  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
    Hmm.. One idea is that you could enable nodes to broadcast (they are not being routed/retransmitted) log data as internal (I_LOG) messages.
    Gateway would pick up these messages if node is in range and just log them to controller.
    • G
      G
      gonzalonal
      wrote on last edited by gonzalonal
      #209
      Hi Tekka.
      Great software, thanks for sharing.
      I 've being doing some tests and found a problem that seems to be related to my own sketches.
      When I upload through OTA the TimeReporter sketch, it uploads fine, and I am able to change the firmware afterward for another one.
      But when I upload my own sketch, It uploads fine, and works fine, but it stops to answer MYScontroller commands, such as reboot or assing firmware. So I am stuck with that sketch in that node. To flash another sketch in that node, I have to reflash MYSBootloader again via usbASP and later on, upload the desire sketch wit MYSController.
      Am I skiping something in my code that allows MYSBootloader to respond to MYSController commands?
      Could you please upload the TimeReporter.ino sketch as example of a working sketch with MYSController/MYSBootloader?
      Thanks, regards!
      Gonzalo
      tekkaT 1 Reply Last reply
      • G gonzalonal
        Hi Tekka.
        Thanks, regards!
        Gonzalo
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #210
        @gonzalonal said:
        Hi Tekka.
        Thanks, regards!
        Gonzalo
        There is nothing special about the sketch, except of calling gw.process() as often as possible. If you have delay() call gw.wait() instead.
        For the sake of completeness, here you go:
        #include <Time.h>
        #include <avr\wdt.h>
        #define NODE_ID AUTO
        #define CHILD_ID_GENERAL 0
        #define CHILD_ID_POWER 1
        #define CHILD_ID_TEMPERATURE 2
        #define SketchName "TimeReporter"
        #define SketchVersion "20150826"
        #define UPDATE_TIME 100000L
        #define REPORT_TIME 5000L
        boolean timeReceived = false;
        unsigned long ms_now;
        unsigned long lastUpdate=0, lastRequest=0;
        MyMessage msgGeneral(CHILD_ID_GENERAL, V_VAR1);
        MyMessage msgPower(CHILD_ID_POWER, V_VOLTAGE);
        MyMessage msgTemperature(CHILD_ID_TEMPERATURE, V_TEMP);
          // watchdog 8s
          wdt_enable(WDTO_8S);
          // repeater mode on
          gw.begin(NULL,NODE_ID,true);
          // Send sketch version and information
          gw.sendSketchInfo(SketchName, SketchVersion);
          // Register sensors to gateway
          gw.present(CHILD_ID_GENERAL, S_ARDUINO_NODE,"Main node");
          gw.present(CHILD_ID_POWER, S_POWER,"ADC power",true);
          gw.present(CHILD_ID_TEMPERATURE, S_TEMP,"Chip temp");
          // request time
          gw.requestTime(receiveTime);
        // time callback
        void receiveTime(unsigned long time) {
          // Ok, set incoming time
          setTime(time);
          timeReceived = true;
        long readMUX(uint8_t aControl) {
          long result;
          ADMUX = aControl;
          delay(20); // Wait for Vref to settle
          ADCSRA |= _BV(ADSC); // Convert
          result = ADCL;
          result |= ADCH<<8;
          return result;
        long readVcc() {
          return 1126400L / readMUX(_BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1));
        float readTemp() {
         // Read 1.1V reference against MUX3
          return (readMUX(_BV(REFS1) | _BV(REFS0) | _BV(MUX3)) - 125) * 0.1075;
          // watchdog reset
          wdt_reset();
          // process incoming messages and repeater function
          // get millis since start
          ms_now = millis();
          // time update needed?
          if (timeReceived && ms_now-lastRequest > UPDATE_TIME) {
            // Request time from controller.
            lastRequest = ms_now;
          // report time
          if (timeReceived && ms_now-lastUpdate > REPORT_TIME) {
            gw.send(msgGeneral.set(ms_now));
            char Output[10];
            String OutStr = String(hour()) + ":" + String(minute()) + ":" + String(second());
            OutStr.toCharArray(Output,10);
            gw.send(msgGeneral.set(Output));
            gw.send(msgTemperature.set(readTemp(),1));
            gw.send(msgPower.set(readVcc()),true);
            lastUpdate = ms_now;
        • G
          G
          gonzalonal
          #211
          Thanks Tekka for replying.
          Just another silly question.
          How should I compile my sketch to later be uploaded into a MYSBootloader Arduino Nano?
          Should I compile for "Arduino Nano" or for "ATMega328 16Mhz MYSBootloader"?
          Thanks, regards.
          Gonzalo
          • G gonzalonal
            Thanks, regards.
            Gonzalo
            tekkaT
            tekkaT
            tekka
            @gonzalonal Assuming that you have the Nano 3.0, you should be good to go with "ATMega328 16Mhz MYSBootloader"...
            • G
              G
              gonzalonal
              Ok, thanks for that.
              I finally found my problem.
              The Node was sleeping most of the time. In spite of waking up twice per second, it was not enough to enter the uploading mode in the mysbootloader, so the node wasn't answering back to the gateway, nor MYSController.
              Now I have a questions
              How can I OTA update/upload the firmware of a sleeping node? Should the gateway, or a relay node, send the upload message to the sleeping node as soon as it wakes up for transmiting its data?
              I guess that in order to do that, the sleeping node should always wait for an aknowledge or some kind of message after waking up. I mean:
              Sleeping node wakes up
              Then, it send its data to controller or to relay node
              Afterwards, it wait for the controller to acknoledge the data just send, and to tell him (sleeping node) if there is a firmware upgrade for it.
              If there's not, go back to sleep. If there is, go to OTA upgrade routine.
              Thanks, regards.
              • G gonzalonal
                Thanks, regards.
                tekkaT
                tekkaT
                tekka
                @gonzalonal
                OTA updates for sleeping nodes with MYSBootloader:
                • add gw.wait(200) after the gw.send() (=node processes incoming messages for 200ms after sending a message)
                • In MYSController, right-click on the node, select "Battery-powered / sleeping", then assign FW, confirm to reboot node (reboot request is now queued)
                MYSController will now wait until it receives a message from that node, send the reboot command and hence, initiate OTA update.
                G 1 Reply Last reply
                • tekkaT tekka
                  @gonzalonal
                  G
                  G
                  gonzalonal
                  @tekka Great Tekka, thanks again. I will try that.
                  Regards.
                  • Z
                    Z
                    zuru
                    I am trying to debug a mysensors temp. sensor using this tool (it is not detected by Domoticz). I connected the serial gateway to your program and when I turn the temperature sensor, I see that there is traffic back and forth between the gateway and the sensor. But my knowledge stops there.... any pointers? I can upload a screenshot of the log if it helps.
                    Z.
                    • Z zuru
                      Z.
                      tekkaT
                      tekkaT
                      tekka
                      @zuru screenshots and/or log files are always good starting points ;)
                      • Z
                        Z
                        zuru
                        I found my problem.... so everything is fine now.
                        Z.
                        • AndurilA
                          AndurilA
                          Anduril
                          Hey guys,
                          maybe anyone can help. I tried to debug my sensors, but didn't got MYSController to talk with my gateway.
                          I have the NRF24L01+ directly connected to my rPi and can use the Gateway with Pimatic plugin. Then I tried different ways to give MYSController access:
                          1. redirecting the serial gateway to tcp port (tried ser2net and socat) to use ethernet option, but didn't got this to work.
                          2. creating a new gateway using a spare nano with NRF24L01+ at my PC. This one worked, but the gateway didn't noticed my nodes. Are they somehow coded to only talk with the gateway they know? I waited serveral minuters (sensors reporting each minute), but didn't got any readings. I assume this programm has an auto update to show now nodes, right?
                          Hope someone can help, I would realy love the option to debug using my windows PC and in future upload new sketches OTA (with new bootloader).
                          Regards,
                          Anduril
                          • A
                            allysmith
                            I have followed the procedure listed and that mentioned in post 77. Pro Mini 3.3v 8mhz Arduino.
                            I keep getting the following message in the debug window every few minutes. Have repeated the process in post 77 several times however get the same results.
                            [2015-09-01 18:09:17.276 Info] DEBUG Undefined firmware/type for node=2
                            [2015-09-01 18:09:17.323 Info] INFO BL version=257
                            [2015-09-01 18:09:17.354 Info] INFO Send FW info to node 2: type=A, version=1, blocks=0x0048, CRC=0xD098
                            [2015-09-01 18:09:17.386 Info] TX 2;0;4;0;1;0A000100480098D0
                            [2015-09-01 18:09:17.417 Info] RX 2;255;4;0;0;FFFFFFFFFFFFFFFF0101
                            Any pointers??
                            • A allysmith
                              Any pointers??
                              tekkaT
                              tekkaT
                              tekka
                              @allysmith please provide more information about the setup and upload the MYSController log for further troubleshooting
                              A 1 Reply Last reply
                              • E
                                E
                                ericvdb
                                @tekka What kind of SPI flash is needed for this OTA stuff? Can you provide part numbers?
                                • E ericvdb
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @ericvdb MYSBootloader works without external flash, in contrary to the sensebender board and dualoptiboot bootloader
                                  • tekkaT tekka
                                    allysmith
                                    @tekka Thanks for getting back to me. This is my my first go at this bootloader. Hope I am not doing something daft!
                                    I have Arduino IDE 1.6.5, MySensors 1.5, MYSBootloader 1.1, MYSController_0_1_2_282 running on Windows 8, USBasp to urn bootloader.
                                    Arduino Pro Mini 3.3v 8mhz board. I am using the standard settings in your write up for the boards.txt
                                    Log file hopefully attached.
                                    MySensors_20150901-185920.log
                                    • A allysmith
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #225
                                      @allysmith Try clearing EEPROM via MYSBootloader command, assign blink FW and upload the entire log again....
                                      • tekkaT tekka
                                        allysmith
                                        @tekka As requested, cleared EEPROM via MYSBootloader, assigned blink FW.
                                        Attached is the log.
                                        Device shows up in the nodes window as Booting: 65535:65535 (BL1.1)
                                        MySensors_20150902-055736.log
                                        • A allysmith
                                          allysmith
                                          @tekka Have made a change to how I was powering the NRF and now straight from battery.
                                          Looks like it was a power issue. Sufficient for transmit from the node ut not for receiving the updates.
                                          See attached log.
                                          Now got a different issue when I tried to reassign the FW from link to Timereporter.
                                          I think I am moving in the right direction now.
                                          Thanks for your help so far.
                                          Keep up this great work.Deug.txt
