  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 473.0k Views 30 Watching
  • scalzS scalz
    @Anticimex:
    ok, it is good to know. You have thought about everything!
    If signer(true) for gateway, Will the controller (Jeedom, Domoticz..) see a crypted payload in serial transmission or will it work like before (I understand there are some changes in message structure, but what about crypted payload, does the controller need to decrypt?)
    AnticimexA
    AnticimexA
    Anticimex
    @scalz We only sign messages. There is no encryption involved. And the signature is stored without affecting the message contents so it is perfectly compatible with all controllers. The only thing that could affect a controller is the new sign bit in the message header but I don't think that will make any difference as it is not relevant to the controller. It is the gateway that manages this for it.
      ok, it is new for me, so I am mixing vocabulary, but I understand the concept. Thank you, and now I have my answer. no big changes for controller side, great! It makes sense, but I was not sure.
        Fix pushed to development.
        • AnticimexA
          AnticimexA
          Anticimex
          Thanks for that!
          • J
            J
            jsondag
            wrote on last edited by jsondag
            #114
            I put together a garage door opening using code from korttoma. I used soft signing, and it works great. I was wanting to use a real atsha though.
            I bought some atsha204a chips from amazon, and the chips are marked with only "3eas", and a "Y" in one corners. They are soic-8. Is that how this should be marked? I wired one up according to the data sheet. Gnd to Gnd, VCC to 5V, and SDA to A3. I ran the personalizer to generate a key and it said "Failed to wake device." in the serial console. Am I doing something wrong? or did I just get the wrong chip from the seller?
            AnticimexA 1 Reply Last reply
            • J jsondag
              AnticimexA
              AnticimexA
              Anticimex
              @jsondag I don't have a good explanation on the software signing not working. Maybe inadequate decoupling leads to a too noisy power rail?
              About the HW issue, it is important that you use the single wire version of atsha204. NOT the i2c version. The i2c version also has an scl line while the single wire only has sda (and power and ground). That means your soic8 should have 5 unused pads. Atmel ordering code for that variant is ATSHA204A-SSHCZ-T but unfortunately it is not printed on the case. So unless you find that information from Amazon, I am afraid it is very difficult to determine the type of the chips you've got.
              • J
                J
                jsondag
                #116
                @Anticimex. Software signing is working fine.
                Thanks for the information though. I didn't realize the soic 8 couldn't do one wire. It's a ATSHA204-SH-DA-B according to the listing.
                EDIT:
                Looking at the datasheet, it says that the SCL pin can be ignored for single wire interface. perhaps I'll wire another one up and give it a go.
                Just connect, SDA to A3, correct?
                • J jsondag
                  EDIT:
                  AnticimexA
                  AnticimexA
                  Anticimex
                  #117
                  @jsondag ok. From what I could read there are two different order codes for i2c and one-wire so I don't think you can take an i2c variant board and treat it as a one-wire board by just ignoring the scl pin. But if the board really is single-wire, the pinout will be the same as the i2c version, you can just ignore the scl pin as it is NC for the one-wire variant. And from the data sheet, SHDAB is i2c not "single-wire" so I am afraid you cannot use my libs for those. I only have drivers for single-wire chips i am afraid.
                  • TD22057T
                    TD22057T
                    TD22057
                    I just received my chips today from digikey (part num ATSHA204A-STUCZ-TCT-ND) which are the small 3 pin versions. Holy cow these are things are tiny. These are going to be a lot more difficult than I expected to hand solder.
                    • TD22057T TD22057
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @TD22057 If you don't have a "inverse" tweezer to fixate the chip to the board, just glue it in place. With proper iron temp (at least 300 deg C, I use 330) it's very doable. Much easier than smd resistors/caps if you ask me :) (just don't forget to solder after you glue if you do that)
                      TD22057T 1 Reply Last reply
                      • AnticimexA Anticimex
                        TD22057T
                        TD22057T
                        TD22057
                        Thanks - I'll try that as soon as everything arrives. Watching parts trickle in from aliexpress shippers is killing me (I think I've become spoiled on Amazon prime shipping).
                        • T
                          tomkxy
                          First of all I would like to thank Anticimex for this great piece of work!
                          I am playing around with signing right now. I set up a temp & humid sensor with soft signing support as well as a MQTT gateway with soft signing.
                          In principle it seems to work. At least sensor values are published to the MQTT broker. However, in the gateway output I see nonce tr errors and sign failures.
                          Started!
                          0;0;3;0;9;read: 21-21-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0107FD8
                          0;0;3;0;9;read: 21-21-0 s=1,c=1,t=0,pt=7,l=5,sg=1:25.1
                          publish: MyMQTT/21/1/V_TEMP 25.1
                          0;0;3;0;9;read: 21-21-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:012B06D
                          0;0;3;0;9;send: 0-0-21-21 s=1,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                          0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5,sg=1:59.0
                          publish: MyMQTT/21/2/V_HUM 59.0
                          0;0;3;0;9;sign fail
                          0;0;3;0;9;send: 0-0-21-21 s=2,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                          0;0;3;0;9;nonce tr err
                          0;0;3;0;9;read: 21-21-0 s=255,c=3,t=17,pt=6,l=25,sg=0:01D5F523C2778AA
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:0104881
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:019A79B
                          0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5,sg=1:59.2
                          publish: MyMQTT/21/2/V_HUM 59.2
                          0;0;3;0;9;sign fail
                          0;0;3;0;9;read: 21-21-0 s=255,c=3,t=17,pt=6,l=25,sg=0:0120D83204D1A06
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01AB761
                          0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:013CD41
                          0;0;3;0;9;read: 21-21-0 s=2,c=1,t=1,pt=7,l=5,sg=1:59.3
                          publish: MyMQTT/21/2/V_HUM 59.3
                          0;0;3;0;9;send: 0-0-21-21 s=1,c=3,t=16,pt=0,l=0,sg=0,st=fail:
                          I am somehow irritated concerning those failures logged after the publish logs. They seem not to be related to receiving and publishing the sensor data. What can be source of that? Why might the gateway trying to transmit?
                          A second question is related to personalization of the ATSHA204. Am I right that the key is displayed in the SlotConfig00 - SlotConfig0F?
                          The second personalization step fails with the message "Data lock failed". What could be the reason for that?
                          • T tomkxy
                            Started!
                            0;0;3;0;9;sign fail
                            0;0;3;0;9;sign fail
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @tomkxy Thanks.
                            "nonce tr err" is sent if sendRoute() fails to send a nonce request. So it suggests the radio link is somewhat unreliable and that in turn causes signing to fail. From what I can see you want to sign messages in both directions, so maybe traimsission from the MQTT gateway is not as reliable as reception? message type 16 (command 3) is a nonce request and sometimes it succeeds
                            and sometimes it fail (with that message as consequence):
                            But the failing one is to a different sensor (2) than the first one (1), so perhaps that node is down or at a long range? But last in your log you also fail a transmission to sensor 1. In any case, the nonce tr err is because of failing radio transmissions and as such not a signing issue as such. Sometimes it works (when there are no radio issues:
                            0;0;3;0;9;read: 21-21-0 s=1,c=3,t=16,pt=0,l=0,sg=0: (request for nonce to GW)
                            0;0;3;0;9;send: 0-0-21-21 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:01AB761 (GW sends nonce back)
                            0;0;3;0;9;read: 21-21-0 s=1,c=1,t=0,pt=7,l=5,sg=1:25.1 (signed message with that nonce is received)
                            publish: MyMQTT/21/1/V_TEMP 25.1 (message/signature is accepted and forwarded)
                            "sign fail" is typically reported if nonce exchange times out. You can adjust the timeout using MY_VERIFICATION_TIMEOUT_MS if you have many hops or for other reasons cannot process messages fast enough.
                            I have not tested MQTT gateway myself, and perhaps it uses the MySensors library differently but I have tested both serial and ethernet gateway. But in this case, it probably fails because you never got the request for the nonce out so your sender never got a chance to send a nonce back, and therefore signing cannot succeed.
                            So the key is to determine why the transmission of the nonce request fail (a radio problem since you get st=fail). Or implement a retransmission at a higher level in your sketch if the radio link is "lossy". The signing backend assumes a working channel and do not handle retransmission for you on failures.
                            Regarding personalization, key is never displayed. It is stored in slot 0. Slotconfigs are used to set the permissions of the slots. They don't store keys themselves.
                            You should get the reason for the data lock failure in the code that is sent together with the message. It is the ATSHA circuit itself that provide this value (or the library communicating with it in case of communication problem).
                            • T
                              tomkxy
                              Thanks for your fast reply. Regarding the communication failures: I was testing this with both transmitters lying side by side. Do you have any idea why the gateway might want to have a nonce. Is it part of the sensor protocol?
                              The two sensors displayed in the log are basically the same sensor (DHT22 providing temp and humidity).
                              With respect to the key topic: The first personalization step provides the following output:
                              Device revision: 00020009
                              Device serial:   {0x01,0x23,0x48,0xC9,0x51,0x6A,0x1A,0x06,0xEE}
                              012348C9516A1A06EE
                              Chip configuration:
                                         SN[0:1]           |         SN[2:3]           | 01   23 | 48   C9
                                                        Revnum                         | 00   09   04   00
                                                        SN[4:7]                        | 51   6A   1A   06
                                  SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 13 | 00 | 00
                                I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                                       SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                                       SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                                       SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                                       SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                                       SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                                       SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                                       SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                                       SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
                                UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
                                UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
                                UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
                                UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                                                    LastKeyUse[0:3]                    | FF   FF   FF   FF
                                                    LastKeyUse[4:7]                    | FF   FF   FF   FF
                                                    LastKeyUse[8:B]                    | FF   FF   FF   FF
                                                    LastKeyUse[C:F]                    | FF   FF   FF   FF
                                UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 55
                              Can I provide any key in the second personalization step or does it have to be same than in the first step being generated?
                              • T tomkxy
                                012348C9516A1A06EE
                                Chip configuration:
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @tomkxy The protocol is described in the first post. Any node that is sending a signed message to another node (that has requested to get signed messages) will ask for a nonce. So you have configured your gateway to require signed messages as well as your node.
                                Regarding the personalization, I do t understand your question. The output is the chip configuration. It does not list any keys. I am not sure I understand what you mean by second step. You can generate a random key and that key you store and after you store it you have an option to also lock it, but then you have no way of ever changing it. I have documented the personalization flow also in the sketch itself.
                                • AnticimexA
                                  AnticimexA
                                  Anticimex
                                  I should emphasise that if you personalize multiple atsha:s you have to have the same key stored in all of them. But the sketch offer to generate a random key (but you can skip that and use any key or password you like). But the key must be the same for all members of a secure network that want to talk to each other.
                                  • T
                                    tomkxy
                                    @Anticimex: The output shown is related to the sketch configuration you described in your description:
                                    Set the following sketch configuration of the personalizer:
                                    Enable LOCK_CONFIGURATION
                                    Disable LOCK_DATA
                                    Enable SKIP_KEY_STORAGE
                                    Disable SKIP_UART_CONFIGURATION
                                    Disable USER_KEY_DATA
                                    Execute the sketch on the “master” device to obtain a randomized key. Save this key to >a secure location and keep it confidential so that you can retrieve it if you need to
                                    personalize more devices later on.
                                    I was wondering that I did not see any explicit reference to a key. So may be I just have to retry.
                                    I should emphasise that if you personalize multiple atsha:s you have to have the same >key stored in all of them. But the sketch offer to generate a random key (but you can >skip that and use any key or password you like). But the key must be the same for all >members of a secure network that want to talk to each other.
                                    Thanks for that clarification. I was aware of that.
                                    • T tomkxy
                                      Disable LOCK_DATA
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @tomkxy are you sure you have enabled all those options? According to the dump, your configuration is still not locked and therefore no randomized key can be generated. Are there no more output from the sketch than that? You mentioned failure to lock data zone but I cannot see that message. And you cannot lock datazone without locking configuration.
                                      After the sketch locks configuration it will print a randomized key in the log.
                                      • T
                                        tomkxy
                                        @Anticimex: Thanks for your patience and your support.
                                        I rerun it with the output and sketch configuration listed below. May be the reason that it is not working that my poor soldering skills bricked the device.
                                        Extract from sketch (1st run):
                                        #include <sha204_library.h>
                                        #include <sha204_lib_return_codes.h>
                                        // The pin the ATSHA204 is connected on
                                        #define ATSHA204_PIN 17 // A3
                                        // Uncomment this to enable locking the configuration zone.
                                        // *** BE AWARE THAT THIS PREVENTS ANY FUTURE CONFIGURATION CHANGE TO THE CHIP ***
                                        // It is still possible to change the key, and this also enable random key generation
                                        #define LOCK_CONFIGURATION
                                        // Uncomment this to enable locking the data zone.
                                        // *** BE AWARE THAT THIS PREVENTS THE KEY TO BE CHANGED ***
                                        // It is not required to lock data, key cannot be retrieved anyway, but by locking
                                        // data, it can be guaranteed that nobody even with physical access to the chip,
                                        // will be able to change the key.
                                        //#define LOCK_DATA
                                        // Uncomment this to skip key storage (typically once key has been written once)
                                        #define SKIP_KEY_STORAGE
                                        // Uncomment this to skip key data storage (once configuration is locked, key
                                        // will aways randomize)
                                        // Uncomment this to skip key generation and use 'user_key_data' as key instead.
                                        //#define USER_KEY_DATA
                                        // Uncomment this for boards that lack UART
                                        // IMPORTANT: No confirmation will be required for locking any zones with this
                                        // configuration!
                                        // Also, key generation is not permitted in this mode as there is no way of
                                        // presenting the generated key.
                                        #if defined(SKIP_UART_CONFIRMATION) && !defined(USER_KEY_DATA)
                                        #error You have to define USER_KEY_DATA for boards that does not have UART
                                        Output:
                                        ATSHA204 personalization sketch for MySensors usage.
                                        012348C9516A1A06EE
                                        Skipping configuration write and lock (configuration already locked).
                                        Chip configuration:
                                          UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
                                        Disable SKIP_KEY_STORAGE to store key.
                                        Data not locked. Define LOCK_DATA to lock for real.
                                        Configuration is LOCKED
                                        Data is UNLOCKED
                                        Second run with the following sketch settings (key used removed):
                                        #define LOCK_DATA
                                        //#define SKIP_KEY_STORAGE
                                        // configuration!
                                        #ifdef USER_KEY_DATA
                                        #define MY_HMAC_KEY 0x…
                                        const int sha204Pin = ATSHA204_PIN;
                                        012348C9516A1A06EE
                                        Chip configuration:
                                        Using this user supplied key:
                                        #define MY_HMAC_KEY 0x…..
                                        Writing key to slot 0...
                                        Data lock failed. Response: D3
                                        Halting!
                                        • T tomkxy
                                          //#define LOCK_DATA
                                          // configuration!
                                          Output:
                                          012348C9516A1A06EE
                                          Chip configuration:
                                          Data is UNLOCKED
                                          #define LOCK_DATA
                                          // configuration!
                                          012348C9516A1A06EE
                                          Chip configuration:
                                          Halting!
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #129
                                          @tomkxy I'm on phone so I cannot check the response code right now but you could look it up in the atsha datasheet or in the software. I have not tried to lock data myself and I do not recommend it because it makes it impossible to change the key later on if it is comprised. From what I can see, everything looks good except the locking of the datazone (your key)
                                          12.5k
