  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.2k Views 73 Watching
  • F
    F
    f1dev
    Very interesting, I´m having the exact issues with my pro minis.. It would be very helpful with a " how-to" to compile the Mysbootloader for pro minis 3.3V 8mhz.
    Kindly
    • rvendrameR
      rvendrameR
      rvendrame
      @f1dev, I'm just trying to thinking 'out of the box'. I really don't know why the MYSBootloader doesn't work (while the original arduino bootloader does).
      @scalz, @tekka, looking at MYSBootloader makefile at github, I noticed you are using
      ISP_PORT = com5
      ISP_SPEED = 115200
      ISP_PROTOCOL = stk500v2
      ISP_MCU = m328p
      Well, my 'Arduino as ISP' only work as 'stk500v1' and 19200 bps --- Any other combination causes the "Yikes! invalid signature found" in avrdude, or no response at all (time-out). Could be that a different avr itself would introduce "strange bytes" during bootloader burning?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      tekkaT 1 Reply Last reply
      • rvendrameR rvendrame
        @scalz, @tekka, maybe if I re-compile the MYSbootloader to match my current fuses? I was trying to find a how-to, but could not find anything related. Perhaps you can give me some guidance on that too?
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #171
        @rvendrame let me try some things here - can you make sure, that the MYSBootloader your are trying to flash is the one from the library and/or MYSController folder (maybe you can upload it here)?
        Importantly, there is no need to re-compile MYSBootloader as it has been successfully tested down to 3.3V and 125kHz pro-minis (!). Can you please update your Arduino IDE to 1.6.5 so that we both run the same version?
          ISP_PORT = com5
          ISP_SPEED = 115200
          ISP_MCU = m328p
          tekkaT
          tekkaT
          tekka
          @rvendrame the speed is not really an issue here - the bytes are verified after flashing...
          • rvendrameR
            rvendrameR
            rvendrame
            @tekka, thank you so much. I have downloaded the .hex again from github, just for the sake. Anyway it is here MYSBootloader.hex I'm using.
            Alexa / Google Home
              Hello guys, I'm trying to burn the MYSBootloader.hex into some Pro minis (clones) here, however after burning it, they get somehow 'bricked' :
              • I'm using my Uno "as ISP" on IDE 1.6.4
              • I've followed the step-by-step tutorial posted above by @tekka
              • My pro-minis are 5V, 16Mhz, external clock , 328p, supposedly a perfect match with 'boards.txt' info...
              • "Burn bootloader" ends successful, with "Done burning boot loader" message.
              • After that, the pro-mini pin 13 led flashes in a kind of random pattern, and it is not possible to upload any sketch, nor any kind of serial monitor on any speed.
              • I can revert it, by selecting the standard 'Arduino Pro or Pro Mini' board , and burn boot loader again. It makes the pro-mini gets back to live, I can upload my sketches and serial monitor it.
              So my questions:
              • I don't have extra eprom connected --- Is it mandatory? I've read somewhere that it can be disabled, but can't find the instructions anymore...
              • Fuse adjustments?
              • What else can I do in order to troubleshooting it?
              tekkaT
              tekkaT
              tekka
              #174
              So my questions:
              • Fuse adjustments?
              How do you know that the bootloader is not functioning properly? you connected the RF module as mentioned earlier? The led is blinking irregularly due to SPI...Do you get a startup message (from MYSBootloader) in MYSController?
              The 327xx bytes mentioned in verbose mode are correct - the entire flash is overwritten...
              • rvendrameR
                rvendrameR
                rvendrame
                Yes, I connect the radio and start the node, but nothing happens --- No serial monitor, nothing in MYSController. Just the pin 13 led flashing randomly.
                Alexa / Google Home
                  tekkaT
                  tekkaT
                  tekka
                  #176
                  Just flashed MYSController.hex on my Arduino pro mini 3V3 and the fuses as mentioned in the boards.txt (L: 0xF7 E: 0x06 H: 0xDA), using USBasp and everything works smoothly...
                  Please keep in mind: There is no serial monitor for MYSBootloader and the 13 led flashing is normal
                  Can you try this (in the indicated order):
                  0) Update Arduino IDE to 1.6.5
                  1. burn the original bootloader and upload the clear eeprom sketch
                  2. burn MYSController, disconnect flasher and connect nRF24L01+ module
                  3. download the most recent MySensors 1.5 library and upload the GW sketch
                  4. launch MYSController 0.1.2.282, activate AutoID, Logging and connect to the serial GW
                  5. let it run for a few mins and upload the log-file here
                  rvendrameR 1 Reply Last reply
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    @tekka, just to clarify, in step 4 above - the 'upload GW sketch' should be OTA? Or via regular FT232 adapter?
                    Alexa / Google Home
                      @rvendrame: I think it is ota. With MYSBootloader you can't use ftdi for uploading sketch.
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        @scalz, thx. I will give it a try tonight.
                        Alexa / Google Home
                          tekkaT
                          tekkaT
                          tekka
                          I meant to update the Gateway node with the most recent Serialgateway sketch...
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            Yep, I'm already on latest version on GW. My GW runs on a pro-mini, with standard bootloader --- I guess this is not a issue?
                            Alexa / Google Home
                              tekkaT
                              tekkaT
                              tekka
                              and MYSController is connected via USB/FTDI to the GW...?
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                It is connected via USB/FTDI into a mac-mini running a TCP-to-serial SW. (so both Vera and MYSController can reach it using IP address). Works like a charm, I can see all nodes and messages, no connection issues so far.
                                Is it required the GW running on MYSBootloader? I hope not...
                                Alexa / Google Home
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @rvendrame Sensor nodes with MYSBootloader (unless they are Sensebender boards) and GW with original bootloader. Curious to see your logs.
                                  • tekkaT tekka
                                    rvendrameR
                                    rvendrameR
                                    rvendrame
                                    wrote on last edited by rvendrame
                                    #185
                                    EDIT: @tekka, @scalz , after so many tries, I don't know why I decided to replace the nRF radio , and guess what?
                                    Funny thing is that the previous radio is working with regular bootloader. Dam fake chips! But I will sort it out later, now I want to play with my OTA ;-)
                                    Thanks a lot!
                                    Alexa / Google Home
                                      @rvendrame: so cool. I am happy for you!
                                      See you soon
                                      • FrancoisF
                                        FrancoisF
                                        Francois
                                        @tekka do MYSBootloader also work with the RFM69 radios?
                                          Thanks a lot!
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @rvendrame excellent :)
