  3. Mailbox/Postbox Alert
31 Posts 8 Posters 22.6k Views 7 Watching
  • n3roN n3ro
    Just finished my new project.
    I have added two magnetic switches to the front and the back of my postbox. Now i get a Mail if the postman was here :)
    You need:
    1x Arduino Mini Pro 3,3
    1x Battery Holder (2xaaa)
    1x NRF
    2x Reed switches (http://www.reichelt.de/KSK-1A663-2025/3/index.html?&ACTION=3&LA=446&ARTICLE=151700&artnr=KSK+1A663+2025&SEARCH=magnet+schlie�er)
    2x magnets (http://www.reichelt.de/MAGNET-M4/3/index.html?&ACTION=3&LA=446&ARTICLE=12483&artnr=MAGNET+M4&SEARCH=magnet)
    And this or a similar sketch: https://github.com/n3roGit/MySensors_n3ro/tree/master/Mailbox_Alert
    It works great =)
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @n3ro I wish mine had a flap... still trying to figure out a way to do that
    • n3roN
      n3roN
      n3ro
      hmm after some days testing it works very fine, but:
      the battery drains very fast and in dont know why. The Arduino sleeps the whole time and wakes up when the postman is coming (maybe 2 times a week).
      The battery drains 11% in 7 Days :(
      Any Ideas?
      The power LED and regulator is cutted and the fuses are modified.
      Regards
      n3ro
      pimatic + MySensors + Homeduino + z-way
      RJ_MakeR 1 Reply Last reply
      • n3roN n3ro
        Any Ideas?
        Regards
        n3ro
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @n3ro Are you using an interrupt to wake everything up?
        RJ_Make
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @n3ro
          I'm guessing that your repeat() function is wearing out the battery.
          By the way you can take advantage of the return of sleep( ) here:
          gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
          like this (untested):
          #include <readVcc.h>
          #define NODE_ID 21                      // ID of node
          #define CHILD_ID 1                      // Id of the sensor child
          #define MAILBOX_FRONT_PIN 2             // Arduino Digital I/O pin for button/reed switch
          #define MAILBOX_BACK_PIN 3              // Arduino Digital I/O pin for button/reed switch
          #define MIN_V 1900 // empty voltage (0%)
          #define MAX_V 3200 // full voltage (100%)
          boolean post = false;
          boolean lastpost = false;
          int oldBatteryPcnt;
          int repeat = 20;
          int trigger = -1;
          unsigned long goToSleepTime;
            gw.begin(NULL, NODE_ID, false);
            pinMode(MAILBOX_FRONT_PIN, INPUT);
            pinMode(MAILBOX_BACK_PIN, INPUT);
            digitalWrite(MAILBOX_FRONT_PIN, HIGH);
            digitalWrite(MAILBOX_BACK_PIN, HIGH);
            gw.sendSketchInfo("Mailbox Alert", "1.0");
            gw.present(CHILD_ID, S_MOTION);
            Serial.println("---------- set Mailbox empty");
            msg.set(0);
            if (millis() - goToSleepTime > 10UL) //debounce
              switch (trigger) {
                case 0:
                  post = true;
                  Serial.println("---------- New Mail");
                case 1:
                  post = false;
                  Serial.println("---------- Mailbox emptied");
                default:
                  Serial.println("---------- I just woke up");
            trigger = -1;
            if (post != lastpost)
              Serial.print("---------- Send Mailboxstate ");
              Serial.println(post ? "full" : "empty");
              msg.set(post);
              lastpost = post;
              sendBattery();
            goToSleepTime = millis();
            trigger = gw.sleep(MAILBOX_FRONT_PIN - 2, CHANGE, MAILBOX_BACK_PIN - 2, CHANGE, 0);
          void sendBattery() // Measure battery
            int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100);
            if (batteryPcnt != oldBatteryPcnt)
              gw.sendBatteryLevel(batteryPcnt); // Send battery percentage
              oldBatteryPcnt = batteryPcnt;
            Serial.print("---------- Battery: ");
            Serial.println(batteryPcnt);
          n3roN 1 Reply Last reply
          • n3roN
            n3roN
            n3ro
            wrote on last edited by n3ro
            Thx for the tips. I will try it.
            I have just measured the current:
            32uA in sleep and both opened
            when one reen switch is closed: 171uA
            when both closed: 309uA
            i use a internal pullup and dont know why the current is so high when switch is closed :(
            • n3roN
              n3roN
              n3ro
              it is fixed :) changed internal pullup to an external with 680k. now its 32uA with both opened and 47uA with both closed :)
              • n3roN n3ro
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @n3ro how do you do that?
                • F
                  F
                  f1dev
                  Hi!
                  I+m trying to do a similar mailbox sensor, but I get different power consumptions hen I ground (pulling down) input pin 2 and 3.
                  I´m using a pro mini, 3.3v standard boot loader with removed LED and 470k resistors as external pull-ups.
                  In sleep mode with it draws about 65uA
                  Roughly the same with input pin 3 -grounded (state 0)
                  But when I ground pin 2 it draws 7mA
                  Any ideas whats wrong?
                  • Moshe LivneM Moshe Livne
                    n3roN
                    n3roN
                    n3ro
                    @Moshe-Livne just deactivate the this lines:
                    //digitalWrite(MAILBOX_FRONT_PIN, HIGH);
                    //digitalWrite(MAILBOX_BACK_PIN, HIGH);
                    and solder two resistor from 3.3v to pin 2 and 3.
                    F 1 Reply Last reply
                    • n3roN n3ro
                      F
                      F
                      f1dev
                      Ok, so I found that it is the radio that draws about 7mA when I ground input pin 2, it is connected to IRQ-pin on the radio.
                      @n3ro Have you connected the radio as described on the build-page? [http://www.mysensors.org/build/connect_radio](link url)
                      • F f1dev
                        n3roN
                        n3roN
                        n3ro
                        @f1dev yes. But you don't need irq on a node :)
                          @n3ro
                          int oldBatteryPcnt;
                          int repeat = 20;
                          int trigger = -1;
                            msg.set(0);
                              switch (trigger) {
                                case 0:
                                  post = true;
                                case 1:
                                  post = false;
                                default:
                            trigger = -1;
                              msg.set(post);
                              lastpost = post;
                              sendBattery();
                          n3roN
                          n3roN
                          n3ro
                          @BulldogLowell could you please explain your changes? I don't understand everything of this :sweat:
                          • F
                            F
                            f1dev
                            @n3ro Ok, thanks! Then I learned something new today.. IRQ is only needed for receiving nodes then, like repeaters and gateways, right?
                            Strange though that my circuit draws so much more current than yours. I have tested different setups, different arduinos and different radios from different suppliers with same result.
                            Well, at least my mailbox are mysensored now! :smiley:
                            • n3roN
                              n3roN
                              n3ro
                              I think you need the irq only for the gw. I have a receive node without irq.
                              Do you have changed fuses on your arduino?
                              And remember. All this stuff is cheap China electronic.The devices can vary consume a lot of electricity.
                              • F
                                F
                                f1dev
                                Nope, havent done that yet. It´s a "stock" 3v3 pro mini. Still reading up on how to do that and how to change to MYS-bootloader, curious on how OTA-update works.
                                Big thanks for your respons! :smile:
                                • F f1dev
                                  n3roN
                                  n3roN
                                  n3ro
                                  @f1dev sweebe wrote a very good howto:
                                  http://forum.pimatic.org/topic/383/tips-battery-powered-sensors
                                  • F
                                    F
                                    f1dev
                                    @n3ro - Thanks, that was really helpfull!:smile:
                                    • n3roN n3ro
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @n3ro Brilliant! He recommends to take out the voltage regulator. it is easier (and works better) just to snip off one leg as described here http://www.mysensors.org/build/battery. I'll try his other mods.... hopefully now my nodes will last forever!!!!
                                      • Ashley SavageA
                                        Ashley SavageA
                                        Ashley Savage
                                        quality project, been having a tinker with mixed results. used sketch from original post, but would it be possible to get a circuit diagram showing pull up locations??? bit of a beginner, but have had a few success with rolling out some power operated sensors , this is my first battery operated sensor...
                                        • n3roN
                                          n3roN
                                          n3ro
                                          No problem. I make one :) give me a day
