  3. W5100 Ethernet module PoE
poew5100ethernetarduino
10 Posts 5 Posters 8.3k Views 4 Watching
    SebDominguez
    Hello everyone !
    I'm trying to supply power to my project using this breakout board (W5100) and a PoE injector.
    The board have PoE+ and PoE- pin directly connected on ethernet pin 8 and 7 but when I provide power through the ethernet cable, there isn't any power on PoE+ and PoE-.
    Probably I'm doing something wrong...
    Can someone give me a little help ?
    Thanks a lot !
      SebDominguez
      Nobody ?
      • P
        P
        pjeterinfo
        Are 7 and 8 not both gnd?
          SebDominguez
          In standard PoE yes, but I'm trying everything here and I can't get current on those pin.
          I'v tried V+ on pin 8 and V- on pin 7, V+ on pin 4, 5, V- to pin 7, 8 and still nothing...
          this guy : http://hazymat.co.uk/2015/01/home-automation-poe-with-arduino-in-praise-of-diy-poe/ had the same issue...
          Is it possible that this ethernet breakout has "fake" PoE label ?
          • P
            P
            pjeterinfo
            wrote on last edited by pjeterinfo
            This module doesn't seem to have a 48v dc/dc converter. At least from the picture I do not recognize it.
            Allso I don't see in the description that it have power over ethernet.
              SebDominguez
              There isn't any DC/DC converter, but there is 2 pin dedicated to PoE according to the labels on the PCB :/
              • P
                P
                poldim
                Did you have any luck on solving this?
                • NiunN
                  NiunN
                  Niun
                  Hi, ive had the same Problem...
                  According to the datasheet from the rj45 port, poe is not possible in this circuitry.
                  http://www.kosmodrom.com.ua/pdf/HR911105A.pdf
                    SebDominguez
                    wrote on last edited by SebDominguez
                    To close this topic : this particular module doesn't have anything close to PoE (passive nor active)
                    The PoE labels on the board are Fake or leftover.
                    • R
                      R
                      Rpx
                      Hi, sorry for the delay, I had just read your post and I could said "me too"
                      But I solved the problem and it works for two years now.
                      I explain my solution here, if the French don't afraid you.
                      https://easydomoticz.com/forum/viewtopic.php?f=20&t=6497
                      I resume, a 7.5volts power supply, a passive injector, and a spécial home-made cable to bypass the RJ45 socket. The 7.5 v go to Vin-Gnd of the Nano to produce 5v wich is returned to the W5100. QED.
                      Rpx.
