  3. Problems uploading Serial Gateway on to Arduino Pro Micro
19 Posts 3 Posters 8.6k Views 3 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    You must see 'Gateway started' or something like that in serial monitor. Otherwise your controller will not notice it.
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • D
      den2k
      wrote on last edited by den2k
      I have a Pi Controller. Do you mean I need to see "Gateway started" in the serial monitor on the Arduino IDE when I have the Pro Micro gateway connected to the PC?
      Just trying to be extra clear, as it seems to be working for some many, so I'm trying to rule out stupid assumptions on my end.
      If yes. I dont see anything.
      I downloaded MySensor 1.5 API and believe I correctly followed the instructions....I've done this a few times already... Hmmm.
      SparkmanS 1 Reply Last reply
      • D den2k
        SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        Yes, that's what you need to see. It's odd that you don't see anything. Are you sure it's programming correctly? I updated my serial gateway from 1.4 to 1.5 tonight and I had no issues. Which version of the Arduino IDE are you using? Did you delete the 1.4 libraries from the Arduino libraries section?
        Al
        • D
          den2k
          I'm using Arduino IDE 1.6.5.
          • D den2k
            SparkmanS
            SparkmanS
            Sparkman
            @den2k That's what I used as well. If you downloaded the 1.5 zip file, delete all of the 1.4 files and drop all of the folders in the libraries folder in the zip file into your local Arduino libraries folder. Also, can you confirm which exact Arduino you are using (maybe provide a link).
            Al
            • D
              den2k
              This is what I see.
              upload-e2cd0ccc-1b64-40ea-913c-c7c34fc342d9
              • rvendrameR
                rvendrameR
                rvendrame
                "Arduino as ISP"? Did you try the standard "AVR ISP mkII' instead?
                "Arduino as ISP" Means you are using an arduino to program another arduino (as described here). If you are connecting the target-arduno directly into an FTDI-USB adapter, use AVR ISP-like ....
                Even if you do have two arduinos, after uploading your program you must use an FTDI adapter directly between your target-arduino and your computer-usb. I'm saying that because I could never get serial monitor using 'ArduinoISP' programmer, maybe it works with some trick.
                Alexa / Google Home
                • D
                  den2k
                  I changed it to AVRISP mkll, Arduino ISP, Arduino as ISP. Didn't seem to make a difference....
                  Still not seeing anything on the serial monitor. After programming it successfully.
                  I may try deleting all libraries and try the install of MySensors again. I've seen that suggested else.
                  I did upgrade from 1.4 previously to 1.5. Was having problems (posted on separate thread) so thought 1.5 might help...
                  upload-3bd3f1e5-1627-40b4-9605-5c31260dd8ee
                  • D
                    den2k
                    Nope.
                    I just finished
                    • reinstalling the Arduino IDE 1.6.5.
                    • Reinstalled Pro Micro Drivers
                    • Reinstalled Pro Micro PlugIn for IDE
                    • Reinstalled MySensors 1.5 libraries into IDE libraries
                    • Uploaded the Serial gateway script to the Pro Micro.
                    • Successfully compiled and uploaded to the micro.
                    Not working....still. I still don't see anything on the Serial Monitor.
                    What am I suppose to see on the Monitor?
                    SparkmanS 2 Replies Last reply
                    • D den2k
                      Nope.
                      I just finished
                      SparkmanS
                      SparkmanS
                      Sparkman
                      @den2k Do you have a different Arduino you can test with?
                      D 1 Reply Last reply
                      • D den2k
                        Nope.
                        I just finished
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @den2k Also, try connecting and pressing a reset switch on the Pro Micro quickly twice in a row just before uploading. See https://learn.sparkfun.com/tutorials/pro-micro--fio-v3-hookup-guide/troubleshooting-and-faq#ts-reset.
                        • D
                          den2k
                          I tried to check if it has anything to do with my nRF24L01+ radios.
                          When I go back to basics and use the RF24 Getting Started example. this is what I get.
                          upload-f193aa6d-a6ea-481a-87b6-f3da60f61bde
                          Looking around I thought I was suppose to get a status register output on the serial monitor.
                          Does it mean the radios are not genuine?
                          I'm really pulling my hair out trying to figure this stuff out.
                          I know my radios works because I've used other examples to have different nRF radios send messages back and forth...
                          • SparkmanS Sparkman
                            den2k
                            @Sparkman
                            I tried that. I'm pretty sure the radios and arduinos themselves work. I have several that I play with and have swapped out some - just to eliminate HW being the issue.
                            I'm guess it's a dumb problem that I caused....hmm
                            thanks for the help everyone! Just wished it was working!
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              Maybe you can post a picture or schematics showing how you are connecting the radio to arduino? You last screenshot is showing only 'failed' for any radio operation.
                              Alexa / Google Home
