  3. RelayActuator problem - sometimes nothing happens
14 Posts 5 Posters 5.6k Views 1 Watching
    @Moshe-Livne
    You could show a schematic of your rig and detail what type/size power supply you are using.
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @BulldogLowell Calling it schematic would be an overkill. It is a nano powered by a 1A wall socket.
    • Moshe LivneM Moshe Livne
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      Are you powering the relay in parallel <to> edit: with the Arduino or from Arduino's Vcc?
      • Moshe LivneM
        Moshe LivneM
        Moshe Livne
        currently from the arduino vcc. I have no idea how to wire it directly from the wall power. without breaking it, that it.
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          Assuming you have a 5V power supply and a single channel 5V relay, it will have a Ground, Vcc and IN pins.
          Connect with a wire from arduino's Vin (not Vcc) and arduino's ground. The third third (IN) will go to the arduino pin you are using to control the relay... start there.
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @BulldogLowell Thanks, will do
            • C
              C
              Chester
              @Moshe-Livne Depending on whether your incoming power is replaceable or hard wired in your module...
              You could look into picking up one of those dual voltage wall warts, that have one output with 1A, and one output with 2.1A. You could then just use one USB lead from the 1A output to run the Arduino and radio, then use the 2.1A output to power the relay board with a sufficient loading ability.
              I have done this with my 8 port SSR relay card, and so far in testing it has been super stable, and I have had no glitches in radio performance due to power drops from turning on or off the relays.
                madmax
                Hello
                i have a sketch with dth22 motion and relay
                it's not optimal but it works
                i want to add another relay but it doesn't work have you a soluce
                thanks
                #include <SimpleTimer.h>
                #define CHILD_ID_HUM 1
                #define CHILD_ID_TEMP 2
                #define CHILD_ID_MOTION 3
                #define CHILD_ID_RELAY 4
                #define MOTION_SENSOR_DIGITAL_PIN 3
                #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                #define RELAY  5// Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
                DHT dht;
                SimpleTimer timer;
                float lastTemp;
                float lastHum;
                boolean lastTripped;
                boolean metric = true;
                MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
                  gw.sendSketchInfo("HumTempRelayMotion", "1.0");
                  gw.present(CHILD_ID_MOTION, S_MOTION);
                  gw.present(CHILD_ID_RELAY, S_LIGHT);
                  pinMode(RELAY, OUTPUT);
                  digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
                  //Serial.begin(9600);
                  timer.setInterval(30000, getMeasure);
                  timer.run();
                  boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
                  if (tripped != lastTripped) {
                    lastTripped = tripped;
                    Serial.print("M: ");
                    Serial.println(tripped);
                    gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
                  if (message.type==V_LIGHT) {
                     // Change relay state
                     digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
                     // Store state in eeprom
                void getMeasure() {
                  if (isnan(temperature)) {
                    lastTemp = temperature;
                    if (!metric) {
                    Serial.print("T: ");
                  if (isnan(humidity)) {
                      lastHum = humidity;
                      Serial.print("H: ");
                      Serial.println(humidity);
                • M madmax
                  Hello
                  thanks
                  DHT dht;
                  SimpleTimer timer;
                  float lastTemp;
                  float lastHum;
                    timer.run();
                  void getMeasure() {
                      if (!metric) {
                        lastHum = humidity;
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @madmax
                  there are examples on the forum on multiple relays on one MCU... try searching the forum.
                    madmax
                    yes i see but with dth 22 it's difficult
                    i use simpletimer.h with this
                    • M madmax
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @madmax
                      yes, so go to mutlti relay, add your libraries for simple timer and DHT. Thge relay code is non-blocking so you should be able to fold it in quite nicely.
