  3. Not working code. Where is the error? (NFC gate opener)
nfc arduino ver
9 Posts 3 Posters 4.3k Views 1 Watching
    mmuukkii
    wrote on last edited by mmuukkii
    Hello All!
    I have a problem what makes my hair gray...
    I have a working MYSENSORS network with VERA3 at home.
    I have found out that our electronic gate should be controlled by NFC cards and/or VERA.
    I did my hardware which was actually not difficult.
    I used a Mini Pro 5V + Radio with step down regulator + RGB LED + RFID reader.+ relay.
    I used 2 sketches to integrate in one solution.
    The first one is from webnology and the another one is from here sample sketch.
    I uploaded both, and they worked without problem.
    Then I tried to integrate, and together they do not want to work, providing very strange result on the serial interface.
    The software should do the followings:
    • store the card data in the EEPROM of the Arduino
    • with master card it is possible to store new athorized cards and delet cards from eeprom
    • relay state should be represented in Vera
    • relay state should be changeable by Vera
    • relay should be closed for a given period (1 minute)
    • RGB LED is a common Anode LED
    In the future I would like to solve that VERA should be able to handle card info (delete or add).
    And now the working code (I marked out the problematic codes what makes the connection to VERA)::
      mmuukkii
      Sorry for the code format, but can somebody explain me how to include the whole code in readable format?
        enclose between 4 back-ticks ````
          mmuukkii
          My code between 4 backticks:
              @file     RfidAccessControlWithEepromStorage.ino
              @author   webnology gmbh
              @license  GPL v2 or later (see  ---> http://www.gnu.org/licenses/gpl-2.0.txt )
              The sketch is an RFID (access) control system that stores RFIDs to EEPROM.
              All RFID cards stored in EEPROM will be granted access, all others will be denied access.
              It is designed to work with Mifare Classic and Mifare Ultralight cards (no other cards have been tested).
              To store or delete RFIDs from EEPROM a 'MASTER' card is used. The UID of the master card
              is hardcoded in the sketch. It has to be a Mifare Classic 4 byte card. When the MASTER card is read by
              the reader the application will remain in MASTER MODE for 30 sec. It will include or exclude the next
              RFID card that is read. If the RFID is already stored in the EEPROM it will be erased (excluded), if the
              RFID is not in the EEPROM it will be stored (included) into the EEPROM.
              The EEPROM rfid storage is organised as following (example):
              |uidLength|uid byte|uid byte|uid byte|uid byte|uidLength|uid byte|uid byte|uid byte|uid byte|uidLength
              |   4     |   BE   |    23  |    2D  |   DE   |    4    |    AB  |    20  |   FE   |   2D   |   7
              |uid byte|uid byte|uid byte|uid byte|uid byte|uid byte|uid byte|uidLength|....|  end  |
              |    2B  |   BE   |    88  |    FE  |    20  |   EC   |   EC   |   4     |....|   0   |
              IMPORTANT: Set the EEPROMSize constant to your EEPROM size!!
                         Go to the setup() section and uncomment initializeEeprom(); Run the sketch and than comment again
                         the initializeEeprom();
              Note that you need the baud rate to be 115200 because we need to
              print out the data and read from the card at the same time!
          	webnology gmbh invests time and resources to provide open source software,
          	please refer to our website to support us.
          	  ----> http://www.webnology.ch
          	This sketch depends on the following library:
          	  ----> https://github.com/adafruit/Adafruit-PN532
          	Acknowledgements:
          	This is a sketch developed to work with the Adafruit PN532 NFC/RFID breakout board,
                  the wiring is explained at: ----> http://learn.adafruit.com/adafruit-pn532-rfid-nfc/breakout-wiring
          	you can buy it at the Adafruit store:
          	  ----> https://www.adafruit.com/products/364
          //INIT VARS
          #include <PN532_I2C.h>
          #include <PN532.h>
          // COMMON ANODE LEDs to indicate the status
          const uint8_t led_red = 6;
          const uint8_t led_green = 7;
          const uint8_t led_blue = 8;
          const boolean OFF = HIGH;
          const boolean ON = LOW;
          // Drived Pin definition
          const int lockPin = 5;           // (Digital 5) The pin that activates the relay/solenoid lock.
          boolean lockStatus;              // The Status will be stored here
          const int gateTime = 1000;       // Open time for circuit in milliseconds
          const int messageTime = 500;     // Message time (lit time for LED)
          // EEPROM
          const uint32_t EEPROMSize = 1023; //BE CAREFULL NOT TO EXCEED EEPROM SIZE OF YOUR ARDUINO
                                      //TO AVOID DAMAGING YOUR EEPROM!!!!!!!
          const uint32_t memBase = 512; // Start the storage of RFID from this address
          // MYSENSORS NETWORK SETUP
          //MyMessage lockMsg(CHILD_ID, V_LOCK_STATUS);
          // RFID MASTER, HARDCODED
          uint32_t uid_master = 347364468;
          uint32_t master_mode = 0;
          uint32_t master_mode_counter = 0;
          PN532_I2C pn532i2c(Wire);
          PN532 nfc(pn532i2c);
          // DEBUG
          boolean debug = true;
          //boolean debug = false;
          // Functions
          // set LEDs
          void led(uint8_t status=1){
            switch (status) {
              case 1:
                // error connecting pn532,	red green
                // error reading RFID
                digitalWrite(led_blue, OFF);
                digitalWrite(led_red, ON);
                digitalWrite(led_green, ON);
              case 2:
                // storage full			red green blue
                digitalWrite(led_blue, ON);
              case 3:
                // ready to read RFID		none
                digitalWrite(led_red, OFF);
                digitalWrite(led_green, OFF);
              case 4:
                // RFID authorized		green
               case 5:
                // RFID not authorized		red
               case 6:
                // RFID read MASTER		blue
                // inclusion/exclusion MODE
               case 7:
                // RFID included			blue green
                case 8:
                // RFID excluded			blue red
          //get RFID as int
          uint64_t getCardIdAsInt(uint8_t uid[],uint8_t uidLength){
            if (uidLength == 4) {
              // We probably have a Mifare Classic card ...
              uint32_t cardid = uid[0];
              cardid <<= 8;
              cardid |= uid[1];
              cardid <<= 8;
              cardid |= uid[2];
              cardid <<= 8;
              cardid |= uid[3];
              if(debug) {
                Serial.print("Seems to be a Mifare Classic card #");
                Serial.println(cardid);
              return cardid;
            else if (uidLength == 7)
              // We probably have a Mifare Ultralight card ...
              uint64_t cardid = 0;
              memcpy(&cardid, uid, sizeof(uid));
              if(debug) {
                Serial.println("Seems to be a Mifare Ultralight card #");
                // Print function does not support 64 bit
              if(debug) {
                for(uint8_t i = 0; i < uidLength; i++) {
                  Serial.print(" byte ");Serial.print(i);Serial.print(" = ");
                  Serial.print(uid[i],HEX);
                  Serial.println(" ");
              return cardid;
          // EEPROM Functions
          // erase EEPROM
          void initializeEeprom() {
            Serial.println("------------------------------------------------------");
            Serial.println("Initializing EEPROM by erasing all RFIDs              ");
            Serial.println("Setting values of EEPROM addresses to 0               ");
            Serial.println("EEPROM max memory size:                               ");
            Serial.println(EEPROMSize);
            byte zero  = 0;
            for(uint32_t adr = memBase; adr <= EEPROMSize; adr++) {
              gw.saveState(adr, zero);
          // printEeprom()
          // Print the EEPROM to serial output
          // for debugging
          void printEeprom(){
            uint32_t ads = memBase;
            while(ads <= EEPROMSize) {
              byte output = gw.loadState(ads);
              if((ads % 10) == 0  ) Serial.println(" ");
              Serial.print(ads);Serial.print(" => ");Serial.print(output,HEX); Serial.print("   ");
              ads++;
          // findRfidInEeprom(uidLength, uid)
          // looks for matching RFID
          // returns the address of the first byte of RFID (length indication) if found
          // returns -1 if NOT found
          // returns -2 if error
          int32_t findRfidInEeprom(uint8_t uidLength, uint8_t uid[]) {
            uint32_t key = memBase;
            byte val = gw.loadState(key);
            boolean match = false;
            if(debug) Serial.print(" key ");Serial.println(key);
            if(debug) Serial.print(" val ");Serial.println(val);
            if(debug) Serial.println(" Finding in EEPROM ...  ");
            if(val == 0 && key == 0) {
              if(debug) Serial.println("EEPROM is empty ");
              return -1;
            else {
              if(debug) Serial.println("in else ");
              while(val != 0)
                if(key >= EEPROMSize)
                  if(debug) Serial.println("ERROR: EEPROM STORAGE MESSED UP! Return -2");//this should not happen! If so initialize EEPROM
                  return -2;
                if(val == uidLength) {
                  // check if uid match the uid in EEPROM
                  uint32_t uidAddress = key + 1;
                  match = true;
                  //compare uid bytes
                  for(byte i = 0; i < uidLength; i++) {
                    byte uidVal = gw.loadState(( uidAddress + i));
                    //the first byte of uidVal is the next address
                    if(uidVal != uid[i]) {
                      //got to next key
                      match = false;
          	    // in case no break => all bytes same
                  if(match) {
                    if(debug) {Serial.println("RFID uid matching in Address = "); Serial.println(key);}
                    return key;
                key = key + val + 1;
            if(debug) { Serial.println("No RFID match in EEPROM, returning -1"); }
            return -1;
          // deleteRfidfromEeprom(address, uidLength)
          // delete the RFID from EEPROM
          // sets the UID values to 0
          // in the EEPROM structure there will be a "hole" with zeroes
          // we are not shifting the addresses to avoid unnecessary writes
          // to the EEPROM. The 'hole' will be filled with next RFID
          // storage that has the same uidLength
          //  BUG if rfid was last rfid in eeprom, length is not set to 0 => not needed because by formatting eeprom all is set to 0
          void deleteRfidfromEeprom(uint32_t address, uint8_t uidLength) {
            byte zero = 0;
            if(debug) Serial.println("Erasing RFID");
            for(uint8_t m = 1; m <= uidLength; m++) {
              uint32_t adr = address + m;
              if(debug) {
                Serial.print("Address: ");
                Serial.print(adr);
            if(debug) { printEeprom(); }
          // getEndOfRfidsChainInEeprom(uidLength)
          // returns the address of the end of the Rfids chain stored in the EEPROM
          // returns -1 if no space left
          // returns -2 if unexpected error
          int32_t getEndOfRfidsChainInEeprom(uint8_t uidLength) {
              return key;
            else {
              // if length byte indicator is 0 it means it is the end of the RFIDs stored, last RFID stored
              while(val != 0) {
                if(key > EEPROMSize) {
                  Serial.println("ERROR: EEPROM STORAGE MESSED UP! EXITING STORAGE READ");
                  return -2;
                key = key + val +1;
              if((key + uidLength) > EEPROMSize) {
                Serial.println("Not enough space left in EEPROM to store RFID");//the RFID to be appended at the end of the storage chain exeeds the EEPROM length
                return -1;
              else return key;
          // getFreeEepromStorageFragment(uint8_t uidLength)
          // return the address where to store the RFID
          // with the rfidLength specified.
          // Instead of just appending the RFID to the end of
          // the storage we look for an erased RFID space and
          // fill this
          // return address
          // return -2 if error
          // return -1 if no free storage address found
          int32_t getFreeEepromStorageFragment(uint8_t uidLength) {
            byte val = gw.loadState(key); //holds the uidLength stored in EEPROM
            boolean free = false;
              // EEPROM empty, use the address at key = memBase
              return key;
            else {
              //loop till the end of storage chain indicated by a zero value in the key position
              while(val != 0) {
                  return -2;
                // check if uidLength  match the uidLength in EEPROM
                  uint32_t uidAddress = key +1;
                  free = true;
                  //check if uid bytes are all zero => free storage fragment
                    if(uidVal != 0) {
                      //got to next key
                      free = false;
                  // in case no break => all bytes have zero value => free fragment
                  if(free) {
                    return key;
              return -1;
          // getEepromStorageAddress(uint8_t uidLength)
          // combination of getFreeEepromStorageFragment
          // and getEndOfRfidsChainInEeprom
          // return address
          int32_t getEepromStorageAddress(uint8_t uidLength) {
            int32_t fragment = getFreeEepromStorageFragment(uidLength);
            if(debug) {
              Serial.print("getFreeEepromStorageFragment returned ");Serial.print(fragment);
            // free fragment found
            if(fragment >= 0) {
              return fragment;
            // error returned
            else if (fragment == -2) {
              return fragment;
            // no free fragment available
            // check if space available at end of rfid storage chain
            else if (fragment == -1) {
              int32_t append = getEndOfRfidsChainInEeprom(uidLength);
              if(debug) {
                Serial.print("getEndOfRfidsChainInEeprom returned ");Serial.print(append);
                return append;
            // should never occur, return error
            else {
              return -2;
          // writeRfidToEeprom(addrees,uidlength,uid)
          // write RFID to EEPROM
          void writeRfidToEeprom(uint32_t StoragePositionAddress, uint8_t uidLength, uint8_t uid[]) {
            // Writing into first free address the length of the RFID uid
            gw.saveState(StoragePositionAddress, uidLength);
            // Writing into the following addresses the RFID uid values (byte per byte)
            uint32_t uidBytePosition = StoragePositionAddress +1; //next position after addressByte which contains the uidLength
            for(uint8_t r=0; r < uidLength; r++) {
              gw.saveState(uidBytePosition, uid[r]);
              uidBytePosition++;
          // setLockState(state, send)
          // unlocks the door
          void setLockState(bool state, bool send){
            if (state)
               if(debug) Serial.println("open lock");
               if(debug) Serial.println("close lock");
            if (send)
          //    gw.send(lockMsg.set(state));
            digitalWrite(lockPin, state);
          // incomingMessage(MyMessage)
          // handling incoming message
            if (message.type==V_LOCK_STATUS) {
              // Change relay state
               setLockState(message.getBool(), false);
               if(debug) {// Write some debug info
                 Serial.print("Incoming lock status:");
          // SETUP
          void setup(void) {
            pinMode(led_blue,  OUTPUT);
            pinMode(led_red,   OUTPUT);
            pinMode(led_green, OUTPUT);
            pinMode(lockPin,   OUTPUT);
            if(debug) Serial.println("Hello!");
            nfc.begin();
            if(debug) Serial.println("nfc.begin OK");
            uint32_t versiondata = nfc.getFirmwareVersion();
            if (! versiondata) {
              led(1);
              if(debug) Serial.print("Didn't find PN53x board");
              while (1);
            if(debug) {
              Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
              Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
              Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
            // Set the max number of retry attempts to read from a card
            // This prevents us from waiting forever for a card, which is
            // the default behaviour of the PN532.
            nfc.setPassiveActivationRetries(0x3);
            // Befor you run this sketch the first time
            // uncoment the following initializeEeprom();
            // to clear the EEPROM neccessary to be shure
            // that all EEPROM values used for the RFID
            // storage are initialized with 0.
            // Connect to the serial to check if all values are 0,
            // then comment the functions again and start using
            // the Rfid access control system
            //initializeEeprom();
            // configure board to read RFID tags
            nfc.SAMConfig();
            // Init mysensors library
          //  gw.begin(incomingMessage);
          //  gw.sendSketchInfo("RFID Makkai Gate Lock", "1.0");
          //  gw.present(CHILD_ID, S_LOCK);
            lockStatus = true;               // this is the default mode
            setLockState( lockStatus, true); // Now set the state and send it to controller
            led(3);
            if(debug) Serial.println("Waiting for an ISO14443A Card ...");
            if(debug) Serial.println("Setup finished.");
          //MAIN
          void loop(void) {
          //  gw.process(); // Process incomming messages
            uint8_t success;
            uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID, 7 bit max
            uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
            uint64_t cardid;                          // UID as int
            // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
            // 'uid' will be populated with the UID, and uidLength will indicate
            // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
            success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
            // MASTER MODE?
            if(master_mode == 1) {
              //stay in master mode for max 30 seconds
              master_mode_counter = master_mode_counter + 1;
              if(master_mode_counter >= 60) {//reset master mode after 30 sec no RFID was inserted
                master_mode= 0;
              if(debug) {Serial.print("MASTER MODE "); Serial.println(master_mode_counter);}
              led(6);
              delay(200);
            //got rfid?
            if (success) {
                // Display some basic information about the card
                if(debug) {
                  Serial.println("Found an ISO14443A card");
                  Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
                  Serial.print("  UID Value: ");nfc.PrintHex(uid, uidLength);
                cardid = getCardIdAsInt(uid,uidLength);
                //is MASTER
                if (cardid == uid_master) {
                  master_mode = 1;
                  led(6);
                  if(debug) Serial.println("MASTER detected, going into MASTER MODE  ");
                // is not MASTER
                else {
                  int32_t findUid = findRfidInEeprom( uidLength, uid);
                  // is MASTER MODE, include or exclude RFID from storage
                    // card rfid already exists so exlude it from storage
                    if( findUid != -1) {
                      if(debug) {Serial.println("removing card from eeprom"); Serial.println(" ");}
                      deleteRfidfromEeprom(findUid, uidLength);
                      led(8);
                      delay(messageTime);
                    // card rfid not found in storage so include it
                    else if (findUid == -1) {
                      // check if space to store rfid available
                      int32_t storageAddress = getEepromStorageAddress(uidLength);
                      // storage available
                      if(storageAddress >= 0) {
                        if(debug) {Serial.print("storing card in position = ");Serial.print(storageAddress);Serial.println(" ");}
                        // storing card
                        writeRfidToEeprom( storageAddress, uidLength, uid);
                        led(7);
                        delay(messageTime);
                      else { // no storage space available or error
                        if(debug) Serial.println("memory full or error");
                        led(2);
                        delay(messageTime);
                    master_mode = 0;
                  // no MASTER MODE, authorise or deny door access
                  else {
                    // card authorised
                      // open door and green light on for a short period
                     if(debug) Serial.println("Card authorised, open door");
                     setLockState(!lockStatus, true);
                     led(4);
                     delay(gateTime);
                     setLockState(lockStatus, true);
                     if(debug) Serial.println("Close door");
                    else {
                      // deny access and red light on
                      if(debug) Serial.println("Card not authorised, access denied");
                      led(5);
                      delay(messageTime);
          led(3);
          //did not get RFID, looping till RFID inserted
            mmuukkii
            This code is working now, but does not make any connection to the Gateway. Moreover, if I uncomment the neccessary lines, it starts to provide strange behaviour on the serial port.
              mmuukkii
              So more info:
              1. I run 1.0.5 Arduino on WIN7
              2. HW:
              • Arduino Mini Pro 5V/16MHz powering from PC via USB and with a good quality step-down regulator (12V->5V) at the gate
              • Mifare RFID reader from ELECHOUSE using SDA -> A4 & SCL -> A5 connections
              • Radio: NRF24L01+ with adapter on normal mysensor radio connections
              • 2 Relay Module on D4 & D5
              • Common Anode RGB LED with 220 Ohm resistors on D6, D7 and D8
              1. I have a MiCasaVerde Vera3 with UI7
              2. MySensor Gateway: Arduino UNO + high gain antenna radio modul + ethernet shield
              3. My MySensor network works fine, I have humidity and temp sensor separately and a switch. actuator. All sensors and Gateway uses v1.41 sketches.
              This project would be an extra control for the electronic gate opener what I have already installed on the garden gate. First I downloaded the RFID sketch from MySensors.org, tried and it worked fine. Without any problem I could immediately include into my network after a short setup, and I could use the card to open and to close.
              Next I had to modify the code a bit to close back automatically after a given time (200 ms), because the gate controlling system require only a shor momentary switch, an impulse. It took 10 minutes, worked, I was happy.
              Than I realised that I can not manage the cards so easy, and found a skech on the net (see reference in the beginning of the attached code) for storing the card data in the eeprom. Fortunately this Arduino has 1 KB, that is far enough for card data AND MySensor's data.
              First I edited and modified a bit of this, the EEPROM user RFID sketch, what was really worked perfectly without using the MySensors network. The problems started when I tried to merege the two sketches. First I had to cut off eeprom.h; and all related functions had to be changed to the MySensors functions for using EEPROM.
              I could follow up everything in the SERIAL PORT. Both sketches separately were running without error. They open and closed, read the cards how I wanted. After integrating the two sketches I could not use it anymore. So I commented out all MySensor related row, then I tried to row-by-row find solution for problem, but no result.
              The above code now working for the NFC part with small eeprom related problem, but does not connect to the MySensors Gateway. Serial monitor showed strange behaviour: It should start normaly with "Hello", but if I uncomment gw lines, it start to put out a lot of HHHHHHHH with strange periodicity.
              I also tried to switch the DEBUGGER on in the MyConfig.h but it is not clear for me what to do, because at the moment I have #define DEBUG there without commenting, but there is no more info on the serial.
              I just wonder If I can manage a real nice system, where
              • I can include and delete cards remotely (using VERA3),
              • I can control the gate remotely, and
              • the system remains work if the Gateway or Vera is down.
                wrote on last edited by hek
                A wild guess is that you're running out of stack-space == Hell breaks lose.
                See if you can optimize code and reduce the allocations where possible.
                You can start by moving all static strings to PROGSPACE.
                  mmuukkii
                  @hek
                  That hint was working. After I reduced the code cutting out memory eaters, the code now works !!!
                  This was the first time when I run into such problem. However I wanted to expand the code more putting additional functionalities.
                  I will publish the final version here when it will be ready.
                  • T
                    tetenfer
                    wrote on last edited by tetenfer
                    hello all ,
                    @mmuukkii your code really looks fantastic , but you said that bug , had you finished? I am not able to fix it. thx
                    12.5k
