RGB-3D only showing 1 dimmer, not 3 in Vera
New to MySensors - built an ethernet gateway and connected it to my VeraEdge running UI7. Works fine as far as I can tell :)
Then I built an analog RGB LED strip controller, using an Uno clone and a protoshield to wire it up. The strip works fine with a simple RGB test sketch, so the hardware is working. Then I loaded the RGB-3D sensor sketch from the latest 1.5 update. I hit the include button in the Vera interface (I didn't build a hardware one on my gateway) and rebooted the RGB node. Vera showed 2 devices detected and in my dashboard, a repeater and a red dimmer channel (an on/off button and a dimmer slider, both of which control one color on the node) appeared. That one channel is working great - however, I'd sorta like to control all 3 colors!
How do I get the other 2 channels to appear?
try the include process a few more times. If the rest of the devices don't show up maybe you could try to add some delay between the gw.present in the RGB sketch.
hi,
did you try to look your serial consol to see if you had st=fail ?
this sketch present 4 devices
The RGB node isn't connected to a pc, so how do you check the console on it? The way I have it wired, it's getting power from the LED strip, so I'd have to disconnect the lights to connect it over USB.
Oh wait, I have to do that anyway to update the sketch, so I can check it then... but is there a way to see the console wirelessly?
if you have a great android phone, you can also using OTG cable with 'UsbTerminal' app.. nothing wirelessly..
but of course try just after up a sketch on your arduino before disconnect from your pc -
You can use at the same time yes
Solved!
It was a hardware problem - I didn't put caps on the radio on the gateway or RGB node originally. I added them and the node added perfectly. I guess I got lucky originally that even the 2 devices appeared on the first try.
Great, have you get the 4 devices ?
I hope you will like this sketch, specialy the color cycle :-) -
I got 5 devices - the 3 R, G, B dimmers, a repeater, and the swirl on/off. However, for some reason my swirl doesn't work. Haven't spent any time messing with it, but clicking that button on Vera just turns on one channel of lights and clicking that button off does nothing. I had to use the matching dimmer to turn it off.
Not sure why, didn't spend any time tracking that down - for now I just needed the dimmers and they work great so I didn't dig :)
strange..
the On/Off button is for start/stop color cycle (rainbow), but is very slow, and start with red color only..
maybe try to wait a bit more..
when you click it Off, it's stop the color cycle, save state and return actuals color to controler..
anyway, I'm glad you like it -
What is the actual solution to this problem? I have the same problem (mysensors v2 (dev)) and domoticz.
I have 2 RBG-3D nodes, the first one is showing all dimmers and works perfect, but when i added the second one i only get "Present Blue" and the "show" button.Under the mysensors hardware in domoticz the second RGB node display "Name: unknown, Sketch name: Unknown".
