  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
    #122
    Your setup roughly resembles my first attempt, where I was also using an Uno. However, I was overwhelmed with noise, which made me try the RFToy. I wasn't using isolators, though. I'm glad you got yours working, because it means that just about anyone with isolators and a scope can maybe do this test for themselves. As illustrated by you, the setup if pretty easy to follow. Good job!
    P.S. Does using ribbon cable, as you are doing, rather than individual Dupont wires (as I did when I tried using the Uno) also help with controlling noise?
      Interestingly, the USB cable that came with my Rigol has big ferrite cores on both ends of it. So, that probably helps as well.
        Actually, you could just power that arduino using a battery. Right? Having the isolator is nice, in that you can monitor what's happening, but not strictly necessary.
        So, really, I guess anyone with an o-scope can do this test, which is great!
          @NeverDie correct!
          With some simple hardware the uno could measure the current by itself and determine the maximum current used!
          This has potential!
          • YveauxY Yveaux
            @NeverDie correct!
            This has potential!
            #126
            @Yveaux said:
            @NeverDie correct!
            This has potential!
            Which hardware would that be?
              #127
              It turns out my scope can do better than I thought. Here's the blob module again, but this time at 5mv/div.
              So, I may be able to use an even smaller resistor, because now I can go down to 1mv/div, whereas before it seemed it wouldn't let me go lower than 10mv/div. Hopefully that will help improve my measurement accuracy.
              YveauxY Z Nca78N 3 Replies Last reply
                @Yveaux said:
                @NeverDie correct!
                This has potential!
                @NeverDie shunt resistor & opamp. Not sure about the sampling speed of the AtMega yet. Have to dive into its data sheet first....
                  @NeverDie transmission takes 233us in my measurements. What's the hdiv on your scope? 500/200us?
                  • YveauxY Yveaux
                    Which chip? The 1242AF (presumed fake), or the one that might be genuine (the one on the Itead module)?
                      #131
                      @NeverDie any chip. Transmission time is identical every time.
                      • YveauxY Yveaux
                        @Yveaux said:
                        @NeverDie any chip. Transmission time if identical every time.
                        Here's my best picture of the start of the transmission cycle for the blob module. I'm not sure where to call the actual start of it though, but we need to agree on that if we're going to compare numbers without pictures.
                        It's labeled on the upper bar (just to the right of the red "STOP") 50us/div
                        I modified the resister to be 1/2ohm, so now the vertical is 4ma/div, because it's 2mv/div vertical. Make sense?
                          #133
                          @NeverDie your horizontal scale is very different from what I measure.
                          The initial low-level part in the last scope picture shows only part of what you identify as transmission time, while it already lasts roughy 250us. That's more than the whole transmission time I measure!
                          We're definitely measuring differently.
                          Quickly off my head: a single message is 14 bytes long (see the sniffer capture above). At 1mbit this will take 14*8/1mbit=112 us. Add some time for startup, preamble, shutdown etc. and I think total time will be in the order of 233us, as I measured.
                          Could you try running the sketch I put on github to compare things? Probably you will only have to change cs/ss pins to run it (I stick to the default mysensors connections)
                          It will also toggle a digital output on pin 3 before/after transmission which you can put on the scope together with the current measured, to have a reference when actual transmission takes place.
                          Tonight (in 12 hours or so) I can do some more measurements if necessary.
                            #134
                            I just now noticed where you put your markers on your o-scope plot. There are two voltage increases, the second settles out higher than the first, and it looks like you're counting both. I would guess transmission doesn't really start until the higher voltage is reached, though, wouldn't you? That also is a better match to your 112us number. Perhaps the lower voltage corresponds to loading the buffer or something like that that doesn't need the higher transmit power.
                            If you don't mind my asking, why the interest in the transmission length? Doesn't it have to be pretty similar from one type of chip to another, or else they won't interoperate?
                              #135
                              I think that's probably what's happening. I'm running on an 8Mhz Pro Mini (effectively), and you're running on a 16Mhz Uno. So, your first hump takes about half the time mine does ( is that right?), whereas both our second humps should take about the same amount of time. Ahhhhh..., except they don't. Your second hump appears to take longer than my blob module's second hump does. Mine is about 100us, and yours is about 150us? Is that what interests you?
                              • Z
                                Z
                                Zeph
                                wrote on last edited by Zeph
                                #136
                                We would expect the data transmission per se to include a fixed prefix byte, 5 bytes of address, 9 bits of control, 4 bytes of payload, and 2 bytes of CRC (I think). 105 bits = 105uS. (I'm not sure where the 14 bytes in the calculation @Yveaux presented comes from. Either the nRF sends a 16 bit control but only documents 9 bits of it, or the nRF actually sends 9 bits but some software translates the 9th bit into a second byte for analysis purposes)
                                Before that there's something like 130 uS to power up and stabilize. And there could be additional time gaps before or after the data per se.
                                And of course before all that, there is the time to load the data and commands via SPI; power might potentially rise during that, I suppose.
                                Only the time to load commands and data would seem to care whether the uC is running at 8 or 16 MHz. The 105 uS data time should be the same, if they are OTA compatible. The 130 uS power up and stabilizing time could vary between chip designs.
                                Any way to see if the fake chip is one of those transmitting with more RF power output? (If it wastes more power doing the same job, not good. If it has the ability to run at higher power but can also be reduced to sip more carefully, that could be a win).
                                I look forward to your further testing. Maybe worth checking how much supply current is saved in the other transmit power settings.
                                  Z
                                  Z
                                  Zeph
                                  How did you reduce the noise so much in your later scope captures?
                                  • Z Zeph
                                    http://www.eevblog.com/forum/testgear/how-do-i-get-1mvdiv-on-the-1054z-i'm-only-getting-10mvdiv/
                                    Also,
                                    https://www.youtube.com/watch?v=DMXiD3dKYJc
                                    How's that for timely?
                                    • Z
                                      Z
                                      Zeph
                                      #139
                                      Suggestion: for the clone/fake chips, could you test whether they have the SI24R01 power control?
                                      That is, set bit 1 of register 6 and see if they draw even more current. That should set the SI24R01 - or perhaps a derivative or clone of it - from 2-3 dBm to 7 dBm, which will probably mean using more supply current when the bit is 1 than when it's 0.
                                      See the (currently) last couple of links in the OP of the fakes thread.
                                      • Z
                                        Z
                                        Zeph
                                        #140
                                        You might also see if the second register bank can be selected (ACTIVATE+0x53) and read. See http://sigrok.org/wiki/Protocol_decoder:Nrf24l01#Variants_and_clones_of_the_chip from the penultimate link on the fakes thread.
                                        If it has a second register bank then it's probably a BK24* series or a clone/derivative thereof. (Note that the contents of that second bank seem to be undocumented, at least in English). This niche is apparently popular enough that there are second level derivatives - for example advertised as being BK24* compatible which is in turn nRF24 compatible with extensions!
                                        I did catch a reference somewhere that implied there was a real RSSI in the second register bank in some derivative; that could be handy if true.
                                        There's a reference at that same link to the Nordic nRF24L01 (no plus) needing an ACTIVATE+0x73 command to enable certain features that are automatically available in the nRF24l01+.
                                        This is not something I am aware of. I wonder if some features like ESB can be enabled on the non-plus version? Anyway, if so, this might also be a test which helps sort out clones - if they look like a non-plus derivative, do they respond to ACTIVATE+0x73? (the linked source does not suggest that 250 Kbps mode is one of the features which could be activated)
                                          #141
                                          @Zeph: I'll may attempt those things tonight, though I'll be giving priority to moving over to TBRH20 first, as it will be better for comparisons if we minimize platform differences, as well as run the same library.
                                          Z 1 Reply Last reply
