  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 50.4k Views 4 Watching
  • CaptainZapC
    CaptainZapC
    CaptainZap
    @Dwalt @m26872 Thanks for the feedback, I did do that on the Vera unit. I've even removed the plugin files and re-did everything. I even, and this is a bit extreme, cleared the eprom on the gateway and reflashed it. None of it worked, I really have no clue what to do next. I'm open to every suggestion :D
    DwaltD 1 Reply Last reply
    • CaptainZapC CaptainZap
      DwaltD
      DwaltD
      Dwalt
      @CaptainZap It your sketch you have this line:
      #define ONE_WIRE_BUS 14
      What pin is your Dallas sensor connected to?
      CaptainZapC 1 Reply Last reply
      • m26872M
        m26872M
        m26872
        First make sure a pure repeater node is working. With only the gw.process() to run, it should be fast to enough catch any new inlusion before the gateway. With a proper range of course. Clear the sensors eeprom and Vera-device before reinclusion, but you should not need to do anything with the gateway.
        • DwaltD Dwalt
          CaptainZapC
          CaptainZapC
          CaptainZap
          wrote on last edited by CaptainZap
          #45
          One sensor is connected to A0(14) the other is connected to D5 as it can be seen in my last sketch. Temperature reporting worked on, in my original sketch, however the sketch wasn't perfect so I improved it based on feedback.
          @m26872 The sensor is on a breadboard 5cm from the gateway, and I'm not sure about the repeater part...
          • CaptainZapC
            CaptainZapC
            CaptainZap
            Well since nobody knew what the problem is I thought I would re-flash my first sketch which was working properly... however after doing it it no longer works... this is blowing my mind away. I don't understand why that would be, as the only changes I've done are listed in this thread, major one was that I upgraded lib to 1.4.1 from 1.4. Anyone has any ideas cause this is driving me crazy now :(
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @CaptainZap would suggest to clear the eeprom
              • m26872M
                m26872M
                m26872
                Did you ever get a repeater-only node to work in your mys network ?
                • CaptainZapC
                  CaptainZapC
                  CaptainZap
                  @Moshe-Livne @m26872 : I did clear the eprom, I've tried everything I could think of... I'm not quite sure if the repeater works, so far everything is at the breadboard state, so I was pretty much prototyping.
                    @AWI Yes I want all my nodes to be repeaters, and that's exactly what I want to do :) However I use a Vera as my controller, and there you are supposed to have a parent node for your arduino sensor, followed by child devices for sensors/relays etc. Right now I have 3 child devices for the My Sensors plugin which isn't right.
                    m26872M
                    m26872M
                    m26872
                    Why?
                    Unless you plan expand your network in the near future, think the increased complexity just will give you trouble.
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @CaptainZap did you clear the eeprom before loading the sketch that used to work?
                      • petoulachiP
                        petoulachiP
                        petoulachi
                        wrote on last edited by petoulachi
                        #52
                        I've read this thread with interest because I want to make my Motion/Temp sensor using Dallas.
                        Adapting the given code was quite easy (well I guess as I have not tested it for now :D ), I only have changed gw.wait with gw.sleep, because if I understand it correctly, gw.sleep put the sensor in sleep mode which is a bit better for battery :
                        #include <OneWire.h>
                        #define CHILD_ID_S1 1   // Id of the sensor child
                        #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
                        #define CHILD_ID_T1 2 //CHILD ID for temp
                        DallasTemperature DallasSensors(&oneWire);
                        float lastTemperature ;
                        unsigned long SLEEP_TIME = 30000; // Sleep time between reports (in milliseconds)
                        unsigned long lastRefreshTime = 0;
                        boolean lastTripped = 0;
                        // Initialize motion message
                        MyMessage motionMsg(CHILD_ID_S1, V_TRIPPED);
                        MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
                           // Startup OneWire Temp Sensors
                            DallasSensors.begin();
                            DallasSensors.setWaitForConversion(false);
                          gw.begin();
                          gw.sendSketchInfo("Motion and Temperature Sensor", "1.0");
                          gw.present(CHILD_ID_S1, S_MOTION);
                          gw.present(CHILD_ID_T1, S_TEMP);
                        	// Process incoming messages (like config from server)
                        	// Read digital motion value
                        	if (lastTripped != tripped )
                        		Serial.println("Tripped");
                        		gw.send(motionMsg.set(tripped?"1":"0")); // Send tripped value to gw
                        		lastTripped=tripped;
                        	boolean bNeedRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                        	if (bNeedRefresh)
                        		lastRefreshTime = millis();
                        		DallasSensors.requestTemperatures();
                        		gw.sleep(750);
                        		float tempC = DallasSensors.getTempCByIndex(1);
                        		float difference = lastTemperature - tempC;
                        		if (tempC != -127.00 && abs(difference) > 0.1)
                        			gw.send(tempMsg.set(tempC, 1));
                        			lastTemperature = tempC;
                        		gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                        But I'm concerned about thoses particular lines :
                        		gw.sleep(750);
                        Why do we need gw.sleep(750) ? My concern is, when the sensor tries to pull temperature, it could not trigger new motion state for at least 750ms ? This is a problem for me, as I want to use these sensor to trigger light when I come in the room, so I need it to be fast.
                        Thanks !
                        • BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          #53
                          @petoulachi said:
                          this will sleep the device until the interrupt triggers it to awaken...
                          you are correct that it seems that the sleep(750) function will block your device, I don't think you want that.
                          • CaptainZapC
                            CaptainZapC
                            CaptainZap
                            @petoulachi @BulldogLowell Glad to hear there is some progress, in regards to my issue and hopefully this is step in the right direction. I'm positive that we're not alone in our need to create multisensors, both powered and battery operated, as arduinos offer too many possibilities to limit yourself to just a single type of device :)
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              you don't have a working sketch?
                                CaptainZapC
                                CaptainZapC
                                CaptainZap
                                @BulldogLowell Temperature isn't working, and is never updated on the Vera interface :|
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  #57
                                  try something like this, which is untested.
                                  //myPins
                                  const int PIR_PIN = 3;
                                  const int INTERRUPT = 1;
                                  const int DALLAS_PIN = 4;
                                  //myDevices
                                  const int PIR_SENSOR = 1;
                                  const int DALLAS_SENSOR = 2;
                                  OneWire oneWire(DALLAS_SENSOR);
                                  int lastTemperature = -99;
                                  unsigned long readTempInterval = 60 * 60 * 1000UL;  // One Hour Sleep time between reports (in milliseconds)
                                  unsigned long sleepTime = readTempInterval;
                                  boolean sendTemp = true;
                                  MyMessage motionMsg(PIR_SENSOR, V_TRIPPED);
                                  MyMessage tempMsg(DALLAS_SENSOR, V_TEMP);
                                    //DallasSensors.setWaitForConversion(false);  /I could not get this to compile
                                    gw.begin();
                                    gw.sendSketchInfo("Multi-Sensor", "1.0alpha");
                                    pinMode(PIR_PIN, INPUT);      // sets the motion sensor digital pin as input
                                    gw.present(PIR_SENSOR, S_MOTION);
                                    gw.present(DALLAS_SENSOR, S_TEMP);
                                    //gw.process(); don't need this, it is a one-way device.
                                    boolean tripped = digitalRead(PIR_PIN);
                                      Serial.println(tripped? "Tripped" : "Not Tripped");
                                      gw.send(motionMsg.set(tripped)); // Send tripped value to gw
                                      lastTripped = tripped;
                                    if (sendTemp)
                                      int tempC = (int) DallasSensors.getTempCByIndex(1);
                                      gw.send(tempMsg.set(tempC));
                                      sendTemp = false;
                                    unsigned long startSleepTime = millis();
                                    gw.sleep(INTERRUPT, CHANGE, sleepTime);
                                    unsigned long endSleepTime = millis();
                                    if (endSleepTime - startSleepTime >= sleepTime)
                                      sendTemp = true;
                                      sleepTime = max(sleepTime -= (endSleepTime - startSleepTime), 1000UL);
                                  It will send temp to controller once an hour... you can change that for testing;
                                  also will detect motion...
                                  it may need debouncing.
                                  CaptainZapC 2 Replies Last reply
                                    //myPins
                                    //myDevices
                                      gw.begin();
                                      if (sendTemp)
                                        sendTemp = false;
                                        sendTemp = true;
                                    CaptainZapC
                                    CaptainZapC
                                    CaptainZap
                                    @BulldogLowell Thanks, I'll try it tonight once I get home.
                                      //myPins
                                      //myDevices
                                        gw.begin();
                                        if (sendTemp)
                                          sendTemp = false;
                                          sendTemp = true;
                                      CaptainZapC
                                      CaptainZapC
                                      CaptainZap
                                      #59
                                      @BulldogLowell I just managed to test this and I have some questions :
                                      1. Motion doesn't seem to work that great - meaning that it takes at least one minute after being untripped to be tripped again
                                      2. Door/window doesn't seem to work - I think I have to add this part, but I'm a bit overwhelmed
                                      3. Temperature starts with temperature of -127C and doesn't update at all (I held my finger on it for 2 minutes) plus I think I need something to avoid -127 temps, like :
                                      if (lastTemperature != tempC && tempC != -127.00)
                                      For your info I used these pins to connect my sensors :
                                      const int PIR_PIN = 3; - PIR sensor
                                      const int INTERRUPT = 4; - Door/Window
                                      const int DALLAS_PIN = 5; - Temperature sensor
                                      unsigned long readTempInterval = 1 * 60 * 1000UL; - modified read interval to 1 minute for testing purposes
                                      Also I get this output of the serial monitor once I compile and upload the sketch to my nano after 2 minutes and multiple tries to trip PIR sensor :
                                      sensor started, id 2
                                      send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                      send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                      send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Multi-Sensor
                                      send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=8,st=ok:1.0alpha
                                      send: 2-2-0-0 s=1,c=0,t=1,pt=0,l=0,st=ok:
                                      send: 2-2-0-0 s=2,c=0,t=6,pt=0,l=0,st=ok:
                                      send: 2-2-0-0 s=2,c=1,t=0,pt=2,l=2,st=ok:-127
                                      Tripped
                                      send: 2-2-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:1
                                      Not Tripped
                                      send: 2-2-0-0 s=1,c=1,t=16,pt=2,l=2,st=ok:0
                                      Tripped
                                      I would appreciate any help I can get to get this started... this project has been on hold for at least 1 year and I would like to implement it now since I have all the parts I need, including 5 cases for the motion detectors (I will need to have at least two variations for them). My focus right now is getting a working sketch, with repeating functions or not, I can place repeaters if needed that is not a problem.
                                        Tripped
                                        Not Tripped
                                        Tripped
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @CaptainZap The motion detector (if you are using one like in the store) has two little dials on it. One is sensitivity and the other is time delay (see http://www.mpja.com/download/31227sc.pdf). Try to play with these until you get the effect you are looking for
                                        • Moshe LivneM Moshe Livne
                                          CaptainZapC
                                          CaptainZapC
                                          CaptainZap
                                          #61
                                          @Moshe-Livne That's not the problem... The previous code had the same pir sensor working, it has a couple of seconds timeout.
                                          At this time I'll take another look at my very first sketch, and remove the repeating part, maybe I can get somewhere...
                                          Looking back 1 year ago this was a nice idea, however I've put more time than I would have hoped for into it and I still don't have something that I can call reliable. I know this is a labor of love, and not perfect in any way, I just expected it to be a bit easier to do...
