  3. Fibaro HC2 Virtual Device Gateway
20 Posts 9 Posters 19.4k Views 8 Watching
    mathias
    I just got some got some basic functionality on a HC2 Controller Gateway for MySensors.
    In my first attempt to make this an fully functional MySensor controller it have the following functionality:
    • Register new Ardino Nodes/Relays with a new free radio ID
    • Autocreate new virtual Device for Door Sensors
    • Update Icon, Status and Last Update on Door sensors when changed
    • Autocreate new virtual device for Light Sensors (Relay)
    • Update Icon, Status and Last Update on Light/Relay sensors when changed
    • Turn On/Off Light/relay sensor from virtual device
    Some teasers on the virtual devices:
    Thanks to hek for his support and time on all my questions on the MySensors API.
    Next step: Order more hardware for more sensors to test with:)
    //Mathias
      mathias
      Now also working with temperature sensor
      Seems to be some conversion issues when writing decimals to label values, it adds way to many decimals even if i try to convert it to just two decimals..
      //Mathias
        mathias
        Restriction #1 You cannot add a MySensor sensor as a main source for light,temp, humidity or thermostat on a room.
        This will not be added to the next coming releases but has been passed to the developeras at fibaro to be able to add Virtual Devices as default devices to room..
        //Mathias
          mathias
          Restriction #2 Its not possible from a MySensor/Virtual Device to register an event to be listed in the Events Panel.
          But you could have some history with fibaro:debug instead or other external source if needed.
          //Mathias
            mathias
            Decimals solved in labels by adding "\"" before and after value
            fibaro:call(nodeDevice,"setProperty", "ui.lblSensorStatus.value", "\"" .. value .. "\"")
            • barduinoB
              barduinoB
              barduino
              Its looking pretty good!
                sonnyboy
                wrote on last edited by sonnyboy
                Nice work :)
                What kind of Gateway do you use?
                To get just 2, decimlas you can try this instead, then you got the celcius sighn to
                "ui.lblSensorStatus.value", value.."°")
                  mathias
                  Im using an Ethernet Gateway as described here on MySensors.org with an arduino nano and W5100 ethernet module.
                  Will add a celcius character so it looks nicer, thanks.
                    wrote on last edited by hek
                    But you're also using this branch of the library right?
                    https://github.com/mysensors/Arduino/tree/gateway-refactoring
                    (at least when compiling eth-gateway..)
                      mathias
                      No i think i took the one you could download from the ordinary pages. What is the differences, im pretty new in the arduino world:)
                        Oh, even better! I thought the plugin needed a gateway which acted as a client (connecting to controller).
                          mathias
                          No, HC2 is connecting to the MySensor Gateway. Fibaro have locked down the ability to create a socket listener and is only available if you create a plugin which has been disabled for public users to upload.
                          The code in HC2 is implemented as a Virtual Device that is creating an outbound tcp connection to the MySensors Ethernet Gateway.
                          thommeT 1 Reply Last reply
                            sonnyboy
                            Thanks for the reply, now i just have to wait for everything to come home so i can test this :) more questions will come 😉
                            • F
                              F
                              fastie81
                              Hi
                              I know this is an old topic, but I am just getting started with Mysensor.
                              I would like to add my Fibaro setup.
                              @mathias would you be able to share your LUNA code for the Virtual device to integrate the Gateway?
                              And just out of interest what version of Fibaro are you running?
                              It would be much appreciated
                              Chris
                              • F fastie81
                                Hi
                                Chris
                                Mille
                                Hi
                                I'm also interested in this code for HC2
                                  medline2c
                                  hello,
                                  I've a HC2 and I'm very interresting to test this code ... where can I found it ?
                                  thanks
                                  • Tomasz PazioT
                                    Tomasz PazioT
                                    Tomasz Pazio
                                    Any progress on this topic? Fibaro have good controller, it would be interesting to have it fully integrated with Mysensors.
                                    F 1 Reply Last reply
                                    • Tomasz PazioT Tomasz Pazio
                                      F
                                      F
                                      fastie81
                                      @Tomasz-Pazio Nothing has happened here. Have reached out a few times.
                                      I am using Domoticz with FibaroLink in the meantime. Would love to not have Domoticz in the middle but with Fibaro not opening plugins and dont know how to code this just have to do..
                                      I am trying to learn Lua very slowly.
                                      Hope the get there some point.
                                      Chris
                                      • M mathias
                                        thommeT
                                        thommeT
                                        thomme
                                        Hello @mathias I dont know if you are still in the business of Writing code and solve problems like the Fibaro one.
                                        Could you please share the solution in full with the rest of us. It seems like this topic Fibaro/Mysensor died 2 years ago. Why is that? It feels strange when you got a proof of concept.
                                        If Mathias is out of business for some reason, could you @hek clearify things with the fibaro/mysensors. I noticed that you participated in a discussion at the z-wave forum in the sam matter.
                                        Regards/Med vänlig hälsning
                                        Thomas
                                          It seems abandoned, but I'll ping @mathias over email.
