  2. Announcements
  3. MySensors micro step-up module revision 1.0
25 Posts 13 Posters 16.0k Views 1 Watching
  • axillentA axillent
    Through a discussion on the forum we found a potential interest to the step-up module with excellent battery saving capabilities
    We decided to present to you such a module
    It is actually same technology as will be used for MySensors Battery board, but it allows to choose any other board for your battery operated project.
    Module is using one of the best in class chip with hight efficiency and low quiescent current, this allows to run your device for longer time
    Module is designed with standard 2.54 pitch connector, can be easily connected using dupon wires
    Output voltage can be selected by switch 3.3V or 5V
    As power source you can use:
    • for 3.3V output - 1-2 alkaline, 1-3 NiMh/NiCd or solar up to 3.3V
    • for 5V - 1-3 alkaline, 1-4 NiMh/NiCd or solar up to 5V
    100mA output for 3.3V or 70mA for 5V are at minimum guaranteed
    Size is just 15x15mm
    Estimated retail price before shipping cost is $5
    Anyone interested?
    Prototype is on photo fully tested
    @axillent Did you do some measurements on the stability of the supply when powering an Arduino + radio?
    axillentA 1 Reply Last reply
    • YveauxY Yveaux
      axillentA
      axillentA
      axillent
      @Yveaux what kind of stability you are interested in?
      the output voltage will be stable while the source is able to source at a level above 0.7V
      sense and drive
        @axillent There was a lot of discussion in another thread about radio troubles caused by fluctuations in power supply. Performance could be improved significantly by adding a capacitor to the supply of the radio. It would be nice if the whole could be powered by just this module, without requiring extra capacitors.
        So, please do some tests with a radio connected running a mysensors sketch with your step-up module (or maybe the whole board once you connect the radio) and compare the results to when directly powered from batteries (without step-up). The range and amount of lost packets should be comparable.
        • YveauxY Yveaux
          axillentA
          axillentA
          axillent
          @Yveaux
          the need of the capacitor for radio is depends on how long are the wires (or PCB tracks) from power source to radio
          my step-up module have a sufficient capacitor (good quality low ESR X7R) on the output
          if wires will be not long there will be no need of an additional capacitor
          otherwise an additional capacitor need to be soldered close to radio
          on Battery board I add a second capacitor for unquestionable performance
          sense and drive
            Anyone interested?
            B
            B
            Bandra
            @axillent Looks like a much-needed part for our battery sensors. Is there any chance of moving the pins together to emulate the current step converter in the store? Ie, having three pins in a row: Vout GND Vin. This makes it a drop-in replacement for the existing part.
            • greglG
              greglG
              gregl
              Wow..Nice! Nice fingernails too...i could never photo mine...all chewed up!!! ;-)
              With respect to the capacitior for the radio - i saw @axillent you are soldering a tantalum cap directly to the radio - i really like that method!
              http://forum.mysensors.org/topic/185/battery-sensor-v-1-0-pcb/29
              Alex - i guess this chip cannot output both 3.3 and 5V at the same time, so would it be possible to have a module with two of these chips each one at 3.3 and the other at 5v ??
              -Then it can be used for 5v sensors/devices.
              Greg
              • Z
                Z
                Zeph
                What is the chip used?
                • Z Zeph
                  axillentA
                  axillentA
                  axillent
                  @Zeph it is the same as for Battery board - tps61222. It has lowest quiescent current on the market
                  sense and drive
                  • BSoftB
                    BSoftB
                    BSoft
                    @axillent said:
                    tps61222
                    In the past i was thinking on TPS78233. The idea was solder it on a pro mini board, then i think it could be difficult to solder something too small and quit the idea :D
                    • B Bandra
                      axillentA
                      axillentA
                      axillent
                      @Bandra
                      unfortunately there is no standard convention of this type. It is hard to match all different needs
                      input and output connectors are a generic tradeoff
                      sense and drive
                      • greglG gregl
                        Greg
                        axillentA
                        axillentA
                        axillent
                        @gregl
                        current draw from the battery is a multiplication from the stepup ratio
                        this means that current draw from the buttery with 5V output is 1.5 times higher comparing to 3.3V with the same current on the output
                        also current on the output much less depends on the voltage etc. MCU will draw 1-5mA regardless (with some extend) the VCC voltage
                        this leads into conclusion that as lower VCC used as better will be battery life
                        In my opinion 2.4V will be even more optimal for Battery board, but it is much more convenient to have 3.3V
                        While you need 5V you need to choose:
                        • best choice is to find all needed components able to work from 3.3V. For example PIR sensor is usually run from 4.5-20V. But there is no problem to purchase PIR running from 0.7-6V
                        • least optimal choice is to select 5V as a basic operation. This way you can use cheap LDO (like XC6206P332MR) to source radio
                        having two channels in stepup as you requested will double cost because you will need double number of components
                        and you always can use two universal modules simultaneously, one configured to 3.3V and other to 5V
                        sense and drive
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Interested.. any ETA?
                          RJ_Make
                          hekH 1 Reply Last reply
                          • RJ_MakeR RJ_Make
                            @ServiceXp
                            A sample has been ordered from factory. When Alexander is back from vacation we'll verify and order production. A wild guess 1-1.5 month.
                            • axillentA
                              axillentA
                              axillent
                              #21
                              I'm finally back from a long trip
                              Sorry to be silent
                              Seeed stepup boards are awaiting me at home.
                              Just need to run final performance tests
                              sense and drive
                                Sorry to be silent
                                bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @axillent Fantastic! But they will come pre-soldered I hope :P
                                  axillentA
                                  axillentA
                                  axillent
                                  @bjornhallberg yes sure
                                  this is for so called engineering samples
                                  sense and drive
                                  • T
                                    Tibus
                                    wich inductor do you use for this chip. Your inductor seems verry small!
                                    • J
                                      J
                                      johnr
                                      wrote on last edited by johnr
                                      #25
                                      How far away are these today?
