  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
    mvader
    I guess these can't be programmed, if my programmer doesn't have a DTR line?
    was hoping OTA would work :)
    I'll order a new programmer any way, but if there is any other way let me know.
    I tried starting it in test mode. but that didn't work
    • tbowmoT
      tbowmoT
      tbowmo
      @mvader
      It's using a standard ftdi header, as used in the arduino mini pro.
      About the testmode, you should hold A0 to GND, while applying power to the unit. Then it starts spewing data to the serial port.
      • F
        F
        Fabien
        Just recieve my 5 sensbender today. Workin fine after some problem with nrf24L01 and Arduino uno (+3.3V doesn't work)
        • tbowmoT
          tbowmoT
          tbowmo
          It's almost too easy to setup a sensor network (for temperature and humidity) now.
          solder a socket for the NRF module, a battery holder. Plug in the NRF module, put batteries in, and you have a sensor online. (I have 3 sensebenders from tiead online at the moment, together with 2 prototypes). Need to get some more battery holders, before I can make more sensors now.
          blaceyB 1 Reply Last reply
          • tbowmoT tbowmo
            blaceyB
            blaceyB
            blacey
            I agree! I ordered 4 from the second ITead batch (I let others get their hands on the first batch because I already had a couple OSHPark deployed) and had the first sensor up and running in no time! Great job and contribution to the MySensor's community! :+1: :+1: :+1:
            • tbowmoT
              tbowmoT
              tbowmo
              @blacey
              Thanks.. It's actually kind of fun, when I see that things I have created, actually brings value to other people.. Always been a driving force for me (no matter what I have had my hands in, whether it's software of various types,VHF radios for ships, mobile phones, bluetooth headsets, or sensor modules :) )
              • tbowmoT tbowmo
                @mvader
                mvader
                @tbowmo said:
                @mvader
                I had meant that i put it in test mode to try and program it.
                getting it in test mode worked. i could see the led blinking.
                however when i gave up and put the radio back on and turn it on, i guess it had actually taken my upload.
                it was reporting in F now.
                so i know the DTR does the auto reset, i guess upload works, but no reset and/or completed msg in the IDE.
                i ordered a new programmer anyway with DTR.
                • nutcrackerN
                  nutcrackerN
                  nutcracker
                  wrote on last edited by nutcracker
                  #149
                  I've received some boards and all working good.
                  I'd like to upload a new sketch to the Sensebender Micro board and I'm attempting to do this via the FTDI FT232RL USB to TTL serial converter adapter that I purchased here (http://www.ebay.co.uk/itm/221552218333).
                  Could someone kindly confirm the pin to pin mapping between the FTDI board and the Senseboard Micro as when I attempt to upload I receive the message:
                     Programmer Type : butterfly
                           Description     : Atmel AppNote AVR109 Boot Loader
                  Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
                  I'm using Arduino 1.6.5 running on Windows 8.1 (inside parallels on a Mac).
                  Any ideas?
                  Thank you
                  Nutz
                  hekH 1 Reply Last reply
                  • nutcrackerN nutcracker
                    Any ideas?
                    Thank you
                    Nutz
                    @nutcracker
                    I usually use the GND pin as a guide.
                    What happens if you run Arduino IDE directly in your native OS?
                    • nutcrackerN
                      nutcrackerN
                      nutcracker
                      #151
                      Thanks @hek. I've had to run Arduino on Windows before because of compatibility issues with certain chip sets on Arduino boards and I didn't fancy running unsigned drivers on my Mac to resolve... I'm able to upload sketches to other boards with no issues.
                      That said, I've updated Arduino to 1.6.5 on my Mac and have attempted to upload the default Sensebendermicro.ino sketch to the micro with a similar error:
                      Arduino: 1.6.5 (Mac OS X), Board: "Arduino Micro"
                      Sketch uses 26,414 bytes (92%) of program storage space. Maximum is 28,672 bytes.
                      Global variables use 799 bytes (31%) of dynamic memory, leaving 1,761 bytes for local variables. Maximum is 2,560 bytes.
                      Found programmer: Id = "�d��b�"; type = F
                          Software Version = �.�; Hardware Version = �.�
                      avrdude: error: buffered memory access not supported. Maybe it isn't
                      a butterfly/AVR109 but a AVR910 device?
                      With verbose output enabled:
                               User configuration file is "/Users/nutcracker/.avrduderc"
                               Using Port                    : /dev/cu.usbserial-A50285BI
                               Using Programmer              : avr109
                               Overriding Baud Rate          : 57600
                               AVR Part                      : ATmega32U4
                               BS2                           : PA0
                                 eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
                                 flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
                                 lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                 hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                 efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                                 lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                      Nutz
                        @nutcracker said:
                        Maybe it isn't
                        Is your programmer setting in Arduino IDE set to "USBasp"?
                        • nutcrackerN
                          nutcrackerN
                          nutcracker
                          Hi @hek, I've never had to change the programmer setting before... I've changed it to USBasp and re-uploaded but same error. I've always used the menu options Sketch=>Upload to upload a sketch to the board. Should I be using Sketch=>Upload via programmer for this micro board ? If so, that fails too but something to do with it not being able to find the USB device.
                                   Using Programmer              : usbasp
                          avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
                          avrdude done.  Thank you.
                          Nutz
                            Hmm. I think I understand what the problem is now. You've selected the "Arduino Micro" board. Not our "MySensors/Sensebender Micro" .
                            Did you follow the instructions here?
                            http://www.mysensors.org/hardware/micro-ide-setup
                            • nutcrackerN
                              nutcrackerN
                              nutcracker
                              Thanks @hek, I also realised my mistake once I retraced my steps...I hadn't scrolled down fully on that screenshot that shows the Sensebender Micro board... I think what through me is that screenshot also shows a "dot" against another board - the Arduino Micro board...and I was selecting that... duh! (may be worth changing the screenshot? ;))
                              Anyway, thanks for your help...sketch uploaded perfectly after that!
                                       Programmer Type : Arduino
                                       Description     : Arduino
                                       Hardware Version: 3
                                       Firmware Version: 5.0
                                       Vtarget         : 0.3 V
                                       Varef           : 0.3 V
                                       Oscillator      : 28.800 kHz
                                       SCK period      : 3.3 us
                              avrdude: reading input file "/var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex"
                              avrdude: writing flash (23678 bytes):
                              Writing | ################################################## | 100% 8.84s
                              avrdude: 23678 bytes of flash written
                              avrdude: verifying flash memory against /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                              avrdude: load data flash data from input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                              avrdude: input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex contains 23678 bytes
                              Reading | ################################################## | 100% 9.94s
                              avrdude: verifying ...
                              avrdude: 23678 bytes of flash verified
                              Cheers!
                              Nutz
                                Ah... there is a dot in the menu-image. Will update it. Thanks.
                                RJ_MakeR 1 Reply Last reply
                                  RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  @hek Interesting.. I didn't know this.. I used the standard Pro Mini 3v3 and it worked...????
                                  RJ_Make
                                  • G
                                    G
                                    gloob
                                    Received my Micros today. Luckily there was no custom and a lot of pins to solder. Can't wait to solder them on wednesday on work and test them.
                                    Is there any instruction how to solder everything? On which side the radio module needs to be soldered.
                                    tbowmoT 1 Reply Last reply
                                    • G gloob
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #159
                                      @gloob
                                      This might help you out :)
                                      • G
                                        G
                                        gbfromhb
                                        I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
                                          @gbfromhb
