Fibaro HC2 Virtual Device Gateway
Restriction #1 You cannot add a MySensor sensor as a main source for light,temp, humidity or thermostat on a room.
This will not be added to the next coming releases but has been passed to the developeras at fibaro to be able to add Virtual Devices as default devices to room..
//Mathias
Im using an Ethernet Gateway as described here on MySensors.org with an arduino nano and W5100 ethernet module.
Will add a celcius character so it looks nicer, thanks.
No, HC2 is connecting to the MySensor Gateway. Fibaro have locked down the ability to create a socket listener and is only available if you create a plugin which has been disabled for public users to upload.
The code in HC2 is implemented as a Virtual Device that is creating an outbound tcp connection to the MySensors Ethernet Gateway.
Hi
I know this is an old topic, but I am just getting started with Mysensor.
I would like to add my Fibaro setup.
@mathias would you be able to share your LUNA code for the Virtual device to integrate the Gateway?
And just out of interest what version of Fibaro are you running?
It would be much appreciated
Chris -
Hi
Chris -
Any progress on this topic? Fibaro have good controller, it would be interesting to have it fully integrated with Mysensors.
@Tomasz-Pazio Nothing has happened here. Have reached out a few times.
I am using Domoticz with FibaroLink in the meantime. Would love to not have Domoticz in the middle but with Fibaro not opening plugins and dont know how to code this just have to do..I am trying to learn Lua very slowly.
Hope the get there some point.
Chris
Hello @mathias I dont know if you are still in the business of Writing code and solve problems like the Fibaro one.
Could you please share the solution in full with the rest of us. It seems like this topic Fibaro/Mysensor died 2 years ago. Why is that? It feels strange when you got a proof of concept.
If Mathias is out of business for some reason, could you @hek clearify things with the fibaro/mysensors. I noticed that you participated in a discussion at the z-wave forum in the sam matter.
Regards/Med vänlig hälsning
Thomas -
