  3. IR Switch for Luminara Candle Automation (repost with video, photos and final sketch)
ir blasterir code
29 Posts 9 Posters 24.2k Views 4 Watching
  • korttomaK korttoma
    @blacey would you mind sharing how you connected the IR-Transmitters to the arduino? Is this what the Transistor is for?
    blaceyB
    blaceyB
    blacey
    wrote on last edited by blacey
    @korttoma, yes the transistor is used to drive the IR LEDs. It is a standard NPN transistor (NTE123AP) capable of delivering 600mA of current through the collector.
    The transistor base lead is connected to the Arduino PWM pin 3 per IRLib, the transistor emitter lead is connected to GND and the transistor collector lead is connected to the IR LED emitters wired in parallel (cathode). It is best practice to place a forward current limiting resistor between IR LEDs anode and VCC but the IRLib drives the LEDs for such short intervals, that you can avoid adding the forward current limiting resistors as I mentioned in the video.
    • korttomaK
      korttomaK
      korttoma
      Thanks @blacey for the clarification. I sort of overlooked the fact that there was a video, sorry. My consirns was about the current limiting resistor but if you say the IR LEDs can take it I believe you. Thanks again for this project ;)
      • Tomas
      • blaceyB
        blaceyB
        blacey
        @korttoma - sorry you missed the video ;) I have it on my to-do list to draw a proper schematic for the IR blaster board and the actuator but I just haven't had time yet. I would like to post one in this thread to make it easier for people to build their own IR actuator. Maybe you will get there first ;)
        jeylitesJ 1 Reply Last reply
        • blaceyB blacey
          jeylitesJ
          jeylitesJ
          jeylites
          @blacey what program are you using to capture the IR codes from the remote ?
          blaceyB 1 Reply Last reply
          • jeylitesJ jeylites
            blaceyB
            blaceyB
            blacey
            @jeylites I used the IRSensor sketch in the MySensors examples.
            • blaceyB blacey
              jeylitesJ
              jeylitesJ
              jeylites
              @blacey Nice. I'm using IR Recorder from the library. I asked because you had a fancy setup in the video :) Very neat setup!
              • jeylitesJ
                jeylitesJ
                jeylites
                wrote on last edited by jeylites
                Hello @blacey , I got a question... If I'm going to add another IR into the sketch, how do I go about doing this? So two independent sensors into one. This is what I have done so far. Correct me if I'm wrong. Should I be changing something in IRsend irsend ....?
                And is your IR LED connected to Pin 1 or Pin3?
                 * Binary IR Switch sketch that controls Luminara Candles
                 * Sketch inspired by, and a derivative work of, Hek's IR Sensor example sketch
                #include <IRLib.h>
                int RECV_PIN =  8;
                #define CHILD1  3 // Arduino Pin 3
                #define CHILD2  4 // Arduino Pin 4
                MyMessage switchMsg1(CHILD1, V_VAR1);
                MyMessage switchMsg2(CHILD2, V_VAR1);
                // IR LED must be connexted to Arduino PWM pin 3
                IRsend irsend;
                #define switchOnIRcode  0x00ff629d  // Luminara On  IR code
                #define switchOffIRcode 0x00ffa857  // Luminara Off IR code
                  gw.begin(incomingMessage);
                  gw.sendSketchInfo("IR Switch", "1.0");
                  // Register a sensors to gw. Use binary light for test purposes.
                  gw.present(CHILD1, S_LIGHT);
                  gw.present(CHILD2, S_LIGHT);
                  // Sync switch state to gateway state upon reset / power-up
                  gw.request(CHILD1, V_LIGHT);
                  gw.request(CHILD2, V_LIGHT);
                  if (message.type==V_LIGHT) {
                     int incomingRelayStatus = message.getInt();
                     // Emit the IR ON/OFF code
                     irsend.send(NEC, (incomingRelayStatus == 1 ? switchOnIRcode : switchOffIRcode), 32);
                     // Sync gateway of the light switch state
                     gw.send(switchMsg1.set(incomingRelayStatus));
                     gw.send(switchMsg2.set(incomingRelayStatus));
                  #include <IRLib.h>
                  int RECV_PIN =  8;
                  IRsend irsend;
                  blaceyB
                  blaceyB
                  blacey
                  @jeylites My IR LEDs are connected to Pin 3 because that is what IR Lib requires. Your sketch looks close but you will need to define separate switchOnIRcode and switchOffIRcode codes for your respective lights. Then in the incomingMessage loop, send the appropriate code based upon the child ID. If you plan to have a large number of child IDs, I would create an array indexed by child ID to hold the on/off IR codes and then simply invoke ir.send() passing the onOffCode[childID] to it. Does that make sense?
                  Also, I just started another thread for an official IR Blaster board that you might want to review. I plan to provide multiple device support out of the box...
                  • jeylitesJ
                    jeylitesJ
                    jeylites
                    @blacey I think I get what you're saying on #define but don't know how to associate child id with ir code. Do you have a sample or something ?
                    IR blaster - you working on looks great. Next project is to use that to control my AV system.
                    Thank you!
                      Thank you!
                      blaceyB
                      blaceyB
                      blacey
                      @jeylites Here is a quick and dirty example for two switch IR devices... Hope this helps you get started. I will give multi-device more thoughts/elegance for the final IR Blaster.
                      #include <IRLib.h>
                      #define NumChildDevices 2
                      typedef struct IRCode {
                        IRTYPES brand;
                        unsigned long on;
                        unsigned long off;
                        unsigned int bits;
                      } ir;
                      ir childIR[NumChildDevices];
                      IRsend iremitter;
                      MyMessage child1Msg(1, V_VAR1);
                      MyMessage child2Msg(2, V_VAR2);
                        gw.begin();
                        gw.sendSketchInfo("Multi IR", "0.1");
                        // Initialize children devices
                        // 1. Candles (Switch)
                        gw.present(1, S_LIGHT);
                        childIR[1] = {NEC, 0x00ff629d, 0x00ffa857, 32};
                        // 2. TV
                        gw.present(2, S_LIGHT);
                        childIR[2] = {SONY, 0x0062ff8d, 0x00aff578, 32};
                        //Determine the child device
                        uint8_t child = message.sensor;
                        //Get the relay status for the child device
                        //Emit the appropriate IR code to the child device
                        iremitter.send( childIR[child].brand, incomingRelayStatus == 1 ? childIR[child].on : childIR[child].off, childIR[child].bits);
                      • jeylitesJ
                        jeylitesJ
                        jeylites
                        @blacey Thank you sir! Will test it out over the weekend.
                        • korttomaK
                          korttomaK
                          korttoma
                          I just wanted to confirm that the cheep ebay Luminara "style" candles does work with blaceys sketch "out of the box".
                          • Tomas
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @korttoma
                            do you have a link to some of the cheap ones on ebay?
                            hekH 1 Reply Last reply
                            • tbowmoT tbowmo
                              @korttoma
                              wrote on last edited by hek
                              #25
                              @tbowmo
                              Scroll up half a page ;)
                              Edit: Opps.. sold out..
                              Here is another one:
                              http://www.ebay.com/itm/Luminara-Style-7-inch-LED-Ivory-Wax-Flameless-Pillar-Candle-with-Remote-control-/301644690382?pt=LH_DefaultDomain_3&hash=item463b6cb3ce
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @hek
                                Hmm by cheap, I thought it was below 15$ :)
                                korttomaK 1 Reply Last reply
                                • tbowmoT tbowmo
                                  @hek
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @tbowmo said:
                                  @hek
                                  They are cheep compared to the Genuine Luminara products + I could not find a good suppler for the real thing sending to Europe
                                  Maybe the once @betonishard mentioned earlier in the thread would be something more in your prize range? Would be nice to know if they also work with blaceys sketch though.
                                  • Tomas
                                  • B
                                    B
                                    betonishard
                                    @korttoma, didn't had time to make the ir blaster yet. So quite frankly I don't know. I am using the remote delivered in the package. It still works by the way, which was surprising for that price. The flicker of the candles is kind of fast, like there is a firm wind in my livingroom.
                                    • BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      Wow this is an old topic!
                                      But... I was working on a project and thought that anyone who was looking for a NeoPixel candle example that isn't blocking, well this would be the place. It flickers and flutters like a real candle. The only thing is that the flame isn't illuminated like these nice Luminaras, but I'm too cheap to buy them!
                                      Keep in mind that my example here uses GRB LEDs, but you merely need to reorder the variables in order to get this working for RGB. Plus the Time Library is not Arduino, so you will have to play with that too for a good randomSeed().
                                      It looks pretty realistic with even a single neoPixel in a sheet of A4 paper rolled into a cylinder. I'll post a video when I can.
                                      Have fun with it:
                                      #include "neopixel.h"
                                      enum CandleStates{
                                        BURN_CANDLE,
                                        FLICKER_CANDLE,
                                        FLUTTER_CANDLE,
                                        MODES_MAX_CANDLE
                                      enum PixelSelect{
                                        EVERY_PIXEL,
                                        SINGLE_PIXEL,
                                      class Candle : public Adafruit_NeoPixel
                                        public:
                                          Candle(uint16_t count, uint8_t pin, uint8_t type);
                                          Candle(uint16_t count, uint8_t pin, uint8_t type, PixelSelect pixel, uint32_t pixNum = 0);
                                          ~Candle(){};
                                          void update();
                                        private:
                                          bool fire(uint8_t greenDropValue, uint32_t cycleTime);
                                          PixelSelect _pixelMode = EVERY_PIXEL;
                                          uint32_t _pixNum = 0;
                                          CandleStates _mode;
                                          uint32_t _lastModeChange;
                                          uint32_t _modeDuration;
                                          uint8_t _redPx = 255;
                                          uint8_t _bluePx = 10; //10 for 5v, 15 for 3.3v
                                          uint8_t _grnHigh = 100; //110-120 for 5v, 135 for 3.3v
                                          uint8_t _grnPx = 100;
                                          uint32_t _lastBurnUpdate = 0;
                                          int _direction = 1;
                                      Candle::Candle(uint16_t count, uint8_t pin, uint8_t type) : Adafruit_NeoPixel(count, pin, type)
                                        randomSeed(Time.now() + micros());
                                        _mode = BURN_CANDLE;
                                      Candle::Candle(uint16_t count, uint8_t pin, uint8_t type, PixelSelect pixel, uint32_t pixNum) : Adafruit_NeoPixel(count, pin, type)
                                        _pixelMode = pixel;
                                        _pixNum = pixNum;
                                      void Candle::update()
                                        if(millis() - _lastModeChange > _modeDuration)
                                          _mode = static_cast<CandleStates>(random(MODES_MAX_CANDLE));
                                          _modeDuration = random(1000, 8000);
                                          _lastModeChange = millis();
                                          //Serial.printlnf("New state: %d\tTime: %d", static_cast<int>(_mode), _modeDuration);
                                        switch(_mode)
                                          case BURN_CANDLE:
                                            this->fire(10, 120);
                                          case FLICKER_CANDLE:
                                            this->fire(15, 120);
                                          case FLUTTER_CANDLE:
                                            this->fire(30, 120);
                                      bool Candle::fire(uint8_t greenDropValue, uint32_t cycleTime)
                                        int currentMillis = millis();
                                        if(currentMillis - _lastBurnUpdate > (cycleTime / greenDropValue / 2))
                                          _grnPx = constrain(_grnPx += _direction, _grnHigh - greenDropValue, _grnHigh);
                                          if(_grnPx == _grnHigh - greenDropValue or _grnPx == _grnHigh)
                                            _direction *= -1;
                                          switch (_pixelMode)
                                            case EVERY_PIXEL:
                                              for(int i = 0; i < this->numPixels(); i++)
                                                this->setPixelColor(i, _grnPx, _redPx, _bluePx);
                                            case SINGLE_PIXEL:
                                              this->setPixelColor(_pixNum, _grnPx, _redPx, _bluePx);
                                          this->show();
                                          _lastBurnUpdate = currentMillis;
                                      #define PIXEL_COUNT 2
                                      #define PIXEL_PIN D2
                                      #define PIXEL_TYPE WS2812B    // I'M USING GRB WS2821B's here
                                      Candle candle = Candle(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE, SINGLE_PIXEL);
                                      void setup(void)
                                        pinMode(13, OUTPUT);
                                        candle.begin();
                                        candle.show();
                                        Serial.println("Started program");
                                      void loop(void)
                                        candle.update();
                                        static uint32_t lastFlashMillis = 0;
                                        if(millis() - lastFlashMillis > 250)
                                          digitalWrite(13, !digitalRead(13));
                                          lastFlashMillis = millis();
