  3. Requesting a sensor value from a different node?
15 Posts 10 Posters 11.4k Views 4 Watching
  • andyunoA andyuno
    @sansespere said:
    Awesome - pushing from the sensor at the same time it sends to the gateway has got it working. Will have to create what will almost be a stripped down version of a gateway to process all incoming messages and assign the contents to the correct variables for the screen : )
    Thanks for the advice!
    Hey Great idea been trying something similar myself sometime but getting nowhere any chance of you sharing some of your code, that might help me get started. What size LCD are you thinking of of using, or are you just going to use a small LCD menu driven with a couple buttons.
    sansespere
    wrote on last edited by sansespere
    @andyuno
    Hey, no problem - the LCD I'm using is this one in a 16x2 format.
    Haven't had much of a chance to work on it yet since first getting it working with Hek's advice above but this is what I have so far. Standard disclaimer though, I'm new to this whole coding and electronics stuff so there may be a better way of doing it.
    To start with, in the sketch of the sensor that has the information you want to display, find where it's sending the data to the gateway, and get it to send to the node that has the LCD at the same time. EG:
    gw.sendVariable(CHILD_ID_TEMP, V_TEMP, temperatureB, 1); //standard line sending data to the gateway
    gw.sendVariable(MONITOR_STATION,CHILD_ID_TEMP, V_TEMP, temperatureB, 1); //new line that needs to be created, where MONITOR_STATION is defined as the radioID of the node with the LCD
    and below is the testing sketch I wrote to receive and display the messages:
     #include <EEPROM.h>
     #include <RF24.h>
     #include <Sensor.h>
     #include <Time.h>
     Sensor gw;
     #define CHILD_ID 10
     LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
     float temp = 0; //for storing temperature values
     float hum = 0; //for storing humidity values
       gw.begin();
       gw.sendSketchInfo("LCD", "1.0");
       // Register any sensortype. This example we just create a motion sensor.
       gw.sendSensorPresentation(CHILD_ID, S_MOTION);
       lcd.begin(16,2);   //Specify LCD size
       lcd.backlight();
       int LoopCount = 0; // LoopCount is there to make sure that we dont get stuck in a never ending loop of processing messages - not sure if this could ever even happen, but just to be safe
       while(gw.messageAvailable()==true && LoopCount < 10){ //while there are messages in the queue and we havent processed more than 10 since entering the loop
           message_s  message = gw.getMessage(); //get the message
           if (message.header.type == 0){  //check the type of message it is - temperature, humidity, etc. as per Variable Types defined in http://www.mysensors.org/build/sensor_api
           temp = atof(message.data); //if it's a temp type, get the data and convert it to float
           if (message.header.type == 1){
           hum =  atof(message.data); //if it's a humidity type, get the data and convert it to float
           LoopCount++;  //increment the loop counter
       if (LoopCount >= 1){ //Check if we need to update the LCD
        UpdateLCD();
       //serial prints for troubleshooting
       Serial.print("Temp: ");
       Serial.println(temp);
       Serial.print("Hum: ");
       Serial.println(hum);
       Serial.println("Waiting");
       delay(10000);   //take a short break
     void UpdateLCD() { //LCD output
       lcd.clear();
       lcd.print("Temp:");
       lcd.print(temp,1);
       lcd.print("C");
       lcd.setCursor(0,1);
       lcd.print("Humi:");
       lcd.print(hum,1);
       lcd.print("%");
    and you end up with something like this.....
    upload-782a7eaa-f12e-4e50-aeb8-d2c106de80aa
    showing data for a sensor I have sitting outside.
    Still a lot of work to do to get it right - there are other things I want to display, using scrolling messages to cycling messages, etc, but this is just a basic proof of concept.
    • S sansespere
      @andyuno
       #include <EEPROM.h>
       #include <RF24.h>
       #include <Sensor.h>
       #include <Time.h>
       Sensor gw;
       #define CHILD_ID 10
         gw.begin();
         lcd.backlight();
          UpdateLCD();
         lcd.clear();
         lcd.print("Temp:");
         lcd.print(temp,1);
         lcd.print("C");
         lcd.setCursor(0,1);
         lcd.print("Humi:");
         lcd.print(hum,1);
         lcd.print("%");
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @sansespere said:
      @andyuno
       #include <EEPROM.h>
       #include <RF24.h>
       #include <Sensor.h>
       #include <Time.h>
       Sensor gw;
       #define CHILD_ID 10
         gw.begin();
         lcd.backlight();
          UpdateLCD();
         lcd.clear();
         lcd.print("Temp:");
         lcd.print(temp,1);
         lcd.print("C");
         lcd.setCursor(0,1);
         lcd.print("Humi:");
         lcd.print(hum,1);
         lcd.print("%");
      nice work.
      for your next revision we can show you how to do this without holding in the while loop or using delays.
      terrific!!!!! :) I like LCD's :)
      S 1 Reply Last reply
        @sansespere said:
        @andyuno
         #include <EEPROM.h>
         #include <RF24.h>
         #include <Sensor.h>
         #include <Time.h>
         Sensor gw;
         #define CHILD_ID 10
           gw.begin();
           lcd.backlight();
            UpdateLCD();
           lcd.clear();
           lcd.print("Temp:");
           lcd.print(temp,1);
           lcd.print("C");
           lcd.setCursor(0,1);
           lcd.print("Humi:");
           lcd.print(hum,1);
           lcd.print("%");
        nice work.
        sansespere
        Ahhh ok - so something more like this:
        #include <EEPROM.h>
        #include <RF24.h>
        #include <Sensor.h>
        #include <Time.h>
        Sensor gw;
        #define CHILD_ID 1
          gw.begin();
          lcd.backlight();
            message_s  message = gw.waitForMessage(); //wait for a message to process
            else if (message.header.type == 1){
            else {
              Serial.print("Unknow Message Type");
          UpdateLCD();
          lcd.clear();
          lcd.print("Temp:");
          lcd.print(temp,1);
          lcd.print("C");
          lcd.setCursor(0,1);
          lcd.print("Humi:");
          lcd.print(hum,1);
          lcd.print("%");
        andyunoA 1 Reply Last reply
        • S sansespere
          #include <EEPROM.h>
          #include <RF24.h>
          #include <Sensor.h>
          #include <Time.h>
          Sensor gw;
          #define CHILD_ID 1
            gw.begin();
            lcd.backlight();
              else {
            UpdateLCD();
            lcd.clear();
            lcd.print("Temp:");
            lcd.print(temp,1);
            lcd.print("C");
            lcd.setCursor(0,1);
            lcd.print("Humi:");
            lcd.print(hum,1);
            lcd.print("%");
          andyunoA
          andyunoA
          andyuno
          @sansespere.. Nice work, I don't think I would've got most of that, now that should give me something to work from thanks.
          :) Any Help is Appreciated Thank You.
          • jendrushJ
            jendrushJ
            jendrush
            If someone have this converted to 1.4 version of library please post it.
            • K
              K
              kwest
              wrote on last edited by kwest
              Have node №2 child 1 - temp sensor.
              For example: how to ask the node 2 child 1 value from node №10?
              • K
                K
                kwest
                • A
                  andriej
                  Anyone?
                  @sansespere
                  • F
                    F
                    franklin216
                    wrote on last edited by franklin216
                    I've just found this thread, which describes the Convertion from 1.3 to 1.4:
                    http://forum.mysensors.org/topic/172/convert-sketch-from-1-3-to-1-4
                    I think, the following would do the trick, i will try it, when i am home this evenening:
                    // process incoming messages (like config from server) <-- insert line
                    gw.process(); <-- insert line
                    gw.sendVariable(MONITOR_STATION, CHILD_ID, V_TEMP, temperature, 1); change to --> gw.send(msg.setSensor(CHILD).set(temperature,1).setDestination(MONITOR_STATION)); // send float with one decimal point
                    • AWIA
                      AWIA
                      AWI
                      I would imagine the "royal" way of getting sensor values is requesting them from the controller. In this case the sensor to be read does not need to bother about sending the values to all of the nodes and waking up is not an issue.
                      • Lawrence HelmL
                        Lawrence HelmL
                        Lawrence Helm
                        did anyone convert this succesfully? I'm having some problems, this would make a great example build :) I looked at other ones like "node to node " but something simple like this would be great to start building from..
