  3. Etching my own boards
17 Posts 4 Posters 11.3k Views 2 Watching
  • axillentA axillent
    @marceltrapman if only etching stops you that means that you just in a few steps before the finish to get your first prize)
    what you do not understand in the etching? It is very simple chemical process. Just put you PCB with design drawing into your etching chemical and spend 15-20 minutes watching how cooper is disappearing
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    @axillent Nothing I don't understand just that imho it is a bit of a primitive process where so many things are automated nicely :)
    I can do everything with clean hands and, more important, having it all standing by except for Etching.
    Fulltime Servoy Developer
    axillentA 1 Reply Last reply
      axillentA
      axillentA
      axillent
      @marceltrapman are all of your kitchen cooking is automated with clean hands? :)
      I'm using long tweezers to keep hands off chemicals but the rest is put for the fan I do DIY for
      if all you do for DIY will be automated what will be the reason to keep it doing?)
      sense and drive
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        @axillent I give in :)
        • jendrushJ
          jendrushJ
          jendrush
          @axillent @marceltrapman Welcome back:)
          My (cheap ~15$ with shipping) driller stand arrived yesterday. Soon i will try how good/bad it is for drilling PCB holes. This is my equiplent for drilling: http://ppl.ug/Gz9FbbglsWE/ . You probably have seen my photos https://www.dropbox.com/sh/ec4ap8dgci1oe0p/AAD3YIqS_JqKMiUFu9TAfF5Ca .
          1, and 2 - right after transfering toner with proper paper, and laminator, and after about 5 minutes in water to get rid of paper
          3 - during the etching process with sodium persuflate, and container like this http://img14.allegroimg.pl/photos/oryginal/44/06/46/49/4406464944
          4, and 5 look after etching process
          6, and 7 look after cleaning from toner
          • jendrushJ jendrush
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            @jendrush Good looking boards (doubt that I am the one to judge it though).
            The stand looks nice.
            I have the Dremel stand, bought it a couple of years ago together with my Dremel.
            Although I am happy with it the disadvantage is not necessarily the position of the board but, imho, more the moving of the board by hand to each position. For that reason alone I look forward to my FABtotum :)
            Looking forward to hear about your experience...
            axillentA jendrushJ 2 Replies Last reply
            • jendrushJ
              jendrushJ
              jendrush
              I think quality is not that bad, but etching lasted too long(due to a little bit to low temperature), so traces are little overetched.
                axillentA
                axillentA
                axillent
                the manual drilling is better to do when etching was finished. It is also a good idea to have a small hole in a center of each pad while designing PCB. This will give you a centering holes after etching for each pad.
                I spend a year to make my CNC very easy to use for PCB drilling & milling
                at the beginning the use of CNC was much worse comparing to manual drilling
                I'm not sure how well FABtotum is prepared
                sense and drive
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  Are you talking about a drill hole here? Like created by default by Eagle?
                  Neither am I, will have to do some experimenting I guess...
                  axillentA D 2 Replies Last reply
                    axillentA
                    axillentA
                    axillent
                    Yes, it is most easiest way to add free from toner holes while transferring design drawing to the copper
                    This holes will get copper dissolved during etching and your drill will became centered while drilling
                    sense and drive
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      @axillent Nice, that is what I already do...
                        jendrushJ
                        jendrushJ
                        jendrush
                        I've tested this stand before moment. Generally not bad, but stability isn't "spectacular". If we have holes in pins, like @axillent mentioned there is no problem with drilling. Most important is that drilling with this stand is really more convinient than without:) I can't complaint to much, becouse more proffesional drilling stand with driller costs about 20 times more than this:)
                          marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          @jendrush Nice, I guess it is like you said, a more professional stand cost serious money but this one will be much better than doing this by hand ;)
                            demir
                            wrote on last edited by demir
                            @marceltrapman, using a smart and nice etching process is never something people have an issue with. The point people are trying to make on this thread is that if you can achieve the same results by using a small tank and an inexpensive chemical, why go for an expensive process. There are so many different etching processes available that you can choose from which are cheap enough to be used by anyone. Etching does impact the quality of a PCB but as long as you’re not making expensive antenna PCBs, usual process work fine.
                            electronics assembly
