  3. converting 12v to 5v
49 Posts 7 Posters 30.2k Views 2 Watching
  • tbowmoT tbowmo
    @Moshe-Livne
    Without knowing the details of the doorbell, I would think it is something like this.. That is, the doorbell get power, when the button is pressed, and makes a connection to GND. So this would be the circuit that I would create:
    It's only the arduino part you should make, the rest is the existing doorbell.. The resistor should be high value, I've put in 56Kohm, but something in the order of 56-220K ohm, whatever you have in your parts bin :)
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @tbowmo I think its just about the same as my messy sketch. only thing is you assumes the grounds are the same, which should be ok. got a bridge rectifier as well but had to take the kids to watch minions. sigh....
    • tbowmoT
      tbowmoT
      tbowmo
      @Moshe-Livne
      It seems that you have the doorbell switch attached accross the supply, so you short circuit it, when you press it.
      You also need a common ground signal, between the door bell, and the arduino.
      Moshe LivneM 2 Replies Last reply
      • tbowmoT tbowmo
        @Moshe-Livne
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @tbowmo oh this power supply represents the bell circuit but i see what you mean. If the kids will give me 10 min today I'll give it a try. Door bell is one of those things you can't do after they go to sleep
        • tbowmoT tbowmo
          @Moshe-Livne
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @tbowmo so, to get a common ground i just connect the "-" from the bell to the gnd on the arduino?
          • tbowmoT
            tbowmoT
            tbowmo
            @Moshe-Livne
            Yes, I would think so.. again, without having any knowledge to how the door bell is functioning..
            • tbowmoT tbowmo
              @Moshe-Livne
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @tbowmo Oh I wish I knew. I might just open it and look although it will be a big hard to put back. currently the power from the bridge seems to be not enough to drive the circuit which is strange. the power lights up but nothing much happens. I'll go over everything once again.
              • tbowmoT tbowmo
                @Moshe-Livne
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @tbowmo I have double checked everything, used the arduino connected to the computer so have a stable 5v power supply to the nano. connected external power supply with 6.3v and 8ma to ground and the external leg of the resistor - nothing...
                wouldn't it be simpler it I used npn transistor to close the circuit? I am on the verge of going the "safe" way - connecting the doorbell loop to the arduino so pressing the doorbell will short pin 3 to gnd and then activating a relay to close the doorbell circuit. this is far from being a good solution as if the sensor does not work the doorbell will not work as well, but this is stuff that I understand (to an extent :-) )
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Moshe-Livne
                  what is the voltage at the arduino input, when you apply the external power supply?
                  Could you try and measure the voltage across the switch terminals in the door bell:
                  1. when button isn't pressed
                  2. when the button is pressed
                  You need to simulate these two input voltages on the input of the circuit..
                  • tbowmoT tbowmo
                    @Moshe-Livne
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @tbowmo this is not connected to the doorbell as I hate working in the air... so, its connected to my laptop for the 5v and debug and to a variable voltage power supply that i set to 6.3v (it shows 8ma are "used")
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Moshe-Livne
                      Yes, but you need to simulate the doorbell, so take some measurements on the doorbell, and copy those to your circuit. That is, if the signal on the doorbell is 0V when the button is pressed, then you should be able to short the input to your signal to 0V.
                      Also, again, when applying 6.3V via your external powersupply, what is the voltage on the input pin on the arduino?
                      • tbowmoT tbowmo
                        @Moshe-Livne
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @tbowmo i get 3.30v when power is off 4.7v when power is on. i think i used the wrong resistor... i am colour blind.... checking...
                        • tbowmoT tbowmo
                          @Moshe-Livne
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @tbowmo no, its 67k so should be fine
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Moshe-Livne
                            What if you short circuit the input to GND, what voltage is there on the arduino pin then?
                            • tbowmoT tbowmo
                              @Moshe-Livne
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @tbowmo When I connect the outside leg of the resistor to gnd i get 0 (both when the power supply is on or off) on the arduino pin
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Moshe-Livne
                                I think you are good to go, and try this on the actual doorbell :)
                                This assumes that when you press the button to activate the doorbell, it shorts the input pin to GND.. otherwise it's ~ 6V
                                • tbowmoT tbowmo
                                  @Moshe-Livne
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @tbowmo I'll give it another try - it didn't work before. anyway getting near midnight here so I better get some sleep. will try it again tomorrow. Thank you for your infinite patience...
                                  Just a question, why not use a transistor to "sense" the closing of the circuit? is the voltage too high?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    you still need a couple of resistors and a transistor.. Here we have 2 diodes, and a resistor..
                                    But it could also be done with a transistor yes..
                                    / Thomas
                                    • tbowmoT tbowmo
                                      / Thomas
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @tbowmo nope, still no go. strangely, when i disconnect the arduino from the computer (so it is not powered), it creates a short after a few seconds and the bell starts ringing continuously.
