Problems uploading Serial Gateway on to Arduino Pro Micro
@den2k That's what I used as well. If you downloaded the 1.5 zip file, delete all of the 1.4 files and drop all of the folders in the libraries folder in the zip file into your local Arduino libraries folder. Also, can you confirm which exact Arduino you are using (maybe provide a link).
Al -
"Arduino as ISP"? Did you try the standard "AVR ISP mkII' instead?
"Arduino as ISP" Means you are using an arduino to program another arduino (as described here). If you are connecting the target-arduno directly into an FTDI-USB adapter, use AVR ISP-like ....
Even if you do have two arduinos, after uploading your program you must use an FTDI adapter directly between your target-arduino and your computer-usb. I'm saying that because I could never get serial monitor using 'ArduinoISP' programmer, maybe it works with some trick.
I changed it to AVRISP mkll, Arduino ISP, Arduino as ISP. Didn't seem to make a difference....
Still not seeing anything on the serial monitor. After programming it successfully.
I may try deleting all libraries and try the install of MySensors again. I've seen that suggested else.
I did upgrade from 1.4 previously to 1.5. Was having problems (posted on separate thread) so thought 1.5 might help...
Nope.
I just finished
- reinstalling the Arduino IDE 1.6.5.
- Reinstalled Pro Micro Drivers
- Reinstalled Pro Micro PlugIn for IDE
- Reinstalled MySensors 1.5 libraries into IDE libraries
- Uploaded the Serial gateway script to the Pro Micro.
- Successfully compiled and uploaded to the micro.
Not working....still. I still don't see anything on the Serial Monitor.
What am I suppose to see on the Monitor?
Nope.
I just finished
Nope.
I just finished
@den2k Also, try connecting and pressing a reset switch on the Pro Micro quickly twice in a row just before uploading. See https://learn.sparkfun.com/tutorials/pro-micro--fio-v3-hookup-guide/troubleshooting-and-faq#ts-reset.
I tried to check if it has anything to do with my nRF24L01+ radios.
When I go back to basics and use the RF24 Getting Started example. this is what I get.
Looking around I thought I was suppose to get a status register output on the serial monitor.
Does it mean the radios are not genuine?
I'm really pulling my hair out trying to figure this stuff out.
I know my radios works because I've used other examples to have different nRF radios send messages back and forth...
I tried that. I'm pretty sure the radios and arduinos themselves work. I have several that I play with and have swapped out some - just to eliminate HW being the issue.
I'm guess it's a dumb problem that I caused....hmm
thanks for the help everyone! Just wished it was working!
Maybe you can post a picture or schematics showing how you are connecting the radio to arduino? You last screenshot is showing only 'failed' for any radio operation.
