  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.0k Views 35 Watching
    shabba
    Ps. Main page at http://www.mysensors.org/hardware/micro still says preorder but when clicking through imall has in stock.
    • hetbeestH
      hetbeestH
      hetbeest
      I ordered another couple a few days ago.
      • tbowmoT
        tbowmoT
        tbowmo
        @shabba
        We don't get notifications from itead, when they change the status in their shop.. So we have to check it ourself..
        RJ_MakeR 1 Reply Last reply
        • K
          K
          kalle
          wrote on last edited by kalle
          #136
          update: I got my 3 pcb from pre-order today (germany) and it works fine - really great design! :thumbsup:
          • tbowmoT tbowmo
            @shabba
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @tbowmo I wanna say Thank You again. I really love how small this sensor is. You did a great job!!!!
            RJ_Make
            • 5546dug5
              5546dug5
              5546dug
              I have mine up and running @tbowmo this is great thank you also.
              Now to learn how to graph my results.
                mvader
                I have mine up and running and MYScontroller sees them.
                i'm trying to send and OTA to these devices. but it doesn't seem to be working.
                @hek can you confirm these came with the correct bootloader to do this? i thought i read in the start of the thread it would.
                when i try to send a OTA nothing happens.
                anyone have this working that can comment on what needs to be done to get it working?
                  @mvader
                  The OTA->flash requires sketches running library code from the development branch (which it isn't currently). The boards comes preloaded with the correct bootloader that supports moving firmware from flash->program memory at boot-time.
                  But something must load the flash over-the-air also. This requires that you:
                  • Compile the sketch using the dev-branch
                  • Enable MY_OTA_FRIMWARE_FEATURE in MyConfig.h
                  • Keep node awake
                  • Call gw.process() in loop-section (which handles the fw-update-commands in the background and resets node when a new firmware has been uploaded).
                  Now that I have received my board I can actually test this code I wrote a while back:). I hope it won't bee too many bugs in it.
                  But note that the default temp/hum sketch on these boards sleeps most of the time it wouldn't hear the fw-update requests anyway. It would probably be better to use this feature on boards that always is awake.
                  For more information on what is actually happening in gw-process you can look at the code that was added in this push:
                  https://github.com/mysensors/Arduino/commit/3a59929b8ed8e1fca9876031264db5d6626876ff
                    mvader
                    thanks for the info. I was hoping i wouldn't have to connect up my programmer.. oh well.
                      mvader
                      I guess these can't be programmed, if my programmer doesn't have a DTR line?
                      was hoping OTA would work :)
                      I'll order a new programmer any way, but if there is any other way let me know.
                      I tried starting it in test mode. but that didn't work
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @mvader
                        It's using a standard ftdi header, as used in the arduino mini pro.
                        About the testmode, you should hold A0 to GND, while applying power to the unit. Then it starts spewing data to the serial port.
                        • F
                          F
                          Fabien
                          Just recieve my 5 sensbender today. Workin fine after some problem with nrf24L01 and Arduino uno (+3.3V doesn't work)
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            It's almost too easy to setup a sensor network (for temperature and humidity) now.
                            solder a socket for the NRF module, a battery holder. Plug in the NRF module, put batteries in, and you have a sensor online. (I have 3 sensebenders from tiead online at the moment, together with 2 prototypes). Need to get some more battery holders, before I can make more sensors now.
                            blaceyB 1 Reply Last reply
                            • tbowmoT tbowmo
                              blaceyB
                              blaceyB
                              blacey
                              I agree! I ordered 4 from the second ITead batch (I let others get their hands on the first batch because I already had a couple OSHPark deployed) and had the first sensor up and running in no time! Great job and contribution to the MySensor's community! :+1: :+1: :+1:
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @blacey
                                Thanks.. It's actually kind of fun, when I see that things I have created, actually brings value to other people.. Always been a driving force for me (no matter what I have had my hands in, whether it's software of various types,VHF radios for ships, mobile phones, bluetooth headsets, or sensor modules :) )
                                • tbowmoT tbowmo
                                  @mvader
                                  mvader
                                  @tbowmo said:
                                  @mvader
                                  I had meant that i put it in test mode to try and program it.
                                  getting it in test mode worked. i could see the led blinking.
                                  however when i gave up and put the radio back on and turn it on, i guess it had actually taken my upload.
                                  it was reporting in F now.
                                  so i know the DTR does the auto reset, i guess upload works, but no reset and/or completed msg in the IDE.
                                  i ordered a new programmer anyway with DTR.
                                  • nutcrackerN
                                    nutcrackerN
                                    nutcracker
                                    wrote on last edited by nutcracker
                                    #149
                                    I've received some boards and all working good.
                                    I'd like to upload a new sketch to the Sensebender Micro board and I'm attempting to do this via the FTDI FT232RL USB to TTL serial converter adapter that I purchased here (http://www.ebay.co.uk/itm/221552218333).
                                    Could someone kindly confirm the pin to pin mapping between the FTDI board and the Senseboard Micro as when I attempt to upload I receive the message:
                                       Programmer Type : butterfly
                                             Description     : Atmel AppNote AVR109 Boot Loader
                                    Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
                                    I'm using Arduino 1.6.5 running on Windows 8.1 (inside parallels on a Mac).
                                    Any ideas?
                                    Thank you
                                    Nutz
                                    hekH 1 Reply Last reply
                                    • nutcrackerN nutcracker
                                      Any ideas?
                                      Thank you
                                      Nutz
                                      @nutcracker
                                      I usually use the GND pin as a guide.
                                      What happens if you run Arduino IDE directly in your native OS?
                                      • nutcrackerN
                                        nutcrackerN
                                        nutcracker
                                        #151
                                        Thanks @hek. I've had to run Arduino on Windows before because of compatibility issues with certain chip sets on Arduino boards and I didn't fancy running unsigned drivers on my Mac to resolve... I'm able to upload sketches to other boards with no issues.
                                        That said, I've updated Arduino to 1.6.5 on my Mac and have attempted to upload the default Sensebendermicro.ino sketch to the micro with a similar error:
                                        Arduino: 1.6.5 (Mac OS X), Board: "Arduino Micro"
                                        Sketch uses 26,414 bytes (92%) of program storage space. Maximum is 28,672 bytes.
                                        Global variables use 799 bytes (31%) of dynamic memory, leaving 1,761 bytes for local variables. Maximum is 2,560 bytes.
                                        Found programmer: Id = "�d��b�"; type = F
                                            Software Version = �.�; Hardware Version = �.�
                                        avrdude: error: buffered memory access not supported. Maybe it isn't
                                        a butterfly/AVR109 but a AVR910 device?
                                        With verbose output enabled:
                                                 User configuration file is "/Users/nutcracker/.avrduderc"
                                                 Using Port                    : /dev/cu.usbserial-A50285BI
                                                 Using Programmer              : avr109
                                                 Overriding Baud Rate          : 57600
                                                 AVR Part                      : ATmega32U4
                                                 BS2                           : PA0
                                                   eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
                                                   flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
                                                   lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                                   hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                                   efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                                   lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                        Nutz
                                          @nutcracker said:
                                          Maybe it isn't
                                          Is your programmer setting in Arduino IDE set to "USBasp"?
