  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
  • YveauxY
    @NeverDIe I committed a small sketch + NRF24 library which should essentially do the same as your sketch.
    Please find it at https://github.com/Yveaux/NRF24_CurrentFingerprint.
    I verified its behavior using the NRF24 sniffer:
    upload-c8184e00-67be-43e9-af4c-43242e39b830
    Maybe we could compare register settings to be absolutely sure settings are identical:
    upload-1418cfa7-5a26-40ff-9531-7221378b1875
    Maybe you can repeat one of your measurements with this sketch, just to make sure we're measuring in the same way?
    Currently I'm having a hard time measuring the actual current during transmit. I've not been able to get the individual spikes on the scope, not by using a uCurrent nor a single 1ohms resistor.
    This is a uCurrent plot, set at 1mV/uA:
    upload-2a6efb00-7e6a-462f-b3ce-f3a179b80ae6
    That boils down to 1.3mA peak during transmission... That can't be right?!
    • YveauxY
      #117
      Small update: using a 10ohms resitor, the current profile looks like:
      upload-fe4a379b-9a19-4e5d-ba78-086f1906e86b
      10mV/mA, so my module peaks at 11.7 mA. This module contains a 100% genuine Nordic nRF24L01+.
      A module containing a proven fake nRF24L01+ (marked 1242AF), reveals following current profile:
      upload-916e4d87-e4f8-4262-bef9-fd82dbfbca1d
      This one peaks at 19.8mA !!
      Register settings and on-air packets are identical.
      For completenes my measurement setup:
      • Lab supply, which powers USB isolator
      • USB isolator between PC & Arduino (otherwise ground-loops mess things up when using a USB scope on the same PC)
      • 10 ohms resistor
      upload-3ba85b97-4e4a-40af-86f6-00f38b5d545b
        #118
        That's great!
        The red module I tested (above) also used 1242AF. So, asuming the NRF chip in the Itead is genuine (which seems increasingly likely), then proportionately speaking, we're getting similar measurements.
        Aside from the Picoscope, what is your test setup? You don't seem to be experiencing the fat scope lines that I am. Where is the NRF module in your photo? Is it being levitated by the wires in the photo? I'm surprised the wires don't seem to be picking up noise.
          That's great!
          #119
          @NeverDie I added it to my previous post.
          Overview of whole setup:
          upload-f518c490-0a0f-4376-899d-14af8966192a
          I never had issues with the wires picking up noise; at least not enough to distort communication. They're approx. 20cm long.
          One more:
          upload-972e72b1-ed33-4440-8f4f-602ac91263bf
          Module with nRF marked 1322DQ, supposedly genuine.
          Also 11.2mA
          Tried it with another, random 1242AF, which gave 21.4mA
            Exactly which USB isolator are you using? Sounds like I should get myself a couple in case I ever need to do this again.
              #121
              @NeverDie A Chinese clone of this circuit: https://www.circuitsathome.com/measurements/usb-isolator
              The power socket is used to power the isolated USB side.
              Beware this isolator ca only handle FullSpeed (12MBit/s), so not USB 2.0 HighSpeed (480MBit/s).
              This prevents me from isolating my USB scope with it...
                #122
                Your setup roughly resembles my first attempt, where I was also using an Uno. However, I was overwhelmed with noise, which made me try the RFToy. I wasn't using isolators, though. I'm glad you got yours working, because it means that just about anyone with isolators and a scope can maybe do this test for themselves. As illustrated by you, the setup if pretty easy to follow. Good job!
                P.S. Does using ribbon cable, as you are doing, rather than individual Dupont wires (as I did when I tried using the Uno) also help with controlling noise?
                  Interestingly, the USB cable that came with my Rigol has big ferrite cores on both ends of it. So, that probably helps as well.
                    Actually, you could just power that arduino using a battery. Right? Having the isolator is nice, in that you can monitor what's happening, but not strictly necessary.
                    So, really, I guess anyone with an o-scope can do this test, which is great!
                      @NeverDie correct!
                      With some simple hardware the uno could measure the current by itself and determine the maximum current used!
                      This has potential!
                      • YveauxY Yveaux
                        @NeverDie correct!
                        This has potential!
                        #126
                        @Yveaux said:
                        @NeverDie correct!
                        This has potential!
                        Which hardware would that be?
                          #127
                          It turns out my scope can do better than I thought. Here's the blob module again, but this time at 5mv/div.
                          So, I may be able to use an even smaller resistor, because now I can go down to 1mv/div, whereas before it seemed it wouldn't let me go lower than 10mv/div. Hopefully that will help improve my measurement accuracy.
                          YveauxY Z Nca78N 3 Replies Last reply
                            @Yveaux said:
                            @NeverDie correct!
                            This has potential!
                            @NeverDie shunt resistor & opamp. Not sure about the sampling speed of the AtMega yet. Have to dive into its data sheet first....
                              @NeverDie transmission takes 233us in my measurements. What's the hdiv on your scope? 500/200us?
                              • YveauxY Yveaux
                                Which chip? The 1242AF (presumed fake), or the one that might be genuine (the one on the Itead module)?
                                  #131
                                  @NeverDie any chip. Transmission time is identical every time.
                                  • YveauxY Yveaux
                                    @Yveaux said:
                                    @NeverDie any chip. Transmission time if identical every time.
                                    Here's my best picture of the start of the transmission cycle for the blob module. I'm not sure where to call the actual start of it though, but we need to agree on that if we're going to compare numbers without pictures.
                                    It's labeled on the upper bar (just to the right of the red "STOP") 50us/div
                                    I modified the resister to be 1/2ohm, so now the vertical is 4ma/div, because it's 2mv/div vertical. Make sense?
                                      #133
                                      @NeverDie your horizontal scale is very different from what I measure.
                                      The initial low-level part in the last scope picture shows only part of what you identify as transmission time, while it already lasts roughy 250us. That's more than the whole transmission time I measure!
                                      We're definitely measuring differently.
                                      Quickly off my head: a single message is 14 bytes long (see the sniffer capture above). At 1mbit this will take 14*8/1mbit=112 us. Add some time for startup, preamble, shutdown etc. and I think total time will be in the order of 233us, as I measured.
                                      Could you try running the sketch I put on github to compare things? Probably you will only have to change cs/ss pins to run it (I stick to the default mysensors connections)
                                      It will also toggle a digital output on pin 3 before/after transmission which you can put on the scope together with the current measured, to have a reference when actual transmission takes place.
                                      Tonight (in 12 hours or so) I can do some more measurements if necessary.
                                        #134
                                        I just now noticed where you put your markers on your o-scope plot. There are two voltage increases, the second settles out higher than the first, and it looks like you're counting both. I would guess transmission doesn't really start until the higher voltage is reached, though, wouldn't you? That also is a better match to your 112us number. Perhaps the lower voltage corresponds to loading the buffer or something like that that doesn't need the higher transmit power.
                                        If you don't mind my asking, why the interest in the transmission length? Doesn't it have to be pretty similar from one type of chip to another, or else they won't interoperate?
                                          #135
                                          I think that's probably what's happening. I'm running on an 8Mhz Pro Mini (effectively), and you're running on a 16Mhz Uno. So, your first hump takes about half the time mine does ( is that right?), whereas both our second humps should take about the same amount of time. Ahhhhh..., except they don't. Your second hump appears to take longer than my blob module's second hump does. Mine is about 100us, and yours is about 150us? Is that what interests you?
