  3. Domoticz
  4. Dimmer doesn't appear in devices
33 Posts 6 Posters 16.2k Views 4 Watching
  • ThomasDecockT
    ThomasDecockT
    ThomasDecock
    the way i should add the dimmer to domoticz is with the 'device' page, then i should be able to select the dimmer and add it to my domoticz configuration..
    but the problem with this sketch is that it doesn't appear in domoticz,
    when i use the sketch from GizMoCuz (DimmableLight)
    see here:
     * This sketch provides an example how to implement a Dimmable Light
     * It is pure virtual and it logs messages to the serial output
     * It can be used as a base sketch for actual hardware.
     * Stores the last light state and level in eeprom.
     * Developed by GizMoCuz (Domoticz)
     * Version 1.0 - January 30, 2015
    #define CHILD_ID_LIGHT 1
    #define EPROM_LIGHT_STATE 1
    #define EPROM_DIMMER_LEVEL 2
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    #define SN "Dimable Light"
    #define SV "1.0"
    int LastLightState=LIGHT_OFF;
    int LastDimValue=100;
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
      gw.begin(incomingMessage, AUTO, false);
      gw.sendSketchInfo(SN, SV);
      gw.present(CHILD_ID_LIGHT, S_DIMMER );
      //Retreive our last light state from the eprom
      int LightState=gw.loadState(EPROM_LIGHT_STATE);
      if (LightState<=1) {
        LastLightState=LightState;
        int DimValue=gw.loadState(EPROM_DIMMER_LEVEL);
        if ((DimValue>0)&&(DimValue<=100)) {
          //There should be no Dim value of 0, this would mean LIGHT_OFF
          LastDimValue=DimValue;
      //Here you actualy switch on/off the light with the last known dim level
      SetCurrentState2Hardware();
      Serial.println( "Node ready to receive messages..." );
      //delay(1000);  // Removed by hek
      // Process incoming messages (like config and light state from controller)
    void incomingMessage(const MyMessage &message)
        Serial.println( "V_LIGHT command received..." );
        int lstate= atoi( message.data );
        if ((lstate<0)||(lstate>1)) {
          Serial.println( "V_LIGHT data invalid (should be 0/1)" );
          return;
        LastLightState=lstate;
        gw.saveState(EPROM_LIGHT_STATE, LastLightState);
        if ((LastLightState==LIGHT_ON)&&(LastDimValue==0)) {
           //In the case that the Light State = On, but the dimmer value is zero,
           //then something (probably the controller) did something wrong,
           //for the Dim value to 100%
          LastDimValue=100;
          gw.saveState(EPROM_DIMMER_LEVEL, LastDimValue);
        //When receiving a V_LIGHT command we switch the light between OFF and the last received dimmer value
        //This means if you previously set the lights dimmer value to 50%, and turn the light ON
        //it will do so at 50%
      else if (message.type == V_DIMMER) {
        Serial.println( "V_DIMMER command received..." );
        int dimvalue= atoi( message.data );
        if ((dimvalue<0)||(dimvalue>100)) {
          return;
        if (dimvalue==0) {
        else {
          LastLightState=LIGHT_ON;
          LastDimValue=dimvalue;
      else {
        Serial.println( "Invalid command received..." );
        return;
      //Here you set the actual light state/level
    void SetCurrentState2Hardware()
      if (LastLightState==LIGHT_OFF) {
         Serial.println( "Light state: OFF" );
      else {
         Serial.print( "Light state: ON, Level: " );
         Serial.println( LastDimValue );
      //Send current state to the controller
      SendCurrentState2Controller();
    void SendCurrentState2Controller()
      if ((LastLightState==LIGHT_OFF)||(LastDimValue==0)) {
        gw.send(dimmerMsg.set(0));
      else {
        gw.send(dimmerMsg.set(LastDimValue));
    with this sketc their does appear an dimmer in the 'device' page from domoticz
    (but this is a virtual sketch with no hardware connected to)
    i can add the hardware code from the DimmableLED sketch an inplement it in the sketch from GizMoCuz (DimmableLight).. but I am new at all this, its still kinda hard understanding all the code...
    I also want to add 2 more dimmers to this node (so 3 dimmers in total) but i'am also still figuring out how to do that
    Thomas
      sebas
      Did you enable Domoticz to detect new hardware? It's the default setting but you can turn of the auto inclusion.
      • ThomasDecockT
        ThomasDecockT
        ThomasDecock
        yes, i did.
        when i hook up a temp sensor and load the temp sketch it appears in my device list
        and it also appears when using the GizMoCuz (DimmableLight) sketch
        blaceyB 1 Reply Last reply
        • ThomasDecockT ThomasDecock
          yes, i did.
          blaceyB
          blaceyB
          blacey
          @ThomasDecock said:
          yes, i did.
          Try moving the gw.sendSketchInfo() before the gw.present() in setup(). Not sure why they are in that order but perhaps the Domoticoz plugin has some order dependence before it assumes a device is valid. If that doesn't work, I will take a look at the Domoticoz plugin to see if I can figure out what is going on...
          Are you using a serial or ethernet gateway?
          ThomasDecockT 1 Reply Last reply
          • blaceyB
            blaceyB
            blacey
            wrote on last edited by blacey
            @ThomasDecock Also, check this out - http://www.domoticz.com/forum/viewtopic.php?f=6&t=6932
            Which version of Domoticoz and the Domoticoz MySensors plugin are you running?
            • blaceyB blacey
              @ThomasDecock said:
              yes, i did.
              ThomasDecockT
              ThomasDecockT
              ThomasDecock
              wrote on last edited by ThomasDecock
              @blacey said:
              @ThomasDecock said:
              yes, i did.
              I did what you suggested and moved the gw.sendSketchInfo() before the gw.present()
              but nothing changed.
              I am using domoticz version 2.2563 on RPI B+ and a serial gateway. I did take a look in that topic on the domoticz forum and left a reply.
              its really strange that when i use the 'Dimable Light' sketch the dimmer does appear in domoticz but not with the DimmableLED sketch.
              EDIT:
              extra info
              if i first use the ''Dimable Light" sketch so that the dimmer appears in the device list from domoticz and then upload the "DimmableLED" to the node, am i able to control the leds (on pin 3) with the dimmer that was created with the 'dimable light' sketch .
              Kind regards!
              Thomas
              • Moshe LivneM
                Moshe LivneM
                Moshe Livne
                Isn't 1 reserved for the gateway?
                  @blacey said:
                  @ThomasDecock said:
                  yes, i did.
                  EDIT:
                  extra info
                  Kind regards!
                  Thomas
                  blaceyB
                  blaceyB
                  blacey
                  @ThomasDecock Glad to hear you got it working! By the way, Domoticoz is up to V2.2657 so you may want to look into updating your version. Let me know if you need help with anything else.
                  Cheers,
                  Bruce
                  • blaceyB blacey
                    Cheers,
                    Bruce
                    ThomasDecockT
                    ThomasDecockT
                    ThomasDecock
                    Cheers,
                    Bruce
                    Thanks! I thought i was using the beta, but after checking i saw that the 'use beta' option wasn't selected anymore...
                    so I just updated and tried once again with the 'DimmableLED' sketch (after deleting the dimmer in my domoticz) and now it does appear in my domoticz device list!!
                    now i will attempt to make it from 1 dimmer to 3 dimmers..
                    Thanks for the help!
                    • A
                      andrezibaia
                      wrote on last edited by andrezibaia
                      Hi!
                      I am kind of new here, but I have been trying to build a simple white led dimmer to control with Domoticz.
                      So far, I have accomplished to get the radio working, then I built the hardware and finally I tested the dimmer with a simple arduino skecth:
                         pinMode( 9, OUTPUT);
                         pinMode(10, OUTPUT);
                       byte b = 0;
                         analogWrite(9, b);
                         analogWrite(10, b);
                         delay(100);
                         ++b;
                      And it worked!
                      Also, I managed to get the node recognized in Domoticz (after some struggle), but I cannot seem to get Domoticz to actually dim the LED!
                      FYI: I used this sketch:
                       * Version 1.0 - February 15, 2014 - Bruce Lacey
                       * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
                       * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
                       * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
                       * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
                       * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
                       * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
                       * to the LED negative terminal and the MOSFET Source pin is connected to ground.
                       * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
                       * http://www.mysensors.org/build/dimmer
                      #define SN "DimmableLED"
                      #define SV "1.1"
                      #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
                      #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                      static int currentLevel = 0;  // Current dim level...
                      MyMessage dimmerMsg(0, V_DIMMER);
                      MyMessage lightMsg(0, V_LIGHT);
                       * Dimmable LED initialization method
                        Serial.println( SN );
                        gw.begin( incomingMessage );
                        // Register the LED Dimmable Light with the gateway
                        gw.present( 0, S_DIMMER );
                        // Pull the gateway's current dim level - restore light level upon sendor node power-up
                        gw.request( 0, V_DIMMER );
                       *  Dimmable LED main processing loop
                        if (message.type == V_LIGHT || message.type == V_DIMMER) {
                          Serial.print( "Changing level to " );
                          Serial.print( ", from " );
                          Serial.println( currentLevel );
                          fadeToLevel( requestedLevel );
                          gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
                          // hek comment: Is this really nessesary?
                          gw.send( dimmerMsg.set(currentLevel) );
                       *  This method provides a graceful fade up/down effect
                      void fadeToLevel( int toLevel ) {
                        int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                        while ( currentLevel != toLevel ) {
                          currentLevel += delta;
                          analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                          delay( FADE_DELAY );
                      Can somebody help me please?
                      I am using a 3.3v Arduino Mini Pro clone, a IRF540 MOSFET and a 12v power supply.
                      Thanks for your help!
                      PS: amazing project!
                      SparkmanS 1 Reply Last reply
                      • A andrezibaia
                        Hi!
                         byte b = 0;
                           analogWrite(9, b);
                           analogWrite(10, b);
                           delay(100);
                           ++b;
                        And it worked!
                        #define SV "1.1"
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @andrezibaia If you have the serial monitor hooked up to the sensor (dimmer), do you see the "Changing level to " output in the serial log?
                        Al
                        • A
                          andrezibaia
                          Hi @Sparkman!
                          No, the sensor does not get any input.
                          This is all I get in the serial monitor:
                          send: 55-55-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                          send: 55-55-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                          sensor started, id=55, parent=0, distance=0
                          send: 55-55-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,st=ok:
                          send: 55-55-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                          send: 55-55-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                          send: 55-55-0-0 s=0,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                          Thanks for the ultra-fast reply!
                          • A andrezibaia
                            Hi @Sparkman!
                            SparkmanS
                            SparkmanS
                            Sparkman
                            @andrezibaia NP. Maybe add a println in the incomingMessage function:
                             Serial.println( message.type );
                            and then send a command from Domoticz and see what the serial log shows when you do that.
                            Al
                            • A
                              andrezibaia
                              @Sparkman, nothing happens...
                              No message at all in the serial monitor.
                              • A andrezibaia
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @andrezibaia To rule out an issue with Domoticz, do you have the ability to hookup the gateway to MYSController? Might be worth a try to see what happens with it.
                                Al
                                • A
                                  andrezibaia
                                  Yes, sure. Just did that.
                                  Here's what I have:
                                  upload-d51ca5cc-04b6-4516-9878-ce26ecbe57ed
                                  What should I do now?
                                  Cheers!
                                  • A andrezibaia
                                    Here's what I have:
                                    Cheers!
                                    SparkmanS
                                    SparkmanS
                                    Sparkman
                                    @andrezibaia Should be able to send a message to the node using the "Send Message" portion on the bottom of the screen.
                                    Al
                                    • A
                                      andrezibaia
                                      Sure. What should I write in the payload section?
                                      I tried this, but nothing happened.
                                      upload-2fe2e7d5-4492-44df-b83d-e35436ce14b3
                                      I'm sorry for all the "noobness", I am still trying to learn all this...
                                      • A andrezibaia
                                        SparkmanS
                                        SparkmanS
                                        Sparkman
                                        @andrezibaia Looks correct. Anything in the serial monitor of the dimmer? Try the light subtype as well and send a 0 or a 1. What does the MYSController log show when you do this?
                                        Al
                                        • A
                                          andrezibaia
                                          Nothing at all in the node serial monitor...
                                          The log from MYSController shows this:
                                          13/09/2015 19:53:01	TX	55;255;3;0;6;M
                                          13/09/2015 19:53:01	RX	55;255;3;0;6;0
                                          13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=0,c=0,t=4,pt=0,l=0,sg=0:
                                          13/09/2015 19:53:04	DEBUG	Update child id=0, type=DIMMER
                                          13/09/2015 19:53:04	RX	55;0;0;0;4;
                                          13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=11,pt=0,l=11,sg=0:DimmableLED
                                          13/09/2015 19:53:04	RX	55;255;3;0;11;DimmableLED
                                          13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                          13/09/2015 19:53:04	RX	55;255;3;0;12;1.1
                                          13/09/2015 19:53:04	RX	0;0;3;0;9;read: 55-55-0 s=0,c=2,t=3,pt=0,l=0,sg=0:
                                          13/09/2015 19:53:04	RX	55;0;2;0;3;
                                          13/09/2015 19:53:12	TX	55;0;1;0;3;50
                                          13/09/2015 19:53:46	RX	0;0;3;0;9;read: 55-55-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
                                          13/09/2015 19:53:46	DEBUG	Update child id=255, type=ARDUINO_NODE
                                          13/09/2015 19:53:46	RX	55;255;0;0;17;1.5
                                          13/09/2015 19:53:46	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          13/09/2015 19:53:46	TX	55;255;3;0;6;M
                                          13/09/2015 19:53:46	RX	55;255;3;0;6;0
                                          13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=0,c=0,t=4,pt=0,l=0,sg=0:
                                          13/09/2015 19:53:48	DEBUG	Update child id=0, type=DIMMER
                                          13/09/2015 19:53:48	RX	55;0;0;0;4;
                                          13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=11,pt=0,l=11,sg=0:DimmableLED
                                          13/09/2015 19:53:48	RX	55;255;3;0;11;DimmableLED
                                          13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                          13/09/2015 19:53:48	RX	55;255;3;0;12;1.1
                                          13/09/2015 19:53:48	RX	0;0;3;0;9;read: 55-55-0 s=0,c=2,t=3,pt=0,l=0,sg=0:
                                          13/09/2015 19:53:48	RX	55;0;2;0;3;
                                          13/09/2015 19:53:56	TX	55;0;1;0;3;50
                                          13/09/2015 19:54:16	TX	55;0;1;0;2;50
                                          13/09/2015 19:55:02	TX	55;0;1;0;2;50
