  3. [contest] My 12 input high precision pulse counter (kWh/ W)
[contest]
43 Posts 9 Posters 55.3k Views 10 Watching
  • AWIA AWI
    A few more pictures: Domoticz graphing for one of the meters. (good thing I can compensate with Solar) upload-7dab3b7d-0a78-430e-85b4-4f0a91782bfb
    Pulse meter used (€ 22 a piece). Take care, not a real hobby article to connect...
    bjornhallbergB
    bjornhallbergB
    bjornhallberg
    @AWI Are those KWH DIN meters from Ebay or did you buy them locally? I was thinking of doing something similar a while back but was put off by the cost and inability to install them myself (not understanding much of mains installation and phases). Would be great to single out the heating system at least so I can have two groups. Not easy to make any serious graphs when the pump is pulling ~3kW once or twice an hour.
    AWIA 1 Reply Last reply
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @bjornhallberg I bought them locally but these things are available everywhere. Not difficult to install when you have a single phase mains. You can also put them in a separate box (piicture from the public domain.....). .
      upload-812b9f87-de2f-4358-8183-81502d355064
      After that you can play with a reliable "once per Wh" pulse..
      • AWIA
        AWIA
        AWI
        The pulse counter and codeupload-3fa9c75e-f258-4a59-a958-efdf1cb678a9
        The pulse counter produces a simple JSON string per S0 meter every 10 secondsupload-ba9d50ce-e940-43c4-96ab-3afb2445720a . The string shows the meter number. Number of counts (Wh ) since last send. Average period (duty cycle in ms) between pulses to calculate the current power (3,600,000,000/ period) and a pulse accumulation since the start of the counter. You can use this to keep things in sync when the serial connection or processing is not always stable.
        https://codebender.cc/sketch:86789
        for the sake of Codebender I have combined all in one file.
        The pulse counter can be attached to any serial port (using a UNO, Nano or FTDI) and used for all kinds applications and counting purposes. I will focus on MySensors...
        • AWIA
          AWIA
          AWI
          The main unit in production. I used a Nano or UNO for easy debugging/ programming and 5v USB charger. The rest is deep down in the closet in a 1 Euro housing (no need for fancy 3d printing). The display is fitted in bamboo left overs from IKEA boxes.
          upload-4db471b2-d055-4eae-a4e0-7802b7ac49a4
          (it displays time/ pressure from a left over BMP180 now)
          Another one with a 4x20 display, with room for some extra information
          upload-e644fd4a-812f-4a16-bdf6-021f0ba8848f
          And the code.
          https://codebender.cc/sketch:87047
          • AWIA
            AWIA
            AWI
            Parts list & build instruction (excluding radio...)
            upload-972620e1-b3fd-40e2-8052-83bb2a51898b
            upload-e450e360-24e1-429c-935d-e68495c2c312
            upload-7d9c8fb5-d554-48b2-b74a-4ec82c3751e2
            upload-1bdc2866-91b9-42e0-9c37-025b6256f1a7
            Price (estimate):
            2 x arduino (ali): Euro 5
            1 x I2C LCD (ali): ,, 4
            1 x rotary encoder ,, 2
            2 x 100nf ,, 0.4
            16 x screw terminals ,, 1.6
            wires ,, 1
            breadboard/ pcb ,, 2
            Total Euro 16
            The S0 meters will cost your more: Euro 12-30 / pcs, including (backlight) display, excluding installation.
            (eg. SDM120.pdf there are also types available which give you a MODBUS RS-485 interface and kWh, V, A, PF, F, kWh-r for around Euro 50/pcs)
            • V
              V
              Vince
              wrote on last edited by Vince
              This is great , exactly what i was looking for.
              I do have a few questions, is it possible to double the amount of inputs ?
              I "need" 24 or 25 inputs since i got so many meters like on the picture.
              Or is it possible to build 2 of these devices and that domoticz detect it ?
              Also, can you maybe tell me if it is possible to keep a log from all the sensors apart from each other ?
              So you can check what meter 1 has used for the amount of days/weeks/years ?
              Or it it all combined to 1 number ?
              • V Vince
                AWIA
                AWIA
                AWI
                @Vince Glad you like it. It is possible to extend the number of inputs but I would suggest to add another arduino for that purpose. The whole thing is timing critical. Especially in relation to "counting" the actual power. Every counter is logged separate and sent to the gateway controller.
                • V
                  V
                  Vince
                  Thanks Awi for the reply, i just noticed it and actually forgot to look.
                  This is great news , i will start collecting some parts i need and a few Arduinos to make it hopefully work.
                  Will report how it goes !
                    MarkV
                      A Former User
                      Great project, ive made this project, i had to declare the chars this was not done in your script? i had to declare:
                      lcd.createChar(1, degCelcius);
                      lcd.createChar(2, hecto);
                      lcd.createChar(3, Pascal);
                      lcd.createChar(4, Lux);
                      lcd.createChar(5, visible);
                      lcd.createChar(6, infrared);
                      lcd.createChar(7, rel_humidity);
                      i declared them for eg:
                      uint8_t degCelcius[8] = {0x18,0x18,0x3,0x4,0x4,0x4,0x3};
                      i had to change the display adress to 0x3F and tested this with a script to verify and this works, display SCL is connected to pin A5 and SDA is connected to A4.
                      ive compiled it without errors and uploaded the sketsh to the arduino nano, when connecting the slave arduino (pro mini) board the Rx led will blink every 10seconds when the json data is received.
                      but the display stays like this:
                      http://forum.arduino.cc/index.php?action=dlattach;topic=157817.0;attach=40625
                      on the top row only blocks are visible, any idea why?
                      • ? A Former User
                        AWIA
                        AWIA
                        AWI
                        @RCF It was a long time ago.... can't remember the details. It could be that the display library does not work for your LCD. If I can find a minute I will review the sketch.
                          A Former User
                          I have the same display as in your post > see the first display on this page: http://arduino-info.wikispaces.com/LCD-Blue-I2C#v1
                          there is also a test script which works fine on adress 0x3F, but i did already change that adres in your script but the display shows blocks on the first line. the library is the same i believe.
                          it would be grat if you could help :).
                          by the way if i connect a RF module will the data sended be compatible with http://openenergymonitor.org/emon/guide the Emonbase unit?
                            MarkV
                            Could you explain how to connect the sensors 2 pins?
                            On http://openenergymonitor.org/emon/buildingblocks/12-input-pulse-counting they connect it like in the picture?
                            Is it by this also like that?? Because i can't see the pull down resistors on yours..
                            • AWIA
                              AWIA
                              AWI
                              You noticed it right. I used the internal pull-up of the Arduino. Gnd is directly connected and input with the internal pull-up to vcc.
                                MarkV
                                So i don't need the extra pulldown resistor and could connect everything like drawn down below?
                                With the differance that i'm using a arduino mini wich runs on 3.3V and doesn't have a 5V point...
                                • M MarkV
                                  AWIA
                                  AWIA
                                  AWI
                                  @MarkV sounds good. I am reworking the master sketch a little to cope with the new libraries and MySensors 1.5
                                  • AWIA
                                    AWIA
                                    AWI
                                    Updated the master sketch... you need the load the latest libraries mentioned in the heading..(RotaryEncoder & arduinoJson). Adapt your settings to your display if needed (I2C address, etc.).
                                    The sketch depends on a "read/ get" from the controller for the last (or user filled) kWh values. Many controllers are lacking this functionality (i.e. Domoticz). I have a version without this (useful ) syncing capability under construction. This will allow local changes in the history by means of the rotary encoder.
                                     * MySensors interface to AWI 12 input usage/ power Meter               *
                                     *  meter generates Power/ Usage/ Cumm. usage for 12 independent chann. *
                                     * 16x2 (I2C) Display shows consumption                                 *
                                    // Licence: GNU GPL
                                    // Author: AWI 2015
                                    // Updates: AWI 20150815, new RotaryEncoder & ArduinoJson libraries
                                    // continuously:
                                    // 1. read JSON strings from Pulse12Counter slave , format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                                    // 2. calculate real time Power from "rate"
                                    // 3. store values
                                    // 4. send to controller
                                    // Get consistency with controller - controller should only be updated when initial values have been received:
                                    // 1. read Wh values from controller (local last values should be in sync with controller)
                                    // 2. compare with stored readings. Action accordingly:
                                    //    - if controller Wh > stored last reading: new startup from counter, send new Wh increment and adjust readings.
                                    //    - if controller Wh < stored last reading: something went wrong with last update, send updated values from counter
                                    // Other:
                                    // 1. display on local LCD, time & energy values, usage can be shown as Daily & Total
                                    // 2. rotary encoder to browse the different displays
                                    // Caution: pulse meter is connected to std serial (pin D0), Serial.print can still be used
                                    //    Disconnect pulse meter when programming via FTDI! (sync error)
                                    #include <MySensor.h>                 // MySensors network
                                    #include <LiquidCrystal_I2C.h>        // display I2C
                                    #include <Time.h>
                                    #include <RotaryEncoder.h>          // RotaryEncoder to browse displays https://github.com/mathertel/RotaryEncoder
                                    #include <ArduinoJson.h>           // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
                                    // Constants
                                    #define NO_METERS  5                // number of meters used (max 12)
                                    #define NODE_ID    11             // fixed MySensors node ID
                                    #define ENCODER_PINA 3            // RotaryEncoder pins
                                    #define ENCODER_PINB 4
                                    // *** Global variables
                                    // stores LCD text
                                    //char lastLCD1[21] = "Line1 - first   ";
                                    //char lastLCD2[21] = "Line2 - second  ";
                                    class pulseMeter              // meter class, store all relevant data (equivalent to struct)
                                    public:
                                      unsigned long UsageWh;                  // last (current) usage (in W) from pulse counter
                                      unsigned long UsageAccumWh;               // usage accumulator (to keep in sync) from pulse counter
                                      unsigned long PowerW;                 // actual power, calculated from pulse "rate"
                                      unsigned long DayUsageWh;           // daily usage for display
                                      bool  Updated ;             // flag to check if update from controller is received
                                    pulseMeter pulseMeters[NO_METERS] ;     // define power meters
                                    RotaryEncoder encoder(ENCODER_PINA, ENCODER_PINB); //, 1, 1, 3000);    // instance of RotaryEncoder: (Pin1, Pin2, Multiplier(), Stepsize(), pause(ms)]
                                    // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
                                        char json[50]="{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";              // Storage for serial JSON string
                                    // flags & counters
                                    bool timeReceived = false;
                                    bool newDay = false;
                                    unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
                                    int display_no = 0;             // determines what is displayed on second line, first line = time display;
                                    int currentMeter = 0;           // actual meter for update & check, cycles through meters
                                    int lastRotary = 0;    // last rotary encoder position
                                    // *** Definition and initialisation
                                    // define the MySensor network
                                    MySensor gw;                    // pins used RFX24(default 9,10)
                                    // Initialize messages for sensor network
                                    MyMessage powerMsg(0,V_WATT);         // message to send power in W
                                    MyMessage usageMsg(0,V_KWH);        // message to send usage in kWH
                                    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                                    // Temp Buffer to print readings on the LCD.
                                    char output_buffer[6];
                                    // OPTIONAL: Custom characters for display - Units (add W/ kWh?)
                                    byte degCelcius[8] = {
                                      B01000,
                                      B10100,
                                      B01000,
                                      B00111,
                                      B00100,
                                      B00100,
                                      B00111,
                                      B00000
                                    byte Pascal[8] = {
                                      B00000,
                                      B11100,
                                      B10100,
                                      B11100,
                                      B10010,
                                      B10111,
                                      B10101,
                                      B00000
                                    byte hecto[8] = {
                                      B00000,
                                      B00000,
                                      B00000,
                                      B00100,
                                      B00110,
                                      B00101,
                                      B00101,
                                      B00000
                                    byte Lux[8] = {
                                      B00000,
                                      B10000,
                                      B10101,
                                      B10010,
                                      B10010,
                                      B10101,
                                      B11100,
                                      B00000
                                    /*byte visible[8] = {
                                      B00000,
                                      B00000,
                                      B00001,
                                      B00000,
                                      B10101,
                                      B10101,
                                      B01001,
                                      B00000
                                    byte infrared[8] = {
                                      B00101,
                                      B00010,
                                      B10101,
                                      B00000,
                                      B10110,
                                      B10100,
                                      B10100,
                                      B00000,
                                    byte rel_humidity[8] = {
                                      B00101,
                                      B00010,
                                      B00101,
                                      B10000,
                                      B11000,
                                      B10100,
                                      B10100,
                                      B00000,
                                    void setup(void)
                                        //Serial in Sensor network = 115200
                                        gw.begin(incomingMessage, NODE_ID, false);  // this node is fixed, no repeat
                                        //Send the sensor node sketch version information to the gateway
                                        gw.sendSketchInfo("AWI-12ChannelPulse", "1.0");
                                        // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                                        for (int x = 0; x < NO_METERS; x++){
                                          gw.present(x, S_POWER);             // present power meters to gateway
                                        delay(100);                         // give it some time to process
                                        // Initializations
                                        Wire.begin();                 // I2C
                                        // Request latest time from controller at startup
                                        gw.requestTime(receiveTime);
                                          gw.request(x, V_KWH);             // for sync get current values from controller
                                          pulseMeters[x].Updated = false ;      // set meter status to not in sync
                                          gw.wait(100);                         // give it some time to process
                                        // ** LCD display **
                                        lcd.begin(16, 2);             // LCD 2 lines * 16 char.
                                        lcd.setBacklight(HIGH);
                                        // send custom characters to display
                                    //    lcd.createChar(5, visible);
                                    //    lcd.createChar(6, infrared);
                                        lcd.setCursor(0, 0);             // Reset cursor position
                                    void loop(void)
                                      unsigned long now = millis();       // Timer in loop for "once in a while" events
                                      gw.process() ;                      // process incoming messages
                                        // If no time has been received yet, request it every 10 second from controller
                                        // When time has been received, request update every hour
                                        if ((!timeReceived && now-lastRequest > 10*1000)
                                          || (timeReceived && now-lastRequest > 60*1000*60)) {
                                          // Request time from controller.
                                           Serial.println("requesting time");
                                           lastRequest = now;
                                      // Check if new day has started (hour == 0) and reset day usage counters of meters
                                      if (hour()==0 && !newDay){
                                        newDay = true;
                                          pulseMeters[x].DayUsageWh = 0 ;   // reset daily counters
                                        newDay = false;
                                      // check if RotaryEncoder action for display selection
                                      encoder.tick();
                                      int enc = encoder.getPosition();
                                      if( enc > lastRotary) {
                                        if (display_no++ >= NO_METERS-1 ) display_no = 0;
                                        lastRotary = enc ;
                                      else if (enc < lastRotary) {
                                        if (display_no-- <  0) display_no = NO_METERS - 1;
                                        lastRotary = enc ;
                                      // Update display every second (mainly for time display)
                                      if (now-lastUpdate > 1000) {
                                        LCD_local_display();
                                        lastUpdate = now;
                                      // If no "RotaryEncoder", Change display every 10 seconds
                                      //if (now-lastDisplay > 10000) {
                                      //  // change display
                                      //  display_no++;
                                      //  if (display_no >= NO_METERS){         // meter display for second line
                                      //    display_no = 0;
                                      //  lastDisplay = now ;
                                      // Every 10 seconds update one meter and check if controller is still in sync
                                      if (now-lastSyncKWH > 10000){
                                        // printPulsemeter(display_no);
                                        sendPowerUpdate(currentMeter);        // update the values for currentMeter
                                        if (currentMeter++ >= NO_METERS){     // increment and wrap current meter
                                          currentMeter = 0 ;
                                        // take care of synchronization
                                        gw.request(currentMeter, V_KWH);        // get current values from controller
                                        lastSyncKWH = now;
                                      // get readings from serial (sent every 10s)
                                      // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                                      // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                                      if(readLineJSON(Serial.read(), json, 80) > 0 ){   //dummySerial(), Serial.read()
                                      // if(readLineJSON(dummySerial(), json, 80) > 0 ){   //dummySerial(), Serial.read()
                                        Serial.println(json);
                                        storeMeterJSON(json);           //store the meter reading
                                        // Ok, set incoming time
                                        setTime(controllerTime); // this sets the clock to the time from controller - which we do want periodically
                                        timeReceived = true;
                                    // This is called when a kWh message is received
                                      // Expect few types of messages from controller, V_KWH for last value of kWh (for each meter)
                                      if (message.type==V_KWH) {
                                      // if message comes in, update the kWH reading for meter with value since last update
                                      Serial.print("Last reading for sensor: ");
                                      Serial.print(message.sensor);                 // kWh is float
                                      Serial.print(", Message: ");
                                      Serial.println(message.getFloat());
                                      unsigned long ControllerUsageWh = message.getFloat()*1000 ;   // update current values
                                      if (ControllerUsageWh > pulseMeters[message.sensor].UsageWh){   // if controller value > current: meter restarted
                                        pulseMeters[message.sensor].UsageWh = ControllerUsageWh ;   //  update with controller value
                                      } // else: do nothing meter value is higher and therefore more recent
                                      pulseMeters[message.sensor].Updated = true;   // set updated status flag. Only process meters if in sync (value received).
                                    void sendPowerUpdate(int currentMeter)
                                    // Sends update to controller for current meter
                                    // !! check needs to be implemented for Correct sync with controller...
                                      if  (pulseMeters[currentMeter].Updated){      // only send when there was a sync response from the controller
                                        gw.send(powerMsg.setSensor(currentMeter).set((int)pulseMeters[currentMeter].PowerW));
                                        gw.send(usageMsg.setSensor(currentMeter).set((float)pulseMeters[currentMeter].UsageWh/1000,3)); // send in kWh!
                                        printPulsemeter(currentMeter);
                                    void LCD_local_display(void)
                                    // prints variables on LCD display with units
                                        char buf[17]; // buffer for 16 char display
                                        // start with time on first line
                                        snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
                                        lcd.setCursor(0,0);               // LCD line 1
                                        lcd.print(buf);
                                      // print meter indicated by "display_no"
                                        snprintf(buf, sizeof buf, "m%2d %4dWh %4dW", display_no+1, (int)pulseMeters[display_no].DayUsageWh, (int)pulseMeters[display_no].PowerW );
                                      lcd.setCursor(0,1);               // LCD line 2
                                      lcd.print(buf);
                                    int storeMeterJSON(char *json)
                                    /* convert JSON to values and store in corresponding meter (if used)
                                     input: JSON string (can be wrong formatted), with length
                                     output: changed meter record number or -1 if error
                                     use JsonParser
                                      StaticJsonBuffer<50> jsonBuffer;
                                      // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                                        JsonObject& root = jsonBuffer.parseObject(json);
                                      if (!root.success())
                                            Serial.println("JsonParser.parse() failed");
                                            return -1;
                                      int m = (long)root["m"];
                                      if (m > NO_METERS){                 // meter value out of range for used meters
                                        return -1 ;
                                      } else {                      // update meter values, Power is momentary, Usage is cumulative
                                        pulseMeters[m-1].UsageWh += (long)root["c"];    // pulsecount = Wh, accumulate
                                        pulseMeters[m-1].DayUsageWh += (long)root["c"];   // daily counter = Wh, accumulate
                                        pulseMeters[m-1].UsageAccumWh = (long)root["cA"]; // accumulated pulse count (only for sync and eventual error correction (serial))
                                        if ((long)root["r"] == 0){            // calculate power from pulse rate (ms) and truncate to whole Watts
                                          pulseMeters[m-1].PowerW = 0;
                                          pulseMeters[m-1].PowerW = int(3600000000 / (long)root["r"]); // rate in microseconds
                                        return m ;
                                    int readLineJSON(int readch, char *buffer, int len)
                                    /* checks for JSON and when started append char tot buffer and checks for line completion
                                    usage:
                                      static char buffer[80];
                                      if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
                                      returns simple JSON
                                      static int pos = 0;
                                      int rpos;
                                      if (readch > 0) {
                                        switch (readch) {
                                          case '\n':                // Ignore new-lines
                                          case '\r':                // Return on CR
                                            rpos = pos;
                                            pos = 0;                  // Reset position index ready for next time
                                            return rpos;
                                          default:
                                            if (pos < len-1) {
                                              buffer[pos++] = readch;
                                              buffer[pos] = 0;
                                      // No end of line has been found, so return -1.
                                      return -1;
                                    int dummySerial()
                                    // Acts as a dummy JSON serial character generator for debugging
                                    // input: none
                                    // output: preset JSON string
                                      static int pos = 0;
                                      char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
                                      if (pos++ >= strlen(json)){
                                        pos = 0;
                                      return json[pos] ;
                                    void printPulsemeter(int meter)
                                    // prints the Pulsemeter record to serial out
                                      Serial.print("m:");
                                      Serial.print(meter);
                                      Serial.print(", power: ");
                                      Serial.print(pulseMeters[meter].PowerW);
                                      Serial.print(", usage: ");
                                      Serial.print(pulseMeters[meter].UsageWh);
                                      Serial.print(", day usage: ");
                                      Serial.print(pulseMeters[meter].DayUsageWh );
                                      Serial.print(", Ca: ");
                                      Serial.println(pulseMeters[meter].UsageAccumWh);
                                      A Former User
                                      Ive updated the libraries and uploaded it to my arduino nano, in the serial of my comport it says: radio init fail.
                                      is the radio module needed to get it working? and does it connect with the emonPI of emon base http://openenergymonitor.org/emon/guide ?
                                      now the display still shows blocks on the first line just like before, is this because the RF module is not present?
                                      • ? A Former User
                                        AWIA
                                        AWIA
                                        AWI
                                        @RCF The radio is needed to have the MySensors stuff working otherwise you will get the "radio init fail" message and block the execution of the code. This sketch is not meant for anything else than MySensors. If you want to connect it to emon or anything else it can serve as inspiration...
                                          A Former User
                                          i just ordered one at ebay, where does your radio module communicated with? with a server ?
                                          i think it should also be possible to connect pin 9 and 10 to an ethernet module right? i would like to setup an emoncs server for openremote (openremote.org) on my Synology NAS
                                          korttomaK 1 Reply Last reply
