  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
  • petewillP
    petewillP
    petewill
    @BulldogLowell said:
    Prints the '0' special character.
    Ok, good to know. I'll see if I can do a little searching on that. Maybe there is a different way to implement them now?? It will be hard to test without an LCD but hopefully it will come soon and I can post back :)
    Speaking of testing I was able to control my relays last night from Vera! SO COOL!! This is one of the devices I have been wanting to add for a long time. I can't wait to be able to turn on my valves from my phone when I'm turning on my sprinkler system. It sure will beat sprinting to/from the basement...
    Thanks again for the awesome work!
    • petewillP petewill
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @petewill
      I edited above to give more detail...
      • petewillP
        petewillP
        petewill
        Ok, thanks. I did a little research and found this from the Arduino website:
        When referencing custom character "0", if it is not in a variable, you need to cast it as a byte, otherwise the compiler throws an error. See the example below.
        http://www.arduino.cc/en/Reference/LiquidCrystalCreateChar
        I changed the code to this:
        byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
        and this
        lcd.write(byte(0));
        and now it's compiling. But, I don't know if it's working.
        I'm still working on a couple of other small things I found. I'll post the code when I get it to a point where it's ready for your review.
        • petewillP
          petewillP
          petewill
          @BulldogLowell
          Here is the code with some changes. I have also attached a document with the changes highlighted. The most notable thing is I added some code to update the valve times when the device is first powered on. I hope that's ok.
          One thing I can't figure out, but hopefully you can, is the button is always acting like it's "pressed" when the Arduino is first powered on. This could be a problem as the power seems to go off in my house a couple of times a year (I don't want my irrigation to run when it's not supposed to). Any idea how to fix it? I've tried everything I could think of (which isn't much) and nothing worked.
          Anyway, here is the PDF with the changes Irrigation Controller Changes.pdf
          And the code:
          MySprinkler for MySensors
          Arduino Multi-Zone Sprinkler Control
          November, 2014
          *** Version 2.0
          *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve times and clock respectively
          your arduino will call to Vera once a minute and update accordingly.
          * Pushbutton activation to RUN_ALL_ZONES
          * LED status indicator
          INSTRUCTIONS:
          * Verify that each new device has a Variable1 and Variable2. Populate data accordingly with whole minutes for
          the RUN_ALL_ZONES routine and the RUN_SINGLE_ZONE routines.  The values entered may be zero.
          on the serial monitor.
          * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
          Contributed by Jim (BulldogLowell@gmail.com) and is released to the public domain
          #include <Time.h>
          #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
          #define RADIO_ID AUTO // AUTO  // Change this to fix your Radio ID or use Auto
          #define SKETCH_VERSION "2.0"
          #define CHILD_ID_SPRINKLER 0
          #define ACTIVE_LOW // comment out this line if your relays are active high
          #ifdef ACTIVE_LOW
          #define ALL_VALVES_OFF 0xFFFF
          #define ALL_VALVES_OFF 0U
          #ifdef DEBUG_ON
          typedef enum {
           STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE}
          SprinklerStates;
          SprinklerStates lastState;
          int allZoneTime [NUMBER_OF_VALVES + 1];
          int valveSoloTime [NUMBER_OF_VALVES + 1];
          int valveNumber;
          int lastValve;
          unsigned long startMillis;
          const int ledPin = 5;
          const int waterButtonPin = 3;
          boolean buttonPushed = false;
          boolean showTime = true;
          boolean clockUpdating = false;
          boolean recentUpdate = true;
          const char *dayOfWeek[] = {
           "Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
          time_t lastTimeRun = 0;
          //Setup Shift Register...
          const int latchPin = 8;
          const int clockPin = 4;
          const int dataPin  = 7;
          byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
          byte raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
          LiquidCrystal_I2C lcd(0x27);  // set the LCD I2C address to 0x27
          MyMessage msg1valve(CHILD_ID_SPRINKLER,V_LIGHT);
          MyMessage var1valve(CHILD_ID_SPRINKLER,V_VAR1);
          MyMessage var2valve(CHILD_ID_SPRINKLER,V_VAR2);
            delay(5000);
           //*Added
          //*Removed
          // lcd.init();
           lcd.clear();
           lcd.backlight();
           lcd.createChar(0, clock);
           lcd.createChar(1, raindrop);
           pinMode(latchPin, OUTPUT);
           pinMode(clockPin, OUTPUT);
           pinMode(dataPin, OUTPUT);
           pinMode(ledPin, OUTPUT);
           attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
           digitalWrite (ledPin, HIGH);
           if (gw.loadState(0) == 0xFF); // EEPROM flag
              for (int i = 0; i < 4 ; i++)
               lastTimeRun = lastTimeRun | gw.loadState(i+1); // assemble 4 bytes into an ussigned long epoch timestamp
           gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
              gw.present(i, S_LIGHT);
           updateRelays(ALL_VALVES_OFF);
           digitalWrite (ledPin, LOW);
           DEBUG_PRINTLN(F("Ready..."));
           lcd.setCursor(0, 0);
           lcd.setCursor(15, 0);
           lcd.write(byte(0));  //lcd.print(0, BYTE);
           lcd.setCursor(0, 1);
           int clockCounter = 0;
           while(timeStatus() == timeNotSet && clockCounter < 21)
              gw.requestTime(receiveTime);
              delay(1000);
              lcd.print(".");
              //DEBUG_PRINT(F("."));
              clockCounter++;
              if (clockCounter > 16)
               lcd.clear();
               lcd.setCursor(0,1);
               delay(2000);
           lcd.clear();
           //Update valve times when first powered on
           for(byte i = 0; i <= NUMBER_OF_VALVES; i++)
             allZoneTime[i]=-1;
             valveSoloTime[i]=-1;
             while((valveSoloTime[i]==-1 || allZoneTime[i]==-1) && clockCounter < 10)
               DEBUG_PRINTLN(F("Calling for Valve Times..."));
               lcd.write(byte(1)); //lcd.write(1);
               gw.request(i, V_VAR1);
               gw.request(i, V_VAR2);
               delay(1000);
               clockCounter++;
               if (clockCounter > 10)
                  DEBUG_PRINTLN(F("Failed initial valve synchronization!"));
                  lcd.clear();
                  lcd.print(F("  Failed Valve  "));
                  lcd.setCursor(0,1);
           updateClock();
           updateDisplay();
           goGetValveTimes();
           if (buttonPushed)
              if (state != RUN_ALL_ZONES)
               state = RUN_ALL_ZONES;
               valveNumber = 1;
               gw.send(msg1valve.setSensor(0).set(true), false);
               startMillis = millis();
               for (byte i = 0; i < 5; i++)  // flash lcd backlight on button press
                  lcd.noBacklight();
                  delay(25);
                  lcd.backlight();
               delay(50);
               fastClear();
               lcd.setCursor(0,0);
               lcd.print(F("*AllZone Active*"));
               lcd.setCursor(0,0);
               lcd.print(F(" Cycling  Zones "));
               delay(1000);
               DEBUG_PRINT(F("State = "));
               DEBUG_PRINTLN(state);
                //valveNumber = 1;
                gw.send(msg1valve.setSensor(0).set(false), false);
                  lcd.noBacklight();
                  delay(25);
                  lcd.backlight();
                delay(50);
                fastClear();
                lcd.setCursor(0,0);
                lcd.print(F("*AllZone Off*"));
                lcd.setCursor(0,0);
                lcd.print(F(" Stopping  Zones "));
                delay(1000);
              slowToggleLED ();
              if (state != lastState)
                  delay(50);
                  gw.send(msg1valve.setSensor(i).set(false), false);
               lastValve = -1;
              if (lastValve != valveNumber)
                   gw.send(msg1valve.setSensor(i).set(true), false);
              lastValve = valveNumber;
              fastToggleLed();
               valveNumber = 1;
               valveNumber++;
                  state = CYCLE_COMPLETE;
                  lastValve = -1;
                  lastTimeRun = now();
              fastToggleLed();
               DEBUG_PRINT(F("Zone: "));
               DEBUG_PRINTLN(valveNumber);
               fastToggleLed();
           lastState = state;
          void updateRelays(int value)
           digitalWrite(latchPin, LOW);
           digitalWrite(latchPin, HIGH);
              buttonPushed = true;
          void fastToggleLed()
              fastLedTimer = millis ();
          void slowToggleLED ()
              slowLedTimer = millis ();
           boolean zoneTimeUpdate = false;
           if (message.isAck())
           for (byte i = 0; i<= NUMBER_OF_VALVES; i++)
              if (message.sensor == i)
               if (message.type == V_LIGHT)
                  if (switchState == 0)
                   if (i == 0)
                      valveNumber = 1;
                      state = RUN_SINGLE_ZONE;
                      valveNumber = i;
                      DEBUG_PRINTLN(i);
                  DEBUG_PRINT(i);
                  DEBUG_PRINT(F(" = "));
                  DEBUG_PRINTLN(variable1);
                   allZoneTime[i] = variable1;
                   zoneTimeUpdate = true;
                  DEBUG_PRINT(i);
                  DEBUG_PRINTLN(variable2);
                   valveSoloTime[i] = variable2;
           if (zoneTimeUpdate)
               if (i != 0)
                  DEBUG_PRINT(F("Zone "));
                  DEBUG_PRINT(i);
                  DEBUG_PRINTLN(allZoneTime[i]);
              recentUpdate = false;
          void updateDisplay()
           static boolean displayToggle = false;
              switch (state){
              case STAND_BY_ALL_OFF:
               fastClear();
               lcd.setCursor(0,0);
               if (displayToggle)
                  if (clockUpdating)
                   lcd.setCursor(15,0);
                   lcd.write(byte(0));
                  lcd.setCursor(0,1);
                  lcd.print(hourFormat12());
                  lcd.print(minute());
                  lcd.print(F(" "));
                  lcd.print(month() < 10? F("0") : F(""));
                  lcd.print(month());
                  lcd.print(day() < 10? F("/0") : F("/"));
                  lcd.print(day());
                  lcd.print(F("/"));
                  lcd.print(year()%100);
                  if (clockUpdating)
                   lcd.write(byte(0));
                  lcd.setCursor(0,1);
                  lcd.setCursor(11,1);
                  lcd.print(day(lastTimeRun));
              case RUN_SINGLE_ZONE:
               fastClear();
               lcd.setCursor(0,0);
               if (displayToggle)
                  lcd.setCursor(0,1);
                  lcd.print(F(" Zone:"));
                  lcd.print(valveNumber);
                  lcd.print(F(" Active"));
                  lcd.setCursor(0,1);
                  lcd.print("min");
                  lcd.print("sec  ");
              case RUN_ALL_ZONES:
               fastClear();
               lcd.setCursor(0,0);
               if (displayToggle)
                  lcd.setCursor(0,1);
                  lcd.print(F(" Active "));
                  lcd.setCursor(0,1);
                  lcd.print("min");
                  lcd.print("sec  ");
              case CYCLE_COMPLETE:
               if (displayToggle)
                  lcd.setCursor(0,0);
                  lcd.setCursor(0,1);
                  int totalTimeRan = 0;
                  lcd.setCursor(0,0);
                  lcd.setCursor(0,1);
                  lcd.print(totalTimeRan);
                  lcd.print(" Minutes   ");
              lastUpdateTime = millis();
           lastDisplayState = state;
           int lastSecond = second();
           int lastMinute = minute();
           int lastHour = hour();
           setTime(newTime);
              DEBUG_PRINT(hourFormat12());
              DEBUG_PRINT(minute());
              DEBUG_PRINT(month());
              DEBUG_PRINT(F("/"));
              DEBUG_PRINT(day());
              DEBUG_PRINTLN(year());
              showTime = false;
          void fastClear()
           lcd.setCursor(0,0);
           lcd.setCursor(0,1);
          void updateClock()
              lcd.write(byte(0));
              clockUpdating = true;
              lastVeraGetTime = millis();
           if (gw.loadState(0) != 0xFF)
              gw.saveState(0,0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
           for (int i = 1; i < 5; i++)
              gw.saveState(5-i, byte(theDate >> 8 * (i-1)));// store epoch datestamp in 4 bytes of EEPROM starting in location one
          void goGetValveTimes()
           static byte valveIndex = 1;
           if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
              gw.request(valveIndex, V_VAR1);
              gw.request(valveIndex, V_VAR2);
              valveUpdateTime = millis();
              valveIndex++;
              if (valveIndex > NUMBER_OF_VALVES+1)
               valveIndex = 1;
            @BulldogLowell
            And the code:
            November, 2014
            *** Version 2.0
            INSTRUCTIONS:
            #include <Time.h>
            #ifdef ACTIVE_LOW
            #ifdef DEBUG_ON
            typedef enum {
            SprinklerStates;
            int valveNumber;
            int lastValve;
              delay(5000);
             //*Added
            //*Removed
            // lcd.init();
             lcd.clear();
             lcd.backlight();
                delay(1000);
                lcd.print(".");
                clockCounter++;
                 lcd.clear();
                 lcd.setCursor(0,1);
                 delay(2000);
             lcd.clear();
               allZoneTime[i]=-1;
                 delay(1000);
                 clockCounter++;
                    lcd.clear();
                    lcd.setCursor(0,1);
             updateClock();
             updateDisplay();
             goGetValveTimes();
             if (buttonPushed)
                 valveNumber = 1;
                    lcd.noBacklight();
                    delay(25);
                    lcd.backlight();
                 delay(50);
                 fastClear();
                 lcd.setCursor(0,0);
                 lcd.setCursor(0,0);
                 delay(1000);
                  //valveNumber = 1;
                    lcd.noBacklight();
                    delay(25);
                    lcd.backlight();
                  delay(50);
                  fastClear();
                  lcd.setCursor(0,0);
                  lcd.setCursor(0,0);
                  delay(1000);
                slowToggleLED ();
                    delay(50);
                 lastValve = -1;
                fastToggleLed();
                 valveNumber = 1;
                 valveNumber++;
                    lastValve = -1;
                fastToggleLed();
                 fastToggleLed();
             lastState = state;
                     if (i == 0)
                        valveNumber = 1;
                        valveNumber = i;
                        DEBUG_PRINTLN(i);
                    DEBUG_PRINT(i);
                    DEBUG_PRINT(i);
             if (zoneTimeUpdate)
                 if (i != 0)
                    DEBUG_PRINT(i);
                switch (state){
                 fastClear();
                 lcd.setCursor(0,0);
                 if (displayToggle)
                    if (clockUpdating)
                     lcd.write(byte(0));
                    lcd.setCursor(0,1);
                    lcd.print(F(" "));
                    lcd.print(month());
                    lcd.print(day());
                    lcd.print(F("/"));
                    if (clockUpdating)
                     lcd.write(byte(0));
                    lcd.setCursor(0,1);
                 fastClear();
                 lcd.setCursor(0,0);
                 if (displayToggle)
                    lcd.setCursor(0,1);
                    lcd.setCursor(0,1);
                    lcd.print("min");
                    lcd.print("sec  ");
                case RUN_ALL_ZONES:
                 fastClear();
                 lcd.setCursor(0,0);
                 if (displayToggle)
                    lcd.setCursor(0,1);
                    lcd.setCursor(0,1);
                    lcd.print("min");
                    lcd.print("sec  ");
                 if (displayToggle)
                    lcd.setCursor(0,0);
                    lcd.setCursor(0,1);
                    lcd.setCursor(0,0);
                    lcd.setCursor(0,1);
             setTime(newTime);
                DEBUG_PRINT(day());
                showTime = false;
            void fastClear()
             lcd.setCursor(0,0);
             lcd.setCursor(0,1);
            void updateClock()
                lcd.write(byte(0));
                valveIndex++;
                 valveIndex = 1;
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            You could try a bigger pullup resistor, maybe the pin floats for a brief moment or it is somehow energized... I've read about others having a problem like that. Alternatively, reverse the logic and pull pull the pin down to ground. I'd expect that one or both can correct that issue.
            Glad to have the improvements in the code, that's great! Always better to have another set of eyes on a project.
            • petewillP
              petewillP
              petewill
              Ok, I'll do some testing with that. I don't think I'll get the chance today but I should be able to do some tomorrow. It works perfectly after the first start up so hopefully a bigger resistor will help.
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @petewill
                yeah, I see in the code that the pushbutton is using interrupt pin, but still needs to be set to input
                pinMode(PushButton, INPUT_PULLUP);
                start there, sorry!
                • petewillP
                  petewillP
                  petewill
                  I thought I added it already with this:
                  Is that correct? Maybe that's my problem...
                  • petewillP
                    petewillP
                    petewill
                    were you not getting a compile error? on the PushButton variable being undeclared?
                    Ok, I still think I have some things to learn about interrupts. I thought PushButton was the method being called when the interrupt was triggered. I didn't think it was the pin. I thought the pin was the first item 1 in this case. But, I thought 1 isn't even the pin. It's the interrupt number which is pin 3 in the case of a Pro Mini. I also thought I needed to declare the pinMode even if it's already in the interrupt. So confusing... Am I totally off?
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @petewill
                      post deleted, my bad! your understanding is 100% correct!
                      your PushButton is the ISR, so you are right
                      Try the extra pullup or pull-down
                      really sorry for confusing you! I'm mega jet lagged
                      • petewillP
                        petewillP
                        petewill
                        I'm mega jet lagged
                        Totally understandable :)
                        Ok, I'll try the other options discussed above and post back. Thanks.
                        • petewillP
                          petewillP
                          petewill
                          Well, I had almost no time to work on MySensors stuff this weekend. :( I did do a quick test last night and it seems the external pullup worked! I power cycled the node 3 times and each time it worked flawlessly. I'll continue to test but so far so good. Thank you!
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @petewill
                            glad to hear that worked!
                            :thumbsup:
                              I put together an extension of the multi-Relay controller for use as a controller for your irrigation project if you have more zones than available pins on your Arduino.
                              • Allows you to cycle through All zones or individual zone control.
                              • Use the (n+1)th device to activate each zone in numeric sequence (zero to n) using
                              • Use the individual zone controller to activate a single zone. This feature uses
                              • Connect according to pinout in the sketch and uses an 74HC595 (or equiv) Shift Register as to
                                allow the MySensors standard radio configuration and still leave available digital pins
                              • Compiles to ~12,000 Bytes, so will run on any Arduino
                              • Turning on any zone will stop the current process and begin that particular process.
                              • Turning off any zone will stop the current process and turn off all zones.
                              • Sketch must collect your desired intervals so it takes several minutes to startup.
                              • If you change your desired time intervals for your zones, simply restart your arduino
                                and it will self update to reflect those changes.
                              Example, I am using with 8 relays:
                              This will create 9 devices. Zero through 7 are the individual relays. Eight is the Sequencer, so to speak (refer to attachment).
                              Once you create this and add it using the gateway, go to each of zero through 7 and edit Variable1 and Variable2 for what time you want to use for the Sequencer or Zone respectively. Then save the settings. Then, restart your arduino; your arduino will extract these settings and save them to an array.
                              When you turn on device 8 (aka the Sequencer) the relays will actuate in order from zero to seven, each one staying on for the period entered in the Variable1 field. There is a 5 second delay at the start of a new zone to allow for the valves to hydraulically reset.
                              When you turn on any of devices zero through 7, it will run that zone only for the period of time entered in Variable2.
                              Selecting any new zone (0-8) will stop the current process and start as per above.
                              Hope you have a use for it. If you see any opportunity to improve, or find a bug, let me know.
                              Jim
                              modified. Attached wrong file, whoops!
                              Sprinkler.ino
                              SparkmanS
                              SparkmanS
                              Sparkman
                              wrote on last edited by Sparkman
                              #46
                              @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
                              For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
                              Al
                              DrJeffD 1 Reply Last reply
                                wrote on last edited by hek
                                #47
                                Added your project to the main site togeter with @petewill excellent new video.
                                http://www.mysensors.org/build/irrigation
                                https://youtu.be/l4GPRTsuHkI
                                BulldogLowellB C 2 Replies Last reply
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  #48
                                  Cool @hek!
                                  Well done @petewill So easy for folks to follow along your outstanding video!
                                  MySensors Community Rocks!
                                  • petewillP
                                    petewillP
                                    petewill
                                    Agreed!!! Thanks to both @BulldogLowell and @hek for making this possible. I love seeing it hanging on my wall every time I go into the basement :)
                                    • RJ_MakeR
                                      RJ_MakeR
                                      RJ_Make
                                      Great Work Guys!!
                                      RJ_Make
                                      • SparkmanS Sparkman
                                        Al
                                        DrJeffD
                                        DrJeffD
                                        DrJeff
                                        @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
                                        @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
                                        You have been coming on with some awesome videos and contributions!
                                        petewillP SparkmanS 2 Replies Last reply
                                        • DrJeffD DrJeff
                                          petewillP
                                          petewillP
                                          petewill
                                          @DrJeff I agree this is a great community! So much fun!
                                          Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video :)
