  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • O
    O
    Omemanti
    wrote on last edited by Omemanti
    #148
    Hi. I was wondering if someone could get the irrigation controller working with this program?
    I'm new to this all, and so far this the easiest controller that I came across. ( got the gateway etc working with almost no effort)
    • F
      F
      fitzpatrick
      Hi, nice work. Is there any chances that you add the possibility to log the nodes information to a mysql database ?
      • 5546dug5
        5546dug5
        5546dug
        Hi @tekka
        I am having trouble understanding the error codes on this gui.
        It is the solar mini weather stn on proto board and it is not working properly.
        At this minute I see that the g/w code is telling me 4-4-5-0 ,there was a node 5 in my My Sensors package and it was configured as a repeater but it is not here as it connected laptop> usb port/cord> ftdi 3.3v> 3.3 v promini.
        As the code cannot get to and from node 5 it is a down as a st=fail
        Is there a why to change this in your program to allow continuing debugging my sketch?
        Am I again missing something?
        • 5546dug5
          5546dug5
          5546dug
          tekkaT 1 Reply Last reply
          • 5546dug5 5546dug
            tekkaT
            tekkaT
            tekka
            @5546dug the log looks like a sensor log, try connecting MYSController to the gateway...
            • rvendrameR
              rvendrameR
              rvendrame
              Hello guys, I'm trying to burn the MYSBootloader.hex into some Pro minis (clones) here, however after burning it, they get somehow 'bricked' :
              • I'm using my Uno "as ISP" on IDE 1.6.4
              • I've followed the step-by-step tutorial posted above by @tekka
              • My pro-minis are 5V, 16Mhz, external clock , 328p, supposedly a perfect match with 'boards.txt' info...
              • "Burn bootloader" ends successful, with "Done burning boot loader" message.
              • After that, the pro-mini pin 13 led flashes in a kind of random pattern, and it is not possible to upload any sketch, nor any kind of serial monitor on any speed.
              • I can revert it, by selecting the standard 'Arduino Pro or Pro Mini' board , and burn boot loader again. It makes the pro-mini gets back to live, I can upload my sketches and serial monitor it.
              So my questions:
              • I don't have extra eprom connected --- Is it mandatory? I've read somewhere that it can be disabled, but can't find the instructions anymore...
              • Fuse adjustments?
              • What else can I do in order to troubleshooting it?
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
                #154
                @rvendrame: it seems to be wrong fuses. MYSBootloader does not use extra eeprom. It's DualOptiboot which uses one. You need to set fuses. Then burn bootloader. For fuses you need to look in boards.txt . It should work. For setting fuses, I use usbasp. I never tried with uno.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @scalz, thanks for the reply. BTW, did you see this?
                  Well, with standard bootloader (working), my pro-minis have fuses as FF DA 05 (Low/High/Ext).
                  The MYSBootloader.hex boot loader (not working) is set in boards.txt with F7 DA 06.
                  I have played with all possible combinations (including changing values in boards.txt), no luck.
                  Maybe I have to compile my own version of MYSBootloader? Sorry, this is all new to me...
                  Thx again
                  Alexa / Google Home
                    @rvendrame: Hi I don't have a mac. But I use a similar tool for win (avrdudess). but your link seems ok.
                    You don't have to recompile MYSBootloader. MYSBootloader needs to match fuses. If not, it will blink like you have seen. Do you have an usbasp? very useful. So you need to burn fuses F7 DA 06. Did you try that? And then burn bootloader.
                    Be careful when burning fuses, don't try combination or you will semi-brick atmel chip (meaning you could not be able to reprogram it normal spi way). Never enable RSTDISBL and DWEN bits in fuse. You can see all of this here http://www.engbedded.com/fusecalc/ very useful too!
                    If in future you want to test new ota, I have made a small breadboard to test it. You can find it here : https://oshpark.com/profiles/scalz You will need to solder eeprom and atsha.
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      @scalz, yes I have tried to burn fuses F7 DA 06, and then MYSBootloader, no joy.
                      Maybe the main diference is the low fuse F7 ( = Ext.Clock full-swing Crystal ) , as my pro-minis run fine with FF ( = Ext. Crystal Osc 8.MHz ) ?
                      Alexa / Google Home
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        @scalz , one more thing: What speed did you set? The AVRFuses seems to work on at 19200 bps --- Could this be a problem?
                        And moreover --- You mentioned that extra eprom is not required --- But what about atsha? I don't have that either... (just pro-mini + radio ). Is it required for OTA?
                        Alexa / Google Home
                          @rvendrame: I am not at home at this moment. but I will check. baudrate is already set up in .hex and in boards.txt . So I think it should work..strange thing. I don't know MYSBootloader so. maybe grandmaster @Tekka have an idea:grinning: maybe something has changed. I don't know.
                          extra eeprom is for new ota in mysensors 1.5
                          ATSHA is optional, it is just on the board too. It is for authentication in 1.5 too.
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            I'm using 1.5 --- So do I need the extra eprom ?
                            Alexa / Google Home
                              no. you don't need it.
                              two ota bootloaders are available for mysensors. MYSBootloader and Dualoptiboot. MYSBootloader does not require extra eeprom. Dualoptiboot needs it. sorry for confusion:smirk:
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                wrote on last edited by rvendrame
                                #162
                                No problem, that's clear. Any other idea? The only thing I could progress was to catch the firmware upload in verbose mode (see bellow, it looks ok to me).
                                One question: Is it okay to have "Boot Flash size = 1024 words" , and the .hex file having ~32Kb ? More strange is that file has 5.676 bytes when I check it via Mac finder.
                                avrdude: input file /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes    <<<<<<< ?????
                                /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                                         System wide configuration file is "/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
                                         User configuration file is "/Users/i007897/.avrduderc"
                                         Using Port                    : /dev/cu.usbmodem1421
                                         Programmer Type : STK500
                                         Hardware Version: 2
                                         Firmware Version: 1.18
                                         Topcard         : Unknown
                                         Vtarget         : 0.0 V
                                         Varef           : 0.0 V
                                         Oscillator      : Off
                                         SCK period      : 0.1 us
                                Reading | ################################################## | 100% 0.05s
                                avrdude: erasing chip
                                Writing | ################################################## | 100% 0.02s
                                avrdude: verifying ...
                                Writing | ################################################## | 100% 0.06s
                                avrdude: reading input file "0xF7"
                                avrdude: verifying lfuse memory against 0xF7:
                                avrdude: load data lfuse data from input file 0xF7:
                                avrdude: input file 0xF7 contains 1 bytes
                                Fuse burn:
                                avrdude done.  Thank you.
                                /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -Uflash:w:/Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                                         Hardware Version: 2
                                         Topcard         : Unknown
                                         Vtarget         : 0.0 V
                                         Varef           : 0.0 V
                                         Oscillator      : Off
                                         SCK period      : 0.1 us
                                avrdude: reading input file "/Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex"
                                avrdude: verifying flash memory against /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:
                                avrdude: load data flash data from input file /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:
                                avrdude: reading input file "0x0F"
                                Writing | ################################################## | 100% 0.05s
                                avrdude: verifying lock memory against 0x0F:
                                avrdude: load data lock data from input file 0x0F:
                                avrdude: input file 0x0F contains 1 bytes
                                And
                                Alexa / Google Home
                                • rvendrameR rvendrame
                                           Hardware Version: 2
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  Fuse burn:
                                           Hardware Version: 2
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  And
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @rvendrame weird...the .hex file size is 5676 bytes (this is the intel hex format and MYSBootloader is under 2kb, so 1024 words are ok). The 32722 bytes are the cause of the problem...
                                  You mentioned that burning the standard bootloader revives your Arduino - can you post the verbose mode output as comparison?
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Sure, here it is. Very similar (including the size of .hex file)... strange...
                                    /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    avrdude: reading input file "0x05"
                                    avrdude: verifying efuse memory against 0x05:
                                    avrdude: load data efuse data from input file 0x05:
                                    avrdude: input file 0x05 contains 1 bytes
                                    avrdude: verifying lfuse memory against 0xFF:
                                    avrdude: load data lfuse data from input file 0xFF:
                                    /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -Uflash:w:/Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i -Ulock:w:0x0F:m
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    avrdude: reading input file "/Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
                                    avrdude: writing flash (32670 bytes):
                                    avrdude: 32670 bytes of flash written
                                    avrdude: verifying flash memory against /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
                                    avrdude: load data flash data from input file /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
                                    avrdude: input file /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
                                    avrdude: 32670 bytes of flash verified
                                    Alexa / Google Home
                                      @rvendrame: when you try to upload a sketch, do you use ftdi? because I think you can't upload with ftdi in MYSBootloader. just ota. I looked quickly at the code. Am I right @tekka ? If you want ota+ftdi options, you must use dualoptiboot.
                                      • scalzS scalz
                                        tekkaT
                                        tekkaT
                                        tekka
                                        wrote on last edited by tekka
                                        #166
                                        @scalz: for flashing bootloaders you have to communicate to the MCU via SPI (e.g. via USBasp, ArduinoISP, Atmel STK500, etc.) but not the usual (ftdi) serial interface.
                                        MYSBootloader 1.1 supports only OTA sketch uploads (at the moment), this is right - but not related to the issue of @rvendrame
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          #167
                                          @scalz , @tekka, I'm using "Arduino as ISP" to burn the bootloader. I have my arduino Uno connected to mac via USB, and running on it the "ArduinoISP" sketch delivered with IDE.
                                          The pins VCC, GND, 11, 12, 13 from Uno are connected to same pins of the pro-mini (the one being programmed). Pin 10 from uno goes to pro-mini's reset pin.
                                          In summary, this scenario. It works perfectly for the standard pro-mini bootloader. I had success with both 3.3V and 5V versions.
                                          To upload my sketches: I understand that I have to compile it, move the generated .hex file to the MYSController "Firmware" folder, and load it via 'Node -> Assign FW' . I did it this part with some sense benders that I have here, and it worked perfectly --- That made me thinking in re-flashing all pro-minis that I have with MYSbootloader ;-)
                                          The problem is that my pro-minis get 'bricked' after burning the MYSbootloader --- pin led flashes randomly , no serial-monitor, I don't think they are really running.
                                          Just to be 100% sure --- I just need the pro-mini itself connected during the "Tools -> Burn bootloader" ? No radio, no extra eprom, no atsha, ... right?
                                          I tried to connect the radio to pro-mini after I burned the MYS, as a last desperated try (who know it would 'wake up' ). But no joy ;-)
                                          Thx!
                                          Alexa / Google Home
