  3. PC Power Switch
PC Power Switch
14 Posts 6 Posters 10.1k Views 3 Watching
  • S Offline
    stephenmhall
    Hi Guys
    Looking for more stuff to control and my eyes fell upon my PC. I was away for a week a while back and it could have been useful to be able to turn my PC on and off remotely. So here it is. Just a test circuit at the moment, but it should just be a case of replacing the power and reset led's with inputs from the case buttons to get it working.
    Luckily, and i'm not sure this is universal but my mobo's USB sockets are permanently live with the pc off so power is not an issue.
    It currently shows up as 3 switches in Vera UI7,
    Power ON/OFF
    Reset
    Power Force OFF
    The circuit has a Power switch and Reset switch for local control, What I do need is some nice code to work out if I am long pressing the Power switch to force a close.
    The toggle switch is to simulate 5V coming from the PC when powered up, this is the On detection.
    The 5V feed to the led's would be replaced by the high side of the switches in the PC.
    Here is the code.
    // Example sketch för a "light switch" where you can control light or something
    // else from both vera and a local physical button (connected between digital
    // pin 3 and GND).
    // This node also works as a repeader for other nodes
    #define BUTTON_PWR_PIN  2  // Arduino Digital I/O pin number for button
    #define BUTTON_RST_PIN  3  // Arduino Digital I/O pin number for button
    #define SWITCH_PRW_PIN  4  // Arduino Digital I/O pin number for SWITCH
    #define SWITCH_RST_PIN  5  // Arduino Digital I/O pin number for SWITCH
    #define PC_ON_PIN 6        // Connected to PC 5v output Molex
    #define PC_ON_LED 7        // PC On LED
    #define NODE_ID AUTO
    #define SKETCH_NAME "MySensor_PC_Switch"
    #define SKETCH_VERSION "1.0"
    #define NODE_REPEAT false
    #define CHILD_ID_SWITCH_PWR 0
    #define CHILD_ID_SWITCH_RST 1
    #define CHILD_ID_SWITCH_OFF 2
    #define SWITCH_ON 0
    #define SWITCH_OFF 1
    Bounce debouncerPWR = Bounce();
    Bounce debouncerRST = Bounce();
    int oldPWRValue=0;
    int oldRSTValue=0;
    int pcState=0;
    int currentpcState=0;
    unsigned long status_timer = millis();
    unsigned long now_time = millis();
    unsigned long update_time = 30000;
    bool statePWR;
    bool stateRST;
    MyMessage msgPwr(CHILD_ID_SWITCH_PWR,V_LIGHT);
    MyMessage msgRst(CHILD_ID_SWITCH_RST,V_LIGHT);
    MyMessage msgOff(CHILD_ID_SWITCH_OFF,V_LIGHT);
     // Setup the buttons
      pinMode(BUTTON_PWR_PIN,INPUT);
      digitalWrite(BUTTON_PWR_PIN,HIGH);
      pinMode(BUTTON_RST_PIN,INPUT);
      digitalWrite(BUTTON_RST_PIN,HIGH);
      debouncerPWR.attach(BUTTON_PWR_PIN);
      debouncerPWR.interval(5);
      debouncerRST.attach(BUTTON_RST_PIN);
      debouncerRST.interval(5);
      gw.present(CHILD_ID_SWITCH_PWR, S_LIGHT);
      gw.present(CHILD_ID_SWITCH_RST, S_LIGHT);
      gw.present(CHILD_ID_SWITCH_OFF, S_LIGHT);
      // Make sure SWITCHs are off when starting up
      digitalWrite(SWITCH_PRW_PIN, SWITCH_OFF);
      digitalWrite(SWITCH_RST_PIN, SWITCH_OFF);
      // Then set SWITCH pins in output mode
      pinMode(SWITCH_PRW_PIN, OUTPUT);
      pinMode(SWITCH_RST_PIN, OUTPUT);
      pinMode(PC_ON_LED, OUTPUT);
      pinMode(PC_ON_PIN, INPUT);
      // Set SWITCH to last known state (using eeprom storage)
      //state = gw.loadState(CHILD_ID);
      //digitalWrite(SWITCH_PIN, state?SWITCH_ON:SWITCH_OFF);
    *  Example on how to asynchronously check for new messages from gw
      debouncerPWR.update();
      debouncerRST.update();
      // Get the update value
      int valuePWR = debouncerPWR.read();
      int valueRST = debouncerRST.read();
      if (valuePWR != oldPWRValue && valuePWR==0) {
        pushButton(SWITCH_PRW_PIN, 200);
        sendPCState(1);
      if (valueRST != oldRSTValue && valueRST==0) {
        pushButton(SWITCH_RST_PIN, 200);
        sendPCState(1);
      oldPWRValue = valuePWR;
      oldRSTValue = valueRST;
      currentpcState = digitalRead(PC_ON_PIN);
      if(currentpcState != pcState) {
        if (currentpcState == HIGH) {
          pcState = 1;
          Serial.println("PC Turned on");
          digitalWrite(PC_ON_LED, HIGH);
        else {
          pcState = 0;
          Serial.println("PC Turned off");
          digitalWrite(PC_ON_LED, LOW);
        delay(50);
        sendPCState(1);
      if (now_time - status_timer > update_time) {
        sendPCState(1);
        status_timer = now_time;
      if (message.isAck()) {
         // Change SWITCH state
         if (message.sensor == 0 && !message.isAck()) {
           Serial.println("Pushing Power Button");
         if (message.sensor == 1 && message.getBool()) {
           Serial.println("Pushing Reset Button");
         if (message.sensor == 2 && !message.isAck()) {
           Serial.println("Pushing and Holding Power Button");
           pushButton(SWITCH_PRW_PIN, 6000);
    void sendPCState(boolean ack){
      gw.send(msgPwr.set(pcState), ack); // Send new state and request ack back
      delay(100);
      gw.send(msgOff.set(pcState), ack); // Send new state and request ack back
      delay(100);
      gw.send(msgRst.set(stateRST), ack); // Send new state and request ack back
    void pushButton(int button, int pushTime) {
      digitalWrite(button, SWITCH_ON);
      delay(pushTime);
      digitalWrite(button, SWITCH_OFF);
    I am using bounce2 for the switches, if anyone has some nice code to detect long presses that would be great.
    What I would like to do is have just a single device in Vera with all the switches on it, but going through the xml and json files makes my head explode.
    This could be expanded to include temps and fan speeds and all sorts of malarkey.
    Oh I just had a thought, this could be really handy for server farms :)
    • DidiD Offline
      DidiD Offline
      Didi
      Here is a nice button libary
      http://www.mathertel.de/Arduino/OneButtonLibrary.aspx
      • S Offline
        stephenmhall
        Eeeeexcellent.. nice library, works great.
        // pin 3 and GND).
        #include <OneButton.h>
        // Setup a new OneButton on pin A1.
        OneButton BUTTON_PWR_PIN(A1, true);
        // Setup a new OneButton on pin A2.
        OneButton BUTTON_RST_PIN(A2, true);
        //#define BUTTON_PWR_PIN  2  // Arduino Digital I/O pin number for button
        //#define BUTTON_RST_PIN  3  // Arduino Digital I/O pin number for button
        #define SWITCH_ON 0
        int pcState=0;
        bool statePWR;
        bool stateRST;
          // link the button 1 functions.
          BUTTON_PWR_PIN.attachClick(click1);
          BUTTON_PWR_PIN.attachLongPressStop(longPressStop1);
          // link the button 2 functions.
          BUTTON_RST_PIN.attachClick(click2);
          BUTTON_PWR_PIN.tick();
          BUTTON_RST_PIN.tick();
              pcState = 1;
            else {
              pcState = 0;
            delay(50);
            sendPCState(1);
            sendPCState(1);
          delay(100);
          delay(100);
          delay(pushTime);
        // ----- button 1 callback functions
        // This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
        void click1() {
          Serial.println("Button 1 click.");
          sendPCState(1);
        } // click1
        // This function will be called once, when the button1 is released after beeing pressed for a long time.
        void longPressStop1() {
          Serial.println("Button 1 longPress stop");
          sendPCState(1);
        } // longPressStop1
        // ... and the same for button 2:
        void click2() {
          Serial.println("Button 2 click.");
          sendPCState(1);
        } // click2```
        • Mohsin HassanM Offline
          Mohsin Hassan
          Not wanting to be dick but if i may suggest an alternative,
          Try Wake on LAN, as long as you are connect via LAN you can just send a command remotely and it will turn on the PC.
          Non the less great project bro.
          • Mohsin HassanM Mohsin Hassan
            Moshe LivneM Offline
            Moshe Livne
            @Mohsin-Hassan you can only turn on computer like that, not turn it off or reset it which are really important operations if the computer is stuck....
            • S Offline
              stephenmhall
              No, it will turn off and reset too. The circuit will "press" all the buttons needed.
              • S Offline
                stephenmhall
                All connected up (temporary, you know, next 2 years) and tested. Except the force shut-down, don't want to put my drive trough that unless it is needed; but I'm running the fast lane Windows 10 so probably sometime this week.
                Only changes to circuit I needed was to link the inputs directly to the switches cutting out the test Led's. power switch is 5V but reset was 3.3V but there is no arduino supplied voltage on the inputs so it seems happy enough.
                I would say sorry about the mess, BUT I'M NOT :)
                • S Offline
                  stephenmhall
                  wrote on last edited by stephenmhall
                  I have been using imperihome to control my vera, a much nicer interface. and this in my PC Screen. It allows protected operations so I get a confirmation request before pushing a button. And because of the 30 second pc status update from the 5v input, the switches show the state of the PC not the switches.
                  • hekH Offline
                    hekH Offline
                    Big phat buttons :)
                    • S Offline
                      stephenmhall
                      Well, I turned on my PC before I left work today, because I could :)
                      • S stephenmhall
                        M Offline
                        M Offline
                        msebbe
                        wrote on last edited by msebbe
                        Awsome! I would do that too even though it takes 20 seconds for pc to boot :D
                        • Moshe LivneM Offline
                          Moshe Livne
                          Now just add to it something that sense your car (garage door opener?) and turn on your pc! Cool project
                          • S Offline
                            stephenmhall
                            Finally got it on strip board and a box is printing. I would like to get into cnc machining of 2 sided pcb's but I need some smaller bits and some extra knowledge before I start that.
                            Here is what the box should look like.
                            Mod Everything!
                            • S Offline
                              stephenmhall
                              pictures of the real thing
