  3. Ethernet Gateway - Radio Init Fail
12 Posts 3 Posters 5.5k Views 2 Watching
  • stevebusS stevebus
    @stevebus Meant to add a couple more details
    • this is all on a breadboard at the moment. prototyping before soldering it all via PCB
    • LEDs are connected to pins 7, 8, and 9
    • I get the same results in the serial monitor if I unplug VCC and GND for the radio!!.. Is this the first place in the code that we try to talk to the radio?? (not having a step debugger stinks :-) )
    SparkmanS
    SparkmanS
    Sparkman
    wrote on last edited by Sparkman
    @stevebus The Ethernet shield does not play nice on the SPI bus, so it's having problems talking to the radio. You need to move the radio to different pins and enable SoftSPI. Search the board for details on that. As a quick test, set up a serial gateway first with the radio on the pins you are currently using and if that works, you know the radio is good.
    Al
    • stevebusS
      stevebusS
      stevebus
      Thanks for the response...
      From the gateway wiring guidance page, I thought the SPI issue was only with the Wiznet based Ethernet shield. Is that not the case?
      I'll give the SoftSPI route a try. Thx for the quick response.
      Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
      Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
        The ENC module usually works without SOFTSPI.. But it is really tight to get it in on the ATMega328.
        SparkmanS 1 Reply Last reply
          You might have picked up a none+ variant of the NRF24 module which doesn't support the 250kbs transfer speed.
          You might get around this by increasing speed to 1mbps in MyConfig.h and remove the sanity check in MySensors library.
            SparkmanS
            SparkmanS
            Sparkman
            Thanks for the clarification!
            Al
            • stevebusS
              stevebusS
              stevebus
              thanks for the clarification and help, guys.. You guys rock with the quick responses! (and Mysensors in general is friggin' awesome!)
              I moved the wires and enabled SoftSPI and got further than I was. I managed to get to the hallowed "gateway started" message, but got gobbledygook for the st param.. this is what got printed..
              c=327,t=310,pt=288,l=273,sg=631,st=»:qmjëlVúšÚö�iÿïs0¼�÷ïÜžºKmýÏO»rgædöûå=_ošóÕëÖÌ›§2ŒT†—<÷¿Îºô}~Bõò>,{÷5/
              does that look right? or an issue? what does a 'working' gateway look like (without yet having any sensors or connecting to Vera)? Should I be able to ping it? (I can't) Should I be able to telnet to port 5003? (I can't)
              • stevebusS
                stevebusS
                stevebus
                disregard the note above about not being able to ping or telnet to the gateway... that was user error :-)...
                the question still remains about the gobbledygook in the st param of the 'gateway started' message. is that legit?
                  wrote on last edited by hek
                  "gateway started" is a good message :)
                  But gobbelgoo is not good.
                  • stevebusS
                    stevebusS
                    stevebus
                    Ok... update... I had some debug code in there from when I was trying to find out where the initialization was failing, and I think I introduced a bug... I removed my code and re-ran and got this:
                    that looks good :-)...
                    thanks for the help guys!
                      SparkmanS
                      SparkmanS
                      Sparkman
                      @stevebus Glad to hear you got it working!
                      Al
