  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 50.4k Views 4 Watching
  • CaptainZapC
    CaptainZapC
    CaptainZap
    Can anyone share their thoughts ? I've been running two identical nodes, with no temperature output for a few days now :(
    DwaltD 1 Reply Last reply
    • CaptainZapC CaptainZap
      DwaltD
      DwaltD
      Dwalt
      @CaptainZap Did you delete the original devices from Vera after you changed the code? I had something similar happen when I rewrote a sketch to modify battery monitoring and Vera would not show the new data. I deleted the node and child devices and reincluded them from scratch and then it worked.
      • m26872M
        m26872M
        m26872
        I think you have to redo inclusion of the sensors if you want them to use the repater in their routing. At least it looks like this when I setup my Vera and sensors.
        • CaptainZapC
          CaptainZapC
          CaptainZap
          @Dwalt @m26872 Thanks for the feedback, I did do that on the Vera unit. I've even removed the plugin files and re-did everything. I even, and this is a bit extreme, cleared the eprom on the gateway and reflashed it. None of it worked, I really have no clue what to do next. I'm open to every suggestion :D
            DwaltD
            DwaltD
            Dwalt
            @CaptainZap It your sketch you have this line:
            #define ONE_WIRE_BUS 14
            What pin is your Dallas sensor connected to?
            CaptainZapC 1 Reply Last reply
            • m26872M
              m26872M
              m26872
              First make sure a pure repeater node is working. With only the gw.process() to run, it should be fast to enough catch any new inlusion before the gateway. With a proper range of course. Clear the sensors eeprom and Vera-device before reinclusion, but you should not need to do anything with the gateway.
              • DwaltD Dwalt
                CaptainZapC
                CaptainZapC
                CaptainZap
                wrote on last edited by CaptainZap
                #45
                One sensor is connected to A0(14) the other is connected to D5 as it can be seen in my last sketch. Temperature reporting worked on, in my original sketch, however the sketch wasn't perfect so I improved it based on feedback.
                @m26872 The sensor is on a breadboard 5cm from the gateway, and I'm not sure about the repeater part...
                • CaptainZapC
                  CaptainZapC
                  CaptainZap
                  Well since nobody knew what the problem is I thought I would re-flash my first sketch which was working properly... however after doing it it no longer works... this is blowing my mind away. I don't understand why that would be, as the only changes I've done are listed in this thread, major one was that I upgraded lib to 1.4.1 from 1.4. Anyone has any ideas cause this is driving me crazy now :(
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @CaptainZap would suggest to clear the eeprom
                    • m26872M
                      m26872M
                      m26872
                      Did you ever get a repeater-only node to work in your mys network ?
                      • CaptainZapC
                        CaptainZapC
                        CaptainZap
                        @Moshe-Livne @m26872 : I did clear the eprom, I've tried everything I could think of... I'm not quite sure if the repeater works, so far everything is at the breadboard state, so I was pretty much prototyping.
                          @AWI Yes I want all my nodes to be repeaters, and that's exactly what I want to do :) However I use a Vera as my controller, and there you are supposed to have a parent node for your arduino sensor, followed by child devices for sensors/relays etc. Right now I have 3 child devices for the My Sensors plugin which isn't right.
                          m26872M
                          m26872M
                          m26872
                          Why?
                          Unless you plan expand your network in the near future, think the increased complexity just will give you trouble.
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @CaptainZap did you clear the eeprom before loading the sketch that used to work?
                            • petoulachiP
                              petoulachiP
                              petoulachi
                              wrote on last edited by petoulachi
                              #52
                              I've read this thread with interest because I want to make my Motion/Temp sensor using Dallas.
                              Adapting the given code was quite easy (well I guess as I have not tested it for now :D ), I only have changed gw.wait with gw.sleep, because if I understand it correctly, gw.sleep put the sensor in sleep mode which is a bit better for battery :
                              #include <OneWire.h>
                              #define CHILD_ID_S1 1   // Id of the sensor child
                              #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
                              #define CHILD_ID_T1 2 //CHILD ID for temp
                              DallasTemperature DallasSensors(&oneWire);
                              float lastTemperature ;
                              unsigned long SLEEP_TIME = 30000; // Sleep time between reports (in milliseconds)
                              unsigned long lastRefreshTime = 0;
                              boolean lastTripped = 0;
                              // Initialize motion message
                              MyMessage motionMsg(CHILD_ID_S1, V_TRIPPED);
                              MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
                                 // Startup OneWire Temp Sensors
                                  DallasSensors.begin();
                                  DallasSensors.setWaitForConversion(false);
                                gw.begin();
                                gw.sendSketchInfo("Motion and Temperature Sensor", "1.0");
                                gw.present(CHILD_ID_S1, S_MOTION);
                                gw.present(CHILD_ID_T1, S_TEMP);
                              	// Process incoming messages (like config from server)
                              	// Read digital motion value
                              	if (lastTripped != tripped )
                              		Serial.println("Tripped");
                              		gw.send(motionMsg.set(tripped?"1":"0")); // Send tripped value to gw
                              		lastTripped=tripped;
                              	boolean bNeedRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                              	if (bNeedRefresh)
                              		lastRefreshTime = millis();
                              		DallasSensors.requestTemperatures();
                              		gw.sleep(750);
                              		float tempC = DallasSensors.getTempCByIndex(1);
                              		float difference = lastTemperature - tempC;
                              		if (tempC != -127.00 && abs(difference) > 0.1)
                              			gw.send(tempMsg.set(tempC, 1));
                              			lastTemperature = tempC;
                              		gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                              But I'm concerned about thoses particular lines :
                              		gw.sleep(750);
                              Why do we need gw.sleep(750) ? My concern is, when the sensor tries to pull temperature, it could not trigger new motion state for at least 750ms ? This is a problem for me, as I want to use these sensor to trigger light when I come in the room, so I need it to be fast.
                              Thanks !
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                #53
                                @petoulachi said:
                                this will sleep the device until the interrupt triggers it to awaken...
                                you are correct that it seems that the sleep(750) function will block your device, I don't think you want that.
                                • CaptainZapC
                                  CaptainZapC
                                  CaptainZap
                                  @petoulachi @BulldogLowell Glad to hear there is some progress, in regards to my issue and hopefully this is step in the right direction. I'm positive that we're not alone in our need to create multisensors, both powered and battery operated, as arduinos offer too many possibilities to limit yourself to just a single type of device :)
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    you don't have a working sketch?
                                      CaptainZapC
                                      CaptainZapC
                                      CaptainZap
                                      @BulldogLowell Temperature isn't working, and is never updated on the Vera interface :|
                                      • BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        #57
                                        try something like this, which is untested.
                                        //myPins
                                        const int PIR_PIN = 3;
                                        const int INTERRUPT = 1;
                                        const int DALLAS_PIN = 4;
                                        //myDevices
                                        const int PIR_SENSOR = 1;
                                        const int DALLAS_SENSOR = 2;
                                        OneWire oneWire(DALLAS_SENSOR);
                                        int lastTemperature = -99;
                                        unsigned long readTempInterval = 60 * 60 * 1000UL;  // One Hour Sleep time between reports (in milliseconds)
                                        unsigned long sleepTime = readTempInterval;
                                        boolean sendTemp = true;
                                        MyMessage motionMsg(PIR_SENSOR, V_TRIPPED);
                                        MyMessage tempMsg(DALLAS_SENSOR, V_TEMP);
                                          //DallasSensors.setWaitForConversion(false);  /I could not get this to compile
                                          gw.begin();
                                          gw.sendSketchInfo("Multi-Sensor", "1.0alpha");
                                          pinMode(PIR_PIN, INPUT);      // sets the motion sensor digital pin as input
                                          gw.present(PIR_SENSOR, S_MOTION);
                                          gw.present(DALLAS_SENSOR, S_TEMP);
                                          //gw.process(); don't need this, it is a one-way device.
                                          boolean tripped = digitalRead(PIR_PIN);
                                            Serial.println(tripped? "Tripped" : "Not Tripped");
                                            gw.send(motionMsg.set(tripped)); // Send tripped value to gw
                                            lastTripped = tripped;
                                          if (sendTemp)
                                            int tempC = (int) DallasSensors.getTempCByIndex(1);
                                            gw.send(tempMsg.set(tempC));
                                            sendTemp = false;
                                          unsigned long startSleepTime = millis();
                                          gw.sleep(INTERRUPT, CHANGE, sleepTime);
                                          unsigned long endSleepTime = millis();
                                          if (endSleepTime - startSleepTime >= sleepTime)
                                            sendTemp = true;
                                            sleepTime = max(sleepTime -= (endSleepTime - startSleepTime), 1000UL);
                                        It will send temp to controller once an hour... you can change that for testing;
                                        also will detect motion...
                                        it may need debouncing.
                                        CaptainZapC 2 Replies Last reply
                                          //myPins
                                          //myDevices
                                            gw.begin();
                                            if (sendTemp)
                                              sendTemp = false;
                                              sendTemp = true;
                                          CaptainZapC
                                          CaptainZapC
                                          CaptainZap
                                          @BulldogLowell Thanks, I'll try it tonight once I get home.
