  3. Doorbell hack
Doorbell hack
13 Posts 3 Posters 5.4k Views 2 Watching
  • M Offline
    M Offline
    msebbe
    Hi!
    Im using a modified version of the Door/Window sketch. I have a random 433mhz doorbell at my door and a arduino nano 3.0 with radio and 433mhz receiver connected.
    I have managed to make the node send this message every time the doorbell is pressed
    gw.send(msg.set(value == HIGH ? 1 : 0));
    Nothing happends in the Vera edge UI tho. I would like to make it so that when doorbell is pushed, same thing happends like when you open the door in the original sketch (red color in Vera UI when door open)
    here is full code;
     this is set up for a 4 pin recv unit GND DATA DATA VCC
     plug GND into D2, DATA into D3 and D4, and VCC into D5
    #include <MySensor.h>
    #include <SPI.h>
    #include <Bounce2.h>
    #include <RCSwitch.h>
    RCSwitch mySwitch = RCSwitch();
    #define CHILD_ID 3
    #define VCC_PIN 5 // source 5V up to 40mA from this pin
    #define GND_PIN 2 // sink up to 40mA on this pin
    #define DATA_PIN 3 // external int 1 on Uno
    MySensor gw;
    int oldValue = -1;
    int bell = -251;
    // Change to V_LIGHT if you use S_LIGHT in presentation below
    MyMessage msg(CHILD_ID, V_TRIPPED);
      gw.begin();
      gw.present(CHILD_ID, S_DOOR);
      // 433mhz Part
      pinMode(DATA_PIN, INPUT);
      // just leave D4 tristated
      pinMode(GND_PIN, OUTPUT);
      digitalWrite(GND_PIN, LOW);
      pinMode(VCC_PIN, OUTPUT);
      digitalWrite(VCC_PIN, HIGH);
      mySwitch.enableReceive(1);  // Receiver on interrupt 1 => that is pin D3
    static unsigned long count = 0;
      if (mySwitch.available()) {
        int value = mySwitch.getReceivedValue();
        if (value == bell) {
        // Send in the new value
        gw.send(msg.set(value== HIGH ? 1 : 0));
        oldValue = 1;
        mySwitch.resetAvailable();
        count = 0;
      else {
        if (++count == 0) Serial.println("no activity");
    Any Ideas how I can just make the message so it triggers "door sensor" in my UI?
    • H Offline
      H Offline
      Guess you'll also have to send/restore the tripped value after some time?
      • H hek
        M Offline
        M Offline
        msebbe
        Yes, that would be ideal. First problem for me is how to change tripped value without using the actual magnetic sensor..
        • M Offline
          M Offline
          msebbe
          • M Offline
            M Offline
            msebbe
            Below is my working sketch. Could somebody help clean it up? I made this sketch by combining two sketches and removing some parts from each.
            #define CHILD_ID 3
            int oldValue = -1;
            int bell = -251;     // This is the value that my 433mhz doorbell sends out when button is pushed
              gw.begin();
              // 433mhz Part
                int value = mySwitch.getReceivedValue(); // This is where 433mhz signal are recieved
                gw.send(msg.set("1"));  // Gives doorbell status tripped
                delay(5000);
                gw.send(msg.set("0"));  // Gives doorbell status not tripped
                count = 0;
              else {
            • B Offline
              B Offline
              BulldogLowell
              not tested, but I'd look to do it like this... with non-blocking code in case of a second press of the doorbell within the 5second timeout:
              #define CHILD_ID 3
              const int bell = -251;     // This is the value that my 433mhz doorbell sends out when button is pushed
              boolean tripped = false;
                gw.begin();
                // 433mhz Part
                  tripped = (mySwitch.getReceivedValue() == bell);
                  if (tripped)
                    timerStart = millis();
                    Serial.println(F("Ding Dong!!"));
                  mySwitch.resetAvailable();  //<<<<<<<<<< I think you want this here... I looked at the library on GitHub
                if (tripped && millis() - timerStart > 5000UL)
                  Serial.println(F("no activity"));
                  tripped = false;
              again, I could not test it...
              • B BulldogLowell
                #define CHILD_ID 3
                  gw.begin();
                  // 433mhz Part
                    if (tripped)
                    tripped = false;
                M Offline
                M Offline
                msebbe
                wrote on last edited by msebbe
                #define CHILD_ID 3
                  gw.begin();
                  // 433mhz Part
                    if (tripped)
                    tripped = false;
                  mySwitch.resetAvailable();// i am not familiar with your library, so I'm not sure where this would go... or if you even need it with the non-blocking code.
                Thank you! Looks much better. I will test later today when its not 31 celsius outside :)
                B 1 Reply Last reply
                • M msebbe
                  #define CHILD_ID 3
                    gw.begin();
                    // 433mhz Part
                      if (tripped)
                      tripped = false;
                  B Offline
                  B Offline
                  BulldogLowell
                  @msebbe
                  OK, I reviewed the arduino library and it looks like mySwitch.resetAvailable(); belonged higher in the code, so I edited it. You may want to be wary of that.
                  • B BulldogLowell
                    @msebbe
                    M Offline
                    M Offline
                    msebbe
                    @msebbe
                    Ok thanks for your effort :+1:
                    When compiling I get this error below. I think this should be quiet easy to fix but I dont understand this language yet :confused:
                    sketch_jul03a.ino: In function 'void loop()':
                    sketch_jul03a:49: error: 'timerStart' was not declared in this scope
                    sketch_jul03a:54: error: 'timerStart' was not declared in this scope
                    • M msebbe
                      @msebbe
                      B Offline
                      B Offline
                      BulldogLowell
                      @msebbe
                      try inserting:
                      unsigned long timerStart;
                      to the header in the next line following:
                      • M Offline
                        M Offline
                        msebbe
                        Thanks that worked, however nothing happends when I test by using the door bell. I will investigate this when I get home on monday and stick to my old sketch until then .
                        • B Offline
                          B Offline
                          BulldogLowell
                          and you cn try this:
                          #define CHILD_ID 3
                            gw.begin();
                            // 433mhz Part
                              if (tripped)
                                gw.send(msg.set(true));
                              gw.send(msg.set(false));
                              tripped = false;
                          • B BulldogLowell
                            #define CHILD_ID 3
                              gw.begin();
                              // 433mhz Part
                                if (tripped)
                                tripped = false;
                            M Offline
                            M Offline
                            msebbe
                            #define CHILD_ID 3
                              gw.begin();
                              // 433mhz Part
                                if (tripped)
                                tripped = false;
                            Hmm, still nothing. It seems to be the 433mhz reciver part that is not working.
                            12.1k
