  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
  • RJ_MakeR RJ_Make
    @petewill There is a MySensors plug-in for HS3, At the moment it is a bit limited, and has some bugs but the developer is working on it.
    petewillP
    petewillP
    petewill
    @ServiceXp Good to know. I'll keep that in mind. Thanks for passing that on!
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      #32
      @petewill
      lcd.write(0)
      Prints the '0' special character.
      There is a raindrop icon, which tells you times are downloading and a clock icon which designates clock updates.
      uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
      uint8_t raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
      convert the hex to binary you can see the shape (5 X 7 pixels, so disregard the first three bits):
      00000000
      00001110
      00010101
      00010111
      00010001
      00001110
      00000000
      can you see the clock face at 3:00?
      00000100
      00000100
      00001010
      00001010
      00010001
      00010001
      00001110
      00000000
      Can you see the raindrop?
      they are created here:
       lcd.createChar(0, clock);
       lcd.createChar(1, raindrop);
      if you look at the video above, they appear from time to time.
      cool right?
      • petewillP
        petewillP
        petewill
        Ok, good to know. I'll see if I can do a little searching on that. Maybe there is a different way to implement them now?? It will be hard to test without an LCD but hopefully it will come soon and I can post back :)
        Speaking of testing I was able to control my relays last night from Vera! SO COOL!! This is one of the devices I have been wanting to add for a long time. I can't wait to be able to turn on my valves from my phone when I'm turning on my sprinkler system. It sure will beat sprinting to/from the basement...
        Thanks again for the awesome work!
        • petewillP petewill
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @petewill
          I edited above to give more detail...
          • petewillP
            petewillP
            petewill
            Ok, thanks. I did a little research and found this from the Arduino website:
            When referencing custom character "0", if it is not in a variable, you need to cast it as a byte, otherwise the compiler throws an error. See the example below.
            http://www.arduino.cc/en/Reference/LiquidCrystalCreateChar
            I changed the code to this:
            byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
            and this
            lcd.write(byte(0));
            and now it's compiling. But, I don't know if it's working.
            I'm still working on a couple of other small things I found. I'll post the code when I get it to a point where it's ready for your review.
            • petewillP
              petewillP
              petewill
              @BulldogLowell
              Here is the code with some changes. I have also attached a document with the changes highlighted. The most notable thing is I added some code to update the valve times when the device is first powered on. I hope that's ok.
              One thing I can't figure out, but hopefully you can, is the button is always acting like it's "pressed" when the Arduino is first powered on. This could be a problem as the power seems to go off in my house a couple of times a year (I don't want my irrigation to run when it's not supposed to). Any idea how to fix it? I've tried everything I could think of (which isn't much) and nothing worked.
              Anyway, here is the PDF with the changes Irrigation Controller Changes.pdf
              And the code:
              MySprinkler for MySensors
              Arduino Multi-Zone Sprinkler Control
              November, 2014
              *** Version 2.0
              *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve times and clock respectively
              your arduino will call to Vera once a minute and update accordingly.
              * Pushbutton activation to RUN_ALL_ZONES
              * LED status indicator
              INSTRUCTIONS:
              * Verify that each new device has a Variable1 and Variable2. Populate data accordingly with whole minutes for
              the RUN_ALL_ZONES routine and the RUN_SINGLE_ZONE routines.  The values entered may be zero.
              on the serial monitor.
              * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
              Contributed by Jim (BulldogLowell@gmail.com) and is released to the public domain
              #include <Time.h>
              #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
              #define RADIO_ID AUTO // AUTO  // Change this to fix your Radio ID or use Auto
              #define SKETCH_VERSION "2.0"
              #define CHILD_ID_SPRINKLER 0
              #define ACTIVE_LOW // comment out this line if your relays are active high
              #ifdef ACTIVE_LOW
              #define ALL_VALVES_OFF 0xFFFF
              #define ALL_VALVES_OFF 0U
              #ifdef DEBUG_ON
              typedef enum {
               STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE}
              SprinklerStates;
              SprinklerStates lastState;
              int allZoneTime [NUMBER_OF_VALVES + 1];
              int valveSoloTime [NUMBER_OF_VALVES + 1];
              int valveNumber;
              int lastValve;
              unsigned long startMillis;
              const int ledPin = 5;
              const int waterButtonPin = 3;
              boolean buttonPushed = false;
              boolean showTime = true;
              boolean clockUpdating = false;
              boolean recentUpdate = true;
              const char *dayOfWeek[] = {
               "Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
              time_t lastTimeRun = 0;
              //Setup Shift Register...
              const int latchPin = 8;
              const int clockPin = 4;
              const int dataPin  = 7;
              byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
              byte raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
              LiquidCrystal_I2C lcd(0x27);  // set the LCD I2C address to 0x27
              MyMessage msg1valve(CHILD_ID_SPRINKLER,V_LIGHT);
              MyMessage var1valve(CHILD_ID_SPRINKLER,V_VAR1);
              MyMessage var2valve(CHILD_ID_SPRINKLER,V_VAR2);
                delay(5000);
               //*Added
              //*Removed
              // lcd.init();
               lcd.clear();
               lcd.backlight();
               pinMode(latchPin, OUTPUT);
               pinMode(clockPin, OUTPUT);
               pinMode(dataPin, OUTPUT);
               pinMode(ledPin, OUTPUT);
               attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
               digitalWrite (ledPin, HIGH);
               if (gw.loadState(0) == 0xFF); // EEPROM flag
                  for (int i = 0; i < 4 ; i++)
                   lastTimeRun = lastTimeRun | gw.loadState(i+1); // assemble 4 bytes into an ussigned long epoch timestamp
               gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                  gw.present(i, S_LIGHT);
               updateRelays(ALL_VALVES_OFF);
               digitalWrite (ledPin, LOW);
               DEBUG_PRINTLN(F("Ready..."));
               lcd.setCursor(0, 0);
               lcd.setCursor(15, 0);
               lcd.write(byte(0));  //lcd.print(0, BYTE);
               lcd.setCursor(0, 1);
               int clockCounter = 0;
               while(timeStatus() == timeNotSet && clockCounter < 21)
                  gw.requestTime(receiveTime);
                  delay(1000);
                  lcd.print(".");
                  //DEBUG_PRINT(F("."));
                  clockCounter++;
                  if (clockCounter > 16)
                   lcd.clear();
                   lcd.setCursor(0,1);
                   delay(2000);
               lcd.clear();
               //Update valve times when first powered on
               for(byte i = 0; i <= NUMBER_OF_VALVES; i++)
                 allZoneTime[i]=-1;
                 valveSoloTime[i]=-1;
                 while((valveSoloTime[i]==-1 || allZoneTime[i]==-1) && clockCounter < 10)
                   DEBUG_PRINTLN(F("Calling for Valve Times..."));
                   lcd.write(byte(1)); //lcd.write(1);
                   gw.request(i, V_VAR1);
                   gw.request(i, V_VAR2);
                   delay(1000);
                   clockCounter++;
                   if (clockCounter > 10)
                      DEBUG_PRINTLN(F("Failed initial valve synchronization!"));
                      lcd.clear();
                      lcd.print(F("  Failed Valve  "));
                      lcd.setCursor(0,1);
               updateClock();
               updateDisplay();
               goGetValveTimes();
               if (buttonPushed)
                  if (state != RUN_ALL_ZONES)
                   state = RUN_ALL_ZONES;
                   valveNumber = 1;
                   gw.send(msg1valve.setSensor(0).set(true), false);
                   startMillis = millis();
                   for (byte i = 0; i < 5; i++)  // flash lcd backlight on button press
                      lcd.noBacklight();
                      delay(25);
                      lcd.backlight();
                   delay(50);
                   fastClear();
                   lcd.setCursor(0,0);
                   lcd.print(F("*AllZone Active*"));
                   lcd.setCursor(0,0);
                   lcd.print(F(" Cycling  Zones "));
                   delay(1000);
                   DEBUG_PRINT(F("State = "));
                   DEBUG_PRINTLN(state);
                    //valveNumber = 1;
                    gw.send(msg1valve.setSensor(0).set(false), false);
                      lcd.noBacklight();
                      delay(25);
                      lcd.backlight();
                    delay(50);
                    fastClear();
                    lcd.setCursor(0,0);
                    lcd.print(F("*AllZone Off*"));
                    lcd.setCursor(0,0);
                    lcd.print(F(" Stopping  Zones "));
                    delay(1000);
                  slowToggleLED ();
                  if (state != lastState)
                      delay(50);
                      gw.send(msg1valve.setSensor(i).set(false), false);
                   lastValve = -1;
                  if (lastValve != valveNumber)
                       gw.send(msg1valve.setSensor(i).set(true), false);
                  lastValve = valveNumber;
                  fastToggleLed();
                   valveNumber = 1;
                   valveNumber++;
                      state = CYCLE_COMPLETE;
                      lastValve = -1;
                      lastTimeRun = now();
                  fastToggleLed();
                   DEBUG_PRINT(F("Zone: "));
                   DEBUG_PRINTLN(valveNumber);
                   fastToggleLed();
               lastState = state;
              void updateRelays(int value)
               digitalWrite(latchPin, LOW);
               digitalWrite(latchPin, HIGH);
                  buttonPushed = true;
              void fastToggleLed()
                  fastLedTimer = millis ();
              void slowToggleLED ()
                  slowLedTimer = millis ();
               boolean zoneTimeUpdate = false;
               if (message.isAck())
               for (byte i = 0; i<= NUMBER_OF_VALVES; i++)
                  if (message.sensor == i)
                   if (message.type == V_LIGHT)
                      if (switchState == 0)
                       if (i == 0)
                          valveNumber = 1;
                          state = RUN_SINGLE_ZONE;
                          valveNumber = i;
                          DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(F(" = "));
                      DEBUG_PRINTLN(variable1);
                       allZoneTime[i] = variable1;
                       zoneTimeUpdate = true;
                      DEBUG_PRINT(i);
                      DEBUG_PRINTLN(variable2);
                       valveSoloTime[i] = variable2;
               if (zoneTimeUpdate)
                   if (i != 0)
                      DEBUG_PRINT(F("Zone "));
                      DEBUG_PRINT(i);
                      DEBUG_PRINTLN(allZoneTime[i]);
                  recentUpdate = false;
              void updateDisplay()
               static boolean displayToggle = false;
                  switch (state){
                  case STAND_BY_ALL_OFF:
                   fastClear();
                   lcd.setCursor(0,0);
                   if (displayToggle)
                      if (clockUpdating)
                       lcd.setCursor(15,0);
                       lcd.write(byte(0));
                      lcd.setCursor(0,1);
                      lcd.print(hourFormat12());
                      lcd.print(minute());
                      lcd.print(F(" "));
                      lcd.print(month() < 10? F("0") : F(""));
                      lcd.print(month());
                      lcd.print(day() < 10? F("/0") : F("/"));
                      lcd.print(day());
                      lcd.print(F("/"));
                      lcd.print(year()%100);
                      if (clockUpdating)
                       lcd.write(byte(0));
                      lcd.setCursor(0,1);
                      lcd.setCursor(11,1);
                      lcd.print(day(lastTimeRun));
                  case RUN_SINGLE_ZONE:
                   fastClear();
                   lcd.setCursor(0,0);
                   if (displayToggle)
                      lcd.setCursor(0,1);
                      lcd.print(F(" Zone:"));
                      lcd.print(valveNumber);
                      lcd.print(F(" Active"));
                      lcd.setCursor(0,1);
                      lcd.print("min");
                      lcd.print("sec  ");
                  case RUN_ALL_ZONES:
                   fastClear();
                   lcd.setCursor(0,0);
                   if (displayToggle)
                      lcd.setCursor(0,1);
                      lcd.print(F(" Active "));
                      lcd.setCursor(0,1);
                      lcd.print("min");
                      lcd.print("sec  ");
                  case CYCLE_COMPLETE:
                   if (displayToggle)
                      lcd.setCursor(0,0);
                      lcd.setCursor(0,1);
                      int totalTimeRan = 0;
                      lcd.setCursor(0,0);
                      lcd.setCursor(0,1);
                      lcd.print(totalTimeRan);
                      lcd.print(" Minutes   ");
                  lastUpdateTime = millis();
               lastDisplayState = state;
               int lastSecond = second();
               int lastMinute = minute();
               int lastHour = hour();
               setTime(newTime);
                  DEBUG_PRINT(hourFormat12());
                  DEBUG_PRINT(minute());
                  DEBUG_PRINT(month());
                  DEBUG_PRINT(F("/"));
                  DEBUG_PRINT(day());
                  DEBUG_PRINTLN(year());
                  showTime = false;
              void fastClear()
               lcd.setCursor(0,0);
               lcd.setCursor(0,1);
              void updateClock()
                  lcd.write(byte(0));
                  clockUpdating = true;
                  lastVeraGetTime = millis();
               if (gw.loadState(0) != 0xFF)
                  gw.saveState(0,0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
               for (int i = 1; i < 5; i++)
                  gw.saveState(5-i, byte(theDate >> 8 * (i-1)));// store epoch datestamp in 4 bytes of EEPROM starting in location one
              void goGetValveTimes()
               static byte valveIndex = 1;
               if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                  gw.request(valveIndex, V_VAR1);
                  gw.request(valveIndex, V_VAR2);
                  valveUpdateTime = millis();
                  valveIndex++;
                  if (valveIndex > NUMBER_OF_VALVES+1)
                   valveIndex = 1;
                @BulldogLowell
                And the code:
                November, 2014
                *** Version 2.0
                INSTRUCTIONS:
                #include <Time.h>
                #ifdef ACTIVE_LOW
                #ifdef DEBUG_ON
                typedef enum {
                SprinklerStates;
                int valveNumber;
                int lastValve;
                  delay(5000);
                 //*Added
                //*Removed
                // lcd.init();
                 lcd.clear();
                 lcd.backlight();
                    delay(1000);
                    lcd.print(".");
                    clockCounter++;
                     lcd.clear();
                     lcd.setCursor(0,1);
                     delay(2000);
                 lcd.clear();
                   allZoneTime[i]=-1;
                     delay(1000);
                     clockCounter++;
                        lcd.clear();
                        lcd.setCursor(0,1);
                 updateClock();
                 updateDisplay();
                 goGetValveTimes();
                 if (buttonPushed)
                     valveNumber = 1;
                        lcd.noBacklight();
                        delay(25);
                        lcd.backlight();
                     delay(50);
                     fastClear();
                     lcd.setCursor(0,0);
                     lcd.setCursor(0,0);
                     delay(1000);
                      //valveNumber = 1;
                        lcd.noBacklight();
                        delay(25);
                        lcd.backlight();
                      delay(50);
                      fastClear();
                      lcd.setCursor(0,0);
                      lcd.setCursor(0,0);
                      delay(1000);
                    slowToggleLED ();
                        delay(50);
                     lastValve = -1;
                    fastToggleLed();
                     valveNumber = 1;
                     valveNumber++;
                        lastValve = -1;
                    fastToggleLed();
                     fastToggleLed();
                 lastState = state;
                         if (i == 0)
                            valveNumber = 1;
                            valveNumber = i;
                            DEBUG_PRINTLN(i);
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(i);
                 if (zoneTimeUpdate)
                     if (i != 0)
                        DEBUG_PRINT(i);
                    switch (state){
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        if (clockUpdating)
                         lcd.write(byte(0));
                        lcd.setCursor(0,1);
                        lcd.print(F(" "));
                        lcd.print(month());
                        lcd.print(day());
                        lcd.print(F("/"));
                        if (clockUpdating)
                         lcd.write(byte(0));
                        lcd.setCursor(0,1);
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        lcd.setCursor(0,1);
                        lcd.setCursor(0,1);
                        lcd.print("min");
                        lcd.print("sec  ");
                    case RUN_ALL_ZONES:
                     fastClear();
                     lcd.setCursor(0,0);
                     if (displayToggle)
                        lcd.setCursor(0,1);
                        lcd.setCursor(0,1);
                        lcd.print("min");
                        lcd.print("sec  ");
                     if (displayToggle)
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                        lcd.setCursor(0,0);
                        lcd.setCursor(0,1);
                 setTime(newTime);
                    DEBUG_PRINT(day());
                    showTime = false;
                void fastClear()
                 lcd.setCursor(0,0);
                 lcd.setCursor(0,1);
                void updateClock()
                    lcd.write(byte(0));
                    valveIndex++;
                     valveIndex = 1;
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                You could try a bigger pullup resistor, maybe the pin floats for a brief moment or it is somehow energized... I've read about others having a problem like that. Alternatively, reverse the logic and pull pull the pin down to ground. I'd expect that one or both can correct that issue.
                Glad to have the improvements in the code, that's great! Always better to have another set of eyes on a project.
                • petewillP
                  petewillP
                  petewill
                  Ok, I'll do some testing with that. I don't think I'll get the chance today but I should be able to do some tomorrow. It works perfectly after the first start up so hopefully a bigger resistor will help.
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @petewill
                    yeah, I see in the code that the pushbutton is using interrupt pin, but still needs to be set to input
                    pinMode(PushButton, INPUT_PULLUP);
                    start there, sorry!
                    • petewillP
                      petewillP
                      petewill
                      I thought I added it already with this:
                      Is that correct? Maybe that's my problem...
                      • petewillP
                        petewillP
                        petewill
                        were you not getting a compile error? on the PushButton variable being undeclared?
                        Ok, I still think I have some things to learn about interrupts. I thought PushButton was the method being called when the interrupt was triggered. I didn't think it was the pin. I thought the pin was the first item 1 in this case. But, I thought 1 isn't even the pin. It's the interrupt number which is pin 3 in the case of a Pro Mini. I also thought I needed to declare the pinMode even if it's already in the interrupt. So confusing... Am I totally off?
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @petewill
                          post deleted, my bad! your understanding is 100% correct!
                          your PushButton is the ISR, so you are right
                          Try the extra pullup or pull-down
                          really sorry for confusing you! I'm mega jet lagged
                          • petewillP
                            petewillP
                            petewill
                            I'm mega jet lagged
                            Totally understandable :)
                            Ok, I'll try the other options discussed above and post back. Thanks.
                            • petewillP
                              petewillP
                              petewill
                              Well, I had almost no time to work on MySensors stuff this weekend. :( I did do a quick test last night and it seems the external pullup worked! I power cycled the node 3 times and each time it worked flawlessly. I'll continue to test but so far so good. Thank you!
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @petewill
                                glad to hear that worked!
                                :thumbsup:
                                  I put together an extension of the multi-Relay controller for use as a controller for your irrigation project if you have more zones than available pins on your Arduino.
                                  • Allows you to cycle through All zones or individual zone control.
                                  • Use the (n+1)th device to activate each zone in numeric sequence (zero to n) using
                                  • Use the individual zone controller to activate a single zone. This feature uses
                                  • Connect according to pinout in the sketch and uses an 74HC595 (or equiv) Shift Register as to
                                    allow the MySensors standard radio configuration and still leave available digital pins
                                  • Compiles to ~12,000 Bytes, so will run on any Arduino
                                  • Turning on any zone will stop the current process and begin that particular process.
                                  • Turning off any zone will stop the current process and turn off all zones.
                                  • Sketch must collect your desired intervals so it takes several minutes to startup.
                                  • If you change your desired time intervals for your zones, simply restart your arduino
                                    and it will self update to reflect those changes.
                                  Example, I am using with 8 relays:
                                  This will create 9 devices. Zero through 7 are the individual relays. Eight is the Sequencer, so to speak (refer to attachment).
                                  Once you create this and add it using the gateway, go to each of zero through 7 and edit Variable1 and Variable2 for what time you want to use for the Sequencer or Zone respectively. Then save the settings. Then, restart your arduino; your arduino will extract these settings and save them to an array.
                                  When you turn on device 8 (aka the Sequencer) the relays will actuate in order from zero to seven, each one staying on for the period entered in the Variable1 field. There is a 5 second delay at the start of a new zone to allow for the valves to hydraulically reset.
                                  When you turn on any of devices zero through 7, it will run that zone only for the period of time entered in Variable2.
                                  Selecting any new zone (0-8) will stop the current process and start as per above.
                                  Hope you have a use for it. If you see any opportunity to improve, or find a bug, let me know.
                                  Jim
                                  modified. Attached wrong file, whoops!
                                  Sprinkler.ino
                                  SparkmanS
                                  SparkmanS
                                  Sparkman
                                  wrote on last edited by Sparkman
                                  #46
                                  @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
                                  For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
                                  Al
                                  DrJeffD 1 Reply Last reply
                                    wrote on last edited by hek
                                    #47
                                    Added your project to the main site togeter with @petewill excellent new video.
                                    http://www.mysensors.org/build/irrigation
                                    https://youtu.be/l4GPRTsuHkI
                                    BulldogLowellB C 2 Replies Last reply
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      #48
                                      Cool @hek!
                                      Well done @petewill So easy for folks to follow along your outstanding video!
                                      MySensors Community Rocks!
                                      • petewillP
                                        petewillP
                                        petewill
                                        Agreed!!! Thanks to both @BulldogLowell and @hek for making this possible. I love seeing it hanging on my wall every time I go into the basement :)
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          Great Work Guys!!
                                          RJ_Make
