  3. Power for (re-used) wall plug
5 Posts 3 Posters 2.4k Views 1 Watching
  • M Offline
    M Offline
    marceltrapman
    I want to re-use two old 433MHz wall plugs (it is an older version of these).
    I can take out all that is in there and replace it with my own stuff.
    However, the thing obviously (EU) has 230 volts and nothing else.
    I am new to this so the question is: what is the (best) way to bring the 230 volts down to what the board (Pro Mini), radio and the relay switch need?
    Thanks in advance,
    Marcel
    Fulltime Servoy Developer
    • H Offline
      H Offline
      I use wall warts like this:
      5V 2A USB Port Wall Adapter Charger EU/US Plug
      • M Offline
        M Offline
        marceltrapman
        wrote on last edited by marceltrapman
        Hmm, I thought of that as well but I did not find any of these at 2A.
        Will (have to) look further now that I know they exist because this supplier does not ship to Germany :(
        Thanks!!!
        Edit: found this one here
        • A Offline
          A Offline
          andriej
          You can also just use transmitter of 433MHz wave and send commands to the wall plug.
          I have all the plugs maintained like that.
          • M Offline
            M Offline
            marceltrapman
            Hi Andriej,
            I won't do that because I have experienced quite some issues with that frequency.
            Some of my neighbours use the same frequency and I have had my (kitchen) light go on and off without doing anything (or even being home) too many times with these 2 devices.
            That is why I decided to re-use their housing but not the technology...
            But, thank you for the suggestion!
            Cheers,
            Marcel
            11.9k
