  3. Log Translation
Log Translation
12 Posts 6 Posters 5.1k Views 2 Watching
  • K Offline
    K Offline
    kopite
    Still trying to get my 1st sensor communication in Domoticz, can anyone translate the arduino serial log for me?
    0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    I think it is communicating but will not show up in Domoticz??
    A 1 Reply Last reply
    • T Offline
      T Offline
      tbowmo
      @kopite
      It's described here http://www.mysensors.org/download/serial_api_14
      • K kopite
        255;255;3;0;3;
        255;255;3;0;3;
        255;255;3;0;3;
        A Offline
        A Offline
        AWI
        @kopite Your sensor-node is trying to get a Node-id from the controller.
        The 0;0;.... messages come from the controller
        The 255;255; message come from you node and are "internal" (3) messages with "node_req" from the node. Domoticz should issue a node-id when received, but supposedly this is not happening.
        • A Offline
          A Offline
          andriej
          Make sure that you have 'accept new devices' in Domoticz's settings enabled.
          • K Offline
            K Offline
            kopite
            Tried this now with a few sensors and gateways and still get the same result in the serial monitor.....im thinking it is the radio now? possible need a capacitor?
            S 1 Reply Last reply
            • K kopite
              Sparkman
              @kopite As others have posted above, it looks like the gateway is receiving the packets from the sensor and the controller (Domoticz) should act on them and issue a node-id to the new node. Domoticz does not appear to be providing that, so it looks like a communications or configuration issue between Domoticz and the gateway, not a radio issue.
              Al
              • K Offline
                K Offline
                kopite
                @Sparkman , the log is from the serial monitor on arduino IDE?
                • F Offline
                  F Offline
                  franckyvrac
                  Your log seems correct. I think your problem comes from Domoticz. Have you declared new arduino gateway in Domoticz? If so, can you show us domoticz's log?
                  • K Offline
                    K Offline
                    kopite
                    All I get from Domoticz is
                    2015-05-15 17:24:33.161 MySensors: Using serial port: COM5
                    2015-05-15 17:24:34.657 MySensors: Gateway Ready...
                    2015-05-15 17:24:45.881 New sensors allowed for 5 minutes...
                    • K kopite
                      A Offline
                      A Offline
                      andriej
                      @kopite have you tried most simple sensors?
                      It should work. What version of Domoticz do you use? Latest beta?
                      • K Offline
                        K Offline
                        kopite
                        im using the latest Beta V2.2439, ive tried Relay, Humidity and Pulse counter
                        • F Offline
                          F Offline
                          franckyvrac
                          What are logs on Domoticz when you restart your node?
                          12.1k
