  3. [contest] My 12 input high precision pulse counter (kWh/ W)
[contest]
43 Posts 9 Posters 55.3k Views 10 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    Parts list & build instruction (excluding radio...)
    upload-972620e1-b3fd-40e2-8052-83bb2a51898b
    upload-e450e360-24e1-429c-935d-e68495c2c312
    upload-7d9c8fb5-d554-48b2-b74a-4ec82c3751e2
    upload-1bdc2866-91b9-42e0-9c37-025b6256f1a7
    Price (estimate):
    2 x arduino (ali): Euro 5
    1 x I2C LCD (ali): ,, 4
    1 x rotary encoder ,, 2
    2 x 100nf ,, 0.4
    16 x screw terminals ,, 1.6
    wires ,, 1
    breadboard/ pcb ,, 2
    Total Euro 16
    The S0 meters will cost your more: Euro 12-30 / pcs, including (backlight) display, excluding installation.
    (eg. SDM120.pdf there are also types available which give you a MODBUS RS-485 interface and kWh, V, A, PF, F, kWh-r for around Euro 50/pcs)
    • V
      V
      Vince
      wrote on last edited by Vince
      This is great , exactly what i was looking for.
      I do have a few questions, is it possible to double the amount of inputs ?
      I "need" 24 or 25 inputs since i got so many meters like on the picture.
      Or is it possible to build 2 of these devices and that domoticz detect it ?
      Also, can you maybe tell me if it is possible to keep a log from all the sensors apart from each other ?
      So you can check what meter 1 has used for the amount of days/weeks/years ?
      Or it it all combined to 1 number ?
      AWIA 1 Reply Last reply
      • V Vince
        AWIA
        AWIA
        AWI
        @Vince Glad you like it. It is possible to extend the number of inputs but I would suggest to add another arduino for that purpose. The whole thing is timing critical. Especially in relation to "counting" the actual power. Every counter is logged separate and sent to the gateway controller.
        • V
          V
          Vince
          Thanks Awi for the reply, i just noticed it and actually forgot to look.
          This is great news , i will start collecting some parts i need and a few Arduinos to make it hopefully work.
          Will report how it goes !
            MarkV
              A Former User
              Great project, ive made this project, i had to declare the chars this was not done in your script? i had to declare:
              lcd.createChar(1, degCelcius);
              lcd.createChar(2, hecto);
              lcd.createChar(3, Pascal);
              lcd.createChar(4, Lux);
              lcd.createChar(5, visible);
              lcd.createChar(6, infrared);
              lcd.createChar(7, rel_humidity);
              i declared them for eg:
              uint8_t degCelcius[8] = {0x18,0x18,0x3,0x4,0x4,0x4,0x3};
              i had to change the display adress to 0x3F and tested this with a script to verify and this works, display SCL is connected to pin A5 and SDA is connected to A4.
              ive compiled it without errors and uploaded the sketsh to the arduino nano, when connecting the slave arduino (pro mini) board the Rx led will blink every 10seconds when the json data is received.
              but the display stays like this:
              http://forum.arduino.cc/index.php?action=dlattach;topic=157817.0;attach=40625
              on the top row only blocks are visible, any idea why?
              • ? A Former User
                AWIA
                AWIA
                AWI
                @RCF It was a long time ago.... can't remember the details. It could be that the display library does not work for your LCD. If I can find a minute I will review the sketch.
                  A Former User
                  I have the same display as in your post > see the first display on this page: http://arduino-info.wikispaces.com/LCD-Blue-I2C#v1
                  there is also a test script which works fine on adress 0x3F, but i did already change that adres in your script but the display shows blocks on the first line. the library is the same i believe.
                  it would be grat if you could help :).
                  by the way if i connect a RF module will the data sended be compatible with http://openenergymonitor.org/emon/guide the Emonbase unit?
                    MarkV
                    Could you explain how to connect the sensors 2 pins?
                    On http://openenergymonitor.org/emon/buildingblocks/12-input-pulse-counting they connect it like in the picture?
                    Is it by this also like that?? Because i can't see the pull down resistors on yours..
                    • AWIA
                      AWIA
                      AWI
                      You noticed it right. I used the internal pull-up of the Arduino. Gnd is directly connected and input with the internal pull-up to vcc.
                        MarkV
                        So i don't need the extra pulldown resistor and could connect everything like drawn down below?
                        With the differance that i'm using a arduino mini wich runs on 3.3V and doesn't have a 5V point...
                        • M MarkV
                          AWIA
                          AWIA
                          AWI
                          @MarkV sounds good. I am reworking the master sketch a little to cope with the new libraries and MySensors 1.5
                          • AWIA
                            AWIA
                            AWI
                            Updated the master sketch... you need the load the latest libraries mentioned in the heading..(RotaryEncoder & arduinoJson). Adapt your settings to your display if needed (I2C address, etc.).
                            The sketch depends on a "read/ get" from the controller for the last (or user filled) kWh values. Many controllers are lacking this functionality (i.e. Domoticz). I have a version without this (useful ) syncing capability under construction. This will allow local changes in the history by means of the rotary encoder.
                             * MySensors interface to AWI 12 input usage/ power Meter               *
                             *  meter generates Power/ Usage/ Cumm. usage for 12 independent chann. *
                             * 16x2 (I2C) Display shows consumption                                 *
                            // Licence: GNU GPL
                            // Author: AWI 2015
                            // Updates: AWI 20150815, new RotaryEncoder & ArduinoJson libraries
                            // continuously:
                            // 1. read JSON strings from Pulse12Counter slave , format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                            // 2. calculate real time Power from "rate"
                            // 3. store values
                            // 4. send to controller
                            // Get consistency with controller - controller should only be updated when initial values have been received:
                            // 1. read Wh values from controller (local last values should be in sync with controller)
                            // 2. compare with stored readings. Action accordingly:
                            //    - if controller Wh > stored last reading: new startup from counter, send new Wh increment and adjust readings.
                            //    - if controller Wh < stored last reading: something went wrong with last update, send updated values from counter
                            // Other:
                            // 1. display on local LCD, time & energy values, usage can be shown as Daily & Total
                            // 2. rotary encoder to browse the different displays
                            // Caution: pulse meter is connected to std serial (pin D0), Serial.print can still be used
                            //    Disconnect pulse meter when programming via FTDI! (sync error)
                            #include <MySensor.h>                 // MySensors network
                            #include <LiquidCrystal_I2C.h>        // display I2C
                            #include <Time.h>
                            #include <RotaryEncoder.h>          // RotaryEncoder to browse displays https://github.com/mathertel/RotaryEncoder
                            #include <ArduinoJson.h>           // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
                            // Constants
                            #define NO_METERS  5                // number of meters used (max 12)
                            #define NODE_ID    11             // fixed MySensors node ID
                            #define ENCODER_PINA 3            // RotaryEncoder pins
                            #define ENCODER_PINB 4
                            // *** Global variables
                            // stores LCD text
                            //char lastLCD1[21] = "Line1 - first   ";
                            //char lastLCD2[21] = "Line2 - second  ";
                            class pulseMeter              // meter class, store all relevant data (equivalent to struct)
                            public:
                              unsigned long UsageWh;                  // last (current) usage (in W) from pulse counter
                              unsigned long UsageAccumWh;               // usage accumulator (to keep in sync) from pulse counter
                              unsigned long PowerW;                 // actual power, calculated from pulse "rate"
                              unsigned long DayUsageWh;           // daily usage for display
                              bool  Updated ;             // flag to check if update from controller is received
                            pulseMeter pulseMeters[NO_METERS] ;     // define power meters
                            RotaryEncoder encoder(ENCODER_PINA, ENCODER_PINB); //, 1, 1, 3000);    // instance of RotaryEncoder: (Pin1, Pin2, Multiplier(), Stepsize(), pause(ms)]
                            // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
                                char json[50]="{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";              // Storage for serial JSON string
                            // flags & counters
                            bool timeReceived = false;
                            bool newDay = false;
                            unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
                            int display_no = 0;             // determines what is displayed on second line, first line = time display;
                            int currentMeter = 0;           // actual meter for update & check, cycles through meters
                            int lastRotary = 0;    // last rotary encoder position
                            // *** Definition and initialisation
                            // define the MySensor network
                            MySensor gw;                    // pins used RFX24(default 9,10)
                            // Initialize messages for sensor network
                            MyMessage powerMsg(0,V_WATT);         // message to send power in W
                            MyMessage usageMsg(0,V_KWH);        // message to send usage in kWH
                            LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                            // Temp Buffer to print readings on the LCD.
                            char output_buffer[6];
                            // OPTIONAL: Custom characters for display - Units (add W/ kWh?)
                            byte degCelcius[8] = {
                              B01000,
                              B10100,
                              B01000,
                              B00111,
                              B00100,
                              B00100,
                              B00111,
                              B00000
                            byte Pascal[8] = {
                              B00000,
                              B11100,
                              B10100,
                              B11100,
                              B10010,
                              B10111,
                              B10101,
                              B00000
                            byte hecto[8] = {
                              B00000,
                              B00000,
                              B00000,
                              B00100,
                              B00110,
                              B00101,
                              B00101,
                              B00000
                            byte Lux[8] = {
                              B00000,
                              B10000,
                              B10101,
                              B10010,
                              B10010,
                              B10101,
                              B11100,
                              B00000
                            /*byte visible[8] = {
                              B00000,
                              B00000,
                              B00001,
                              B00000,
                              B10101,
                              B10101,
                              B01001,
                              B00000
                            byte infrared[8] = {
                              B00101,
                              B00010,
                              B10101,
                              B00000,
                              B10110,
                              B10100,
                              B10100,
                              B00000,
                            byte rel_humidity[8] = {
                              B00101,
                              B00010,
                              B00101,
                              B10000,
                              B11000,
                              B10100,
                              B10100,
                              B00000,
                            void setup(void)
                                //Serial in Sensor network = 115200
                                gw.begin(incomingMessage, NODE_ID, false);  // this node is fixed, no repeat
                                //Send the sensor node sketch version information to the gateway
                                gw.sendSketchInfo("AWI-12ChannelPulse", "1.0");
                                // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
                                for (int x = 0; x < NO_METERS; x++){
                                  gw.present(x, S_POWER);             // present power meters to gateway
                                delay(100);                         // give it some time to process
                                // Initializations
                                Wire.begin();                 // I2C
                                // Request latest time from controller at startup
                                gw.requestTime(receiveTime);
                                  gw.request(x, V_KWH);             // for sync get current values from controller
                                  pulseMeters[x].Updated = false ;      // set meter status to not in sync
                                  gw.wait(100);                         // give it some time to process
                                // ** LCD display **
                                lcd.begin(16, 2);             // LCD 2 lines * 16 char.
                                lcd.setBacklight(HIGH);
                                // send custom characters to display
                            //    lcd.createChar(5, visible);
                            //    lcd.createChar(6, infrared);
                                lcd.setCursor(0, 0);             // Reset cursor position
                            void loop(void)
                              unsigned long now = millis();       // Timer in loop for "once in a while" events
                              gw.process() ;                      // process incoming messages
                                // If no time has been received yet, request it every 10 second from controller
                                // When time has been received, request update every hour
                                if ((!timeReceived && now-lastRequest > 10*1000)
                                  || (timeReceived && now-lastRequest > 60*1000*60)) {
                                  // Request time from controller.
                                   Serial.println("requesting time");
                                   lastRequest = now;
                              // Check if new day has started (hour == 0) and reset day usage counters of meters
                              if (hour()==0 && !newDay){
                                newDay = true;
                                  pulseMeters[x].DayUsageWh = 0 ;   // reset daily counters
                                newDay = false;
                              // check if RotaryEncoder action for display selection
                              encoder.tick();
                              int enc = encoder.getPosition();
                              if( enc > lastRotary) {
                                if (display_no++ >= NO_METERS-1 ) display_no = 0;
                                lastRotary = enc ;
                              else if (enc < lastRotary) {
                                if (display_no-- <  0) display_no = NO_METERS - 1;
                                lastRotary = enc ;
                              // Update display every second (mainly for time display)
                              if (now-lastUpdate > 1000) {
                                LCD_local_display();
                                lastUpdate = now;
                              // If no "RotaryEncoder", Change display every 10 seconds
                              //if (now-lastDisplay > 10000) {
                              //  // change display
                              //  display_no++;
                              //  if (display_no >= NO_METERS){         // meter display for second line
                              //    display_no = 0;
                              //  lastDisplay = now ;
                              // Every 10 seconds update one meter and check if controller is still in sync
                              if (now-lastSyncKWH > 10000){
                                // printPulsemeter(display_no);
                                sendPowerUpdate(currentMeter);        // update the values for currentMeter
                                if (currentMeter++ >= NO_METERS){     // increment and wrap current meter
                                  currentMeter = 0 ;
                                // take care of synchronization
                                gw.request(currentMeter, V_KWH);        // get current values from controller
                                lastSyncKWH = now;
                              // get readings from serial (sent every 10s)
                              // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
                              // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
                              if(readLineJSON(Serial.read(), json, 80) > 0 ){   //dummySerial(), Serial.read()
                              // if(readLineJSON(dummySerial(), json, 80) > 0 ){   //dummySerial(), Serial.read()
                                Serial.println(json);
                                storeMeterJSON(json);           //store the meter reading
                                // Ok, set incoming time
                                setTime(controllerTime); // this sets the clock to the time from controller - which we do want periodically
                                timeReceived = true;
                            // This is called when a kWh message is received
                              // Expect few types of messages from controller, V_KWH for last value of kWh (for each meter)
                              if (message.type==V_KWH) {
                              // if message comes in, update the kWH reading for meter with value since last update
                              Serial.print("Last reading for sensor: ");
                              Serial.print(message.sensor);                 // kWh is float
                              Serial.print(", Message: ");
                              Serial.println(message.getFloat());
                              unsigned long ControllerUsageWh = message.getFloat()*1000 ;   // update current values
                              if (ControllerUsageWh > pulseMeters[message.sensor].UsageWh){   // if controller value > current: meter restarted
                                pulseMeters[message.sensor].UsageWh = ControllerUsageWh ;   //  update with controller value
                              } // else: do nothing meter value is higher and therefore more recent
                              pulseMeters[message.sensor].Updated = true;   // set updated status flag. Only process meters if in sync (value received).
                            void sendPowerUpdate(int currentMeter)
                            // Sends update to controller for current meter
                            // !! check needs to be implemented for Correct sync with controller...
                              if  (pulseMeters[currentMeter].Updated){      // only send when there was a sync response from the controller
                                gw.send(powerMsg.setSensor(currentMeter).set((int)pulseMeters[currentMeter].PowerW));
                                gw.send(usageMsg.setSensor(currentMeter).set((float)pulseMeters[currentMeter].UsageWh/1000,3)); // send in kWh!
                                printPulsemeter(currentMeter);
                            void LCD_local_display(void)
                            // prints variables on LCD display with units
                                char buf[17]; // buffer for 16 char display
                                // start with time on first line
                                snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
                                lcd.setCursor(0,0);               // LCD line 1
                                lcd.print(buf);
                              // print meter indicated by "display_no"
                                snprintf(buf, sizeof buf, "m%2d %4dWh %4dW", display_no+1, (int)pulseMeters[display_no].DayUsageWh, (int)pulseMeters[display_no].PowerW );
                              lcd.setCursor(0,1);               // LCD line 2
                              lcd.print(buf);
                            int storeMeterJSON(char *json)
                            /* convert JSON to values and store in corresponding meter (if used)
                             input: JSON string (can be wrong formatted), with length
                             output: changed meter record number or -1 if error
                             use JsonParser
                              StaticJsonBuffer<50> jsonBuffer;
                              // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
                                JsonObject& root = jsonBuffer.parseObject(json);
                              if (!root.success())
                                    Serial.println("JsonParser.parse() failed");
                                    return -1;
                              int m = (long)root["m"];
                              if (m > NO_METERS){                 // meter value out of range for used meters
                                return -1 ;
                              } else {                      // update meter values, Power is momentary, Usage is cumulative
                                pulseMeters[m-1].UsageWh += (long)root["c"];    // pulsecount = Wh, accumulate
                                pulseMeters[m-1].DayUsageWh += (long)root["c"];   // daily counter = Wh, accumulate
                                pulseMeters[m-1].UsageAccumWh = (long)root["cA"]; // accumulated pulse count (only for sync and eventual error correction (serial))
                                if ((long)root["r"] == 0){            // calculate power from pulse rate (ms) and truncate to whole Watts
                                  pulseMeters[m-1].PowerW = 0;
                                  pulseMeters[m-1].PowerW = int(3600000000 / (long)root["r"]); // rate in microseconds
                                return m ;
                            int readLineJSON(int readch, char *buffer, int len)
                            /* checks for JSON and when started append char tot buffer and checks for line completion
                            usage:
                              static char buffer[80];
                              if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
                              returns simple JSON
                              static int pos = 0;
                              int rpos;
                              if (readch > 0) {
                                switch (readch) {
                                  case '\n':                // Ignore new-lines
                                  case '\r':                // Return on CR
                                    rpos = pos;
                                    pos = 0;                  // Reset position index ready for next time
                                    return rpos;
                                  default:
                                    if (pos < len-1) {
                                      buffer[pos++] = readch;
                                      buffer[pos] = 0;
                              // No end of line has been found, so return -1.
                              return -1;
                            int dummySerial()
                            // Acts as a dummy JSON serial character generator for debugging
                            // input: none
                            // output: preset JSON string
                              static int pos = 0;
                              char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
                              if (pos++ >= strlen(json)){
                                pos = 0;
                              return json[pos] ;
                            void printPulsemeter(int meter)
                            // prints the Pulsemeter record to serial out
                              Serial.print("m:");
                              Serial.print(meter);
                              Serial.print(", power: ");
                              Serial.print(pulseMeters[meter].PowerW);
                              Serial.print(", usage: ");
                              Serial.print(pulseMeters[meter].UsageWh);
                              Serial.print(", day usage: ");
                              Serial.print(pulseMeters[meter].DayUsageWh );
                              Serial.print(", Ca: ");
                              Serial.println(pulseMeters[meter].UsageAccumWh);
                              A Former User
                              Ive updated the libraries and uploaded it to my arduino nano, in the serial of my comport it says: radio init fail.
                              is the radio module needed to get it working? and does it connect with the emonPI of emon base http://openenergymonitor.org/emon/guide ?
                              now the display still shows blocks on the first line just like before, is this because the RF module is not present?
                              • ? A Former User
                                AWIA
                                AWIA
                                AWI
                                @RCF The radio is needed to have the MySensors stuff working otherwise you will get the "radio init fail" message and block the execution of the code. This sketch is not meant for anything else than MySensors. If you want to connect it to emon or anything else it can serve as inspiration...
                                  A Former User
                                  i just ordered one at ebay, where does your radio module communicated with? with a server ?
                                  i think it should also be possible to connect pin 9 and 10 to an ethernet module right? i would like to setup an emoncs server for openremote (openremote.org) on my Synology NAS
                                  korttomaK 1 Reply Last reply
                                  • ? A Former User
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @RCF Maybe you should start here -> http://www.mysensors.org/about
                                    • Tomas
                                      A Former User
                                      Yes i understand that this is for extra sensors http://www.mysensors.org/about/network but when i do not have any external sensors the radio module should be there anyway
                                        MarkV
                                        I've uploaded both sketches without errors, but can't get any readings when i check the serial monitor? Also it doesn't say anything about the communication with the gateway.
                                        What's wrong? What should i check?
                                        • M MarkV
                                          AWIA
                                          AWIA
                                          AWI
                                          @MarkV Hi Mark, good hear you are trying to get it working. You need two arduino's which one is not showing serial information? You first need to get the "measurement" arduino working. This one is supposed to spit out JSON strings. Second you try the "master".
