  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
    @rvendrame: I am not at home at this moment. but I will check. baudrate is already set up in .hex and in boards.txt . So I think it should work..strange thing. I don't know MYSBootloader so. maybe grandmaster @Tekka have an idea:grinning: maybe something has changed. I don't know.
    extra eeprom is for new ota in mysensors 1.5
    ATSHA is optional, it is just on the board too. It is for authentication in 1.5 too.
    • rvendrameR
      rvendrameR
      rvendrame
      I'm using 1.5 --- So do I need the extra eprom ?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
        no. you don't need it.
        two ota bootloaders are available for mysensors. MYSBootloader and Dualoptiboot. MYSBootloader does not require extra eeprom. Dualoptiboot needs it. sorry for confusion:smirk:
        • rvendrameR
          rvendrameR
          rvendrame
          wrote on last edited by rvendrame
          #162
          No problem, that's clear. Any other idea? The only thing I could progress was to catch the firmware upload in verbose mode (see bellow, it looks ok to me).
          One question: Is it okay to have "Boot Flash size = 1024 words" , and the .hex file having ~32Kb ? More strange is that file has 5.676 bytes when I check it via Mac finder.
          avrdude: input file /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes    <<<<<<< ?????
          /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                   System wide configuration file is "/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
                   User configuration file is "/Users/i007897/.avrduderc"
                   Using Port                    : /dev/cu.usbmodem1421
                   Programmer Type : STK500
                   Hardware Version: 2
                   Firmware Version: 1.18
                   Topcard         : Unknown
                   Vtarget         : 0.0 V
                   Varef           : 0.0 V
                   Oscillator      : Off
                   SCK period      : 0.1 us
          Reading | ################################################## | 100% 0.05s
          avrdude: erasing chip
          Writing | ################################################## | 100% 0.02s
          avrdude: verifying ...
          Writing | ################################################## | 100% 0.06s
          avrdude: reading input file "0xF7"
          avrdude: verifying lfuse memory against 0xF7:
          avrdude: load data lfuse data from input file 0xF7:
          avrdude: input file 0xF7 contains 1 bytes
          Fuse burn:
          avrdude done.  Thank you.
          /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -Uflash:w:/Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                   Hardware Version: 2
                   Topcard         : Unknown
                   Vtarget         : 0.0 V
                   Varef           : 0.0 V
                   Oscillator      : Off
                   SCK period      : 0.1 us
          avrdude: reading input file "/Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex"
          avrdude: verifying flash memory against /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:
          avrdude: load data flash data from input file /Users/i007897/Dropbox/Bench/Arduino/hardware/MySensors/avr/bootloaders/MySensors/MYSBootloader.hex:
          avrdude: reading input file "0x0F"
          Writing | ################################################## | 100% 0.05s
          avrdude: verifying lock memory against 0x0F:
          avrdude: load data lock data from input file 0x0F:
          avrdude: input file 0x0F contains 1 bytes
          And
          Alexa / Google Home
          tekkaT 1 Reply Last reply
          • rvendrameR rvendrame
                     Hardware Version: 2
                     Topcard         : Unknown
                     Vtarget         : 0.0 V
                     Varef           : 0.0 V
                     Oscillator      : Off
                     SCK period      : 0.1 us
            Fuse burn:
                     Hardware Version: 2
                     Topcard         : Unknown
                     Vtarget         : 0.0 V
                     Varef           : 0.0 V
                     Oscillator      : Off
                     SCK period      : 0.1 us
            And
            tekkaT
            tekkaT
            tekka
            @rvendrame weird...the .hex file size is 5676 bytes (this is the intel hex format and MYSBootloader is under 2kb, so 1024 words are ok). The 32722 bytes are the cause of the problem...
            You mentioned that burning the standard bootloader revives your Arduino - can you post the verbose mode output as comparison?
            • rvendrameR
              rvendrameR
              rvendrame
              Sure, here it is. Very similar (including the size of .hex file)... strange...
              /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
                       Hardware Version: 2
                       Topcard         : Unknown
                       Vtarget         : 0.0 V
                       Varef           : 0.0 V
                       Oscillator      : Off
                       SCK period      : 0.1 us
              avrdude: reading input file "0x05"
              avrdude: verifying efuse memory against 0x05:
              avrdude: load data efuse data from input file 0x05:
              avrdude: input file 0x05 contains 1 bytes
              avrdude: verifying lfuse memory against 0xFF:
              avrdude: load data lfuse data from input file 0xFF:
              /Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 1.6.4.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -Uflash:w:/Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i -Ulock:w:0x0F:m
                       Hardware Version: 2
                       Topcard         : Unknown
                       Vtarget         : 0.0 V
                       Varef           : 0.0 V
                       Oscillator      : Off
                       SCK period      : 0.1 us
              avrdude: reading input file "/Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
              avrdude: writing flash (32670 bytes):
              avrdude: 32670 bytes of flash written
              avrdude: verifying flash memory against /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
              avrdude: load data flash data from input file /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
              avrdude: input file /Applications/Arduino 1.6.4.app/Contents/Java/hardware/arduino/avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
              avrdude: 32670 bytes of flash verified
              Alexa / Google Home
                @rvendrame: when you try to upload a sketch, do you use ftdi? because I think you can't upload with ftdi in MYSBootloader. just ota. I looked quickly at the code. Am I right @tekka ? If you want ota+ftdi options, you must use dualoptiboot.
                • scalzS scalz
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #166
                  @scalz: for flashing bootloaders you have to communicate to the MCU via SPI (e.g. via USBasp, ArduinoISP, Atmel STK500, etc.) but not the usual (ftdi) serial interface.
                  MYSBootloader 1.1 supports only OTA sketch uploads (at the moment), this is right - but not related to the issue of @rvendrame
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    #167
                    @scalz , @tekka, I'm using "Arduino as ISP" to burn the bootloader. I have my arduino Uno connected to mac via USB, and running on it the "ArduinoISP" sketch delivered with IDE.
                    The pins VCC, GND, 11, 12, 13 from Uno are connected to same pins of the pro-mini (the one being programmed). Pin 10 from uno goes to pro-mini's reset pin.
                    In summary, this scenario. It works perfectly for the standard pro-mini bootloader. I had success with both 3.3V and 5V versions.
                    To upload my sketches: I understand that I have to compile it, move the generated .hex file to the MYSController "Firmware" folder, and load it via 'Node -> Assign FW' . I did it this part with some sense benders that I have here, and it worked perfectly --- That made me thinking in re-flashing all pro-minis that I have with MYSbootloader ;-)
                    The problem is that my pro-minis get 'bricked' after burning the MYSbootloader --- pin led flashes randomly , no serial-monitor, I don't think they are really running.
                    Just to be 100% sure --- I just need the pro-mini itself connected during the "Tools -> Burn bootloader" ? No radio, no extra eprom, no atsha, ... right?
                    I tried to connect the radio to pro-mini after I burned the MYS, as a last desperated try (who know it would 'wake up' ). But no joy ;-)
                    Thx!
                    Alexa / Google Home
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      @scalz, @tekka, maybe if I re-compile the MYSbootloader to match my current fuses? I was trying to find a how-to, but could not find anything related. Perhaps you can give me some guidance on that too?
                      Alexa / Google Home
                      • F
                        F
                        f1dev
                        Very interesting, I´m having the exact issues with my pro minis.. It would be very helpful with a " how-to" to compile the Mysbootloader for pro minis 3.3V 8mhz.
                        Kindly
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          @f1dev, I'm just trying to thinking 'out of the box'. I really don't know why the MYSBootloader doesn't work (while the original arduino bootloader does).
                          @scalz, @tekka, looking at MYSBootloader makefile at github, I noticed you are using
                          ISP_PORT = com5
                          ISP_SPEED = 115200
                          ISP_PROTOCOL = stk500v2
                          ISP_MCU = m328p
                          Well, my 'Arduino as ISP' only work as 'stk500v1' and 19200 bps --- Any other combination causes the "Yikes! invalid signature found" in avrdude, or no response at all (time-out). Could be that a different avr itself would introduce "strange bytes" during bootloader burning?
                          Alexa / Google Home
                            tekkaT
                            tekkaT
                            tekka
                            #171
                            @rvendrame let me try some things here - can you make sure, that the MYSBootloader your are trying to flash is the one from the library and/or MYSController folder (maybe you can upload it here)?
                            Importantly, there is no need to re-compile MYSBootloader as it has been successfully tested down to 3.3V and 125kHz pro-minis (!). Can you please update your Arduino IDE to 1.6.5 so that we both run the same version?
                              ISP_PORT = com5
                              ISP_SPEED = 115200
                              ISP_MCU = m328p
                              tekkaT
                              tekkaT
                              tekka
                              @rvendrame the speed is not really an issue here - the bytes are verified after flashing...
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                @tekka, thank you so much. I have downloaded the .hex again from github, just for the sake. Anyway it is here MYSBootloader.hex I'm using.
                                Alexa / Google Home
                                  Hello guys, I'm trying to burn the MYSBootloader.hex into some Pro minis (clones) here, however after burning it, they get somehow 'bricked' :
                                  • I'm using my Uno "as ISP" on IDE 1.6.4
                                  • I've followed the step-by-step tutorial posted above by @tekka
                                  • My pro-minis are 5V, 16Mhz, external clock , 328p, supposedly a perfect match with 'boards.txt' info...
                                  • "Burn bootloader" ends successful, with "Done burning boot loader" message.
                                  • After that, the pro-mini pin 13 led flashes in a kind of random pattern, and it is not possible to upload any sketch, nor any kind of serial monitor on any speed.
                                  • I can revert it, by selecting the standard 'Arduino Pro or Pro Mini' board , and burn boot loader again. It makes the pro-mini gets back to live, I can upload my sketches and serial monitor it.
                                  So my questions:
                                  • I don't have extra eprom connected --- Is it mandatory? I've read somewhere that it can be disabled, but can't find the instructions anymore...
                                  • Fuse adjustments?
                                  • What else can I do in order to troubleshooting it?
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #174
                                  So my questions:
                                  • Fuse adjustments?
                                  How do you know that the bootloader is not functioning properly? you connected the RF module as mentioned earlier? The led is blinking irregularly due to SPI...Do you get a startup message (from MYSBootloader) in MYSController?
                                  The 327xx bytes mentioned in verbose mode are correct - the entire flash is overwritten...
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Yes, I connect the radio and start the node, but nothing happens --- No serial monitor, nothing in MYSController. Just the pin 13 led flashing randomly.
                                    Alexa / Google Home
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #176
                                      Just flashed MYSController.hex on my Arduino pro mini 3V3 and the fuses as mentioned in the boards.txt (L: 0xF7 E: 0x06 H: 0xDA), using USBasp and everything works smoothly...
                                      Please keep in mind: There is no serial monitor for MYSBootloader and the 13 led flashing is normal
                                      Can you try this (in the indicated order):
                                      0) Update Arduino IDE to 1.6.5
                                      1. burn the original bootloader and upload the clear eeprom sketch
                                      2. burn MYSController, disconnect flasher and connect nRF24L01+ module
                                      3. download the most recent MySensors 1.5 library and upload the GW sketch
                                      4. launch MYSController 0.1.2.282, activate AutoID, Logging and connect to the serial GW
                                      5. let it run for a few mins and upload the log-file here
                                      rvendrameR 1 Reply Last reply
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @tekka, just to clarify, in step 4 above - the 'upload GW sketch' should be OTA? Or via regular FT232 adapter?
                                        Alexa / Google Home
                                          @rvendrame: I think it is ota. With MYSBootloader you can't use ftdi for uploading sketch.
