  3. Homeseer
  4. Moving From Vera to HomeSeer
Scheduled Pinned Locked Moved Homeseer
10 Posts 3 Posters 6.8k Views 2 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    I'm in the process of evaluating HomeSeer (From what I've seen I'm most likely going to make the move) for a move from Vera.
    What is the best and easiest way to move my MySensors network from the Vera controller to the HomeSeer computer?
    RJ_Make
    SparkmanS 1 Reply Last reply
    • RJ_MakeR RJ_Make
      SparkmanS
      SparkmanS
      Sparkman
      @ServiceXp I use HS3 (have been using HS for over 15 years) and the MySensors plugin. One thing to note is that the HS MySensors plugin does not yet support all of the same devices as the Vera plugin does. What types of sensors are you using? I believe that when you hook-up the gateway to HS3 and put the plugin in inclusion mode, it should see all of the data come in and then create the associated HS devices automatically.
      Al
      RJ_MakeR 1 Reply Last reply
      • SparkmanS Sparkman
        Al
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @Sparkman
        I'm Using Temp, Humidity, Relay and Motion.
        RJ_Make
        • RJ_MakeR RJ_Make
          @Sparkman
          SparkmanS
          SparkmanS
          Sparkman
          @ServiceXp Those are all supported so you should be good.
          Al
          RJ_MakeR 2 Replies Last reply
            Al
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @Sparkman Thank You!
            RJ_Make
              Al
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @Sparkman I have a question: When I added the gateway to HS3, It's say "WARNING: Expires: 5/31/2015 12:00:00 PM"
              What does that exactly mean?
              RJ_Make
              • RJ_MakeR RJ_Make
                SparkmanS
                SparkmanS
                Sparkman
                wrote on last edited by Sparkman
                @ServiceXp It means the plugin will stop working on that date. The author should release a new version prior to then, so it should not be an issue. I'm not sure why the author elected to release the plugin with an expiry date.
                Al
                  Al
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @Sparkman Oh.... Ok....
                  RJ_Make
                  • H
                    H
                    hleidecker
                    wrote on last edited by hleidecker
                    I'm the developer of the MySensors HomeSeer plugin. The expiry date was implemented in order to ensure that most users are running the latest version of the plugin.
                    I'm happy to hear that you are taking my plugin into use.
                    A lot of effort has been spent on adding support for retransmission, timeout, unit strings etc. Adding support for new sensors is in principle trivial as long as the protocol is clear - for some of the sensors I had to talk to HEK about the definition of the protocol.
                    Maybe focus should be changed to additional sensor support for the coming releases.
                    Best regards,
                    Henrik
                    • H hleidecker
                      Best regards,
                      Henrik
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @hleidecker Thank you VERY much for your plug in. I tried posting some questions to problems that I'm having but they must be moderated first...
                      If you have a chance:
                      1. How do I display battery levels?
                      2. The "Light indicators" don't work with a status change (Light is always off)
                      RJ_Make
