  3. First node: nothing work
16 Posts 6 Posters 7.0k Views 2 Watching
    A Former User
    I already try that without success.
    Using same cable with same arduino works like a charm for the gateway.
    • rvendrameR
      rvendrameR
      rvendrame
      Do you get any output on serial monitor on node side?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
        A Former User
        No, nothing.
        • msamy.earthM
          msamy.earthM
          msamy.earth
          Try to clear the EEPROM first, then re-upload your sketch.
            A Former User
            I have already clear the EEPROM many times. No changes.
            I have activate the DEBUG mode on the RF24_config.h file:
              #define FAILURE_HANDLING
              #define SERIAL_DEBUG
            I can now see some debug informations:
            send: 255-255-255-255 s=255,c=3,
            And nothing more. Some kind of "failed broadcast" ?
            Maybe, the gateway seems to never respond to this first broadcast; the gateway never receive it anyway.
              Looks like it is dying in the middle of serial log output.
              What happens if you try the same sketch on the working "serial-gateway"-Arduino you were talking about in the first post? You might have some faulty hardware there..
              • K
                K
                kalle
                Is the NRF24 connected to externel 3.3V power or to the 3.3V from the Nano? The NRF24 antenna version has a higher power consumption as the version without antenna.
                  A Former User
                  Same thing append if I try the serial sketch on the working "serial-gateway". If I try the gateway sktech on the "bad" arduino, the gateway seems to start.
                  The NRF24 is connected to the 3.3V out from the Arduino nano. I will try to use and external power supply; or maybe, I will buy the NRF24 without antena. Thanks for that suggestion.
                  • H
                    H
                    Harrdy
                    wrote on last edited by Harrdy
                    • The NRF24 antenna version is:
                      -- working current in transmit mode is 115mA
                      -- working current in receiver mode is 45mA
                    For the NRF24 non antenna version i did'nt find any details of power consum. (only 1uA on Power down mode)
                    Arduino Nano:
                    • The total current from all the IO pins together is 200 mA max.
                    • The 3.3V output is capable of supplying 150 mA.
                      -- Note - Any power drawn from the 3.3V rail has to go through the 5V rail. Therefore, if you have a 100 mA device on the 3.3V output, you need to also count it against the 5V total current.
                    The 5V output is much powerful on the Arduino nano. U can try to use a 5V to 3.3V stepdown regulator like AMS1117
                    • K
                      K
                      kalle
                      Here are the specifications from the NRF24 without antenna
                      http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01#Specification
