  3. Domoticz
  4. Dimmer doesn't appear in devices
33 Posts 6 Posters 16.2k Views 4 Watching
  • ThomasDecockT ThomasDecock
    Hi!
    I just added a led dimmer to my setup
    i used this to build it:
    http://www.mysensors.org/build/dimmer
    the problem is that it doesn't appear in my list 'devices' in domoticz
    in the domoticz log i see this:
    2015-07-13 12:53:36.517 MySensors: Node: 1, Sketch Name: DimmableLED
    2015-07-13 12:53:36.523 MySensors: Node: 1, Sketch Version: 1.1
    someone who can help me with this?
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @ThomasDecock did you hardcode the node id?
      Hi!
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @ThomasDecock oh and if you can send the sketch and serial monitor outout please?
      • ThomasDecockT
        ThomasDecockT
        ThomasDecock
        I used this sketch:
         * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
         * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
         * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
         * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
         * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
         * to the LED negative terminal and the MOSFET Source pin is connected to ground.
         * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
         * Version 1.0 - February 15, 2014 - Bruce Lacey
         * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
        #define SN "DimmableLED"
        #define SV "1.1"
        #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
        static int currentLevel = 0;  // Current dim level...
        MyMessage dimmerMsg(0, V_DIMMER);
        MyMessage lightMsg(0, V_LIGHT);
         * Dimmable LED initialization method
          Serial.println( SN );
          gw.begin( incomingMessage );
          // Register the LED Dimmable Light with the gateway
          gw.present( 0, S_DIMMER );
          gw.sendSketchInfo(SN, SV);
          // Pull the gateway's current dim level - restore light level upon sendor node power-up
          gw.request( 0, V_DIMMER );
         *  Dimmable LED main processing loop
          if (message.type == V_LIGHT || message.type == V_DIMMER) {
            Serial.print( "Changing level to " );
            Serial.print( ", from " );
            Serial.println( currentLevel );
            fadeToLevel( requestedLevel );
            gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
            // hek comment: Is this really nessesary?
            gw.send( dimmerMsg.set(currentLevel) );
         *  This method provides a graceful fade up/down effect
        void fadeToLevel( int toLevel ) {
          int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
          while ( currentLevel != toLevel ) {
            currentLevel += delta;
            analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
            delay( FADE_DELAY );
        when i open the serial monitor (from the node) i see this: 5àèàÒààð
        i did try with an other script based on that from: GizMoCuz (DimmableLight) (just added one line to control the led's) this is working, but its without the fading and kinda complex :s
         * This sketch provides an example how to implement a Dimmable Light
         * It is pure virtual and it logs messages to the serial output
         * It can be used as a base sketch for actual hardware.
         * Stores the last light state and level in eeprom.
         * Developed by GizMoCuz (Domoticz)
         * Version 1.0 - January 30, 2015
        #define CHILD_ID_LIGHT 1
        #define LED_PIN 3
        #define EPROM_LIGHT_STATE 1
        #define EPROM_DIMMER_LEVEL 2
        #define LIGHT_OFF 0
        #define LIGHT_ON 1
        #define SN "Dimable Light"
        #define SV "1.0"
        int LastLightState=LIGHT_OFF;
        int LastDimValue=100;
        MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
        MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
          gw.begin(incomingMessage, AUTO, false);
          gw.present(CHILD_ID_LIGHT, S_DIMMER );
          //Retreive our last light state from the eprom
          int LightState=gw.loadState(EPROM_LIGHT_STATE);
          if (LightState<=1) {
            LastLightState=LightState;
            int DimValue=gw.loadState(EPROM_DIMMER_LEVEL);
            if ((DimValue>0)&&(DimValue<=100)) {
              //There should be no Dim value of 0, this would mean LIGHT_OFF
              LastDimValue=DimValue;
          //Here you actualy switch on/off the light with the last known dim level
          SetCurrentState2Hardware();
          Serial.println( "Node ready to receive messages..." );
          //delay(1000);  // Removed by hek
          // Process incoming messages (like config and light state from controller)
            Serial.println( "V_LIGHT command received..." );
            int lstate= atoi( message.data );
            if ((lstate<0)||(lstate>1)) {
              Serial.println( "V_LIGHT data invalid (should be 0/1)" );
              return;
            LastLightState=lstate;
            gw.saveState(EPROM_LIGHT_STATE, LastLightState);
            if ((LastLightState==LIGHT_ON)&&(LastDimValue==0)) {
               //In the case that the Light State = On, but the dimmer value is zero,
               //then something (probably the controller) did something wrong,
               //for the Dim value to 100%
              LastDimValue=100;
              gw.saveState(EPROM_DIMMER_LEVEL, LastDimValue);
            //When receiving a V_LIGHT command we switch the light between OFF and the last received dimmer value
            //This means if you previously set the lights dimmer value to 50%, and turn the light ON
            //it will do so at 50%
          else if (message.type == V_DIMMER) {
            Serial.println( "V_DIMMER command received..." );
            int dimvalue= atoi( message.data );
            if ((dimvalue<0)||(dimvalue>100)) {
              return;
            if (dimvalue==0) {
            else {
              LastLightState=LIGHT_ON;
              LastDimValue=dimvalue;
          else {
            Serial.println( "Invalid command received..." );
            return;
          //Here you set the actual light state/level
        void SetCurrentState2Hardware()
          if (LastLightState==LIGHT_OFF) {
             Serial.println( "Light state: OFF" );
          else {
             Serial.print( "Light state: ON, Level: " );
             Serial.println( LastDimValue );
        analogWrite( LED_PIN, (int)(LastDimValue / 100. * 255) );
          //Send current state to the controller
          SendCurrentState2Controller();
        void SendCurrentState2Controller()
          if ((LastLightState==LIGHT_OFF)||(LastDimValue==0)) {
            gw.send(dimmerMsg.set(0));
          else {
            gw.send(dimmerMsg.set(LastDimValue));
        blaceyB 1 Reply Last reply
          I used this sketch:
          #define SV "1.1"
          #define LED_PIN 3
          #define LIGHT_OFF 0
          #define LIGHT_ON 1
          #define SV "1.0"
                return;
                LastDimValue=100;
                return;
              if (dimvalue==0) {
              else {
            else {
              return;
            else {
            else {
          blaceyB
          blaceyB
          blacey
          Gibberish to the console is usually an indication that the IDE is set to the wrong board (e.g. 5V vs. 3.3V, Nano vs. Mini Pro, etc.) or the console baud in the Arduino IDE. The DimmableLED sketch above has been verified on 1.4.1, Github/Master and Github/development. Double-check your IDE settings and if that doesn't work, ping me and I will try to help you sort it out.
          Bruce
          • ThomasDecockT
            ThomasDecockT
            ThomasDecock
            Thanks for the fast reply!
            I use an arduino nano,
            and i see i selected the wrong baud,
            now i get this on the serial monitor:
            sensor started, id 1
            send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
            send: 1-1-0-0 s=0,c=0,t=4,pt=0,l=0,st=ok:
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=11,st=ok:DimmableLED
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.1
            send: 1-1-0-0 s=0,c=2,t=3,pt=0,l=0,st=ok:
            in the domoticz log i get this:
            2015-07-13 16:13:15.077 MySensors: Node: 1, Sketch Name: DimmableLED
            2015-07-13 16:13:15.083 MySensors: Node: 1, Sketch Version: 1.1
            but the dimmer doesn't appear in the 'device' list from domoticz
              blaceyB
              blaceyB
              blacey
              Seems like a Domoticoz / gateway issue because the sketch is sending the information to the gateway. Have you added the dimmer to Domoticoz using the Domoticoz UI? Perhaps remove and re-add because you toggled between sketches or force Domoticoz to reload - bottom-line, it could just be a transient state issue that you need to reset once...
              • ThomasDecockT
                ThomasDecockT
                ThomasDecock
                the way i should add the dimmer to domoticz is with the 'device' page, then i should be able to select the dimmer and add it to my domoticz configuration..
                but the problem with this sketch is that it doesn't appear in domoticz,
                when i use the sketch from GizMoCuz (DimmableLight)
                see here:
                #define LIGHT_OFF 0
                #define LIGHT_ON 1
                #define SV "1.0"
                      return;
                      LastDimValue=100;
                      return;
                    if (dimvalue==0) {
                    else {
                  else {
                    return;
                  else {
                  else {
                with this sketc their does appear an dimmer in the 'device' page from domoticz
                (but this is a virtual sketch with no hardware connected to)
                i can add the hardware code from the DimmableLED sketch an inplement it in the sketch from GizMoCuz (DimmableLight).. but I am new at all this, its still kinda hard understanding all the code...
                I also want to add 2 more dimmers to this node (so 3 dimmers in total) but i'am also still figuring out how to do that
                Thomas
                  sebas
                  Did you enable Domoticz to detect new hardware? It's the default setting but you can turn of the auto inclusion.
                  • ThomasDecockT
                    ThomasDecockT
                    ThomasDecock
                    yes, i did.
                    when i hook up a temp sensor and load the temp sketch it appears in my device list
                    and it also appears when using the GizMoCuz (DimmableLight) sketch
                      yes, i did.
                      blaceyB
                      blaceyB
                      blacey
                      @ThomasDecock said:
                      yes, i did.
                      Try moving the gw.sendSketchInfo() before the gw.present() in setup(). Not sure why they are in that order but perhaps the Domoticoz plugin has some order dependence before it assumes a device is valid. If that doesn't work, I will take a look at the Domoticoz plugin to see if I can figure out what is going on...
                      Are you using a serial or ethernet gateway?
                      ThomasDecockT 1 Reply Last reply
                      • blaceyB
                        blaceyB
                        blacey
                        wrote on last edited by blacey
                        @ThomasDecock Also, check this out - http://www.domoticz.com/forum/viewtopic.php?f=6&t=6932
                        Which version of Domoticoz and the Domoticoz MySensors plugin are you running?
                        • blaceyB blacey
                          @ThomasDecock said:
                          yes, i did.
                          ThomasDecockT
                          ThomasDecockT
                          ThomasDecock
                          wrote on last edited by ThomasDecock
                          @blacey said:
                          @ThomasDecock said:
                          yes, i did.
                          I did what you suggested and moved the gw.sendSketchInfo() before the gw.present()
                          but nothing changed.
                          I am using domoticz version 2.2563 on RPI B+ and a serial gateway. I did take a look in that topic on the domoticz forum and left a reply.
                          its really strange that when i use the 'Dimable Light' sketch the dimmer does appear in domoticz but not with the DimmableLED sketch.
                          EDIT:
                          extra info
                          if i first use the ''Dimable Light" sketch so that the dimmer appears in the device list from domoticz and then upload the "DimmableLED" to the node, am i able to control the leds (on pin 3) with the dimmer that was created with the 'dimable light' sketch .
                          Kind regards!
                          Thomas
                          • Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            Isn't 1 reserved for the gateway?
                              @blacey said:
                              @ThomasDecock said:
                              yes, i did.
                              EDIT:
                              extra info
                              Kind regards!
                              Thomas
                              blaceyB
                              blaceyB
                              blacey
                              @ThomasDecock Glad to hear you got it working! By the way, Domoticoz is up to V2.2657 so you may want to look into updating your version. Let me know if you need help with anything else.
                              Cheers,
                              Bruce
                              • blaceyB blacey
                                Cheers,
                                Bruce
                                ThomasDecockT
                                ThomasDecockT
                                ThomasDecock
                                Cheers,
                                Bruce
                                Thanks! I thought i was using the beta, but after checking i saw that the 'use beta' option wasn't selected anymore...
                                so I just updated and tried once again with the 'DimmableLED' sketch (after deleting the dimmer in my domoticz) and now it does appear in my domoticz device list!!
                                now i will attempt to make it from 1 dimmer to 3 dimmers..
                                Thanks for the help!
                                • A
                                  andrezibaia
                                  wrote on last edited by andrezibaia
                                  Hi!
                                  I am kind of new here, but I have been trying to build a simple white led dimmer to control with Domoticz.
                                  So far, I have accomplished to get the radio working, then I built the hardware and finally I tested the dimmer with a simple arduino skecth:
                                     pinMode( 9, OUTPUT);
                                     pinMode(10, OUTPUT);
                                   byte b = 0;
                                     analogWrite(9, b);
                                     analogWrite(10, b);
                                     delay(100);
                                     ++b;
                                  And it worked!
                                  Also, I managed to get the node recognized in Domoticz (after some struggle), but I cannot seem to get Domoticz to actually dim the LED!
                                  FYI: I used this sketch:
                                   * http://www.mysensors.org/build/dimmer
                                  #define SV "1.1"
                                  Can somebody help me please?
                                  I am using a 3.3v Arduino Mini Pro clone, a IRF540 MOSFET and a 12v power supply.
                                  Thanks for your help!
                                  PS: amazing project!
                                  SparkmanS 1 Reply Last reply
                                  • A andrezibaia
                                    Hi!
                                     byte b = 0;
                                       analogWrite(9, b);
                                       analogWrite(10, b);
                                       delay(100);
                                       ++b;
                                    And it worked!
                                    #define SV "1.1"
                                    SparkmanS
                                    SparkmanS
                                    Sparkman
                                    @andrezibaia If you have the serial monitor hooked up to the sensor (dimmer), do you see the "Changing level to " output in the serial log?
                                    Al
                                    • A
                                      andrezibaia
                                      Hi @Sparkman!
                                      No, the sensor does not get any input.
                                      This is all I get in the serial monitor:
                                      send: 55-55-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                                      send: 55-55-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                      sensor started, id=55, parent=0, distance=0
                                      send: 55-55-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                                      send: 55-55-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                                      send: 55-55-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                      send: 55-55-0-0 s=0,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                                      Thanks for the ultra-fast reply!
                                      • A andrezibaia
                                        Hi @Sparkman!
                                        SparkmanS
                                        SparkmanS
                                        Sparkman
                                        @andrezibaia NP. Maybe add a println in the incomingMessage function:
                                         Serial.println( message.type );
                                        and then send a command from Domoticz and see what the serial log shows when you do that.
                                        Al
                                        • A
                                          andrezibaia
                                          @Sparkman, nothing happens...
                                          No message at all in the serial monitor.
