  3. sensors in boxes
sensors in boxes
57 Posts 11 Posters 44.1k Views 16 Watching
  • GuyPG GuyP
    @DrJeff At the moment just temperature sensors.. however the plan is to also control my heating system around the house.
    I will put putting controllers on all the radiators around the house, and replacing the controller in the house with simple radio buttons which feed back to openhab for manual over ride.
    Just not had time yet! :(
    DrJeffD
    DrJeffD
    DrJeff
    @GuyP Yes we always got to deal with real life! On the board I assume the red lines are wires due to the single sided board?
    GuyPG 1 Reply Last reply
    • DrJeffD DrJeff
      GuyPG
      GuyPG
      GuyP
      @DrJeff yes correct.. I'm just etching single sided. I couldn't solve the it completely so four links.
      • G
        G
        gigaguy
        @GuyP Are you using the MYS or the Uno bootloader?
        • GuyPG
          GuyPG
          GuyP
          I'm just flashing with the uno boot loader...
          I have been looking at doing away with the boot loader, but really the advantages such as extra space and boot speed are not important at the moment.
          • GuyPG GuyP
            I'm running everything at 3 volts from the 2 AAA batteries. The box is 3D printed and integrates the battery box. I'm not using any screws, just slide rails for the PCB , top and back.
            TempSensorBase.stl
            I have two board types now. One with just the single Dallas temp sensor on it, which turns out to be what I need most of.
            I also created another board which has three Connectors, JP1-3, which allows to additional Dallas Temp sensors. I have these in locations where I can run wires more easily, like my loft spaces.
            I'm etching everything myself. Very simple really. I'm using the print on to glossy paper and transfer onto copper board, using a laminator, method. Works really well. As these boards are small I tend to etch a few at a time onto a single copper board and then cut the board at the end.
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @GuyP can you please export it in brd or dxf?
            • GuyPG
              GuyPG
              GuyP
              Here's the BRD files..
              TempSensorRepeater.brd
              TempSensor.brd
              • GuyPG GuyP
                TempSensor.brd
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @GuyP Thanks!!!!
                • Moshe LivneM Moshe Livne
                  @GuyP Thanks!!!!
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @GuyP Ordered 3 from oshpark... 12$. lets see how quickly they get here. so, other than the sensor and the resistors and oscillator (16mhz?) is there anything else there? I am sorry, I am just hopeless at reading sketchs. Is that a diod on the top left?
                  • GuyPG
                    GuyPG
                    GuyP
                    Sorry my fault... I'm not very good at documentation! :(
                    There are no diodes on the boards... Which board are you referring to.. the TempSensor board just has:
                    • 1x dallas Tempensor
                    • 2x capacitors for the crystal
                    • 1x 16Mhz Crystal
                    • 1x 4.7uf Capacitor accros the power lines
                    • 1 resistor for the Dallas sensor to provide power
                    • 1x 470k resistor and 1x 1m resistor for the battery power level monitoring.
                    I don't even have the pins for updating the Arduino, I pull it from the socket and write it in a uno board. I do however have a GND, and serial TX pin so I can see the chip working if necessary.
                    • GuyPG GuyP
                      • 1x 16Mhz Crystal
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @GuyP excellent!! That comes out as a really inexpensive and low power board. What sockets do you use? will these work? http://www.aliexpress.com/item/Free-shipping-17PCS-28pin-DIP-IC-sockets-Adaptor-Solder-Type-28-pin-Narrow-body/32313568228.html?spm=2114.32010308.4.2.lkcXJR
                      • GuyPG
                        GuyPG
                        GuyP
                        Yes it's very cheap and simple to build, When I was etching the boards I was etching 12 at a time and cutting them down.
                        That 28pin Narrow socket looks to be the right thing (seems to say the right things anyway), the graphic is odd though.
                        I also bought all the parts in bulk which made for even more savings, specially for resistors and capacitors where I bought maybe 100 and was paying less than 1p a unit.
                        I was also able to buy the Dallas Temp sensors in bulk and saved quite well on those as well
                        • GuyPG GuyP
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @GuyP Yes, i think that they tried to show what chip fits the socket. They move in mysterious ways... I have all the transistors and capacitors i'll ever need (they are really cheap...) but ordered the oscillators so now I have to wait for a week or two. I am not into etching - seems like something I'll manage to mess up. oshpark will print nice pcbs for you for a really reasonable price. I have ordered only 3 so cost is 4$ each but if you order quantity its much much less (and most of the price is the shipping i think :-) ).
                          I also have some Dallas so I am all set. As I don't have a 3d printer but really good at woodworking I think i'll build some nice oak boxes for these....
                          • GuyPG
                            GuyPG
                            GuyP
                            Awesome... send photos when you've made them! :)
                            • GuyPG
                              GuyPG
                              GuyP
                              Oh a few people have suggested these guys for cheap PCB production..
                              http://dirtypcbs.com
                              I've not tried them myself yet.
                              • GuyPG GuyP
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @GuyP They are very cheap per board. Might give them a go if the 3 works fine. early days yet!
                                • GuyPG GuyP
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @GuyP PCB arrived from oshpark!
                                  What capacitors did you use for the crystal? and what resistor for the dallas?
                                  mntlvrM 1 Reply Last reply
                                  • GuyPG
                                    GuyPG
                                    GuyP
                                    Ok now I'm jealous.. that looks fantastic.
                                    • GuyPG GuyP
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @GuyP It does... Now I realize that if I knew what I was doing (and I don't) it could probably be made smaller and no need for soldering at all.
                                      Thanks! will let you know how it worked out. Might take a bit of time as I am now finishing my AirCon remote sensor.
                                      • 5546dug5
                                        5546dug5
                                        5546dug
                                        @GuyP Can you post the 3d files for the box in original post if possible?
                                        • GuyPG
                                          GuyPG
                                          GuyP
                                          Sure here you go..
                                          TempSensorBase.stl
                                          TempSensorTop.stl
