  3. Battery Sensor v 1.0 PCB
56 Posts 9 Posters 44.4k Views 3 Watching
  • BSoftB BSoft
    Ok, since sma antenna is more power demanding and works ok, maybe capacitor isn't solution.
    But i get better than 30 feet on zigzag antenna, maybe you have a not so perfect pcb unit (nRF). It is nice and residue clean?
    clippermiamiC
    clippermiamiC
    clippermiami
    @BSoft I've tried several different ones, theyt all look clean, no "gunk" or anything. I even tried taking it off the board and putting it on a extension cable, same results.Yeah, 30 feet seems a bit of a drag :)
    john
    • clippermiamiC clippermiami
      @BSoft re: Capacitor Bypass. I assume you are talking about the 4.7uFd cap between the Vcc and Gnd on the radio? If so its been installed from the get-go, its part of the design and is within millimeters of the NRF connector.
      BSoftB
      BSoftB
      BSoft
      Yes it is!
      Sorry i wasn't aware of 4.7uF presence.
      You could add more since it as been reported as better (220µF), check here: link text
      clippermiamiC 1 Reply Last reply
      • BSoftB BSoft
        Yes it is!
        clippermiamiC
        clippermiamiC
        clippermiami
        @BSoft Interesting discussion. Bottom line seem to be that 4.7 uF doesn't do much, the more the merrier then.
        • Z
          Z
          Zeph
          It's not just about capacity, it's about using a capacitor with low ESR.
          • Z
            Z
            Zeph
            Are you trying different orientations of the antenna? While I've not seen any spec's for the cheap module antenna ("7" shape or zigzag), I think I recall seeing reference to a pattern with two peak lobes and two nulls for another nRF24L01+ or nRF51822 based module. It's unlikely that the antenna is omnidirectional. (I don't know if the antenna also has polarization issues, another possibility).
            • Z Zeph
              clippermiamiC
              clippermiamiC
              clippermiami
              @Zeph I changed orientation buy door of "incidentally" , I held the unit up over my head to see if I got updates and I did, more often than just sitting on the counter but still not all the time. In this case the antennas would have been vertical rather than horizontal. Puzzling to be sure.
              • axillentA
                axillentA
                axillent
                about capacitor for radio. Attached you can see picture from one of my successful project
                capacitor is tantalum 22uF soldered directly to pins of the module, from the side of module PCB
                you can see capacitor as a small yellow box on top of the 8 pin radio connector
                sense and drive
                • axillentA axillent
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  @axillent Do you have a feel for the range of this rig? If this is the answer I'll get the capacitor and mod every radio :)
                  My Gateway has the SMA antenna on it and is less than 30 feet, and one interior wall, from the sensor and it doesn't work. When I bring the sensor to within about 10-12 feet it works every time but out at 20+ feet it fails almost every time. Its hard to believe that there is so little range
                  I've tried a number of things:
                  (a) several different radios - no change
                  (b) remove the radio and place it on a 8 inch cable to get away from the ground plane - no change;
                  (c) jumpered around the up-regulator (i.e. everything direct connected to battery) - no change;
                  (d) radio with SMA antenna - works every time but the battery consumption goes through the roof. In 12 hours with the SMA antenna the battery dropped 0.12 V versus 0.04 V in 24 hours with the regular radio. The AMP on the antenna version consumes a lot of juice.
                  Puzzlement :)
                  axillentA 1 Reply Last reply
                    Puzzlement :)
                    axillentA
                    axillentA
                    axillent
                    @clippermiami My distances are not too long, Just measured - this particular device is ranged 5m with one wall on the way to gateway
                    you have to distinguish radio with SMA **without **PA&LNA and radio **with **SMA and with PA&LNA
                    last one have an additional chip to amplify radio signal both way
                    radio without PA & LNA with SMA can sometimes be worse comparing to radio with PCB antenna
                    it depends on how well external antenna is aligned by frequency and impedance
                    List of your actions have radio channel tuning missed
                    sense and drive
                      clippermiamiC
                      clippermiamiC
                      clippermiami
                      wrote on last edited by clippermiami
                      #32
                      @axillent This SMA unit has the PA on it. The radio channel is the default for everything.
                      You distance is similar to mine, about 4.5-5 meters with one wall and it works. Beyond that NADA :)
                        axillentA
                        axillentA
                        axillent
                        #33
                        @clippermiami
                        works and works the best way are different things, If you live far from big cities probably it make no sense.
                        Otherwise it is recommended to run network scan from RF24 examples to find less busy channel at your location.
                        sense and drive
                          @clippermiami
                          clippermiamiC
                          clippermiamiC
                          clippermiami
                          @axillent The wireless channel is the one thing I hadn't investigated as yet so i will. I suppose it could be congested around here.
                          • clippermiamiC
                            clippermiamiC
                            clippermiami
                            I ran the scanner but got page after page of:
                                 RF24/examples/scanner/
                                 Scanning all available frequencies...Scan completed.
                            My radio is configured exactly as described although I will admit i just loaded the sketch to the sensor board and ran it on there rather than set up a special build just for that.
                              axillentA
                              axillentA
                              axillent
                              wrote on last edited by hek
                              #36
                              @clippermiami do not knew why but there are a few versions of this example
                              try this one
                              sorry, do not knew how to insert a code here
                               Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
                               Copyright (c) 2012 Greg Copeland
                               * Channel scanner
                               * Example to detect interference on the various channels available.
                               * This is a good diagnostic tool to check whether you're picking a
                               * good channel for your application.
                               * Inspired by cpixip.
                               * See http://arduino.cc/forum/index.php/topic,54795.0.html
                              #include "RF24.h"
                              #include "printf.h"
                              // Only display active frequencies
                              static const bool activeOnly = true ;
                              // Hardware configuration
                              // Set up nRF24L01 radio on SPI bus plus pins 8 & 9
                              RF24 radio(9,10);
                              // Channel info
                              const short num_channels = 128;
                              short values[num_channels];
                              uint8_t signalMeter[55] ;
                              // Setup
                              void setup(void)
                                // Print preamble
                                printf_begin();
                                printf("\n\rRF24/examples/scanner/\n\r");
                                // Setup and configure rf radio
                                radio.begin();
                                radio.powerUp() ;
                                radio.setAutoAck(false);
                                // Get into standby mode
                                radio.openReadingPipe( 0, 0xFFFFFFFFFFULL ) ;
                                //  radio.setDataRate( RF24_250KBPS ) ; // may fallback to 1Mbps
                                radio.setDataRate( RF24_1MBPS ) ; // may fallback to 1Mbps
                                radio.startListening() ;
                                radio.stopListening() ;
                              // Loop
                              void loop(void)
                                // Clear measurement values
                                memset( values, 0x00, num_channels ) ;
                                printf( "Scanning all available frequencies..." ) ;
                                // Repeatedly scan multiple channels
                                for( int channel=0 ; channel < num_channels; channel++ ) {
                                  radio.setChannel( channel ) ;
                                  // Amplify the signal based on carrier bandwidth
                                  int ampFactor ;
                                  for( int amp=0; amp <= 300; amp++ ) {
                                    // Alternate data rates
                                    ampFactor = amp%3 ;
                                    switch( ampFactor ) {
                                    case 0:
                              	break ;
                                    case 1:
                              	break ;
                                    default:
                              	radio.setDataRate( RF24_2MBPS ) ;
                              	break ;
                                    // Listen for carrier
                                    ampFactor++ ;
                                    delayMicroseconds( 6 - ampFactor ) ;
                                    // Was carrier detected? If so, signal level based on bandwidth
                                    if( radio.testRPD() ) {
                              	values[channel] += ampFactor ;
                                // Now display our results
                                printf( "Scan completed.\r\n" ) ;
                                  if( !activeOnly || (activeOnly && values[channel] > 0) ) {
                                    memset( signalMeter, '*', min( values[channel], 54 ) ) ;
                                    signalMeter[min(values[channel], 54)] = 0x00 ;
                                    printf( "%03d (%4dMhz): %02d - %s\r\n",
                              	      channel,
                              	      2400+channel,
                              	      values[channel],
                              	      signalMeter ) ;
                                    // Reset the scanned value since its already beend displayed
                                    values[channel] = 0 ;
                              // vim:ai:cin:sts=2 sw=2 ft=cpp
                              sense and drive
                                try this one
                                 * Channel scanner
                                #include "RF24.h"
                                #include "printf.h"
                                RF24 radio(9,10);
                                // Channel info
                                // Setup
                                void setup(void)
                                  // Print preamble
                                  printf_begin();
                                  radio.begin();
                                  radio.powerUp() ;
                                // Loop
                                void loop(void)
                                    int ampFactor ;
                                      ampFactor = amp%3 ;
                                      case 0:
                                	break ;
                                      case 1:
                                	break ;
                                      default:
                                	break ;
                                      ampFactor++ ;
                                	      channel,
                                	      2400+channel,
                                	      values[channel],
                                	      signalMeter ) ;
                                clippermiamiC
                                clippermiamiC
                                clippermiami
                                @axillent First thing I see is that this version has the radio on pins 8,9 whereas the version I used has it on pins 9,10 which is where it is in my hardware.
                                  axillentA
                                  axillentA
                                  axillent
                                  @clippermiami That is a good point. But something tells me that you do need an assistance to adjust this code to your hardware :)
                                  sense and drive
                                    clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    @axillent I won't deny that, but it seems simple enough. :)
                                    • clippermiamiC
                                      clippermiamiC
                                      clippermiami
                                      #40
                                      So i breadboarded a Nano and a NRFL2401 with a PA and antenna, uploaded the scanner sketch and this is what I got: I'm using the default radio channel from the distribution library.
                                       000 (2400Mhz): 96 - ******************************************************
                                       001 (2401Mhz): 100 - ******************************************************
                                       002 (2402Mhz): 95 - ******************************************************
                                       003 (2403Mhz): 99 - ******************************************************
                                       004 (2404Mhz): 98 - ******************************************************
                                       005 (2405Mhz): 104 - ******************************************************
                                       006 (2406Mhz): 91 - ******************************************************
                                       007 (2407Mhz): 95 - ******************************************************
                                       008 (2408Mhz): 98 - ******************************************************
                                       009 (2409Mhz): 96 - ******************************************************
                                       010 (2410Mhz): 96 - ******************************************************
                                       011 (2411Mhz): 86 - ******************************************************
                                       012 (2412Mhz): 89 - ******************************************************
                                       013 (2413Mhz): 94 - ******************************************************
                                       014 (2414Mhz): 95 - ******************************************************
                                       015 (2415Mhz): 92 - ******************************************************
                                       016 (2416Mhz): 93 - ******************************************************
                                       017 (2417Mhz): 92 - ******************************************************
                                       018 (2418Mhz): 99 - ******************************************************
                                       019 (2419Mhz): 85 - ******************************************************
                                       020 (2420Mhz): 99 - ******************************************************
                                       021 (2421Mhz): 96 - ******************************************************
                                       022 (2422Mhz): 90 - ******************************************************
                                       023 (2423Mhz): 98 - ******************************************************
                                       024 (2424Mhz): 85 - ******************************************************
                                       025 (2425Mhz): 99 - ******************************************************
                                       026 (2426Mhz): 100 - ******************************************************
                                       027 (2427Mhz): 95 - ******************************************************
                                       028 (2428Mhz): 95 - ******************************************************
                                       029 (2429Mhz): 90 - ******************************************************
                                       030 (2430Mhz): 95 - ******************************************************
                                       031 (2431Mhz): 96 - ******************************************************
                                       032 (2432Mhz): 95 - ******************************************************
                                       033 (2433Mhz): 91 - ******************************************************
                                       034 (2434Mhz): 93 - ******************************************************
                                       035 (2435Mhz): 97 - ******************************************************
                                       036 (2436Mhz): 104 - ******************************************************
                                       037 (2437Mhz): 99 - ******************************************************
                                       038 (2438Mhz): 92 - ******************************************************
                                       039 (2439Mhz): 96 - ******************************************************
                                       040 (2440Mhz): 94 - ******************************************************
                                       041 (2441Mhz): 100 - ******************************************************
                                       042 (2442Mhz): 92 - ******************************************************
                                       043 (2443Mhz): 100 - ******************************************************
                                       044 (2444Mhz): 110 - ******************************************************
                                       045 (2445Mhz): 92 - ******************************************************
                                       046 (2446Mhz): 111 - ******************************************************
                                       047 (2447Mhz): 99 - ******************************************************
                                       048 (2448Mhz): 98 - ******************************************************
                                       049 (2449Mhz): 93 - ******************************************************
                                       050 (2450Mhz): 97 - ******************************************************
                                       051 (2451Mhz): 99 - ******************************************************
                                       052 (2452Mhz): 93 - ******************************************************
                                       053 (2453Mhz): 96 - ******************************************************
                                       054 (2454Mhz): 93 - ******************************************************
                                       055 (2455Mhz): 94 - ******************************************************
                                       056 (2456Mhz): 106 - ******************************************************
                                       057 (2457Mhz): 101 - ******************************************************
                                       058 (2458Mhz): 94 - ******************************************************
                                       059 (2459Mhz): 106 - ******************************************************
                                       060 (2460Mhz): 91 - ******************************************************
                                       061 (2461Mhz): 96 - ******************************************************
                                       062 (2462Mhz): 98 - ******************************************************
                                       063 (2463Mhz): 100 - ******************************************************
                                       064 (2464Mhz): 107 - ******************************************************
                                       065 (2465Mhz): 101 - ******************************************************
                                       066 (2466Mhz): 93 - ******************************************************
                                       067 (2467Mhz): 90 - ******************************************************
                                       068 (2468Mhz): 102 - ******************************************************
                                       069 (2469Mhz): 103 - ******************************************************
                                       070 (2470Mhz): 95 - ******************************************************
                                       071 (2471Mhz): 102 - ******************************************************
                                       072 (2472Mhz): 99 - ******************************************************
                                       073 (2473Mhz): 94 - ******************************************************
                                       074 (2474Mhz): 97 - ******************************************************
                                       075 (2475Mhz): 105 - ******************************************************
                                       076 (2476Mhz): 97 - ******************************************************
                                       077 (2477Mhz): 92 - ******************************************************
                                       078 (2478Mhz): 103 - ******************************************************
                                       079 (2479Mhz): 94 - ******************************************************
                                       080 (2480Mhz): 98 - ******************************************************
                                       081 (2481Mhz): 99 - ******************************************************
                                       082 (2482Mhz): 103 - ******************************************************
                                       083 (2483Mhz): 98 - ******************************************************
                                       084 (2484Mhz): 89 - ******************************************************
                                       085 (2485Mhz): 97 - ******************************************************
                                       086 (2486Mhz): 94 - ******************************************************
                                       087 (2487Mhz): 97 - ******************************************************
                                       088 (2488Mhz): 92 - ******************************************************
                                       089 (2489Mhz): 101 - ******************************************************
                                       090 (2490Mhz): 98 - ******************************************************
                                       091 (2491Mhz): 99 - ******************************************************
                                       092 (2492Mhz): 92 - ******************************************************
                                       093 (2493Mhz): 88 - ******************************************************
                                       094 (2494Mhz): 95 - ******************************************************
                                       095 (2495Mhz): 92 - ******************************************************
                                       096 (2496Mhz): 95 - ******************************************************
                                       097 (2497Mhz): 95 - ******************************************************
                                       098 (2498Mhz): 90 - ******************************************************
                                       099 (2499Mhz): 100 - ******************************************************
                                       100 (2500Mhz): 94 - ******************************************************
                                       101 (2501Mhz): 107 - ******************************************************
                                       102 (2502Mhz): 90 - ******************************************************
                                       103 (2503Mhz): 95 - ******************************************************
                                       104 (2504Mhz): 105 - ******************************************************
                                       105 (2505Mhz): 99 - ******************************************************
                                       106 (2506Mhz): 101 - ******************************************************
                                       107 (2507Mhz): 100 - ******************************************************
                                       108 (2508Mhz): 103 - ******************************************************
                                       109 (2509Mhz): 99 - ******************************************************
                                       110 (2510Mhz): 99 - ******************************************************
                                       111 (2511Mhz): 92 - ******************************************************
                                       112 (2512Mhz): 90 - ******************************************************
                                       113 (2513Mhz): 96 - ******************************************************
                                       114 (2514Mhz): 102 - ******************************************************
                                       115 (2515Mhz): 96 - ******************************************************
                                       116 (2516Mhz): 91 - ******************************************************
                                       117 (2517Mhz): 98 - ******************************************************
                                       118 (2518Mhz): 95 - ******************************************************
                                       119 (2519Mhz): 101 - ******************************************************
                                       120 (2520Mhz): 104 - ******************************************************
                                       121 (2521Mhz): 93 - ******************************************************
                                       122 (2522Mhz): 98 - ******************************************************
                                       123 (2523Mhz): 98 - ******************************************************
                                       124 (2524Mhz): 96 - ******************************************************
                                       125 (2525Mhz): 95 - ******************************************************
                                       126 (2526Mhz): 94 - ******************************************************
                                       127 (2527Mhz): 96 - ******************************************************
                                      Which does not look much like the display at the reference: http://arduino.cc/forum/index.php/topic,54795.0.html
                                      and i'm not sure what its telling me other than some relative signal level data. Perhaps someone could help me interpret this :)
                                      Updagte:
                                      As it continues to run it shows significantly different values over time, some reaching as high as
                                       063 (2463Mhz): 84 - ******************************************************
                                       064 (2464Mhz): 89 - ******************************************************
                                       065 (2465Mhz): 97 - ******************************************************
                                       066 (2466Mhz): 201 - ******************************************************
                                       067 (2467Mhz): 252 - ******************************************************
                                       068 (2468Mhz): 300 - ******************************************************
                                       069 (2469Mhz): 284 - ******************************************************
                                      • clippermiamiC
                                        clippermiamiC
                                        clippermiami
                                        I'm about idea'd out. I put a 200 uF electrolytic directly on the Vcc and Gnd terminals of the radio module and it made no difference whatsoever ... the sensor fails to report beyond about 10 meters and one interior wall. That doesn't leave much upside.
                                        I'm at a loss at this point, I've tried different radio modules to no avail. I've taken the radio off the board ground plane to no avail.Thus far the only thing I've found that allows decent distance is a radio with the PA/SMA antenna and that simply eats battery. I can't make hide nor hair out of the scanner output ... the channel variation doesn't appear to be more than a few percent for the most part so it doesn't look like that's much of a solution.
                                        I admit to being curious if anyone has actually had these things work beyond the workbench :)
                                        YveauxY Z 2 Replies Last reply
                                          #42
                                          Maybe your house is just a lot bigger than ours :office: :laughing:
