  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.2k Views 73 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @tekka said:
    Unfortunately your suggestion is not possible: bootloader and sketch run sequentially, not in parallel, and thus, cannot communicate with each other.
    Maybe by re-implementing serial.print methods, in order to first checking which FW is installed, and if MYSBootloader, re-direct the output to a internal radio message? Just brainstorming....
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    tekkaT 1 Reply Last reply
    • tekkaT tekka
      @NewFolk said:
      @tekka is there a way to change the default channel in MYSbootloader ?
      Yes, but for that you'll have to re-compile it.
      N
      N
      NewFolk
      @tekka
      Could you help me to find where to change channel? It is in MYSBootloaderHW.h ?
      • P
        P
        Pendragon
        Du you all connect the controller direct to the gateway?
        I have a serial gateway which is connected directly to a raspberry running domoticz. I can rum ser2net and then connect the MYSController via ethernet. While ser2net is running, domoticz does not get any data from the gateway.
        Has anyone found a solution to use both, MYSController and a controller software (e.g. domoticz) in parallel?
        • N NewFolk
          @tekka
          tekkaT
          tekkaT
          tekka
          No, it's defined in MyConfig.h (see here)
          • rvendrameR rvendrame
            tekkaT
            tekkaT
            tekka
            I like the idea, but again, the bootloader cannot handle that.
            However, we may think about implementing an OTA serial monitor in the library, let's say re-routing the serial output and transmit it via a dedicated debug sensor instance back to the GW...@hek, what do you think about that?
              Hmm.. One idea is that you could enable nodes to broadcast (they are not being routed/retransmitted) log data as internal (I_LOG) messages.
              Gateway would pick up these messages if node is in range and just log them to controller.
              • G
                G
                gonzalonal
                wrote on last edited by gonzalonal
                #209
                Hi Tekka.
                Great software, thanks for sharing.
                I 've being doing some tests and found a problem that seems to be related to my own sketches.
                When I upload through OTA the TimeReporter sketch, it uploads fine, and I am able to change the firmware afterward for another one.
                But when I upload my own sketch, It uploads fine, and works fine, but it stops to answer MYScontroller commands, such as reboot or assing firmware. So I am stuck with that sketch in that node. To flash another sketch in that node, I have to reflash MYSBootloader again via usbASP and later on, upload the desire sketch wit MYSController.
                Am I skiping something in my code that allows MYSBootloader to respond to MYSController commands?
                Could you please upload the TimeReporter.ino sketch as example of a working sketch with MYSController/MYSBootloader?
                Thanks, regards!
                Gonzalo
                • G gonzalonal
                  Hi Tekka.
                  Thanks, regards!
                  Gonzalo
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #210
                  @gonzalonal said:
                  Hi Tekka.
                  Thanks, regards!
                  Gonzalo
                  There is nothing special about the sketch, except of calling gw.process() as often as possible. If you have delay() call gw.wait() instead.
                  For the sake of completeness, here you go:
                  #include <Time.h>
                  #include <avr\wdt.h>
                  #define NODE_ID AUTO
                  #define CHILD_ID_GENERAL 0
                  #define CHILD_ID_POWER 1
                  #define CHILD_ID_TEMPERATURE 2
                  #define SketchName "TimeReporter"
                  #define SketchVersion "20150826"
                  #define UPDATE_TIME 100000L
                  #define REPORT_TIME 5000L
                  boolean timeReceived = false;
                  unsigned long ms_now;
                  unsigned long lastUpdate=0, lastRequest=0;
                  MyMessage msgGeneral(CHILD_ID_GENERAL, V_VAR1);
                  MyMessage msgPower(CHILD_ID_POWER, V_VOLTAGE);
                  MyMessage msgTemperature(CHILD_ID_TEMPERATURE, V_TEMP);
                    // watchdog 8s
                    wdt_enable(WDTO_8S);
                    // repeater mode on
                    gw.begin(NULL,NODE_ID,true);
                    // Send sketch version and information
                    gw.sendSketchInfo(SketchName, SketchVersion);
                    // Register sensors to gateway
                    gw.present(CHILD_ID_GENERAL, S_ARDUINO_NODE,"Main node");
                    gw.present(CHILD_ID_POWER, S_POWER,"ADC power",true);
                    gw.present(CHILD_ID_TEMPERATURE, S_TEMP,"Chip temp");
                    // request time
                    gw.requestTime(receiveTime);
                  // time callback
                  void receiveTime(unsigned long time) {
                    // Ok, set incoming time
                    setTime(time);
                    timeReceived = true;
                  long readMUX(uint8_t aControl) {
                    long result;
                    ADMUX = aControl;
                    delay(20); // Wait for Vref to settle
                    ADCSRA |= _BV(ADSC); // Convert
                    result = ADCL;
                    result |= ADCH<<8;
                    return result;
                  long readVcc() {
                    return 1126400L / readMUX(_BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1));
                  float readTemp() {
                   // Read 1.1V reference against MUX3
                    return (readMUX(_BV(REFS1) | _BV(REFS0) | _BV(MUX3)) - 125) * 0.1075;
                    // watchdog reset
                    wdt_reset();
                    // process incoming messages and repeater function
                    // get millis since start
                    ms_now = millis();
                    // time update needed?
                    if (timeReceived && ms_now-lastRequest > UPDATE_TIME) {
                      // Request time from controller.
                      lastRequest = ms_now;
                    // report time
                    if (timeReceived && ms_now-lastUpdate > REPORT_TIME) {
                      gw.send(msgGeneral.set(ms_now));
                      char Output[10];
                      String OutStr = String(hour()) + ":" + String(minute()) + ":" + String(second());
                      OutStr.toCharArray(Output,10);
                      gw.send(msgGeneral.set(Output));
                      gw.send(msgTemperature.set(readTemp(),1));
                      gw.send(msgPower.set(readVcc()),true);
                      lastUpdate = ms_now;
                  • G
                    G
                    gonzalonal
                    #211
                    Thanks Tekka for replying.
                    Just another silly question.
                    How should I compile my sketch to later be uploaded into a MYSBootloader Arduino Nano?
                    Should I compile for "Arduino Nano" or for "ATMega328 16Mhz MYSBootloader"?
                    Thanks, regards.
                    Gonzalo
                    • G gonzalonal
                      Thanks, regards.
                      Gonzalo
                      tekkaT
                      tekkaT
                      tekka
                      @gonzalonal Assuming that you have the Nano 3.0, you should be good to go with "ATMega328 16Mhz MYSBootloader"...
                      • G
                        G
                        gonzalonal
                        Ok, thanks for that.
                        I finally found my problem.
                        The Node was sleeping most of the time. In spite of waking up twice per second, it was not enough to enter the uploading mode in the mysbootloader, so the node wasn't answering back to the gateway, nor MYSController.
                        Now I have a questions
                        How can I OTA update/upload the firmware of a sleeping node? Should the gateway, or a relay node, send the upload message to the sleeping node as soon as it wakes up for transmiting its data?
                        I guess that in order to do that, the sleeping node should always wait for an aknowledge or some kind of message after waking up. I mean:
                        Sleeping node wakes up
                        Then, it send its data to controller or to relay node
                        Afterwards, it wait for the controller to acknoledge the data just send, and to tell him (sleeping node) if there is a firmware upgrade for it.
                        If there's not, go back to sleep. If there is, go to OTA upgrade routine.
                        Thanks, regards.
                        • G gonzalonal
                          Thanks, regards.
                          tekkaT
                          tekkaT
                          tekka
                          @gonzalonal
                          OTA updates for sleeping nodes with MYSBootloader:
                          • add gw.wait(200) after the gw.send() (=node processes incoming messages for 200ms after sending a message)
                          • In MYSController, right-click on the node, select "Battery-powered / sleeping", then assign FW, confirm to reboot node (reboot request is now queued)
                          MYSController will now wait until it receives a message from that node, send the reboot command and hence, initiate OTA update.
                          G 1 Reply Last reply
                          • tekkaT tekka
                            @gonzalonal
                            G
                            G
                            gonzalonal
                            @tekka Great Tekka, thanks again. I will try that.
                            Regards.
                            • Z
                              Z
                              zuru
                              I am trying to debug a mysensors temp. sensor using this tool (it is not detected by Domoticz). I connected the serial gateway to your program and when I turn the temperature sensor, I see that there is traffic back and forth between the gateway and the sensor. But my knowledge stops there.... any pointers? I can upload a screenshot of the log if it helps.
                              Z.
                              • Z zuru
                                Z.
                                tekkaT
                                tekkaT
                                tekka
                                @zuru screenshots and/or log files are always good starting points ;)
                                • Z
                                  Z
                                  zuru
                                  I found my problem.... so everything is fine now.
                                  Z.
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    Hey guys,
                                    maybe anyone can help. I tried to debug my sensors, but didn't got MYSController to talk with my gateway.
                                    I have the NRF24L01+ directly connected to my rPi and can use the Gateway with Pimatic plugin. Then I tried different ways to give MYSController access:
                                    1. redirecting the serial gateway to tcp port (tried ser2net and socat) to use ethernet option, but didn't got this to work.
                                    2. creating a new gateway using a spare nano with NRF24L01+ at my PC. This one worked, but the gateway didn't noticed my nodes. Are they somehow coded to only talk with the gateway they know? I waited serveral minuters (sensors reporting each minute), but didn't got any readings. I assume this programm has an auto update to show now nodes, right?
                                    Hope someone can help, I would realy love the option to debug using my windows PC and in future upload new sketches OTA (with new bootloader).
                                    Regards,
                                    Anduril
                                    • A
                                      allysmith
                                      I have followed the procedure listed and that mentioned in post 77. Pro Mini 3.3v 8mhz Arduino.
                                      I keep getting the following message in the debug window every few minutes. Have repeated the process in post 77 several times however get the same results.
                                      [2015-09-01 18:09:17.276 Info] DEBUG Undefined firmware/type for node=2
                                      [2015-09-01 18:09:17.323 Info] INFO BL version=257
                                      [2015-09-01 18:09:17.354 Info] INFO Send FW info to node 2: type=A, version=1, blocks=0x0048, CRC=0xD098
                                      [2015-09-01 18:09:17.386 Info] TX 2;0;4;0;1;0A000100480098D0
                                      [2015-09-01 18:09:17.417 Info] RX 2;255;4;0;0;FFFFFFFFFFFFFFFF0101
                                      Any pointers??
                                      • A allysmith
                                        Any pointers??
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @allysmith please provide more information about the setup and upload the MYSController log for further troubleshooting
                                        A 1 Reply Last reply
                                        • E
                                          E
                                          ericvdb
                                          @tekka What kind of SPI flash is needed for this OTA stuff? Can you provide part numbers?
