  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 322.6k Views 52 Watching
  • petewillP petewill
    @BulldogLowell said:
    You could try a bigger pullup resistor, maybe the pin floats for a brief moment or it is somehow energized...
    Ok, I'll do some testing with that. I don't think I'll get the chance today but I should be able to do some tomorrow. It works perfectly after the first start up so hopefully a bigger resistor will help.
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @petewill
    yeah, I see in the code that the pushbutton is using interrupt pin, but still needs to be set to input
    pinMode(PushButton, INPUT_PULLUP);
    start there, sorry!
    • petewillP
      petewillP
      petewill
      I thought I added it already with this:
      Is that correct? Maybe that's my problem...
      • petewillP
        petewillP
        petewill
        were you not getting a compile error? on the PushButton variable being undeclared?
        Ok, I still think I have some things to learn about interrupts. I thought PushButton was the method being called when the interrupt was triggered. I didn't think it was the pin. I thought the pin was the first item 1 in this case. But, I thought 1 isn't even the pin. It's the interrupt number which is pin 3 in the case of a Pro Mini. I also thought I needed to declare the pinMode even if it's already in the interrupt. So confusing... Am I totally off?
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @petewill
          post deleted, my bad! your understanding is 100% correct!
          your PushButton is the ISR, so you are right
          Try the extra pullup or pull-down
          really sorry for confusing you! I'm mega jet lagged
          • petewillP
            petewillP
            petewill
            I'm mega jet lagged
            Totally understandable :)
            Ok, I'll try the other options discussed above and post back. Thanks.
            • petewillP
              petewillP
              petewill
              Well, I had almost no time to work on MySensors stuff this weekend. :( I did do a quick test last night and it seems the external pullup worked! I power cycled the node 3 times and each time it worked flawlessly. I'll continue to test but so far so good. Thank you!
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @petewill
                glad to hear that worked!
                :thumbsup:
                  I put together an extension of the multi-Relay controller for use as a controller for your irrigation project if you have more zones than available pins on your Arduino.
                  • Allows you to cycle through All zones or individual zone control.
                  • Use the (n+1)th device to activate each zone in numeric sequence (zero to n) using
                    Variable1 as the "ON" time in minutes in each of the vera devices created.
                  • Use the individual zone controller to activate a single zone. This feature uses
                  • Connect according to pinout in the sketch and uses an 74HC595 (or equiv) Shift Register as to
                    allow the MySensors standard radio configuration and still leave available digital pins
                  • Compiles to ~12,000 Bytes, so will run on any Arduino
                  • Turning on any zone will stop the current process and begin that particular process.
                  • Turning off any zone will stop the current process and turn off all zones.
                  • Sketch must collect your desired intervals so it takes several minutes to startup.
                  • If you change your desired time intervals for your zones, simply restart your arduino
                    and it will self update to reflect those changes.
                  Example, I am using with 8 relays:
                  This will create 9 devices. Zero through 7 are the individual relays. Eight is the Sequencer, so to speak (refer to attachment).
                  Once you create this and add it using the gateway, go to each of zero through 7 and edit Variable1 and Variable2 for what time you want to use for the Sequencer or Zone respectively. Then save the settings. Then, restart your arduino; your arduino will extract these settings and save them to an array.
                  When you turn on device 8 (aka the Sequencer) the relays will actuate in order from zero to seven, each one staying on for the period entered in the Variable1 field. There is a 5 second delay at the start of a new zone to allow for the valves to hydraulically reset.
                  When you turn on any of devices zero through 7, it will run that zone only for the period of time entered in Variable2.
                  Selecting any new zone (0-8) will stop the current process and start as per above.
                  Hope you have a use for it. If you see any opportunity to improve, or find a bug, let me know.
                  Jim
                  modified. Attached wrong file, whoops!
                  Sprinkler.ino
                  SparkmanS
                  SparkmanS
                  Sparkman
                  wrote on last edited by Sparkman
                  #46
                  @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
                  For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
                  Al
                  DrJeffD 1 Reply Last reply
                    wrote on last edited by hek
                    #47
                    Added your project to the main site togeter with @petewill excellent new video.
                    http://www.mysensors.org/build/irrigation
                    https://youtu.be/l4GPRTsuHkI
                    BulldogLowellB C 2 Replies Last reply
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      #48
                      Cool @hek!
                      Well done @petewill So easy for folks to follow along your outstanding video!
                      MySensors Community Rocks!
                      • petewillP
                        petewillP
                        petewill
                        Agreed!!! Thanks to both @BulldogLowell and @hek for making this possible. I love seeing it hanging on my wall every time I go into the basement :)
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Great Work Guys!!
                          RJ_Make
                          • SparkmanS Sparkman
                            Al
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
                            @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
                            You have been coming on with some awesome videos and contributions!
                            petewillP SparkmanS 2 Replies Last reply
                            • DrJeffD DrJeff
                              petewillP
                              petewillP
                              petewill
                              @DrJeff I agree this is a great community! So much fun!
                              Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video :)
                                Cool @hek!
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @BulldogLowell Sorry For not giving the credit where it is due! Major Props @BulldogLowell !
                                • DrJeffD DrJeff
                                  SparkmanS
                                  SparkmanS
                                  Sparkman
                                  They've been running for about 9 months on the first set of batteries (2xAAA) so far and are still going strong.
                                  Al
                                  • DrJeffD DrJeff
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    Thanks @DrJeff
                                    I just made an irrigation controller... @petewill made it for everyone!
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
                                      https://www.youtube.com/watch?v=BRU0xrd8dn0
                                      petewillP DrJeffD 2 Replies Last reply
                                      • DidiD
                                        DidiD
                                        Didi
                                        Wow 48 channels thats awesome
                                        • tbowmoT tbowmo
                                          petewillP
                                          petewillP
                                          petewill
                                          @tbowmo WOW! What did he use that for??
                                          tbowmoT 1 Reply Last reply
