' in Domoticz's settings enabled.
      • K
        K
        kopite
        Tried this now with a few sensors and gateways and still get the same result in the serial monitor.....im thinking it is the radio now? possible need a capacitor?
        SparkmanS 1 Reply Last reply
        • K kopite
          SparkmanS
          SparkmanS
          Sparkman
          @kopite As others have posted above, it looks like the gateway is receiving the packets from the sensor and the controller (Domoticz) should act on them and issue a node-id to the new node. Domoticz does not appear to be providing that, so it looks like a communications or configuration issue between Domoticz and the gateway, not a radio issue.
          Al
          • K
            K
            kopite
            @Sparkman , the log is from the serial monitor on arduino IDE?
            • F
              F
              franckyvrac
              Your log seems correct. I think your problem comes from Domoticz. Have you declared new arduino gateway in Domoticz? If so, can you show us domoticz's log?
              • K
                K
                kopite
                All I get from Domoticz is
                2015-05-15 17:24:33.161 MySensors: Using serial port: COM5
                2015-05-15 17:24:34.657 MySensors: Gateway Ready...
                2015-05-15 17:24:45.881 New sensors allowed for 5 minutes...
                A 1 Reply Last reply
                • K kopite
                  andriej
                  @kopite have you tried most simple sensors?
                  It should work. What version of Domoticz do you use? Latest beta?
                  • K
                    K
                    kopite
                    im using the latest Beta V2.2439, ive tried Relay, Humidity and Pulse counter
                    • F
                      F
                      franckyvrac
                      What are logs on Domoticz when you restart your node?
